The TI E2E™ design support forums will undergo maintenance from Sept. 28 to Oct. 2. If you need design support during this time, contact your TI representative or open a new support request with our customer support center.
TPS92630-Q1: Reg. Power Dissipation Calc.
Part Number: TPS92630-Q1
As per the Datasheet of TPS92630, the Power dissipation of the IC is as given below. Pls help me understanding the I(VIN). should I consider the quiescent current to calculate the Pd??
If I consider Iq, then i get wrong value.
My requirement is to calculate the Pd for Vin = 12V, I(LED) = 50mA and all 8 channels are loaded with LEDs (3/channel), Vf(LED) = 2.5 V/LED.
Pls revert at the earliest.
