TDA4VM: UART app not running alongside Linux for mcu1_0
Part Number: TDA4VM
Other Parts Discussed in Thread: SYSBIOS,
Hi team,
We are trying to run UART app for mcu1_0 on linux using the following linker file:
8168.linker_r5f_mcu1_0_btcm_sysbios.txt
/* File: linker_r5f_mcu1_0_btcm_sysbios.lds                                        */
/* Description:			  					      */
/*    Link command file for J7ES MCU1_0 view				      */
/*	  TI ARM Compiler version 15.12.3 LTS or later			      */
/* (c) Texas Instruments 2018, All rights reserved.                           */
/*  History:								      */
/*    Aug 26th, 2016 Original version .......................... Loc Truong   */
/*    Aug 01th, 2017 new TCM mem map  .......................... Loc Truong   */
/*    Nov 07th, 2017 Changes for R5F Init Code.................. Vivek Dhande */
/*    Sep 17th, 2018 Added DDR sections for IPC................. J. Bergsagel */
/*    Sep 26th, 2018 Extra mem sections for IPC resource table.. J. Bergsagel */
/*    Nov 06th, 2018 Correction to TCM addresses for MCU1_0..... J. Bergsagel */
/*    Nov 07th, 2018 Split up OCMRAM_MCU for split-mode R5Fs.... J. Bergsagel */
/*    Feb 20th, 2019 Use R5F BTCM memory for boot vectors........J. Bergsagel */
/*    Apr 23th, 2019 Changes for R5F startup Code............... Vivek Dhande */
/* Linker Settings                                                            */
/* Standard linker options						      */
--retain="*(.bootCode)"
--retain="*(.startupCode)"
--retain="*(.startupData)"
--fill_value=0
--stack_size=0xC0000
--heap_size=0x1000
-stack  0xC0000 //org 0x2000                              /* SOFTWARE STACK SIZE           */
-heap   0x2000 //org 0x2000                              /* HEAP AREA SIZE                */
--define FILL_PATTERN=0xFEAA55EF
--define FILL_LENGTH=0x100
#define DDR0_ALLOCATED_START 0xA0000000
#define MCU1_0_EXT_DATA_BASE     (DDR0_ALLOCATED_START + 0x00100000)
#define MCU1_0_R5F_MEM_TEXT_BASE (DDR0_ALLOCATED_START + 0x00200000)
#define MCU1_0_R5F_MEM_DATA_BASE (DDR0_ALLOCATED_START + 0x00300000)
#define MCU1_0_DDR_SPACE_BASE    (DDR0_ALLOCATED_START + 0x00400000)
#define MCU1_1_ALLOCATED_START   DDR0_ALLOCATED_START + 0x01000000
#define MCU1_1_EXT_DATA_BASE     (MCU1_1_ALLOCATED_START + 0x00100000)
#define MCU1_1_R5F_MEM_TEXT_BASE (MCU1_1_ALLOCATED_START + 0x00200000)
#define MCU1_1_R5F_MEM_DATA_BASE (MCU1_1_ALLOCATED_START + 0x00300000)
#define MCU1_1_DDR_SPACE_BASE    (MCU1_1_ALLOCATED_START + 0x00400000)
#define MCU2_0_ALLOCATED_START   DDR0_ALLOCATED_START + 0x02000000
#define MCU2_0_EXT_DATA_BASE     (MCU2_0_ALLOCATED_START + 0x00100000)
#define MCU2_0_R5F_MEM_TEXT_BASE (MCU2_0_ALLOCATED_START + 0x00200000)
#define MCU2_0_R5F_MEM_DATA_BASE (MCU2_0_ALLOCATED_START + 0x00300000)
#define MCU2_0_DDR_SPACE_BASE    (MCU2_0_ALLOCATED_START + 0x00400000)
#define MCU2_1_ALLOCATED_START   DDR0_ALLOCATED_START + 0x03000000
#define MCU2_1_EXT_DATA_BASE     (MCU2_1_ALLOCATED_START + 0x00100000)
#define MCU2_1_R5F_MEM_TEXT_BASE (MCU2_1_ALLOCATED_START + 0x00200000)
#define MCU2_1_R5F_MEM_DATA_BASE (MCU2_1_ALLOCATED_START + 0x00300000)
#define MCU2_1_DDR_SPACE_BASE    (MCU2_1_ALLOCATED_START + 0x00400000)
#define ATCM_START 0x00000000
#define BTCM_START 0x41010000
-e __VECS_ENTRY_POINT
//--retain="*(.intvecs)"
//--retain="*(.intc_text)"
//--retain="*(.rstvectors)"
--retain="*(.utilsCopyVecsToAtcm)"
/* Memory Map        */
MEMORY
    /* MCU1_R5F_0 local view  */
    MCU_ATCM (RWX)		: origin=ATCM_START	length=0x8000
    /* MCU1_R5F0_TCMB0 (RWIX)	: origin=BTCM_START	length=0x8000 (documented only, to void conflict below) */
    /* MCU1_R5F_0 SoC view  */
    MCU1_R5F0_ATCM (RWIX)  	: origin=0x41000000 length=0x8000
    MCU1_R5F0_BTCM_VECS (RWIX)  : origin=0x41010000 length=0x0100
    MCU1_R5F0_BTCM (RWIX) 	: origin=0x41010100 length=0x7F00
    DDR0_RESERVED    (RWIX)  	: origin=0x80000000 length=0x20000000	  	/* 512MB */
    MCU1_0_IPC_DATA (RWIX)	: origin=DDR0_ALLOCATED_START     length=0x00100000	/*   1MB */
    MCU1_0_EXT_DATA  (RWIX)	: origin=MCU1_0_EXT_DATA_BASE     length=0x00100000	/*   1MB */
    MCU1_0_R5F_MEM_TEXT (RWIX)	: origin=MCU1_0_R5F_MEM_TEXT_BASE length=0x00100000	/*   1MB */
    MCU1_0_R5F_MEM_DATA (RWIX)	: origin=MCU1_0_R5F_MEM_DATA_BASE length=0x00100000	/*   1MB */
    MCU1_0_DDR_SPACE (RWIX)	: origin=MCU1_0_DDR_SPACE_BASE    length=0x00C00000	/*  12MB */
    MCU1_1_IPC_DATA (RWIX)	: origin=MCU1_1_ALLOCATED_START   length=0x00100000	/*   1MB */
    MCU1_1_EXT_DATA  (RWIX)	: origin=MCU1_1_EXT_DATA_BASE     length=0x00100000	/*   1MB */
    MCU1_1_R5F_MEM_TEXT (RWIX)	: origin=MCU1_1_R5F_MEM_TEXT_BASE length=0x00100000	/*   1MB */
    MCU1_1_R5F_MEM_DATA (RWIX)	: origin=MCU1_1_R5F_MEM_DATA_BASE length=0x00100000	/*   1MB */
    MCU1_1_DDR_SPACE (RWIX)	: origin=MCU1_1_DDR_SPACE_BASE    length=0x00C00000	/*  12MB */
    MCU2_0_IPC_DATA (RWIX)	: origin=MCU2_0_ALLOCATED_START   length=0x00100000	/*   1MB */
    MCU2_0_EXT_DATA  (RWIX)	: origin=MCU2_0_EXT_DATA_BASE     length=0x00100000	/*   1MB */
    MCU2_0_R5F_MEM_TEXT (RWIX)	: origin=MCU2_0_R5F_MEM_TEXT_BASE length=0x00100000	/*   1MB */
    MCU2_0_R5F_MEM_DATA (RWIX)	: origin=MCU2_0_R5F_MEM_DATA_BASE length=0x00100000	/*   1MB */
    MCU2_0_DDR_SPACE (RWIX)	: origin=MCU2_0_DDR_SPACE_BASE    length=0x00C00000	/*  12MB */
    MCU2_1_IPC_DATA (RWIX)	: origin=MCU2_1_ALLOCATED_START   length=0x00100000	/*   1MB */
    MCU2_1_EXT_DATA  (RWIX)	: origin=MCU2_1_EXT_DATA_BASE     length=0x00100000	/*   1MB */
    MCU2_1_R5F_MEM_TEXT (RWIX)	: origin=MCU2_1_R5F_MEM_TEXT_BASE length=0x00100000	/*   1MB */
    MCU2_1_R5F_MEM_DATA (RWIX)	: origin=MCU2_1_R5F_MEM_DATA_BASE length=0x00100000	/*   1MB */
    MCU2_1_DDR_SPACE (RWIX)	: origin=MCU2_1_DDR_SPACE_BASE    length=0x00C00000	/*  12MB */
    SHARED_DDR_SPACE (RWIX)	: origin=0xAA000000 length=0x01C00000           /*  28MB */
}  /* end of MEMORY */
/* Section Configuration                                                      */
SECTIONS
    .vecs : {
         *(.vecs)
    } palign(8) > BTCM_START
    .vecs       : {
        __VECS_ENTRY_POINT = .;
    } > MCU1_R5F0_BTCM_VECS
    xdc.meta (COPY): { *(xdc.meta) } > MCU1_R5F0_BTCM
    .init_text  : {
                     boot.*(.text)
                     *(.text:ti_sysbios_family_arm_MPU_*)
                     *(.text:ti_sysbios_family_arm_v7r_Cache_*)
                  }  palign(8) > MCU1_R5F0_BTCM
    .text:xdc_runtime_Startup_reset__I     : {} palign(8) > MCU1_R5F0_BTCM
    .bootCode    	: {} palign(8) 		> MCU1_R5F0_BTCM
    .startupCode 	: {} palign(8) 		> MCU1_R5F0_BTCM
    .startupData 	: {} palign(8) 		> MCU1_R5F0_BTCM, type = NOINIT
    .utilsCopyVecsToAtcm                   : {} palign(8) > MCU1_R5F0_BTCM
    .text	: {} palign(8)		> MCU1_0_DDR_SPACE
    .const   	: {} palign(8) 		> MCU1_0_DDR_SPACE
    .cinit   	: {} palign(8) 		> MCU1_0_DDR_SPACE
    .pinit   	: {} palign(8) 		> MCU1_0_DDR_SPACE
    .bss     	: {} align(4)  		> MCU1_0_DDR_SPACE
    .data    	: {} palign(128) 	> MCU1_0_DDR_SPACE
    .data_buffer: {} palign(128) 	> MCU1_0_DDR_SPACE
    .sysmem  	: {} 			> MCU1_0_DDR_SPACE
    .stack	: {} align(4)		> MCU1_0_DDR_SPACE
    .resource_table : {
        __RESOURCE_TABLE = .;
    } > MCU1_0_EXT_DATA
    .tracebuf   : {}			> MCU1_0_EXT_DATA
    .const.devgroup.MCU_WAKEUP    : {} align(4)      > MCU1_0_DDR_SPACE
    .const.devgroup.MAIN          : {} align(4)      > MCU1_0_DDR_SPACE
    .const.devgroup.DMSC_INTERNAL : {} align(4)      > MCU1_0_DDR_SPACE
    .bss.devgroup.MAIN            : {} align(4)      > MCU1_0_DDR_SPACE
    .bss.devgroup.MCU_WAKEUP      : {} align(4)      > MCU1_0_DDR_SPACE
    .bss.devgroup.DMSC_INTERNAL   : {} align(4)      > MCU1_0_DDR_SPACE
    .boardcfg_data                : {} align(4)      > MCU1_0_DDR_SPACE
    .bss.devgroup*                : {} align(4)      > MCU1_0_DDR_SPACE
    .const.devgroup*              : {} align(4)      > MCU1_0_DDR_SPACE
/* Misc linker settings                                                       */
#if 0
   /* Additional sections settings     */
    McalTextSection : fill=FILL_PATTERN, align=4, load > MCU1_0_DDR_SPACE
        .=align(4);
        __linker_can_text_start = .;
        . += FILL_LENGTH;
        *(CAN_TEXT_SECTION)
        *(CAN_ISR_TEXT_SECTION)
        .=align(4);
        . += FILL_LENGTH;
        __linker_can_text_end = .;
        .=align(4);
        __linker_dio_text_start = .;
        . += FILL_LENGTH;
        *(DIO_TEXT_SECTION)
        .=align(4);
        . += FILL_LENGTH;
        __linker_dio_text_end = .;
    McalConstSection : fill=FILL_PATTERN, align=4, load > MCU1_0_DDR_SPACE
        .=align(4);
        __linker_can_const_start = .;
        . += FILL_LENGTH;
        *(CAN_CONST_8_SECTION)
        *(CAN_CONST_32_SECTION)
        *(CAN_CONFIG_SECTION)
        .=align(4);
        . += FILL_LENGTH;
        __linker_can_const_end = .;
        .=align(4);
        __linker_dio_const_start = .;
        . += FILL_LENGTH;
        *(DIO_CONST_32_SECTION)
        *(DIO_CONST_UNSPECIFIED_SECTION)
        *(DIO_CONFIG_SECTION)
        .=align(4);
        . += FILL_LENGTH;
        __linker_dio_const_end = .;
    McalInitSection : fill=FILL_PATTERN, align=4, load > MCU1_0_DDR_SPACE
        .=align(4);
        __linker_can_init_start = .;
        . += FILL_LENGTH;
        *(CAN_DATA_INIT_8_SECTION)
        .=align(4);
        . += FILL_LENGTH;
        __linker_can_init_end = .;
    McalNoInitSection : fill=FILL_PATTERN, align=4, load > MCU1_0_DDR_SPACE, type = NOINIT
        .=align(4);
        __linker_can_no_init_start = .;
        . += FILL_LENGTH;
        *(CAN_DATA_NO_INIT_UNSPECIFIED_SECTION)
        *(CAN_DATA_NO_INIT_32_SECTION)
        .=align(4);
        . += FILL_LENGTH;
        __linker_can_no_init_end = .;
    /* Example Utility specifics */
    UtilityNoInitSection : align=4, load > MCU1_0_DDR_SPACE, type = NOINIT
        .=align(4);
        __linker_utility_no_init_start = .;
        . += FILL_LENGTH;
        *(EG_TEST_RESULT_32_SECTION)
        .=align(4);
        . += FILL_LENGTH;
        __linker_utility_no_init_end = .;
#endif
}  /* end of SECTIONS */
/*-------------------------------- END ---------------------------------------*/
1]Following is the elf output for the following command : readelf -l UART_j721e_evm_mcu2_0TestApp_release_strip.xer5f
UART_elf.txt
Elf file type is EXEC (Executable file)
Entry point 0x0
There are 5 program headers, starting at offset 98644
Program Headers:
  Type           Offset   VirtAddr   PhysAddr   FileSiz MemSiz  Flg Align
  LOAD           0x000040 0x00000000 0x00000000 0x00518 0x00518 R E 0x10
  LOAD           0x000558 0xa2400000 0xa2400000 0x00000 0x19dd1 RW  0x8
  LOAD           0x000560 0xa2419de0 0xa2419de0 0x164e0 0x164e0 R E 0x10
  LOAD           0x016a80 0xa2430300 0xa2430300 0x00000 0x05d00 RW  0x80
  LOAD           0x016a80 0xa2436000 0xa2436000 0x012f8 0x012f8 R   0x8
 Section to Segment mapping:
  Segment Sections...
