My customer encountered a problem when using BQ27426.
RD set terminate voltage at 3.3V. Terminate voltage is system shutdown voltage, and also the RSOC 0% relative voltage.
But now when the discharge reaches 3.3V, SOC is still 9%. Then it turns off when the shutdown voltage reaches 3.3V. Plugging in and charging can make SOC normally increase from 0%.
- Are there any other settings that I can check to see if they are correct? Or any other settings that I can suggest I can adjust?
- Does this gauge have a learning function? Will it become more and more accurate after several charges and discharges? And can the accurate profile be taken out and applied?
BR,
Zach
