Is TPS92662 water washable with "de-ionized" water?
I see no indication of water / aqueous wash ability on the part's home page or in the datasheet.
What is your recommendation?
Florian Helling
Florian Helling
Hello fhoude,
thanks a lot for your answer!
Is there a TI document available with process recommendations for water washing? e.g. max. water temperature, max. pressure, max. soak time, drying time, ...?
Best regards,,
Florian
Hello Florian,
I don't think so, but I will do some research and let you know.
-fhoude
Hello Florian,
Here are a couple application notes that gives additional information about handling and process recommendations and also information about the affects of moisture in plastics.
http://www.ti.com/lit/an/snoa550e/snoa550e.pdf
http://www.ti.com/lit/an/snoa300a/snoa300a.pdf
fhoude