   00     .vecs .vecs .init_text .text:xdc_runtime_Startup_reset__I .utilsCopyVecsToAtcm .data_buffer
   01     .bss __llvm_prf_cnts
   02     .text .const
   03     .data .stack
I have also updated the .utilsVecstoAtcm file from location :/home/$(USER)/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/utils/copyVecs2Atcm/utilsCopyVecs2ATcm.asm
where I have disabled the ATCM section read
6131.utilsCopyVecs2ATcm.asm
I have updated the file at location:
/home/$(USER)/ti-processor-sdk-linux-j7-evm-07_03_00_05/board-support/linux-5.4.106+gitAUTOINC+023faefa70-g023faefa70/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dts  with the follwoing lines,
&mcu_uart0 {
    status = "disabled";
4314.k3-j721e-common-proc-board.txt
// SPDX-License-Identifier: GPL-2.0
 * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/
/dts-v1/;
#include "k3-j721e-som-p0.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/input/input.h>
#include <dt-bindings/sound/ti-mcasp.h>
#include <dt-bindings/net/ti-dp83867.h>
	chosen {
		stdout-path = "serial2:115200n8";
		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
	gpio_keys: gpio-keys {
		compatible = "gpio-keys";
		autorepeat;
		pinctrl-names = "default";
		pinctrl-0 = <&sw10_button_pins_default &sw11_button_pins_default>;
		sw10: sw10 {
			label = "GPIO Key USER1";
			linux,code = <BTN_0>;
			gpios = <&main_gpio0 0 GPIO_ACTIVE_LOW>;
		sw11: sw11 {
			label = "GPIO Key USER2";
			linux,code = <BTN_1>;
			gpios = <&wkup_gpio0 7 GPIO_ACTIVE_LOW>;
	evm_12v0: fixedregulator-evm12v0 {
		/* main supply */
		compatible = "regulator-fixed";
		regulator-name = "evm_12v0";
		regulator-min-microvolt = <12000000>;
		regulator-max-microvolt = <12000000>;
		regulator-always-on;
		regulator-boot-on;
	vsys_3v3: fixedregulator-vsys3v3 {
		/* Output of LMS140 */
		regulator-name = "vsys_3v3";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		vin-supply = <&evm_12v0>;
		regulator-boot-on;
	vsys_5v0: fixedregulator-vsys5v0 {
		/* Output of LM5140 */
		regulator-name = "vsys_5v0";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		regulator-boot-on;
	/* Used for 48KHz family */
	pll4: pll4_fixed {
		#clock-cells = <0>;
		compatible = "fixed-clock";
		clock-frequency = <1179648000>;
	/* Used for 44.1KHz family */
	pll15: pll15_fixed {
		#clock-cells = <0>;
		clock-frequency = <1083801600>;
	sound0: sound@0 {
		compatible = "ti,j721e-cpb-audio";
		ti,model = "j721e-cpb-analog";
		ti,cpb-mcasp = <&mcasp10>;
		ti,cpb-codec = <&pcm3168a_1>;
		clocks = <&pll4>, <&pll15>,
			 <&k3_clks 184 1>,
			 <&k3_clks 184 2>, <&k3_clks 184 4>,
			 <&k3_clks 157 371>,
			 <&k3_clks 157 400>, <&k3_clks 157 401>;
		clock-names = "pll4", "pll15",
			      "cpb-mcasp",
			      "cpb-mcasp-48000", "cpb-mcasp-44100",
			      "audio-refclk2",
			      "audio-refclk2-48000", "audio-refclk2-44100";
	vdd_mmc1: fixedregulator-sd {
		regulator-name = "vdd_mmc1";
		regulator-boot-on;
		enable-active-high;
		vin-supply = <&vsys_3v3>;
		gpio = <&exp2 2 GPIO_ACTIVE_HIGH>;
	vdd_sd_dv_alt: gpio-regulator-TLV71033 {
		compatible = "regulator-gpio";
		pinctrl-0 = <&vdd_sd_dv_alt_pins_default>;
		regulator-name = "tlv71033";
		regulator-min-microvolt = <1800000>;
		regulator-boot-on;
		vin-supply = <&vsys_5v0>;
		gpios = <&main_gpio0 117 GPIO_ACTIVE_HIGH>;
		states = <1800000 0x0
			  3300000 0x1>;
	cpsw9g_virt_mac: main_r5fss_cpsw9g_virt_mac0 {
		compatible = "ti,j721e-cpsw-virt-mac";
		dma-coherent;
		ti,psil-base = <0x4a00>;
		ti,remote-name = "mpu_1_0_ethswitch-device-0";
		dmas = <&main_udmap 0xca00>,
		       <&main_udmap 0xca01>,
		       <&main_udmap 0xca02>,
		       <&main_udmap 0xca03>,
		       <&main_udmap 0xca04>,
		       <&main_udmap 0xca05>,
		       <&main_udmap 0xca06>,
		       <&main_udmap 0xca07>,
		       <&main_udmap 0x4a00>;
		dma-names = "tx0", "tx1", "tx2", "tx3",
			    "tx4", "tx5", "tx6", "tx7",
			    "rx";
		virt_emac_port {
			ti,label = "virt-port";
			/* local-mac-address = [0 0 0 0 0 0]; */
	dp0: connector {
		compatible = "dp-connector";
		label = "DP0";
		port {
			dp_connector_in: endpoint {
				remote-endpoint = <&dp_bridge_output>;
	clk_ov5640_fixed: ov5640-xclk {
		#clock-cells = <0>;
		clock-frequency = <25000000>;
&main_pmx0 {
	sw10_button_pins_default: sw10_button_pins_default {
		pinctrl-single,pins = <
			J721E_IOPAD(0x0, PIN_INPUT, 7) /* (AC18) EXTINTn.GPIO0_0 */
	dp0_pins_default: dp0_pins_default {
			J721E_IOPAD(0x1c4, PIN_INPUT, 5) /* SPI0_CS1.DP0_HPD */
	main_i2c1_exp4_pins_default: main-i2c1-exp4-pins-default {
			J721E_IOPAD(0x230, PIN_INPUT, 7) /* (U2) ECAP0_IN_APWM_OUT.GPIO1_11 */
	main_i2c0_pins_default: main-i2c0-pins-default {
			J721E_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (AC5) I2C0_SCL */
			J721E_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (AA5) I2C0_SDA */
	main_i2c1_pins_default: main-i2c1-pins-default {
			J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */
			J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */
	main_i2c2_pins_default: main-i2c2-pins-default {
			J721E_IOPAD(0x1c8, PIN_INPUT_PULLUP, 2) /* (AB5) SPI0_CLK.I2C2_SCL */
			J721E_IOPAD(0x1cc, PIN_INPUT_PULLUP, 2) /* (AA1) SPI0_D0.I2C2_SDA */
	main_i2c3_pins_default: main-i2c3-pins-default {
			J721E_IOPAD(0x270, PIN_INPUT_PULLUP, 4) /* (T26) MMC2_CLK.I2C3_SCL */
			J721E_IOPAD(0x274, PIN_INPUT_PULLUP, 4) /* (T25) MMC2_CMD.I2C3_SDA */
	main_i2c6_pins_default: main-i2c6-pins-default {
			J721E_IOPAD(0x1d0, PIN_INPUT_PULLUP, 2) /* (AA3) SPI0_D1.I2C6_SCL */
			J721E_IOPAD(0x1e4, PIN_INPUT_PULLUP, 2) /* (Y2) SPI1_D1.I2C6_SDA */
	mcasp10_pins_default: mcasp10_pins_default {
			J721E_IOPAD(0x158, PIN_OUTPUT_PULLDOWN, 12) /* (U23) RGMII5_TX_CTL.MCASP10_ACLKX */
			J721E_IOPAD(0x15c, PIN_OUTPUT_PULLDOWN, 12) /* (U26) RGMII5_RX_CTL.MCASP10_AFSX */
			J721E_IOPAD(0x160, PIN_OUTPUT_PULLDOWN, 12) /* (V28) RGMII5_TD3.MCASP10_AXR0 */
			J721E_IOPAD(0x164, PIN_OUTPUT_PULLDOWN, 12) /* (V29) RGMII5_TD2.MCASP10_AXR1 */
			J721E_IOPAD(0x170, PIN_OUTPUT_PULLDOWN, 12) /* (U29) RGMII5_TXC.MCASP10_AXR2 */
			J721E_IOPAD(0x174, PIN_OUTPUT_PULLDOWN, 12) /* (U25) RGMII5_RXC.MCASP10_AXR3 */
			J721E_IOPAD(0x198, PIN_INPUT_PULLDOWN, 12) /* (V25) RGMII6_TD1.MCASP10_AXR4 */
			J721E_IOPAD(0x19c, PIN_INPUT_PULLDOWN, 12) /* (W27) RGMII6_TD0.MCASP10_AXR5 */
			J721E_IOPAD(0x1a0, PIN_INPUT_PULLDOWN, 12) /* (W29) RGMII6_TXC.MCASP10_AXR6 */
	audi_ext_refclk2_pins_default: audi_ext_refclk2_pins_default {
			J721E_IOPAD(0x1a4, PIN_OUTPUT, 3) /* (W26) RGMII6_RXC.AUDIO_EXT_REFCLK2 */
	main_mmc1_pins_default: main_mmc1_pins_default {
			J721E_IOPAD(0x254, PIN_INPUT, 0) /* (R29) MMC1_CMD */
			J721E_IOPAD(0x250, PIN_INPUT, 0) /* (P25) MMC1_CLK */
			J721E_IOPAD(0x2ac, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */
			J721E_IOPAD(0x24c, PIN_INPUT, 0) /* (R24) MMC1_DAT0 */
			J721E_IOPAD(0x248, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */
			J721E_IOPAD(0x244, PIN_INPUT, 0) /* (R25) MMC1_DAT2 */
			J721E_IOPAD(0x240, PIN_INPUT, 0) /* (R26) MMC1_DAT3 */
			J721E_IOPAD(0x258, PIN_INPUT, 0) /* (P23) MMC1_SDCD */
			J721E_IOPAD(0x25c, PIN_INPUT, 0) /* (R28) MMC1_SDWP */
	vdd_sd_dv_alt_pins_default: vdd_sd_dv_alt_pins_default {
			J721E_IOPAD(0x1d8, PIN_INPUT, 7) /* (W4) SPI1_CS1.GPIO0_117 */
	main_usbss0_pins_default: main_usbss0_pins_default {
			J721E_IOPAD(0x290, PIN_OUTPUT, 0) /* (U6) USB0_DRVVBUS */
			J721E_IOPAD(0x210, PIN_INPUT, 7) /* (W3) MCAN1_RX.GPIO1_3 */
	main_usbss1_pins_default: main_usbss1_pins_default {
			J721E_IOPAD(0x214, PIN_OUTPUT, 4) /* (V4) MCAN1_TX.USB1_DRVVBUS */
&wkup_pmx0 {
	sw11_button_pins_default: sw11_button_pins_default {
			J721E_WKUP_IOPAD(0xcc, PIN_INPUT, 7) /* (G28) WKUP_GPIO0_7 */
	mcu_fss0_ospi1_pins_default: mcu-fss0-ospi1-pins-default {
			J721E_WKUP_IOPAD(0x34, PIN_OUTPUT, 0) /* (F22) MCU_OSPI1_CLK */
			J721E_WKUP_IOPAD(0x50, PIN_OUTPUT, 0) /* (C22) MCU_OSPI1_CSn0 */
			J721E_WKUP_IOPAD(0x40, PIN_INPUT, 0) /* (D22) MCU_OSPI1_D0 */
			J721E_WKUP_IOPAD(0x44, PIN_INPUT, 0) /* (G22) MCU_OSPI1_D1 */
			J721E_WKUP_IOPAD(0x48, PIN_INPUT, 0) /* (D23) MCU_OSPI1_D2 */
			J721E_WKUP_IOPAD(0x4c, PIN_INPUT, 0) /* (C23) MCU_OSPI1_D3 */
			J721E_WKUP_IOPAD(0x3c, PIN_INPUT, 0) /* (B23) MCU_OSPI1_DQS */
			J721E_WKUP_IOPAD(0x38, PIN_INPUT, 0) /* (A23) MCU_OSPI1_LBCLKO */
&wkup_pmx0 {
	mcu_cpsw_pins_default: mcu_cpsw_pins_default {
			J721E_WKUP_IOPAD(0x0058, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */
			J721E_WKUP_IOPAD(0x005c, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */
			J721E_WKUP_IOPAD(0x0060, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */
			J721E_WKUP_IOPAD(0x0064, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */
			J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */
			J721E_WKUP_IOPAD(0x006c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */
			J721E_WKUP_IOPAD(0x0078, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */
			J721E_WKUP_IOPAD(0x007c, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */
			J721E_WKUP_IOPAD(0x0080, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */
			J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */
			J721E_WKUP_IOPAD(0x0070, PIN_INPUT, 0) /* MCU_RGMII1_TXC */
			J721E_WKUP_IOPAD(0x0074, PIN_INPUT, 0) /* MCU_RGMII1_RXC */
	mcu_mdio_pins_default: mcu_mdio1_pins_default {
			J721E_WKUP_IOPAD(0x008c, PIN_OUTPUT, 0) /* MCU_MDIO0_MDC */
			J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* MCU_MDIO0_MDIO */
	mcu_mcan0_pins_default: mcu-mcan0-pins-default {
			J721E_WKUP_IOPAD(0xac, PIN_INPUT, 0) /* (C29) MCU_MCAN0_RX */
			J721E_WKUP_IOPAD(0xa8, PIN_OUTPUT, 0) /* (D29) MCU_MCAN0_TX */
	mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-pins-default {
			J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 7) /* (F26) WKUP_GPIO0_0 */
			J721E_WKUP_IOPAD(0x98, PIN_INPUT, 7) /* (E28) MCU_SPI0_D1.WKUP_GPIO0_54 */
	mcu_mcan1_pins_default: mcu-mcan1-pins-default {
			J721E_WKUP_IOPAD(0xc4, PIN_INPUT, 0) /* (G24) WKUP_GPIO0_5.MCU_MCAN1_RX */
			J721E_WKUP_IOPAD(0xc0, PIN_OUTPUT, 0) /* (G25) WKUP_GPIO0_4.MCU_MCAN1_TX */
	mcu_mcan1_gpio_pins_default: mcu-mcan1-gpio-pins-default {
			J721E_WKUP_IOPAD(0xb8, PIN_INPUT, 7) /* (F28) WKUP_GPIO0_2 */
&wkup_uart0 {
	/* Wakeup UART is used by System firmware */
&mcu_uart0 {
	/*status = "disabled";*/
&main_uart0 {
	power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
&main_uart3 {
	/* UART not brought out */
&main_uart5 {
&main_uart6 {
&main_uart7 {
&main_uart8 {
&main_uart9 {
&main_gpio2 {
&main_gpio3 {
&main_gpio4 {
&main_gpio5 {
&main_gpio6 {
&main_gpio7 {
&wkup_gpio1 {
&mailbox0_cluster0 {
	interrupts = <436>;
	mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 {
		ti,mbox-rx = <0 0 0>;
		ti,mbox-tx = <1 0 0>;
	mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 {
		ti,mbox-rx = <2 0 0>;
		ti,mbox-tx = <3 0 0>;
&mailbox0_cluster1 {
	interrupts = <432>;
	mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 {
	mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 {
&mailbox0_cluster2 {
	interrupts = <428>;
	mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 {
	mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 {
&mailbox0_cluster3 {
	interrupts = <424>;
	mbox_c66_0: mbox-c66-0 {
	mbox_c66_1: mbox-c66-1 {
&mailbox0_cluster4 {
	interrupts = <420>;
	mbox_c71_0: mbox-c71-0 {
&mailbox0_cluster5 {
&mailbox0_cluster6 {
&mailbox0_cluster7 {
&mailbox0_cluster8 {
&mailbox0_cluster9 {
&mailbox0_cluster10 {
&mailbox0_cluster11 {
&mcu_r5fss0_core0 {
	mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>;
&mcu_r5fss0_core1 {
	mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>;
&main_r5fss0_core0 {
	mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>;
&main_r5fss0_core1 {
	mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>;
&main_r5fss1_core0 {
	mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core0>;
&main_r5fss1_core1 {
	mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core1>;
&c66_0 {
	mboxes = <&mailbox0_cluster3 &mbox_c66_0>;
&c66_1 {
	mboxes = <&mailbox0_cluster3 &mbox_c66_1>;
&c71_0 {
	mboxes = <&mailbox0_cluster4 &mbox_c71_0>;
&ospi1 {
	pinctrl-0 = <&mcu_fss0_ospi1_pins_default>;
	flash@0{
		compatible = "jedec,spi-nor";
		reg = <0x0>;
		spi-tx-bus-width = <1>;
		spi-rx-bus-width = <4>;
		spi-max-frequency = <40000000>;
		cdns,tshsl-ns = <60>;
		cdns,tsd2d-ns = <60>;
		cdns,tchsh-ns = <60>;
		cdns,tslch-ns = <60>;
		cdns,read-delay = <2>;
		#address-cells = <1>;
		#size-cells = <1>;
&tscadc0 {
	adc {
		ti,adc-channels = <0 1 2 3 4 5 6 7>;
&tscadc1 {
	adc {
&dss {
	status = "ok";
&dss_ports {
	#size-cells = <0>;
	port@0 {
		reg = <0>;
		dpi_out_real0: endpoint {
			remote-endpoint = <&dp_bridge_input>;
&mhdp {
	status = "ok";
	pinctrl-0 = <&dp0_pins_default>;
&dp0_ports {
	#size-cells = <0>;
	port@0 {
		reg = <0>;
		dp_bridge_input: endpoint {
			remote-endpoint = <&dpi_out_real0>;
	port@1 {
		reg = <1>;
		dp_bridge_output: endpoint {
			remote-endpoint = <&dp_connector_in>;
&main_i2c0 {
	pinctrl-0 = <&main_i2c0_pins_default>;
	clock-frequency = <400000>;
	exp1: gpio@20 {
		compatible = "ti,tca6416";
		reg = <0x20>;
		gpio-controller;
		#gpio-cells = <2>;
	exp2: gpio@22 {
		compatible = "ti,tca6424";
		reg = <0x22>;
		gpio-controller;
		#gpio-cells = <2>;
		p08 {
			/* P10 - PM_I2C_CTRL_OE */
			gpio-hog;
			gpios = <8 GPIO_ACTIVE_HIGH>;
			output-high;
			line-name = "CTRL_PM_I2C_OE";
		p09 {
			/* P11 - MCASP/TRACE_MUX_S0 */
			gpio-hog;
			gpios = <9 GPIO_ACTIVE_HIGH>;
			output-low;
			line-name = "MCASP/TRACE_MUX_S0";
		p10 {
			/* P12 - MCASP/TRACE_MUX_S1 */
			gpio-hog;
			gpios = <10 GPIO_ACTIVE_HIGH>;
			output-high;
			line-name = "MCASP/TRACE_MUX_S1";
&main_i2c2 {
	pinctrl-0 = <&main_i2c2_pins_default>;
	ina226@40 {
		compatible = "ti,ina226";
		reg = <0x40>;
		shunt-resistor = <10000>;
	ina226@41 {
		reg = <0x41>;
	ina226@42 {
		reg = <0x42>;
	ina226@43 {
		reg = <0x43>;
	ina226@44 {
		reg = <0x44>;
	ina226@45 {
		reg = <0x45>;
		shunt-resistor = <5000>;
	ina226@46 {
		reg = <0x46>;
	ina226@47 {
		reg = <0x47>;
	ina226@48 {
		reg = <0x48>;
	ina226@49 {
		reg = <0x49>;
	ina226@4a {
		reg = <0x4a>;
	ina226@4b {
		reg = <0x4b>;
	ina226@4c {
		reg = <0x4c>;
	ina226@4d {
		reg = <0x4d>;
	ina226@4e {
		reg = <0x4e>;
	ina226@4f {
		reg = <0x4f>;
&main_i2c1 {
	pinctrl-0 = <&main_i2c1_pins_default>;
	exp4: gpio@20 {
		compatible = "ti,tca6408";
		reg = <0x20>;
		gpio-controller;
		#gpio-cells = <2>;
		pinctrl-0 = <&main_i2c1_exp4_pins_default>;
		interrupt-parent = <&main_gpio1>;
		interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
		interrupt-controller;
		#interrupt-cells = <2>;
		p0 {
			/* P0 - DP0_PWR_SW_EN */
			gpio-hog;
			gpios = <0 GPIO_ACTIVE_HIGH>;
			output-high;
			line-name = "DP0_PWR_SW_EN";
&k3_clks {
	/* Confiure AUDIO_EXT_REFCLK2 pin as output */
	pinctrl-0 = <&audi_ext_refclk2_pins_default>;
&main_i2c3 {
	pinctrl-0 = <&main_i2c3_pins_default>;
	exp3: gpio@20 {
		reg = <0x20>;
		gpio-controller;
		#gpio-cells = <2>;
	pcm3168a_1: audio-codec@44 {
		compatible = "ti,pcm3168a";
		reg = <0x44>;
		#sound-dai-cells = <1>;
		reset-gpios = <&exp3 0 GPIO_ACTIVE_LOW>;
		/* C_AUDIO_REFCLK2 -> RGMII6_RXC (W26) */
		clocks = <&k3_clks 157 371>;
		clock-names = "scki";
		/* HSDIV3_16FFT_MAIN_4_HSDIVOUT2_CLK -> REFCLK2 */
		assigned-clocks = <&k3_clks 157 371>;
		assigned-clock-parents = <&k3_clks 157 400>;
		assigned-clock-rates = <24576000>; /* for 48KHz */
		VDD1-supply = <&vsys_3v3>;
		VDD2-supply = <&vsys_3v3>;
		VCCAD1-supply = <&vsys_5v0>;
		VCCAD2-supply = <&vsys_5v0>;
		VCCDA1-supply = <&vsys_5v0>;
		VCCDA2-supply = <&vsys_5v0>;
&main_i2c6 {
	pinctrl-0 = <&main_i2c6_pins_default>;
	exp5: gpio@20 {
		reg = <0x20>;
		gpio-controller;
		#gpio-cells = <2>;
	ov5640: camera@3c {
		compatible = "ovti,ov5640";
		reg = <0x3c>;
		clocks = <&clk_ov5640_fixed>;
		clock-names = "xclk";
		reset-gpios = <&exp5 0 GPIO_ACTIVE_LOW>;
		port {
			csi2_cam0: endpoint {
				remote-endpoint = <&csi2rx0_in_sensor>;
				clock-lanes = <0>;
				data-lanes = <1 2>;
&mcasp10 {
	#sound-dai-cells = <0>;
	pinctrl-0 = <&mcasp10_pins_default>;
	op-mode = <0>;          /* MCASP_IIS_MODE */
	tdm-slots = <2>;
	auxclk-fs-ratio = <256>;
	serial-dir = <	/* 0: INACTIVE, 1: TX, 2: RX */
		1 1 1 1
		2 2 2 0
	tx-num-evt = <0>;
	rx-num-evt = <0>;
	status = "okay";
&mcu_cpsw {
	pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>;
&davinci_mdio {
	phy0: ethernet-phy@0 {
		reg = <0>;
		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
&cpsw_port1 {
	phy-mode = "rgmii-rxid";
	phy-handle = <&phy0>;
&main_sdhci0 {
	/* eMMC */
	non-removable;
	ti,driver-strength-ohm = <50>;
	disable-wp;
&main_sdhci1 {
	/* SD/MMC */
	vmmc-supply = <&vdd_mmc1>;
	vqmmc-supply = <&vdd_sd_dv_alt>;
	pinctrl-0 = <&main_mmc1_pins_default>;
	disable-wp;
&main_sdhci2 {
	/* Unused */
&serdes0 {
	serdes0_pcie_link: link@0 {
		reg = <0>;
		cdns,num-lanes = <1>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_PCIE>;
		resets = <&serdes_wiz0 1>;
&serdes1 {
	serdes1_pcie_link: link@0 {
		reg = <0>;
		cdns,num-lanes = <2>;
		#phy-cells = <0>;
		resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>;
&serdes2 {
	serdes2_pcie_link: link@0 {
		reg = <0>;
		#phy-cells = <0>;
		resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>;
&pcie0_rc {
	reset-gpios = <&exp1 6 GPIO_ACTIVE_HIGH>;
	phys = <&serdes0_pcie_link>;
	phy-names = "pcie_phy";
	num-lanes = <1>;
&pcie1_rc {
	reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>;
	phys = <&serdes1_pcie_link>;
	num-lanes = <2>;
&pcie2_rc {
	reset-gpios = <&exp2 20 GPIO_ACTIVE_HIGH>;
	phys = <&serdes2_pcie_link>;
	num-lanes = <2>;
&pcie0_ep {
	num-lanes = <1>;
&pcie1_ep {
	num-lanes = <2>;
&pcie2_ep {
	num-lanes = <2>;
&pcie3_rc {
&pcie3_ep {
&usb_serdes_mux {
	idle-states = <1>, <0>; /* USB0 to SERDES3, USB1 to SERDES1 */
&serdes_ln_ctrl {
	idle-states = <SERDES0_LANE0_PCIE0_LANE0>, <SERDES0_LANE1_PCIE0_LANE1>,
		      <SERDES1_LANE0_PCIE1_LANE0>, <SERDES1_LANE1_PCIE1_LANE1>,
		      <SERDES2_LANE0_PCIE2_LANE0>, <SERDES2_LANE1_PCIE2_LANE1>,
		      <SERDES3_LANE0_USB3_0_SWAP>, <SERDES3_LANE1_USB3_0>,
		      <SERDES4_LANE0_EDP_LANE0>, <SERDES4_LANE1_EDP_LANE1>, <SERDES4_LANE2_EDP_LANE2>, <SERDES4_LANE3_EDP_LANE3>;
&serdes_wiz3 {
	typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_HIGH>;
	typec-dir-debounce-ms = <700>;	/* TUSB321, tCCB_DEFAULT 133 ms */
&serdes3 {
	serdes3_usb_link: link@0 {
		reg = <0>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_USB3>;
		resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>;
&usbss0 {
	pinctrl-0 = <&main_usbss0_pins_default>;
	ti,vbus-divider;
&usb0 {
	dr_mode = "otg";
	maximum-speed = "super-speed";
	phys = <&serdes3_usb_link>;
	phy-names = "cdns3,usb3-phy";
&usbss1 {
	pinctrl-0 = <&main_usbss1_pins_default>;
	ti,usb2-only;
&usb1 {
	dr_mode = "host";
	maximum-speed = "high-speed";
/* uart2 assigned to cpsw9g eth-switch fw running on remote CPU core */
&main_uart2 {
&mcu_mcan0 {
/*	status = "okay";*/
	pinctrl-0 = <&mcu_mcan0_pins_default &mcu_mcan0_gpio_pins_default>;
	stb-gpios = <&wkup_gpio0 54 GPIO_ACTIVE_HIGH>;
	en-gpios = <&wkup_gpio0 0 GPIO_ACTIVE_HIGH>;
	can-transceiver {
		max-bitrate = <5000000>;
&mcu_mcan1 {
	status = "disabled:";
	pinctrl-0 = <&mcu_mcan1_pins_default &mcu_mcan1_gpio_pins_default>;
	stb-gpios = <&wkup_gpio0 2 GPIO_ACTIVE_LOW>;
	can-transceiver {
&main_mcan0 {
&main_mcan1 {
&main_mcan2 {
&main_mcan3 {
&main_mcan4 {
&main_mcan5 {
&main_mcan6 {
&main_mcan7 {
&main_mcan8 {
&main_mcan9 {
&main_mcan10 {
&main_mcan11 {
&main_mcan12 {
&main_mcan13 {
&csi2_0 {
	csi2rx0_in_sensor: endpoint {
		remote-endpoint = <&csi2_cam0>;
		bus-type = <4>; /* CSI2 DPHY. */
		clock-lanes = <0>;
		data-lanes = <1 2>;
And I am getting the following output :
U-Boot SPL 2020.01-dirty (Aug 23 2022 - 15:05:56 )
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.1.1--v202)
Reading on-board EEPROM at 0x50 failed -1
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No t
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.4(release):07.03.00.005-dirty
NOTICE:  BL31: Built : 00:15:40, Apr 10 2021
Please provide help  with respect to the changes needed to get this app running.
Thanks & Regards,
Tanvi
  • Hi team,
    Any updates?
    Tanvi
  • Hi Tanvi,
    For which core are you building the UART App, mcu1_0 or mcu2_0? The UART instance in use will change based on that. Make sure you are disabling the correct UART instance based on that.
    Also, if you are loading the app on mcu1_0, you need to setup the sciserver as well did you take care of that?
    Parth
  • Hi Parth,
    1]Building the UART App for mcu1_0.
    The elf output for the command: readelf -l UART_j721e_evm_mcu1_0TestApp_release_strip.xer5f
    is as follows:
    UART_m1_0.txt
    Entry point 0x41010000
    There are 14 program headers, starting at offset 189440
    Program Headers:
      LOAD           0x000038 0x41010000 0x41010000 0x00040 0x00040 R   0x8
      LOAD           0x000080 0x41010100 0x41010100 0x00588 0x00588 R E 0x10
      LOAD           0x000608 0xa0400000 0xa0400000 0x00000 0x1bef1 RW  0x8
      LOAD           0x000608 0xa041bef4 0xa041bef4 0x0000a 0x0000a R   0x4
      LOAD           0x000620 0xa041bf00 0xa041bf00 0x269c8 0x269c8 R E 0x10
      LOAD           0x026fe8 0xa04428c8 0xa04428c8 0x00000 0x00004 RW  0x4
      LOAD           0x027000 0xa0442900 0xa0442900 0x00000 0x05880 RW  0x80
      LOAD           0x027000 0xa0448180 0xa0448180 0x03b1e 0x03b1e R   0x4
      LOAD           0x02ab20 0xa044bca0 0xa044bca0 0x00000 0x02000 RW  0x8
      LOAD           0x02ab80 0xa044dd00 0xa044dd00 0x01700 0x01700 R   0x80
      LOAD           0x02c280 0xa044f400 0xa044f400 0x00000 0x00f14 RW  0x4
      LOAD           0x02c280 0xa0450314 0xa0450314 0x00770 0x00770 R   0x4
      LOAD           0x02c9f0 0xa0450a84 0xa0450a84 0x00000 0x001e8 RW  0x4
      LOAD           0x02c9f0 0xa0450c70 0xa0450c70 0x015a0 0x015a0 R   0x8
      Segment Sections...
       00     .vecs .vecs
       01     .init_text .text:xdc_runtime_Startup_reset__I .utilsCopyVecsToAtcm
       02     .bss __llvm_prf_cnts
       03     .const.devgroup.DMSC_INTERNAL
       04     .text .const
       05     .bss.devgroup.DMSC_INTERNAL
       06     .data
       07     .const.devgroup.MAIN
       08     .stack
       09     .boardcfg_data
       10     .bss.devgroup.MAIN
       11     .const.devgroup.MCU_WAKEUP
       12     .bss.devgroup.MCU_WAKEUP
       13     .cinit
    2]I am building UART_TestApp default application which comes with PDK 7.3. Do I need to make any changes in SciServer ?
    Tanvi
  • Hi Parth,
    I tried the steps for setting up the sci server from the above link:
    1] Applied this patch:
    Please apply the following patch on the top of your "Function" directory.
    0001-Removing-ATCM-disable-check.zip
    2]The conversation further linked:
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1074907/tda4vm-tda4vm-how-to-run-multicore-image-app-on-linux/4074247#4074247
    so added the patches as:
    I'm attaching the patches on PDK, u-boot and Linux to make MCSPI_Master_TestApp run along with Linux on A72. These are validated on the EVM.
    patches: patches_ mcspi-master-w-linux.zip and followed the steps  to disable the UART in dtb. for the UART_Testapp.
    Still the app is not running.
    Output:
    U-Boot SPL 2020.01-dirty (Aug 26 2022 - 16:18:58 +0530)
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Ll)
    Loading Environment from MMC... *** Warning - No MMC card found, ust
    Did I made right changes?
    If not Can you suggest specific changes to setup sci-server.
    Ketaki
  • Hi Ketaki,
    Apologies for delay in response. Can you please provide the patch of changes that you have done for UART test, I'll check the changes on my end and get back to you.
    Parth
  • Hello Parth,
    Considering UART_TestApp and the below patch suggestions I have made the following changes:
    0001-Update-MCSPI_Master_TestApp-to-run-along-side-Linux.txt
    From cc292e88d6ed443455b309809da6d3e23a6f38cd Mon Sep 17 00:00:00 2001
    Date: Mon, 9 May 2022 08:52:21 -0400
    Subject: [PATCH] Update MCSPI_Master_TestApp to run along side Linux
    - Patches needed:
      - u-boot: to disable MCU UART
      - Linux : to disable MCU UART
      - PDK   : changes to application's mem map, bios config and startup hook fxn
    Note that w/o a valid slave app, the master app on MCU1_0 will wait in a loop.
    Signed-off-by: Karan Saxena <karan@ti.com>
     .../j721e/linker_mcu_sysbios.lds              |  51 ----
     .../j721e/linker_r5f_mcu1_0_btcm_sysbios.lds  | 149 +++++++++++
     .../mcspi_slavemode/j721e/r5_mpu_ipc.xs       | 159 ++++++++++++
     .../j721e/sysbios_r5f_btcm.cfg                | 239 ++++++++++++++++++
     .../drv/spi/example/mcspi_slavemode/makefile  |   5 +-
     .../mcspi_slavemode/src/ipcCopyVecs2Exc.asm   |  59 +++++
     .../src/main_mcspi_slave_mode.c               |   4 +
     7 files changed, 613 insertions(+), 53 deletions(-)
     delete mode 100755 packages/ti/drv/spi/example/mcspi_slavemode/j721e/linker_mcu_sysbios.lds
     create mode 100755 packages/ti/drv/spi/example/mcspi_slavemode/j721e/linker_r5f_mcu1_0_btcm_sysbios.lds
     create mode 100644 packages/ti/drv/spi/example/mcspi_slavemode/j721e/r5_mpu_ipc.xs
     create mode 100644 packages/ti/drv/spi/example/mcspi_slavemode/j721e/sysbios_r5f_btcm.cfg
     create mode 100644 packages/ti/drv/spi/example/mcspi_slavemode/src/ipcCopyVecs2Exc.asm
    diff --git a/packages/ti/drv/spi/example/mcspi_slavemode/j721e/linker_mcu_sysbios.lds b/packages/ti/drv/spi/example/mcspi_slavemode/j721e/linker_mcu_sysbios.lds
    deleted file mode 100755
    index 76ef5d9..0000000
    --- a/packages/ti/drv/spi/example/mcspi_slavemode/j721e/linker_mcu_sysbios.lds
    +++ /dev/null
    @@ -1,51 +0,0 @@
    -/* linker options */
    ---fill_value=0
    ---stack_size=0x2000
    ---heap_size=0x1000
    --e __VECS_ENTRY_POINT
    ---retain="*(.utilsCopyVecsToAtcm)"
    -MEMORY
    -    R5F_TCMA_SBL_RSVD(X): ORIGIN = 0x00000000 , LENGTH = 0x100
    -    R5F_TCMB0(RWIX)     : ORIGIN = 0x41010000 , LENGTH = 0x00008000
    -    /* Refer the user guide for details on persistence of these sections */
    -    OCMC_RAM_BOARD_CFG (RWIX)   : origin=0x41C80000 length=0x2000
    -    OCMC_RAM_SCISERVER (RWIX)   : origin=0x41C82000 length=0x60000
    -    RESET_VECTORS (X)           : origin=0x41CE2000 length=0x100
    -    OCMC_RAM (RWIX)             : origin=0x41CE2100 length=0x1DA00
    -    OCMC_RAM_X509_HEADER (RWIX) : origin=0x41CFFB00 length=0x500
    -    /* Donot use MSMC. Used by MPU. */
    -    MSMC3(RWIX)         : ORIGIN = 0x70080000 , LENGTH = 0x770000
    -    DDR0(RWIX)          : ORIGIN = 0x88000000 , LENGTH = 0x8000000
    -SECTIONS
    -    .vecs       : {
    -        __VECS_ENTRY_POINT = .;
    -    } palign(8) > RESET_VECTORS
    -    .text_boot {
    -        *boot.aer5f*<*boot.o*>(.text)
    -     }  palign(8)   > R5F_TCMB0
    -    .text:xdc_runtime_Startup_reset__I     : {} palign(8) > R5F_TCMB0
    -    .text:ti_sysbios_family_arm_v7r_Cache* : {} palign(8) > R5F_TCMB0
    -    .text:ti_sysbios_family_arm_MPU*       : {} palign(8) > R5F_TCMB0
    -    .utilsCopyVecsToAtcm                   : {} palign(8) > R5F_TCMB0
    -    .text       : {} palign(8)   > DDR0
    -    .cinit      : {} palign(8)   > DDR0
    -    .bss        : {} align(8)    > DDR0
    -    .far        : {} align(8)    > DDR0
    -    .const      : {} palign(8)   > DDR0
    -    .data       : {} palign(128) > DDR0
    -    .sysmem     : {} align(8)    > DDR0
    -    .stack      : {} align(4)    > DDR0
    -    .data_buffer: {} palign(128) > DDR0
    -    .bss.devgroup*  : {} align(4) > DDR0
    -    .const.devgroup*: {} align(4) > DDR0
    -    .boardcfg_data  : {} align(4) > DDR0
    diff --git a/packages/ti/drv/spi/example/mcspi_slavemode/j721e/linker_r5f_mcu1_0_btcm_sysbios.lds b/packages/ti/drv/spi/example/mcspi_slavemode/j721e/linker_r5f_mcu1_0_btcm_sysbios.lds
    new file mode 100755
    index 0000000..f5ddf57
    --- /dev/null
    +++ b/packages/ti/drv/spi/example/mcspi_slavemode/j721e/linker_r5f_mcu1_0_btcm_sysbios.lds
    @@ -0,0 +1,149 @@
    +/* File: linker_r5f_mcu1_0_btcm_sysbios.lds                                        */
    +/* Description:			  					      */
    +/*    Link command file for J7ES MCU1_0 view				      */
    +/*	  TI ARM Compiler version 15.12.3 LTS or later			      */
    +/* (c) Texas Instruments 2018, All rights reserved.                           */
    +/*  History:								      */
    +/*    Aug 26th, 2016 Original version .......................... Loc Truong   */
    +/*    Aug 01th, 2017 new TCM mem map  .......................... Loc Truong   */
    +/*    Nov 07th, 2017 Changes for R5F Init Code.................. Vivek Dhande */
    +/*    Sep 17th, 2018 Added DDR sections for IPC................. J. Bergsagel */
    +/*    Sep 26th, 2018 Extra mem sections for IPC resource table.. J. Bergsagel */
    +/*    Nov 06th, 2018 Correction to TCM addresses for MCU1_0..... J. Bergsagel */
    +/*    Nov 07th, 2018 Split up OCMRAM_MCU for split-mode R5Fs.... J. Bergsagel */
    +/*    Feb 20th, 2019 Use R5F BTCM memory for boot vectors........J. Bergsagel */
    +/*    Apr 23th, 2019 Changes for R5F startup Code............... Vivek Dhande */
    +/* Linker Settings                                                            */
    +/* Standard linker options						      */
    +--retain="*(.bootCode)"
    +--retain="*(.startupCode)"
    +--retain="*(.startupData)"
    +--fill_value=0
    +--stack_size=0x2000
    +--heap_size=0x1000
    +-stack  0x2000                              /* SOFTWARE STACK SIZE           */
    +-heap   0x2000                              /* HEAP AREA SIZE                */
    +#define DDR0_ALLOCATED_START 0xA0000000
    +#define MCU1_0_EXT_DATA_BASE     (DDR0_ALLOCATED_START + 0x00100000)
    +#define MCU1_0_R5F_MEM_TEXT_BASE (DDR0_ALLOCATED_START + 0x00200000)
    +#define MCU1_0_R5F_MEM_DATA_BASE (DDR0_ALLOCATED_START + 0x00300000)
    +#define MCU1_0_DDR_SPACE_BASE    (DDR0_ALLOCATED_START + 0x00400000)
    +#define MCU1_1_ALLOCATED_START   DDR0_ALLOCATED_START + 0x01000000
    +#define MCU1_1_EXT_DATA_BASE     (MCU1_1_ALLOCATED_START + 0x00100000)
    +#define MCU1_1_R5F_MEM_TEXT_BASE (MCU1_1_ALLOCATED_START + 0x00200000)
    +#define MCU1_1_R5F_MEM_DATA_BASE (MCU1_1_ALLOCATED_START + 0x00300000)
    +#define MCU1_1_DDR_SPACE_BASE    (MCU1_1_ALLOCATED_START + 0x00400000)
    +#define MCU2_0_ALLOCATED_START   DDR0_ALLOCATED_START + 0x02000000
    +#define MCU2_0_EXT_DATA_BASE     (MCU2_0_ALLOCATED_START + 0x00100000)
    +#define MCU2_0_R5F_MEM_TEXT_BASE (MCU2_0_ALLOCATED_START + 0x00200000)
    +#define MCU2_0_R5F_MEM_DATA_BASE (MCU2_0_ALLOCATED_START + 0x00300000)
    +#define MCU2_0_DDR_SPACE_BASE    (MCU2_0_ALLOCATED_START + 0x00400000)
    +#define MCU2_1_ALLOCATED_START   DDR0_ALLOCATED_START + 0x03000000
    +#define MCU2_1_EXT_DATA_BASE     (MCU2_1_ALLOCATED_START + 0x00100000)
    +#define MCU2_1_R5F_MEM_TEXT_BASE (MCU2_1_ALLOCATED_START + 0x00200000)
    +#define MCU2_1_R5F_MEM_DATA_BASE (MCU2_1_ALLOCATED_START + 0x00300000)
    +#define MCU2_1_DDR_SPACE_BASE    (MCU2_1_ALLOCATED_START + 0x00400000)
    +#define ATCM_START 0x00000000
    +#define BTCM_START 0x41010000
    +-e __VECS_ENTRY_POINT
    +--retain="*(.ipcCopyVecsToExc)"
    +/* Memory Map        */
    +MEMORY
    +    /* MCU1_R5F_0 local view  */
    +    MCU_ATCM (RWX)		: origin=ATCM_START	length=0x8000
    +    /* MCU1_R5F0_TCMB0 (RWIX)	: origin=BTCM_START	length=0x8000 (documented only, to avoid conflict below) */
    +    /* MCU1_R5F_0 SoC view  */
    +    MCU1_R5F0_ATCM (RWIX)  	: origin=0x41000000 length=0x8000
    +    MCU1_R5F0_BTCM_VECS (RWIX)  : origin=0x41010000 length=0x0100
    +    MCU1_R5F0_BTCM (RWIX) 	: origin=0x41010100 length=0x7F00
    +    DDR0_RESERVED    (RWIX)  	: origin=0x80000000 length=0x20000000	  	/* 512MB */
    +    MCU1_0_IPC_DATA (RWIX)	: origin=DDR0_ALLOCATED_START     length=0x00100000	/*   1MB */
    +    MCU1_0_EXT_DATA  (RWIX)	: origin=MCU1_0_EXT_DATA_BASE     length=0x00100000	/*   1MB */
    +    MCU1_0_R5F_MEM_TEXT (RWIX)	: origin=MCU1_0_R5F_MEM_TEXT_BASE length=0x00100000	/*   1MB */
    +    MCU1_0_R5F_MEM_DATA (RWIX)	: origin=MCU1_0_R5F_MEM_DATA_BASE length=0x00100000	/*   1MB */
    +    MCU1_0_DDR_SPACE (RWIX)	: origin=MCU1_0_DDR_SPACE_BASE    length=0x00C00000	/*  12MB */
    +    MCU1_1_IPC_DATA (RWIX)	: origin=MCU1_1_ALLOCATED_START   length=0x00100000	/*   1MB */
    +    MCU1_1_EXT_DATA  (RWIX)	: origin=MCU1_1_EXT_DATA_BASE     length=0x00100000	/*   1MB */
    +    MCU1_1_R5F_MEM_TEXT (RWIX)	: origin=MCU1_1_R5F_MEM_TEXT_BASE length=0x00100000	/*   1MB */
    +    MCU1_1_R5F_MEM_DATA (RWIX)	: origin=MCU1_1_R5F_MEM_DATA_BASE length=0x00100000	/*   1MB */
    +    MCU1_1_DDR_SPACE (RWIX)	: origin=MCU1_1_DDR_SPACE_BASE    length=0x00C00000	/*  12MB */
    +    MCU2_0_IPC_DATA (RWIX)	: origin=MCU2_0_ALLOCATED_START   length=0x00100000	/*   1MB */
    +    MCU2_0_EXT_DATA  (RWIX)	: origin=MCU2_0_EXT_DATA_BASE     length=0x00100000	/*   1MB */
    +    MCU2_0_R5F_MEM_TEXT (RWIX)	: origin=MCU2_0_R5F_MEM_TEXT_BASE length=0x00100000	/*   1MB */
    +    MCU2_0_R5F_MEM_DATA (RWIX)	: origin=MCU2_0_R5F_MEM_DATA_BASE length=0x00100000	/*   1MB */
    +    MCU2_0_DDR_SPACE (RWIX)	: origin=MCU2_0_DDR_SPACE_BASE    length=0x00C00000	/*  12MB */
    +    MCU2_1_IPC_DATA (RWIX)	: origin=MCU2_1_ALLOCATED_START   length=0x00100000	/*   1MB */
    +    MCU2_1_EXT_DATA  (RWIX)	: origin=MCU2_1_EXT_DATA_BASE     length=0x00100000	/*   1MB */
    +    MCU2_1_R5F_MEM_TEXT (RWIX)	: origin=MCU2_1_R5F_MEM_TEXT_BASE length=0x00100000	/*   1MB */
    +    MCU2_1_R5F_MEM_DATA (RWIX)	: origin=MCU2_1_R5F_MEM_DATA_BASE length=0x00100000	/*   1MB */
    +    MCU2_1_DDR_SPACE (RWIX)	: origin=MCU2_1_DDR_SPACE_BASE    length=0x00C00000	/*  12MB */
    +    SHARED_DDR_SPACE (RWIX)	: origin=0xAA000000 length=0x01C00000           /*  28MB */
    +}  /* end of MEMORY */
    +/* Section Configuration                                                      */
    +SECTIONS
    +    .vecs : {
    +         *(.vecs)
    +    } palign(8) > BTCM_START
    +    .vecs       : {
    +        __VECS_ENTRY_POINT = .;
    +    } > MCU1_R5F0_BTCM_VECS
    +    xdc.meta (COPY): { *(xdc.meta) } > MCU1_R5F0_BTCM
    +    .init_text  : {
    +                     boot.*(.text)
    +                     *(.text:ti_sysbios_family_arm_MPU_*)
    +                     *(.text:ti_sysbios_family_arm_v7r_Cache_*)
    +                  }  palign(8) > MCU1_R5F0_BTCM
    +    .text:xdc_runtime_Startup_reset__I     : {} palign(8) > MCU1_R5F0_BTCM
    +    .bootCode    	: {} palign(8) 		> MCU1_R5F0_BTCM
    +    .startupCode 	: {} palign(8) 		> MCU1_R5F0_BTCM
    +    .startupData 	: {} palign(8) 		> MCU1_R5F0_BTCM, type = NOINIT
    +    .ipcCopyVecsToExc                   : {} palign(8) > MCU1_R5F0_BTCM
    +    .text	: {} palign(8)		> MCU1_0_DDR_SPACE
    +    .const   	: {} palign(8) 		> MCU1_0_DDR_SPACE
    +    .cinit   	: {} palign(8) 		> MCU1_0_DDR_SPACE
    +    .pinit   	: {} palign(8) 		> MCU1_0_DDR_SPACE
    +    .bss     	: {} align(4)  		> MCU1_0_DDR_SPACE
    +    .data    	: {} palign(128) 	> MCU1_0_DDR_SPACE
    +    .data_buffer: {} palign(128) 	> MCU1_0_DDR_SPACE
    +    .sysmem  	: {} 			> MCU1_0_DDR_SPACE
    +    .stack	: {} align(4)		> MCU1_0_DDR_SPACE
    +    .const.devgroup.MCU_WAKEUP    : {} align(4)      > MCU1_0_DDR_SPACE
    +    .const.devgroup.MAIN          : {} align(4)      > MCU1_0_DDR_SPACE
    +    .const.devgroup.DMSC_INTERNAL : {} align(4)      > MCU1_0_DDR_SPACE
    +    .bss.devgroup.MAIN            : {} align(4)      > MCU1_0_DDR_SPACE
    +    .bss.devgroup.MCU_WAKEUP      : {} align(4)      > MCU1_0_DDR_SPACE
    +    .bss.devgroup.DMSC_INTERNAL   : {} align(4)      > MCU1_0_DDR_SPACE
    +    .boardcfg_data                : {} align(4)      > MCU1_0_DDR_SPACE
    +    .bss.devgroup*                : {} align(4)      > MCU1_0_DDR_SPACE
    +    .const.devgroup*              : {} align(4)      > MCU1_0_DDR_SPACE
    +}  /* end of SECTIONS */
    +/* Misc linker settings                                                       */
    +/*-------------------------------- END ---------------------------------------*/
    diff --git a/packages/ti/drv/spi/example/mcspi_slavemode/j721e/r5_mpu_ipc.xs b/packages/ti/drv/spi/example/mcspi_slavemode/j721e/r5_mpu_ipc.xs
    new file mode 100644
    index 0000000..44f66e4
    --- /dev/null
    +++ b/packages/ti/drv/spi/example/mcspi_slavemode/j721e/r5_mpu_ipc.xs
    @@ -0,0 +1,159 @@
    + * Copyright (c) 2019, Texas Instruments Incorporated
    + * All rights reserved.
    + * Redistribution and use in source and binary forms, with or without
    + * modification, are permitted provided that the following conditions
    + * are met:
    + * *  Redistributions of source code must retain the above copyright
    + *    notice, this list of conditions and the following disclaimer.
    + * *  Redistributions in binary form must reproduce the above copyright
    + *    notice, this list of conditions and the following disclaimer in the
    + *    documentation and/or other materials provided with the distribution.
    + * *  Neither the name of Texas Instruments Incorporated nor the names of
    + *    its contributors may be used to endorse or promote products derived
    + *    from this software without specific prior written permission.
    + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
    + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
    + * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
    + * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
    + * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
    + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
    + * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
    + * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
    + * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
    + * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
    + * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    + *  ======== event_MPU.xs ========
    + *  MPU Settings for J721E device's Cortex-R5F
    + * | Id | Base Address | Size | En | Cacheable                                 | XN | AccPerm             | Mask |
    + * | 0  | 0x00000000   | 4GB  | T  | uncacheable, Shareable                    | F  | RW at PL 1 & PL 2   | 0x0  |
    + * | 1  | 0 (local TCM)| 32K  | T  | Write-through, Shareable                  | F  | RW at PL 1          | 0x0  |
    + * | 2  | 0x41000000   | 32K  | T  | Write-through, Shareable                  | F  | RW at PL 1          | 0x0  |
    + * | 3  | 0x41010000   | 32K  | T  | Write-through, Shareable                  | F  | RW at PL 1          | 0x0  |
    + * | 4  | 0x41C00000   | 1MB  | T  | Write-through, Shareable                  | F  | RW at PL 1          | 0x0  |
    + * | 5  | 0x70000000   | 8MB  | T  | MSMC Ram - Cachable                       | F  | RW at PL 1          | 0x0  |
    + * | 6  | 0x80000000   | 2GB  | T  | DDR - Strongly Ordered, Shareable         | F  | RW at PL 1 & PL 3   | 0x0  |
    + * | 7  | 0xAA000000   | 32MB | T  | DDR (VRing Buffer) - Uncacheble           | F  | RW at PL 1 & PL 3   | 0x0  |
    + * Note: Marking a region as shareable will cause the region to behave as outer shareable with write through
    + *       no write-allocate caching policy irrespective of the actual cache policy set. Therefore, only select
    + *       regions that are actually shared outside the R5 CPUSS must be marked as shared.
    +var MPU = xdc.useModule('ti.sysbios.family.arm.MPU');
    +MPU.enableMPU = true;
    +MPU.enableBackgroundRegion = true;
    +var attrs = new MPU.RegionAttrs();
    +MPU.initRegionAttrsMeta(attrs);
    +/* This entry covers the whole 32 bit memory range
    +   Address: 0x00000000-0xffffffff */
    +attrs.enable = true;
    +attrs.bufferable = false;
    +attrs.cacheable = false;
    +attrs.shareable = true;
    +attrs.noExecute = true;
    +attrs.accPerm = 1;          /* RW at PL1 */
    +attrs.tex = 0;
    +attrs.subregionDisableMask = 0;
    +MPU.setRegionMeta(0, 0x00000000, MPU.RegionSize_4G, attrs);
    +/* This entry covers the ATCM mapped to 0 */
    +attrs.cacheable = true;
    +attrs.noExecute = false;
    +attrs.tex = 0;
    +MPU.setRegionMeta(1, 0x00000000, MPU.RegionSize_32K, attrs);
    +/* This entry covers ATCM if mapped to 0x41000000 */
    +attrs.tex = 0;
    +MPU.setRegionMeta(2, 0x41000000, MPU.RegionSize_32K, attrs);
    +/* This entry covers BTCM if mapped to 0x41010000 */
    +attrs.tex = 0;
    +attrs.subregionDisableMask = 0x0;
    +MPU.setRegionMeta(3, 0x41010000, MPU.RegionSize_32K, attrs);
    +/* This entry covers RAM0 */
    +attrs.tex = 0;
    +MPU.setRegionMeta(4, 0x41C00000, MPU.RegionSize_1M, attrs);
    +/* This entry covers MSMC SRAM */
    +attrs.bufferable = true;
    +attrs.shareable = false;
    +attrs.tex = 1;
    +MPU.setRegionMeta(5, 0x70000000, MPU.RegionSize_8M, attrs);
    +/* This entry covers DDR memory */
    +attrs.accPerm = 0x3;          /* RW at PL1 & PL2 */
    +attrs.tex = 1;
    +MPU.setRegionMeta(6, 0x80000000, MPU.RegionSize_2G, attrs);
    +/* Ring Buffer uncached.... */
    +attrs.accPerm = 3;          /* RW at PL1 */
    +attrs.tex = 0;
    +MPU.setRegionMeta(7, 0xAA000000, MPU.RegionSize_32M, attrs);
    diff --git a/packages/ti/drv/spi/example/mcspi_slavemode/j721e/sysbios_r5f_btcm.cfg b/packages/ti/drv/spi/example/mcspi_slavemode/j721e/sysbios_r5f_btcm.cfg
    index 0000000..f3c6801
    --- /dev/null
    +++ b/packages/ti/drv/spi/example/mcspi_slavemode/j721e/sysbios_r5f_btcm.cfg
    @@ -0,0 +1,239 @@
    + *   Copyright (c) Texas Instruments Incorporated 2020
    + *  are met:
    + *    Redistributions of source code must retain the above copyright
    + *    Redistributions in binary form must reproduce the above copyright
    + *    distribution.
    + *    Neither the name of Texas Instruments Incorporated nor the names of
    + *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    + *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    + *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    + *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    + *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    + *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    + *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    + *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    + *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    + *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    +var Defaults = xdc.useModule('xdc.runtime.Defaults');
    +var Diags = xdc.useModule('xdc.runtime.Diags');
    +var Error = xdc.useModule('xdc.runtime.Error');
    +var Log = xdc.useModule('xdc.runtime.Log');
    +var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
    +var Main = xdc.useModule('xdc.runtime.Main');
    +var Memory = xdc.useModule('xdc.runtime.Memory')
    +var System = xdc.useModule('xdc.runtime.System');
    +var Text = xdc.useModule('xdc.runtime.Text');
    +var Clock = xdc.useModule('ti.sysbios.knl.Clock');
    +var Task = xdc.useModule('ti.sysbios.knl.Task');
    +var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
    +var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
    +var GateSwi = xdc.useModule('ti.sysbios.gates.GateSwi');
    +var BIOS = xdc.useModule('ti.sysbios.BIOS');
    +var Hwi = xdc.useModule('ti.sysbios.family.arm.v7r.keystone3.Hwi');
    +var Core = xdc.useModule('ti.sysbios.family.arm.v7r.keystone3.Core');
    +var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
    +var SysMin = xdc.useModule('xdc.runtime.SysMin');
    +/* System stack size (used by ISRs and Swis) */
    +Program.stack = 0x2000;
    +Task.defaultStackSize = 0x4000;
    +Task.common$.namedInstance = true;
    +Task.common$.namedModule = true;
    +/* Enable cache */
    +var Cache = xdc.useModule('ti.sysbios.family.arm.v7r.Cache');
    +Cache.enableCache = true;
    + * Direct CIO to UART
    +/* System.SupportProxy = SysUart; */
    +System.SupportProxy = SysMin;
    +System.extendedFormats += "%f";
    + * Program.argSize sets the size of the .args section.
    + * The examples don't use command line args so argSize is set to 0.
    +Program.argSize = 0x0;
    + * Uncomment this line to globally disable Asserts.
    + * All modules inherit the default from the 'Defaults' module.  You
    + * can override these defaults on a per-module basis using Module.common$.
    + * Disabling Asserts will save code space and improve runtime performance.
    +Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF;
    + * Uncomment this line to keep module names from being loaded on the target.
    + * The module name strings are placed in the .const section. Setting this
    + * parameter to false will save space in the .const section.  Error and
    + * Assert messages will contain an "unknown module" prefix instead
    + * of the actual module name.
    +Defaults.common$.namedModule = false;
    +/* Create default heap and hook it into Memory */
    +var heapMemParams = new HeapMem.Params;
    +heapMemParams.size = 16384*4;
    +var heap0 = HeapMem.create(heapMemParams);
    +Memory.defaultHeapInstance = heap0;
    + * Minimize exit handler array in System.  The System module includes
    + * an array of functions that are registered with System_atexit() to be
    + * called by System_exit().
    +System.maxAtexitHandlers = 4;
    + * Uncomment this line to disable the Error print function.
    + * We lose error information when this is disabled since the errors are
    + * not printed.  Disabling the raiseHook will save some code space if
    + * your app is not using System_printf() since the Error_print() function
    + * calls System_printf().
    +Error.raiseHook = null;
    + * Uncomment this line to keep Error, Assert, and Log strings from being
    + * loaded on the target.  These strings are placed in the .const section.
    + * Setting this parameter to false will save space in the .const section.
    + * Error, Assert and Log message will print raw ids and args instead of
    + * a formatted message.
    +Text.isLoaded = false;
    + * Uncomment this line to disable the output of characters by SysMin
    + * when the program exits.  SysMin writes characters to a circular buffer.
    + * This buffer can be viewed using the SysMin Output view in ROV.
    +SysMin.flushAtExit = false;
    + * Create and install logger for the whole system
    +var loggerBufParams = new LoggerBuf.Params();
    +loggerBufParams.numEntries = 32;
    +var logger0 = LoggerBuf.create(loggerBufParams);
    +Defaults.common$.logger = logger0;
    +Main.common$.diags_INFO = Diags.ALWAYS_ON;
    +BIOS.libType = BIOS.LibType_Custom;
    +BIOS.cpuFreq.lo = 1000000000;
    +BIOS.cpuFreq.hi = 0;
    +var coreId = java.lang.System.getenv("CORE");
    +var DMTimer = xdc.useModule('ti.sysbios.timers.dmtimer.Timer');
    +DMTimer.checkFrequency = false;
    +for (var i=0; i < DMTimer.numTimerDevices; i++) {
    +    DMTimer.intFreqs[i].lo = 19200000;
    +    DMTimer.intFreqs[i].hi = 0;
    +if(coreId=="mcu1_0")
    +    Core.id = 0;
    +    /* DM timer cfg */
    +    Clock.timerId = 1;
    +if(coreId=="mcu1_1")
    +    Core.id = 1;
    +    Clock.timerId = 2;
    +if(coreId=="mcu2_0")
    +    Core.id = 0;
    +    Clock.timerId = 0;
    +    /* DMTimer #12 - in general, address is 0x024x0000 where x is timer # */
    +    DMTimer.timerSettings[0].baseAddr = 0x024c0000;
    +    DMTimer.timerSettings[0].intNum = 168;
    +if(coreId=="mcu2_1")
    +    Core.id = 1;
    +    /* DMTimer #13 - in general, address is 0x024x0000 where x is timer # */
    +    DMTimer.timerSettings[1].baseAddr = 0x024d0000;
    +    DMTimer.timerSettings[1].intNum = 169;
    +if(coreId=="mcu3_0")
    +    Core.id = 0;
    +    /* DMTimer #14 - in general, address is 0x024x0000 where x is timer # */
    +    DMTimer.timerSettings[2].baseAddr = 0x024e0000;
    +    DMTimer.timerSettings[2].intNum = 170;
    +if(coreId=="mcu3_1")
    +    Core.id = 1;
    +    Clock.timerId = 3;
    +    /* DMTimer #15 - in general, address is 0x024x0000 where x is timer # */
    +    DMTimer.timerSettings[3].baseAddr = 0x024f0000;
    +    DMTimer.timerSettings[3].intNum = 171;
    +/* Set base address of Vector Interrupt Manager */
    +if((coreId=="mcu2_0") || (coreId=="mcu2_1") || (coreId=="mcu3_0") || (coreId=="mcu3_1"))
    +    var Hwi = xdc.useModule('ti.sysbios.family.arm.v7r.keystone3.Hwi');
    +    Hwi.vimBaseAddress = 0x0ff80000;
    +/* Sysbios supports workaround for Silicon issue https://jira.itg.ti.com/browse/K3_OPEN_SI-148
    + * Details of silicon issue : https://confluence.itg.ti.com/display/PROCIPDEV/%2310+The+same+interrupt+cannot+be+nested+back-2-back+within+another+interrupt
    + * Sysbios Requirement Details: https://jira.itg.ti.com/browse/SYSBIOS-1419
    + * Workaround requires use of a resevred dummyIRQ.
    + * Using DummyIRQ#383 as per cslr_intr_mss.h it is a reserved interrupt not connected to any
    + * peripheral interrupt sources
    +if((coreId=="mcu1_0") || (coreId=="mcu1_1"))
    +    Hwi.dummyIRQ                   = 383;
    +    Hwi.dummyIRQ                   = 511;
    +var Reset = xdc.useModule("xdc.runtime.Reset");
    +Reset.fxns[Reset.fxns.length++] = "&ipcCopyVecs2Exc";
    + * Initialize MPU and enable it
    + * Note: MPU must be enabled and properly configured for caching to work.
    +xdc.loadCapsule("r5_mpu_ipc.xs");
    +/* Check if application needs to update with custom configuration options */
    +/* Caution: This should be at the end of this file after all other common cfg */
    +var cfgUpdate = java.lang.System.getenv("XDC_CFG_UPDATE")
    +if ((cfgUpdate != '')&&(cfgUpdate != null))
    +    xdc.print("Loading configuration update " + cfgUpdate);
    +    xdc.loadCapsule(cfgUpdate);
    diff --git a/packages/ti/drv/spi/example/mcspi_slavemode/makefile b/packages/ti/drv/spi/example/mcspi_slavemode/makefile
    index 7ec572c..2c325ba 100644
    --- a/packages/ti/drv/spi/example/mcspi_slavemode/makefile
    +++ b/packages/ti/drv/spi/example/mcspi_slavemode/makefile
    @@ -20,7 +20,7 @@ XDC_CFG_FILE_mpu1_0 = ./am65xx/mcspiMasterSlaveTest_a53.cfg
     XDC_CFG_FILE_mcu1_0 = ./am65xx/mcspiMasterSlaveTest_r5.cfg
     else
     ifeq ($(SOC),$(filter $(SOC), j721e j7200 am64x))
    -XDC_CFG_FILE_$(CORE) = $(PDK_INSTALL_PATH)/ti/build/$(SOC)/sysbios_$(ISA).cfg
    +XDC_CFG_FILE_$(CORE) = $(PDK_INSTALL_PATH)/ti/drv/spi/example/mcspi_slavemode/$(SOC)/sysbios_$(ISA)_btcm.cfg
     endif
     endif
    @@ -57,11 +57,12 @@ else
     CFLAGS_SPI_MS     = -DMCSPI_MASTER_TASK
     APP_MASTER_SLAVE  = Master
     ifeq ($(SOC),$(filter $(SOC), j721e j7200))
    +SRCS_ASM_COMMON += ipcCopyVecs2Exc.asm
     # Slave uses local linker command file to avoid code/data memory conflict with master application
     ifeq ($(IS_BAREMETAL),yes)
     EXTERNAL_LNKCMD_FILE_LOCAL =  $(PDK_INSTALL_PATH)/ti/drv/spi/example/mcspi_slavemode/$(SOC)/linker_mcu.lds
     else
    -EXTERNAL_LNKCMD_FILE_LOCAL =  $(PDK_INSTALL_PATH)/ti/drv/spi/example/mcspi_slavemode/$(SOC)/linker_mcu_sysbios.lds
    +EXTERNAL_LNKCMD_FILE_LOCAL =  $(PDK_INSTALL_PATH)/ti/drv/spi/example/mcspi_slavemode/$(SOC)/linker_r5f_mcu1_0_btcm_sysbios.lds
     endif
     endif
    diff --git a/packages/ti/drv/spi/example/mcspi_slavemode/src/ipcCopyVecs2Exc.asm b/packages/ti/drv/spi/example/mcspi_slavemode/src/ipcCopyVecs2Exc.asm
    index 0000000..d740900
    --- /dev/null
    +++ b/packages/ti/drv/spi/example/mcspi_slavemode/src/ipcCopyVecs2Exc.asm
    @@ -0,0 +1,59 @@
    +;  Copyright (c) 2020, Texas Instruments Incorporated
    +;  All rights reserved.
    +;  Redistribution and use in source and binary forms, with or without
    +;  modification, are permitted provided that the following conditions
    +;  are met:
    +;  *  Redistributions of source code must retain the above copyright
    +;     notice, this list of conditions and the following disclaimer.
    +;  *  Redistributions in binary form must reproduce the above copyright
    +;     notice, this list of conditions and the following disclaimer in the
    +;     documentation and/or other materials provided with the distribution.
    +;  *  Neither the name of Texas Instruments Incorporated nor the names of
    +;     its contributors may be used to endorse or promote products derived
    +;     from this software without specific prior written permission.
    +;  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
    +;  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
    +;  THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
    +;  PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
    +;  CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
    +;  EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
    +;  PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
    +;  OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
    +;  WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
    +;  OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
    +;  EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    +; ======== ipcCopyVecs2Exc.asm ========
    +; Copies sysbios defined vector to Exception Handler area
    +    .text
    +    .sect   ".ipcCopyVecsToExc"
    +;   void ipcCopyVecs2Exc( void )
    +    .global ti_sysbios_family_arm_v7r_keystone3_Hwi_vectors
    +    .global ipcCopyVecs2Exc
    +ipcCopyVecs2Exc:
    +        .asmfunc
    +        movw    r0, ti_sysbios_family_arm_v7r_keystone3_Hwi_vectors
    +        movt    r0, ti_sysbios_family_arm_v7r_keystone3_Hwi_vectors
    +        mov     r1, #0                  ; Exeception Handler address
    +        mov	r2, #64			; 64 bytes
    +loop:
    +        ldr	r3, [r0], #4
    +        str     r3, [r1], #4
    +        subs    r2, r2, #4
    +        bgt     loop
    +exit:
    +        bx      lr
    +        .endasmfunc
    +        .end
    diff --git a/packages/ti/drv/spi/example/mcspi_slavemode/src/main_mcspi_slave_mode.c b/packages/ti/drv/spi/example/mcspi_slavemode/src/main_mcspi_slave_mode.c
    index 04d7493..cb8c0cd 100755
    --- a/packages/ti/drv/spi/example/mcspi_slavemode/src/main_mcspi_slave_mode.c
    +++ b/packages/ti/drv/spi/example/mcspi_slavemode/src/main_mcspi_slave_mode.c
    @@ -1588,6 +1588,8 @@ void slaveTaskFxn()
    +/* Make this variable non zero to debug using CCS */
    +volatile uint32_t ccs_debug_loop = 0x0;
      *  ======== masterTaskFxn ========
      *  This task is part of master example project.
    @@ -1601,6 +1603,8 @@ Void masterTaskFxn (UArg arg0, UArg arg1)
     void masterTaskFxn()
     #endif
    +    while(ccs_debug_loop);
         uint32_t  i;
         bool      testFail = false;
         SPI_Tests *test;
    2.17.1
    1] .../j721e/linker_mcu_sysbios.lds              |  51 ----
    Refereing to this as we need to delete the suggested lines from this linker file.
    But for UART I couldnt find exact which  file is used .Also getting error while linking as:
    linking_error_log.txt
    error: creating output section ".utilsCopyVecsToAtcm" without a SECTIONS
       specification
    error: errors encountered during linking;
       "/home/ketaki/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_
       00_29/packages/ti/binary/UART_TestApp/bin/j721e_evm/UART_j721e_evm_mcu1_0Tes
       tApp_release.xer5f" not built
    >> Compilation failure
    /home/ketaki/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/build/makerules/rules_ti_cgt_arm.mk:312: recipe for target '/home/ketaki/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/binary/UART_TestApp/bin/j721e_evm/UART_j721e_evm_mcu1_0TestApp_release.xer5f' failed
    make[2]: *** [/home/ketaki/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/binary/UART_TestApp/bin/j721e_evm/UART_j721e_evm_mcu1_0TestApp_release.xer5f] Error 1
    /home/ketaki/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/build/makerules/common.mk:405: recipe for target 'mcu1_0' failed
    make[1]: *** [mcu1_0] Error 2
    makefile:361: recipe for target 'UART_TestApp' failed
    make: *** [UART_TestApp] Error 2
    2] .../j721e/linker_r5f_mcu1_0_btcm_sysbios.lds
    (Added changes as suggested)
    2630.linker_r5f_mcu1_0_btcm_sysbios.txt
    /* Description:			  					      */
    /*  History:								      */
    --fill_value=0
    --stack_size=0x2000
    --heap_size=0x1000
    -stack  0x20000 //org 0x2000                              /* SOFTWARE STACK SIZE           */
    /* Memory Map        */
    MEMORY
    SECTIONS
        .vecs : {
             *(.vecs)
        .vecs       : {
        .init_text  : {
                         boot.*(.text)
        .resource_table : {
        } > MCU1_0_EXT_DATA
    #if 0
            .=align(4);
            . += FILL_LENGTH;
            *(CAN_TEXT_SECTION)
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            *(DIO_TEXT_SECTION)
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
            .=align(4);
            . += FILL_LENGTH;
    #endif
    Its path added in env.mk as
    2251.env.txt
    # Copyright (c) 2013-2019, Texas Instruments Incorporated
    # All rights reserved.
    # Redistribution and use in source and binary forms, with or without
    # modification, are permitted provided that the following conditions
    # are met:
    # *  Redistributions of source code must retain the above copyright
    #    notice, this list of conditions and the following disclaimer.
    # *  Redistributions in binary form must reproduce the above copyright
    #    notice, this list of conditions and the following disclaimer in the
    #    documentation and/or other materials provided with the distribution.
    # *  Neither the name of Texas Instruments Incorporated nor the names of
    #    its contributors may be used to endorse or promote products derived
    #    from this software without specific prior written permission.
    # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
    # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
    # THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
    # PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
    # CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
    # EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
    # PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
    # OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
    # WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
    # OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
    # EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    # File: env.mk. This file contains all the paths and other ENV variables
    # Module paths
    # Destination root directory.
    #   - specify the directory where you want to place the object, archive/library,
    #     binary and other generated files in a different location than source tree
    #   - or leave it blank to place then in the same tree as the source
    DEST_ROOT ?= $(pdk_PATH)/ti/binary
    # Utilities directory. This is required only if the build machine is Windows.
    #   - specify the installation directory of utility which supports POSIX commands
    #     (eg: Cygwin installation or MSYS installation).
    UTILS_INSTALL_DIR ?= $(utils_PATH)
    # Set path separator, etc based on the OS
    ifeq ($(OS),Windows_NT)
      PATH_SEPARATOR = ;
      UTILSPATH = $(UTILS_INSTALL_DIR)/
      export SHELL := $(UTILSPATH)sh.exe
    else
      # else, assume it is linux
      PATH_SEPARATOR = :
      UTILSPATH = /bin/
    endif
    ifeq ($(BUILD_OS_TYPE),tirtos)
      # BIOS
      bios_INCLUDE = $(bios_PATH)/packages
      export bios_INCLUDE
      # XDC
      xdc_INCLUDE = $(xdc_PATH)/packages
      export xdc_INCLUDE
      # EDMA
      edma_INCLUDE = $(edma3_lld_PATH)/packages
      export edma_INCLUDE
      # - used to ignore include if component not present
      -include $(edma3_lld_PATH)/packages/component.mk
      # NDK
      ndk_INCLUDE = $(ndk_PATH)/packages
      export ndk_INCLUDE
      # NS
      ns_INCLUDE = $(ns_PATH)/source/
      export ns_INCLUDE
    endif
    #Below applicable only for TDA devices
    # Radar mmwavelink
    radarLink_INCLUDE = $(radarLink_PATH) \
                        $(radarLink_PATH)/ti/control/mmwavelink/include \
                        $(radarLink_PATH)/ti/control/mmwavelink/src     \
    radarFirmware_INCLUDE = $(radarMssFirmware_PATH) $(radarBssFirmware_PATH)   \
                            $(radarLink_PATH)/firmware
    export radarLink_INCLUDE
    export radarFirmware_INCLUDE
    # PDK
    pdk_INCLUDE = $(pdk_PATH)
    # Add additional pdk include paths if sub-components are in different directories
    ifneq ($(PDK_CSL_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_CSL_ROOT_PATH)
    endif
    ifneq ($(PDK_CSL2_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_CSL2_ROOT_PATH)
      pdk_INCLUDE += $(PDK_CSL2_ROOT_PATH)/ti/csl/arch/r5
    endif
    ifneq ($(PDK_SA_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_SA_ROOT_PATH)
    endif
    ifneq ($(PDK_PM_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_PM_ROOT_PATH)
    endif
    ifneq ($(PDK_PMIC_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_PMIC_ROOT_PATH)
    endif
    ifneq ($(PDK_OSAL_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_OSAL_ROOT_PATH)
    endif
    ifneq ($(PDK_I2C_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_I2C_ROOT_PATH)
    endif
    ifneq ($(PDK_VPS_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_VPS_ROOT_PATH)
    endif
    ifneq ($(PDK_GPIO_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_GPIO_ROOT_PATH)
    endif
    ifneq ($(PDK_FATFS_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_FATFS_ROOT_PATH)
    endif
    ifneq ($(PDK_MMCSD_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_MMCSD_ROOT_PATH)
    endif
    ifneq ($(PDK_PCIE_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_PCIE_ROOT_PATH)
    endif
    ifneq ($(PDK_USB_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_USB_ROOT_PATH)
    endif
    ifneq ($(PDK_MCASP_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_MCASP_ROOT_PATH)
    endif
    ifneq ($(PDK_TIMESYNC_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_TIMESYNC_ROOT_PATH)
    endif
    ifneq ($(PDK_MCBSP_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_MCBSP_ROOT_PATH)
    endif
    ifneq ($(PDK_PROFILING_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_PROFILING_ROOT_PATH)
    endif
    ifneq ($(PDK_TRACE_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_TRACE_ROOT_PATH)
    endif
    ifneq ($(PDK_PRUSS_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_PRUSS_ROOT_PATH)
    endif
    ifneq ($(PDK_NIMU_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_NIMU_ROOT_PATH)
    endif
    ifneq ($(PDK_NIMU_ICSS_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_NIMU_ICSS_ROOT_PATH)
    endif
    ifneq ($(PDK_ICSS_EMAC_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_ICSS_EMAC_ROOT_PATH)
    endif
    ifneq ($(PDK_EMAC_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_EMAC_ROOT_PATH)
    endif
    ifneq ($(PDK_UART_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_UART_ROOT_PATH)
    endif
    ifneq ($(PDK_SPI_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_SPI_ROOT_PATH)
    endif
    ifneq ($(PDK_BOARD_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_BOARD_ROOT_PATH)
    endif
    ifneq ($(PDK_GPMC_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_GPMC_ROOT_PATH)
    endif
    ifneq ($(PDK_IOLINK_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_IOLINK_ROOT_PATH)
    endif
    ifneq ($(PDK_BOARD_DIAG_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_BOARD_DIAG_ROOT_PATH)
    endif
    ifneq ($(PDK_BOARD_UTILS_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_BOARD_UTILS_ROOT_PATH)
    endif
    #Below applicable only for K3 devices
    ifneq ($(PDK_UDMA_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_UDMA_ROOT_PATH)
    endif
    ifneq ($(PDK_ENET_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_ENET_ROOT_PATH)
    endif
    ifneq ($(PDK_CSIRX_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_CSIRX_ROOT_PATH)
    endif
    ifneq ($(PDK_CSITX_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_CSITX_ROOT_PATH)
    endif
    ifneq ($(PDK_DSS_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_DSS_ROOT_PATH)
    endif
    ifneq ($(PDK_SCICLIENT_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_SCICLIENT_ROOT_PATH)
    endif
    ifneq ($(PDK_IPC_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_IPC_ROOT_PATH)
    endif
    ifneq ($(PDK_FVID2_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_FVID2_ROOT_PATH)
    endif
    ifneq ($(PDK_CAL_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_CAL_ROOT_PATH)
    endif
    #Below are used for TDA/DRA SBL
    ifneq ($(PDK_STW_LLD_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_STW_LLD_ROOT_PATH)
    endif
    ifneq ($(PDK_SBL_AUTO_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_SBL_AUTO_ROOT_PATH)
    endif
    ifneq ($(PDK_NORFLASH_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_NORFLASH_ROOT_PATH)
    endif
    ifneq ($(PDK_QSPIFLASH_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_QSPIFLASH_ROOT_PATH)
    endif
    #Below applicable only for TPR12 devices
    ifneq ($(PDK_CRC_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_CRC_ROOT_PATH)
    endif
    ifneq ($(PDK_EDMA_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_EDMA_ROOT_PATH)
    endif
    ifneq ($(PDK_MAILBOX_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_MAILBOX_ROOT_PATH)
    endif
    ifneq ($(PDK_ESM_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_ESM_ROOT_PATH)
    endif
    ifneq ($(PDK_CAN_ROOT_PATH), $(pdk_PATH))
      pdk_INCLUDE += $(PDK_CAN_ROOT_PATH)
    endif
    export pdk_INCLUDE
    include $(pdk_PATH)/ti/build/makerules/component.mk
    # Package Relative path and destination directory
    PACKAGE_RELPATH = pdk_/packages
    PACKAGE_ROOT = $(DEST_ROOT)/package/$(PACKAGE_SELECT)/$(PACKAGE_RELPATH)
    export PACKAGE_RELPATH
    export PACKAGE_ROOT
    # Tools paths
    # Cortex-A8
    CODEGEN_PATH_A8 =
    # DSP
    CODEGEN_PATH_C674 = $(C6X_GEN_INSTALL_PATH)
    # Commands commonly used within the make files
    RM = $(UTILSPATH)rm -f
    MV = $(UTILSPATH)mv
    RMDIR = $(UTILSPATH)rm -rf
    MKDIR = $(UTILSPATH)mkdir
    ECHO = @$(UTILSPATH)echo
    CAT	= $(UTILSPATH)cat
    #emake provides detailed info for build analysis.
    EMAKE = emake --emake-emulation=gmake --emake-gen-subbuild-db=1 --emake-annodetail=waiting
    #if XDCTOOLS present use xdctools' gmake, else use the one available in the system
      ifneq ($(xdc_PATH),)
        MAKE = $(xdc_PATH)/gmake
      else
        MAKE = gmake
      endif
    else
      MAKE = make
    endif
    EGREP = $(UTILSPATH)egrep
    CP = $(UTILSPATH)cp
      CHMOD = $(UTILSPATH)echo
    else
      CHMOD = $(UTILSPATH)chmod
    endif
    ifeq ($(BUILD_OS_TYPE),freertos)
      ifeq ($(SOC),$(filter $(SOC), am65xx j721e j7200 tpr12 awr294x))
        ifeq ($(CONFIG_BLD_XDC_r5f),)
           CONFIG_BLD_LNK_r5f   = $(pdk_PATH)/ti/build/$(SOC)/linker_r5_freertos.lds
        endif
      endif
      ifeq ($(SOC),$(filter $(SOC), tpr12 awr294x))
        ifeq ($(CONFIG_BLD_XDC_c66),)
            CONFIG_BLD_LNK_c66   = $(pdk_PATH)/ti/build/$(SOC)/linker_c66_freertos.cmd
        endif
      endif
    endif
    ifeq ($(BUILD_OS_TYPE),baremetal)
      ifeq ($(SOC),$(filter $(SOC), am65xx j721e am77x j7200 am64x))
            CONFIG_BLD_LNK_r5f   = $(pdk_PATH)/ti/build/$(SOC)/linker_r5.lds
        endif
      endif
      ifeq ($(SOC),$(filter $(SOC), am65xx am64x))
        ifeq ($(CONFIG_BLD_XDC_a53),)
            CONFIG_BLD_LNK_a53   = $(pdk_PATH)/ti/build/$(SOC)/linker_a53.lds
        endif
      endif
      ifeq ($(SOC),$(filter $(SOC), am64x))
        ifeq ($(CONFIG_BLD_XDC_m4f),)
            CONFIG_BLD_LNK_m4f   = $(pdk_PATH)/ti/build/$(SOC)/linker_m4f.lds
        endif
      endif
      ifeq ($(SOC),$(filter $(SOC), j721e am77x j7200))
        ifeq ($(CONFIG_BLD_XDC_a72),)
            CONFIG_BLD_LNK_a72   = $(pdk_PATH)/ti/build/$(SOC)/linker_a72_mpu1_0.lds
        endif
            CONFIG_BLD_LNK_c66   = $(pdk_PATH)/ti/build/$(SOC)/linker_c66.cmd
        endif
        ifeq ($(CONFIG_BLD_XDC_c7x),)
            CONFIG_BLD_LNK_c7x   = $(pdk_PATH)/ti/build/$(SOC)/linker_c7x.lds
        endif
      endif
        endif
            CONFIG_BLD_LNK_c66   = $(pdk_PATH)/ti/build/$(SOC)/linker_c66_baremetal.cmd
        endif
      endif
    endif
      # XDC specific ENV variables
      # XDC Config.bld file (required for configuro); Derives from top-level pdk_PATH
            CONFIG_BLD_XDC_r5f   = $(pdk_PATH)/ti/build/$(SOC)/config_$(SOC)_r5f.bld
            CONFIG_BLD_LNK_r5f   = $(pdk_PATH)/ti/build/$(SOC)/linker_r5_sysbios.lds
        endif
            CONFIG_BLD_XDC_c66   = $(pdk_PATH)/ti/build/$(SOC)/config_$(SOC)_c66.bld
        endif
      endif
      ifeq ($(SOC),tda2xx)
        ifeq ($(CONFIG_BLD_XDC_a15),)
         CONFIG_BLD_XDC_a15 = $(pdk_PATH)/ti/build/tda2xx/config_tda2xx_a15.bld
        endif
        ifeq ($(CONFIG_BLD_XDC_m4),)
            CONFIG_BLD_XDC_m4     = $(pdk_PATH)/ti/build/tda2xx/config_tda2xx.bld
        endif
          CONFIG_BLD_XDC_c66     = $(pdk_PATH)/ti/build/tda2xx/config_tda2xx_c66.bld
        endif
      endif
      ifeq ($(SOC),tda2px)
        endif
        endif
        endif
      endif
      ifeq ($(SOC),dra75x)
        endif
        endif
        endif
      endif
      ifeq ($(SOC),tda2ex)
         CONFIG_BLD_XDC_a15 = $(pdk_PATH)/ti/build/tda2ex/config_tda2ex_a15.bld
        endif
            CONFIG_BLD_XDC_m4     = $(pdk_PATH)/ti/build/tda2ex/config_tda2ex.bld
        endif
          CONFIG_BLD_XDC_c66     = $(pdk_PATH)/ti/build/tda2ex/config_tda2ex_c66.bld
        endif
      endif
      ifeq ($(SOC),dra72x)
        endif
        endif
        endif
      endif
      ifeq ($(SOC),tda3xx)
            CONFIG_BLD_XDC_m4   = $(pdk_PATH)/ti/build/tda3xx/config_tda3xx.bld
        endif
          CONFIG_BLD_XDC_c66     = $(pdk_PATH)/ti/build/tda3xx/config_tda3xx_c66.bld
        endif
      endif
      ifeq ($(SOC),dra78x)
        endif
        endif
      endif
      ifeq ($(SOC),am571x)
         CONFIG_BLD_XDC_a15 = $(pdk_PATH)/ti/build/am571x/config_am571x_a15.bld
        endif
            CONFIG_BLD_XDC_m4     = $(pdk_PATH)/ti/build/am571x/config_am571x.bld
        endif
          CONFIG_BLD_XDC_c66     = $(pdk_PATH)/ti/build/am571x/config_am571x_c66.bld
        endif
      endif
      ifeq ($(SOC),am572x)
         CONFIG_BLD_XDC_a15 = $(pdk_PATH)/ti/build/am572x/config_am572x_a15.bld
        endif
            CONFIG_BLD_XDC_m4     = $(pdk_PATH)/ti/build/am572x/config_am572x.bld
        endif
          CONFIG_BLD_XDC_c66     = $(pdk_PATH)/ti/build/am572x/config_am572x_c66.bld
        endif
      endif
      ifeq ($(SOC),am574x)
         CONFIG_BLD_XDC_a15 = $(pdk_PATH)/ti/build/am574x/config_am574x_a15.bld
        endif
            CONFIG_BLD_XDC_m4     = $(pdk_PATH)/ti/build/am574x/config_am574x.bld
        endif
          CONFIG_BLD_XDC_c66     = $(pdk_PATH)/ti/build/am574x/config_am574x_c66.bld
        endif
      endif
      ifeq ($(SOC),am335x)
        ifeq ($(CONFIG_BLD_XDC_a8),)
         CONFIG_BLD_XDC_a8 = $(pdk_PATH)/ti/build/am335x/config_am335x_a8.bld
        endif
      endif
      ifeq ($(SOC),am437x)
        ifeq ($(CONFIG_BLD_XDC_a9),)
         CONFIG_BLD_XDC_a9 = $(pdk_PATH)/ti/build/am437x/config_am437x_a9.bld
        endif
      endif
      ifeq ($(SOC),k2g)
         CONFIG_BLD_XDC_a15 = $(pdk_PATH)/ti/build/k2g/config_k2g_a15.bld
        endif
          CONFIG_BLD_XDC_c66 = $(pdk_PATH)/ti/build/k2g/config_k2g_c66.bld
        endif
      endif
    #Used linker file
           #CONFIG_BLD_LNK_r5f   = $(pdk_PATH)/ti/build/$(SOC)/linker_r5_sysbios.lds
       ifeq ($(CORE), mcu1_0)
       CONFIG_BLD_LNK_r5f = /home/ketaki/Desktop/SBL_boot/linker_files/linker_r5f_mcu1_0_btcm_sysbios.lds
       endif
        ifeq ($(CORE), mcu2_0)
        CONFIG_BLD_LNK_r5f = /home/ketaki/Desktop/SBL_boot/linker_files/linker_r5f_mcu2_0_btcm_sysbios.lds
       endif
        ifeq ($(CORE), mcu2_1)
        CONFIG_BLD_LNK_r5f = /home/ketaki/Desktop/SBL_boot/linker_files/linker_r5f_mcu2_1_btcm_sysbios.lds
       endif
       endif
      endif
            CONFIG_BLD_XDC_a53   = $(pdk_PATH)/ti/build/$(SOC)/config_$(SOC)_a53.bld
        endif
      endif
            CONFIG_BLD_XDC_a72   = $(pdk_PATH)/ti/build/$(SOC)/config_$(SOC)_a72.bld
        endif
        endif
            CONFIG_BLD_XDC_c7x   = $(pdk_PATH)/ti/build/$(SOC)/config_$(SOC)_c7x.bld
        endif
      endif
      XDCROOT = $(xdc_PATH)
      XDCTOOLS = $(xdc_PATH)
      BIOSROOT = $(bios_PATH)
      export XDCROOT
      export XDCTOOLS
      export BIOSROOT
    endif
    CGTOOLS = $(TOOLCHAIN_PATH_M4)
    export CGTOOLS
    CGTOOLS_DSP = $(CODEGEN_PATH_C674)
    export CGTOOLS_DSP
    CGTOOLS_A8 = $(TOOLCHAIN_PATH_A8)
    export CGTOOLS_A8
    CGTOOLS_A9 = $(TOOLCHAIN_PATH_A9)
    export CGTOOLS_A9
    CGTOOLS_ARM9 = $(TOOLCHAIN_PATH_Arm9)
    export CGTOOLS_ARM9
    CGTOOLS_A15 = $(TOOLCHAIN_PATH_A15)
    export CGTOOLS_A15
    CGTOOLS_EVE = $(TOOLCHAIN_PATH_EVE)
    export CGTOOLS_EVE
    export CGTOOLS_A53 = $(TOOLCHAIN_PATH_A53)
    export CGTOOLS_A72 = $(TOOLCHAIN_PATH_A72)
    STRIP470 = $(TOOLCHAIN_PATH_M4)/bin/strip470 -p
    STRIP6x = $(CODEGEN_PATH_C674)/bin/strip6x -p
    STRIP_ALL_ARM = $(CODEGEN_PREFIX)strip -s
    STRIP_DEBUG_ARM = $(CODEGEN_PREFIX)strip --strip-debug
    # Nothing beyond this point
    Also I wanted to ask as this is the make file used by UART,do we need to make any other changes in it.
    3] .../mcspi_slavemode/j721e/r5_mpu_ipc.xs       | 159 ++++++++++++
    Added this file. in location :
    /home/ketaki/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/drv/uart/test/j721e
    And added it in uartUnitTest_r5.cfg present in the above path
    xdc.loadCapsule("r5_mpu_ipc.xs");  //changed from mpu.xs to r5_mpu_ipc.xs
    4] .../j721e/sysbios_r5f_btcm.cfg                | 239 ++++++++++++++++++
    Added the patch:
    sysbios_r5f_btcm.txt
     *  are met:
     *    distribution.
    /* Enable cache */
        Core.id = 0;
        /* DM timer cfg */
        Clock.timerId = 1;
        Core.id = 1;
        /* DM timer cfg */
        Clock.timerId = 2;
        Core.id = 0;
        Clock.timerId = 0;
        Core.id = 1;
        Clock.timerId = 1;
        Core.id = 0;
        Clock.timerId = 2;
        Core.id = 1;
        Clock.timerId = 3;
        Hwi.dummyIRQ                   = 383;
        Hwi.dummyIRQ                   = 511;
    And added its path in file
    /home/ketaki/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/drv/uart/test/makefile
    5684.makefile.txt
    # Makefile for UART unit test app
    include $(PDK_INSTALL_PATH)/ti/build/Rules.make
    BUILD_OS_TYPE = baremetal
    CFLAGS_OS_DEFINES =
    LNKFLAGS_LOCAL_mpu1_0  += --entry Entry
    COMP_LIST_COMMON  = $(PDK_COMMON_BAREMETAL_COMP)
    EXTERNAL_INTERFACES =
    else
    BUILD_OS_TYPE = tirtos
    CFLAGS_OS_DEFINES = -DUSE_BIOS
    EXTERNAL_INTERFACES = bios xdc
    COMP_LIST_COMMON  = $(PDK_COMMON_TIRTOS_COMP)
    ifeq ($(SOC),$(filter $(SOC), j721e j7200 am65xx am64x tpr12 awr294x))
    else
      XDC_CFG_FILE_mpu1_0 = ./$(SOC)/uartUnitTest_$(ISA).cfg
      #XDC_CFG_FILE_mcu1_0 = ./$(SOC)/uartUnitTest_r5.cfg
      XDC_CFG_FILE_mcu1_0 = $(PDK_INSTALL_PATH)/ti/build/$(SOC)/sysbios_$(ISA)_btcm.cfg
    endif
    ifeq ($(ISA),$(filter $(ISA), a53))
      LIB_PATHS_DIR=$(BIOS_INSTALL_PATH)/packages/gnu/targets/arm/libs/install-native/aarch64-none-elf/lib/
    endif
    endif
    endif
    SRCDIR = . src
    INCDIR = . src
    # Common source files across all platforms and cores
    SRCS_COMMON += main_uart_test.c
    # List all the external components/interfaces, whose interface header files
    # need to be included for this component
    INCLUDE_EXTERNAL_INTERFACES = pdk $(EXTERNAL_INTERFACES)
    ifeq ($(BUILD_OS_TYPE), tirtos)
    UART_OS_TYPE=
    else
    UART_OS_TYPE=_Baremetal
    endif
    # DMA enabled build
    ifeq ($(DMA), enable)
        ifeq ($(SMP), enable)
            #Name of the directory created under packages/ti/binary/
            APP_NAME = UART$(UART_OS_TYPE)_DMA_SMP_TestApp
            # Name of the binary if different from the default (APP_NAME)_$(BOARD_$(CORE)_<build_profile>
            LOCAL_APP_NAME =  UART$(UART_OS_TYPE)_DMA_$(BOARD)_$(CORE)_SMP_TestApp
    	else
            APP_NAME = UART$(UART_OS_TYPE)_DMA_TestApp
            LOCAL_APP_NAME =  UART$(UART_OS_TYPE)_DMA_$(BOARD)_$(CORE)TestApp
        endif
        COMP_LIST_COMMON := $(filter-out uart,$(COMP_LIST_COMMON))
        COMP_LIST_COMMON   += uart_dma
        #COMP_LIST_COMMON   += uart_dma_profile
        CFLAGS_UART_DMA    = -DUART_DMA_ENABLE
    else
            APP_NAME = UART$(UART_OS_TYPE)_SMP_TestApp
            LOCAL_APP_NAME =  UART$(UART_OS_TYPE)_$(BOARD)_$(CORE)_SMP_TestApp
        else
            APP_NAME = UART$(UART_OS_TYPE)_TestApp
            LOCAL_APP_NAME =  UART$(UART_OS_TYPE)_$(BOARD)_$(CORE)TestApp
        endif
        #COMP_LIST_COMMON   += uart_profile
        CFLAGS_UART_DMA    =
    endif
    # List all the specific components required by the application
    #COMP_LIST_COMMON  += profiling
    PACKAGE_SRCS_COMMON = .
    ifeq ($(CORE),$(filter $(CORE), m4f_0))
    CONFIG_BLD_LNK_m4f = am64x/uart_linker_m4f.lds
    PACKAGE_SRCS_COMMON += $(SOC)
    endif
    endif
    CFLAGS_LOCAL_COMMON = $(PDK_CFLAGS) $(CFLAGS_UART_DMA) $(CFLAGS_OS_DEFINES)
    # Include common make files
    ifeq ($(MAKERULEDIR), )
    #Makerule path not defined, define this and assume relative path from ROOTDIR
      MAKERULEDIR := $(ROOTDIR)/ti/build/makerules
      export MAKERULEDIR
    endif
    include $(MAKERULEDIR)/common.mk
    # OBJs and libraries are built by using rule defined in rules_<target>.mk
    #     and need not be explicitly specified here
    5] .../drv/spi/example/mcspi_slavemode/makefile  |   5 +-
    For UART,Added path in env.mk for linker_r5f_mcu1_0_btcm_sysbios.lds ,You can refer the env.mk file attached above.
    Couldnt find path to attach :ipcCopyVecs2Exc.asm file .
    I tried to add it as given for SPI but didnt work in env.mk
    6] .../mcspi_slavemode/src/ipcCopyVecs2Exc.asm   |  59 +++++
    Added patch but what sould be the location to place it and the which make file should contain its path as done in spi make file :
    7] .../src/main_mcspi_slave_mode.c               |   4 +
    I think we should neglect this chnages for UART,right?
    I have disabled UART for mcu1_0 in both rtos and linux as suggested in the patch.
    Please ,let me know where I am going wrong ..I am quite new to using makefiles and linker files.
    Ketaki
    We are trying to run UART app for mcu1_0 on linux using the following linker file:
    I am not able to build using this linker file at my end, are you sure this is the linker file you are using at your end? Also, please confirm which SDK version are you using?
    Parth
  • Hello Parth,
    Yes using the same linker file ./linker_r5f_mcu1_0_btcm_sysbios.lds  with Pdk 7.3.
    The App was getting build earlier with the same Linker file but did not run along with linux ,after we made changes in the file as per the patches suggested in the thread you asked to follow which was for SPIMaster as example:
    --retain="*(.ipcCopyVecsToExc)" adding this .asm  The App is not getting build and getting the linking issue maybe due to the issue as point
    Getting the following error:
    # Linking into /home/ketaki/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/binary/UART_TestApp/bin/j721e_evm/UART_j721e_evm_mcu1_0TestApp_release.xer5f...
    <Linking>
    undefined       first referenced
      symbol             in file
    ipcCopyVecs2Exc <whole-program>
    error: unresolved symbols remain
    >> Compilation failure
    Can you try building the Uart Test app along with linux following the patches for MasterSPI so we can get clear idea,if anything extra or different is needed for UART.
    Ketaki
  • Hello Parth,
    Any updates !
    Ketaki
  • Hi Ketaki,
    I have been able to run the UART_TestApp alongside Linux at my end. Will be sharing the patch in sometime.
    Parth
  • Hi Ketaki,
    Please follow the steps below to run the UART_TestApp on mcu1_0 alongside Linux on A72.
    Download and unzip the folder Patch_to_run_UartTestApp_with_linux.zip
    On RTOS Side
    Apply the patch Uart_TestApp_with_linux.patch in PDK and replace the linker_r5_sysbios.lds in <PDK>packages/ti/build/j721e with the one available in zip folder.
    Re-build the UART TestApp
    //Re-build the copyvecs lib
    make BOARD=j721e_evm CORE=mcu1_0 copyvecs
    //Re-build UART_TestApp
    make BOARD=j721e_evm CORE=mcu1_0 UART_TestApp
    On Linux Side
    Modify Makefile to point UBOOT_DM to newly generate UART_TestApp image
    Re-build the U-boot and dtb and copy the required files to the SD card
    //Re-buld dtbs
    make linux-dtbs
    Re-build u-boot
    make u-boot_clean
    make u-boot -j
    Copy the following files to SD card
    cp board-support/u-boot_build/r5/tiboot3.bin /media/Parth/boot/
    cp board-support/u-boot_build/a72/tispl.bin /media/Parth/boot/
    cp board-support/u-boot_build/a72/u-boot.img /media/Parth/boot/
    sudo cp board-support/linux-5.4.106+gitAUTOINC+023faefa70-g023faefa70/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dtb /media/mistral/rootfs/boot/
    With the above changes you should be able to run UART_TestApp alongside Linux.
    Parth
  • Hello Parth,
    Thanks for the solution.
    But still getting the error as:
    U-Boot SPL 2020.01-dirty (Sep 06 2022 - 15:37:53 +05)
    SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.0)
    Loading Environment from MMC... *** Warning - No MMCt
    Attaching the changes made in the file :
    PDK changes
    1.Makefile:
    5775.makefile.txt
    -include Rules.make
    MAKE_JOBS ?= 1
    all: linux arm-benchmarks am-sysinfo oprofile-example linux-dtbs cryptodev sysfw-image jailhouse ti-img-rogue-driver oob-demo u-boot-spl-j7 ti-img-encode-decode
    clean: linux_clean arm-benchmarks_clean am-sysinfo_clean oprofile-example_clean linux-dtbs_clean cryptodev_clean sysfw-image_clean jailhouse_clean ti-img-rogue-driver_clean oob-demo_clean u-boot-spl-j7_clean ti-img-encode-decode_clean
    install: linux_install arm-benchmarks_install am-sysinfo_install oprofile-example_install linux-dtbs_install cryptodev_install sysfw-image_install jailhouse_install ti-img-rogue-driver_install oob-demo_install u-boot-spl-j7_install ti-img-encode-decode_install
    # Kernel build targets
    linux: linux-dtbs
    	@echo =================================
    	@echo     Building the Linux Kernel
    	$(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) ARCH=arm64 CROSS_COMPILE=$(CROSS_COMPILE) $(DEFCONFIG)
    	$(MAKE) -j $(MAKE_JOBS) -C $(LINUXKERNEL_INSTALL_DIR) ARCH=arm64 CROSS_COMPILE=$(CROSS_COMPILE)  Image
    	$(MAKE) -j $(MAKE_JOBS) -C $(LINUXKERNEL_INSTALL_DIR) ARCH=arm64 CROSS_COMPILE=$(CROSS_COMPILE) modules
    linux_install: linux-dtbs_install
    	@echo ===================================
    	@echo     Installing the Linux Kernel
    	@if [ ! -d $(DESTDIR) ] ; then \
    		echo "The extracted target filesystem directory doesn't exist."; \
    		echo "Please run setup.sh in the SDK's root directory and then try again."; \
    		exit 1; \
    	fi
    	install -d $(DESTDIR)/boot
    	install $(LINUXKERNEL_INSTALL_DIR)/arch/arm64/boot/Image $(DESTDIR)/boot
    	install $(LINUXKERNEL_INSTALL_DIR)/vmlinux $(DESTDIR)/boot
    	install $(LINUXKERNEL_INSTALL_DIR)/System.map $(DESTDIR)/boot
    	$(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) ARCH=arm64 CROSS_COMPILE=$(CROSS_COMPILE) INSTALL_MOD_PATH=$(DESTDIR) INSTALL_MOD_STRIP=$(INSTALL_MOD_STRIP) modules_install
    linux_clean:
    	@echo     Cleaning the Linux Kernel
    	$(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) ARCH=arm64 CROSS_COMPILE=$(CROSS_COMPILE) mrproper
    # arm-benchmarks build targets
    arm-benchmarks:
    	@echo    Building ARM Benchmarks
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*arm-benchmarks*"`; make CC="$(CC)"
    arm-benchmarks_clean:
    	@echo    Cleaning ARM Benchmarks
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*arm-benchmarks*"`; make clean
    arm-benchmarks_install:
    	@echo ==============================================
    	@echo   Installing ARM Benchmarks - Release version
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*arm-benchmarks*"`; make install
    arm-benchmarks_install_debug:
    	@echo   Installing ARM Benchmarks - Debug Version
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*arm-benchmarks*"`; make install_debug
    # am-sysinfo build targets
    am-sysinfo:
    	@echo    Building AM Sysinfo
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*am-sysinfo*"`; make CC="$(CC)"
    am-sysinfo_clean:
    	@echo    Cleaning AM Sysinfo
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*am-sysinfo*"`; make clean
    am-sysinfo_install:
    	@echo ===============================================
    	@echo     Installing AM Sysinfo - Release version
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*am-sysinfo*"`; make install
    am-sysinfo_install_debug:
    	@echo     Installing AM Sysinfo - Debug version
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*am-sysinfo*"`; make install_debug
    # oprofile-example build targets
    oprofile-example:
    	@echo    Building OProfile Example
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*oprofile-example*"`; make CC="$(CC)"
    oprofile-example_clean:
    	@echo    Cleaning OProfile Example
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*oprofile-example*"`; make clean
    oprofile-example_install:
    	@echo     Installing OProfile Example - Debug version
    	@cd example-applications; cd `find . -maxdepth 1 -type d -name "*oprofile-example*"`; make install
    # Kernel DTB build targets
    linux-dtbs:
    	@echo     Building the Linux Kernel DTBs
    	@for DTB in      ti/k3-j721e-common-proc-board.dtb     ti/k3-j721e-proc-board-tps65917.dtb     ti/k3-j721e-common-proc-board-infotainment.dtbo     ti/k3-j721e-pcie-backplane.dtbo     ti/k3-j721e-common-proc-board-jailhouse.dtbo  	ti/k3-j721e-vision-apps.dtbo 	ti/k3-j721e-pcie-backplane.dtbo ; do \
    		$(MAKE) -j $(MAKE_JOBS) -C $(LINUXKERNEL_INSTALL_DIR) ARCH=arm64 CROSS_COMPILE=$(CROSS_COMPILE) $$DTB; \
    	done
    linux-dtbs_install:
    	@echo     Installing the Linux Kernel DTBs
    		exit 1; \
    	fi
    		install -m 0644 $(LINUXKERNEL_INSTALL_DIR)/arch/arm64/boot/dts/$$DTB $(DESTDIR)/boot/; \
    	done
    linux-dtbs_clean:
    	@echo     Cleaning the Linux Kernel DTBs
    	@echo "Nothing to do"
    cryptodev: linux
    	@echo      Building cryptodev-linux
    	@cd board-support/extra-drivers; \
    	cd `find . -maxdepth 1 -type d -name "cryptodev*"`; \
    	make ARCH=arm64 KERNEL_DIR=$(LINUXKERNEL_INSTALL_DIR)
    cryptodev_clean:
    	@echo      Cleaning cryptodev-linux
    	make ARCH=arm64 KERNEL_DIR=$(LINUXKERNEL_INSTALL_DIR) clean
    cryptodev_install:
    	@echo      Installing cryptodev-linux
    		exit 1; \
    	fi
    	make ARCH=arm64  KERNEL_DIR=$(LINUXKERNEL_INSTALL_DIR)  INSTALL_MOD_PATH=$(DESTDIR) PREFIX=$(SDK_PATH_TARGET) INSTALL_MOD_STRIP=$(INSTALL_MOD_STRIP) install
    # Define the following to support multple platforms
    PLATFORM_TYPE_$(PLATFORM) = gp
    PLATFORM_TYPE_am65xx-hs-evm = hs
    PLATFORM_TYPE_j7-hs-evm = hs
    PLATFORM_TYPE = $(PLATFORM_TYPE_$(PLATFORM))
    SYSFW_CONFIG = evm
    SYSFW_SOC_$(PLATFORM) = NULL
    SYSFW_SOC_am65xx-evm = am65x
    SYSFW_SOC_am65xx-hs-evm = am65x
    SYSFW_SOC_j7-evm = j721e
    SYSFW_SOC_j7-hs-evm = j721e
    SYSFW_SOC_j7200-evm = j7200
    SYSFW_SOC = $(SYSFW_SOC_$(PLATFORM))
    SYSFW_PREFIX_$(PLATFORM) = NULL
    SYSFW_PREFIX_am65xx-evm = ti-sci-firmware
    SYSFW_PREFIX_am65xx-hs-evm = ti-sci-firmware
    SYSFW_PREFIX_j7-evm = ti-fs-firmware
    SYSFW_PREFIX_j7-hs-evm = ti-fs-firmware
    SYSFW_PREFIX_j7200-evm = ti-fs-firmware
    SYSFW_PREFIX = $(SYSFW_PREFIX_$(PLATFORM))
    ifeq ($(SYSFW_SOC),j7200)
    	SYSFW_BASE = tiboot3
    else
    	SYSFW_BASE = $(SYSFW_PREFIX)-$(SYSFW_SOC)-$(PLATFORM_TYPE)
    endif
    SYSFW_MAKEARGS_common = SYSFW_DL_URL="" SYSFW_HS_DL_URL="" SYSFW_HS_INNER_CERT_DL_URL="" \
                            SYSFW_PATH=$(TI_SDK_PATH)/board-support/prebuilt-images/$(SYSFW_BASE).bin \
                            SOC=$(SYSFW_SOC) CONFIG=$(SYSFW_CONFIG)
    SYSFW_MAKEARGS_gp =
    SYSFW_MAKEARGS_hs = HS=1 SYSFW_HS_PATH=$(TI_SDK_PATH)/board-support/prebuilt-images/$(SYSFW_BASE)-enc.bin \
                        SYSFW_HS_INNER_CERT_PATH=$(TI_SDK_PATH)/board-support/prebuilt-images/$(SYSFW_BASE)-cert.bin
    SYSFW_MAKEARGS = $(SYSFW_MAKEARGS_common) $(SYSFW_MAKEARGS_$(PLATFORM_TYPE))
    # Depend on linux-dtbs for the dtc utility
    sysfw-image: linux-dtbs
    	@echo    Building SYSFW Image
    	@cd board-support; cd `find . -maxdepth 1 -type d -name "*k3-image*"`; \
    		make $(SYSFW_MAKEARGS) CROSS_COMPILE=$(CROSS_COMPILE_ARMV7) PATH=$(PATH):$(LINUXKERNEL_INSTALL_DIR)/scripts/dtc SOC=$(SYSFW_SOC)
    sysfw-image_clean:
    	@echo    Cleaning SYSFW Image
    	@cd board-support; cd `find . -maxdepth 1 -type d -name "*k3-image*"`; make clean SOC=$(SYSFW_SOC)
    sysfw-image_install:
    	@echo   Installing SYSFW Image
    # jailhouse module
    JH_ARCH = "arm64"
    JH_PLATFORM = "k3"
    jailhouse_config:
    	@echo      Configuring jailhouse
    	cd `find . -maxdepth 1 -name "jailhouse*" -type d`; \
    	echo "#define CONFIG_TRACE_ERROR    1" >> include/jailhouse/config.h
    jailhouse: linux jailhouse_config
    	@echo      Building jailhouse
    	make ARCH=$(JH_ARCH) KDIR=${LINUXKERNEL_INSTALL_DIR}
    jailhouse_clean:
    	@echo      Cleaning jailhouse
    	make ARCH=$(JH_ARCH) KDIR=${LINUXKERNEL_INSTALL_DIR} clean
    jailhouse_distclean: jailhouse_clean
    	@echo      Distclean jailhouse
    	rm -vf ./hypervisor/include/jailhouse/config.h
    jailhouse_install:
    	@echo      Installing jailhouse
    	make ARCH=$(JH_ARCH) KDIR=${LINUXKERNEL_INSTALL_DIR} DESTDIR=$(DESTDIR) INSTALL_MOD_STRIP=$(INSTALL_MOD_STRIP) prefix=/usr install
    # ti-img-rogue-driver
    ti-img-rogue-driver: linux
    	@echo     Building ti-img-rogue-driver
    	cd `find . -maxdepth 1 -type d -name "ti-img-rogue-driver*" -type d`; \
    	make ARCH=arm64 KERNELDIR=${LINUXKERNEL_INSTALL_DIR} RGX_BVNC="22.104.208.318" BUILD=release PVR_BUILD_DIR=j721e_linux WINDOW_SYSTEM=wayland
    ti-img-rogue-driver_clean:
    	@echo     Cleaning ti-img-rogue-driver
    	make ARCH=arm64 KERNELDIR=${LINUXKERNEL_INSTALL_DIR} RGX_BVNC="22.104.208.318" BUILD=release PVR_BUILD_DIR=j721e_linux WINDOW_SYSTEM=wayland clean
    ti-img-rogue-driver_install:
    	@echo     Installing ti-img-rogue-driver
    	cd binary_j721e_linux_wayland_release/target_aarch64/kbuild; \
    	make -C ${LINUXKERNEL_INSTALL_DIR} INSTALL_MOD_PATH=${DESTDIR} INSTALL_MOD_STRIP=${INSTALL_MOD_STRIP} M=`pwd` modules_install
    oob-demo:
    oob-demo_clean:
    oob-demo_install:
    	@echo Updating oob-demo wallpaper
    	sed -i 's%background-image.*%background-image=/usr/share/demo/j7-evm-p0-wallpaper.jpg%' $(DESTDIR)/etc/weston.ini
    # u-boot build targets
    u-boot-spl-j7: u-boot
    u-boot-spl-j7_clean: u-boot_clean
    u-boot-spl-j7_install: u-boot_install
    UBOOT_SYSFW=$(TI_SDK_PATH)/board-support/prebuilt-images/sysfw.bin
    ifeq ($(PLATFORM),j7-evm)
    	UBOOT_A72_BUILD_DIR=$(TI_SDK_PATH)/board-support/u-boot_build/a72
    	UBOOT_R5_BUILD_DIR=$(TI_SDK_PATH)/board-support/u-boot_build/r5
    	UBOOT_ATF=$(TI_SDK_PATH)/board-support/prebuilt-images/bl31.bin
    	UBOOT_TEE=$(TI_SDK_PATH)/board-support/prebuilt-images/bl32.bin
    	#UBOOT_DM=$(TI_SDK_PATH)/board-support/prebuilt-images/ipc_echo_testb_mcu1_0_release_strip.xer5f
    	#UBOOT_DM=/home/ketaki/Downloads/UART_j721e_evm_mcu1_0TestApp_release_strip.xer5f
            UBOOT_DM=/home/ketaki/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/binary/UART_TestApp/bin/j721e_evm/UART_j721e_evm_mcu1_0TestApp_release_strip.xer5f
    else
    	UBOOT_A72_BUILD_DIR=$(TI_SDK_PATH)/board-support/u-boot_hs_build/a72
    	UBOOT_R5_BUILD_DIR=$(TI_SDK_PATH)/board-support/u-boot_hs_build/r5
    	UBOOT_ATF=$(TI_SDK_PATH)/board-support/prebuilt-images/bl31.bin.signed
    	UBOOT_TEE=$(TI_SDK_PATH)/board-support/prebuilt-images/bl32.bin.signed
    	UBOOT_DM=$(TI_SDK_PATH)/board-support/prebuilt-images/ipc_echo_testb_mcu1_0_release_strip.xer5f.signed
    endif
    u-boot: u-boot-a72 u-boot-r5
    u-boot_clean: u-boot-a72_clean u-boot-r5_clean
    u-boot-a72:
    	@echo    Building U-boot for A72
    	$(MAKE) -j $(MAKE_JOBS) -C $(TI_SDK_PATH)/board-support/u-boot-* CROSS_COMPILE=$(CROSS_COMPILE) \
    		 $(UBOOT_MACHINE) O=$(UBOOT_A72_BUILD_DIR)
    		CONFIG_MKIMAGE_DTC_PATH=$(UBOOT_A72_BUILD_DIR)/scripts/dtc/dtc \
    		ATF=$(UBOOT_ATF) TEE=$(UBOOT_TEE) DM=$(UBOOT_DM) \
    u-boot-a72_clean:
    	@echo    Cleaining U-boot for A72
    	$(MAKE) -C $(TI_SDK_PATH)/board-support/u-boot-* CROSS_COMPILE=$(CROSS_COMPILE) \
    		O=$(UBOOT_A72_BUILD_DIR) distclean
    	@rm -rf $(UBOOT_A72_BUILD_DIR)
    u-boot-r5:
    	@echo    Building U-boot for R5
    	$(MAKE) -j $(MAKE_JOBS) -C $(TI_SDK_PATH)/board-support/u-boot-* CROSS_COMPILE=$(CROSS_COMPILE_ARMV7) \
    		 $(UBOOT_MACHINE_R5) O=$(UBOOT_R5_BUILD_DIR)
    u-boot-r5_clean:
    	@echo    Cleaining U-boot for R5
    	$(MAKE) -C $(TI_SDK_PATH)/board-support/u-boot-* CROSS_COMPILE=$(CROSS_COMPILE_ARMV7) \
    		O=$(UBOOT_R5_BUILD_DIR) distclean
    	@rm -rf $(UBOOT_R5_BUILD_DIR)
    u-boot_install:
    	@echo    Installing U-boot
    # ti-img-encode-decode
    ti-img-encode-decode: linux
    	@echo     Building ti-img-encode-decode
    	cd `find . -maxdepth 1 -type d -name "ti-img-encode-decode*" -type d`; \
    	cd linux/decoder; \
    	make ARCH=arm64 KPATH=${LINUXKERNEL_INSTALL_DIR} all; \
    	cd ../encoder; \
    ti-img-encode-decode_clean:
    	@echo     Cleaning ti-img-encode-decode
    	cd linux/decoder; \
    	make ARCH=arm64 KPATH=${LINUXKERNEL_INSTALL_DIR} clean; \
    	cd ../encoder; \
    ti-img-encode-decode_install:
    	@echo     Installing ti-img-encode-decode
    	cd linux/decoder; \
    	make -C ${LINUXKERNEL_INSTALL_DIR} INSTALL_MOD_PATH=${DESTDIR} INSTALL_MOD_STRIP=${INSTALL_MOD_STRIP} M=`pwd` modules_install; \
    	cd ../encoder; \
    2. ipcCopyVecs2Exc.asm
    ipcCopyVecs2Exc.txt
    ;  are met:
        .text
    ipcCopyVecs2Exc:
            .asmfunc
    loop:
            ldr	r3, [r0], #4
            str     r3, [r1], #4
            subs    r2, r2, #4
            bgt     loop
    exit:
            bx      lr
            .endasmfunc
            .end
    3.main_uart_test.c
    main_uart_test.txt
    3.utilsCopyVecs2ATcm.asm
    utilsCopyVecs2ATcm.txt
    ;  are met:
    ; ======== utilsCopyVecs2ATcm.asm ========
    ; Copies sysbios defined vector to ATM area
        .text
        .sect   ".utilsCopyVecsToAtcm"
    ;   void utilsCopyVecs2ATcm( void )
        .global utilsCopyVecs2ATcm
    utilsCopyVecs2ATcm:
            .asmfunc
    ;        mrc     p15, #0, r0, c9, c1, #1 ; read ATCM Region Register
    ;        tst     r0, #1
    ;        beq     exit                    ; do nothing if ATCM disabled
            mov     r1, #0                  ; ATCM address
            mov	r2, #64			; 256 bytes
    loop:
            ldr	r3, [r0], #4
            str     r3, [r1], #4
            subs    r2, r2, #4
            bgt     loop
    exit:
            bx      lr
            .endasmfunc
            .end
    Linux changes:
    4.k3-j721e-common-proc-board.dts
    3566.k3-j721e-common-proc-board.txt
    // SPDX-License-Identifier: GPL-2.0
     * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/
    /dts-v1/;
    #include "k3-j721e-som-p0.dtsi"
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/input/input.h>
    #include <dt-bindings/sound/ti-mcasp.h>
    #include <dt-bindings/net/ti-dp83867.h>
    	chosen {
    		stdout-path = "serial2:115200n8";
    		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
    	gpio_keys: gpio-keys {
    		compatible = "gpio-keys";
    		autorepeat;
    		pinctrl-names = "default";
    		pinctrl-0 = <&sw10_button_pins_default &sw11_button_pins_default>;
    		sw10: sw10 {
    			label = "GPIO Key USER1";
    			linux,code = <BTN_0>;
    			gpios = <&main_gpio0 0 GPIO_ACTIVE_LOW>;
    		sw11: sw11 {
    			label = "GPIO Key USER2";
    			linux,code = <BTN_1>;
    			gpios = <&wkup_gpio0 7 GPIO_ACTIVE_LOW>;
    	evm_12v0: fixedregulator-evm12v0 {
    		/* main supply */
    		compatible = "regulator-fixed";
    		regulator-name = "evm_12v0";
    		regulator-min-microvolt = <12000000>;
    		regulator-max-microvolt = <12000000>;
    		regulator-always-on;
    		regulator-boot-on;
    	vsys_3v3: fixedregulator-vsys3v3 {
    		/* Output of LMS140 */
    		regulator-name = "vsys_3v3";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		vin-supply = <&evm_12v0>;
    		regulator-boot-on;
    	vsys_5v0: fixedregulator-vsys5v0 {
    		/* Output of LM5140 */
    		regulator-name = "vsys_5v0";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-boot-on;
    	/* Used for 48KHz family */
    	pll4: pll4_fixed {
    		#clock-cells = <0>;
    		compatible = "fixed-clock";
    		clock-frequency = <1179648000>;
    	/* Used for 44.1KHz family */
    	pll15: pll15_fixed {
    		#clock-cells = <0>;
    		clock-frequency = <1083801600>;
    	sound0: sound@0 {
    		compatible = "ti,j721e-cpb-audio";
    		ti,model = "j721e-cpb-analog";
    		ti,cpb-mcasp = <&mcasp10>;
    		ti,cpb-codec = <&pcm3168a_1>;
    		clocks = <&pll4>, <&pll15>,
    			 <&k3_clks 184 1>,
    			 <&k3_clks 184 2>, <&k3_clks 184 4>,
    			 <&k3_clks 157 371>,
    			 <&k3_clks 157 400>, <&k3_clks 157 401>;
    		clock-names = "pll4", "pll15",
    			      "cpb-mcasp",
    			      "cpb-mcasp-48000", "cpb-mcasp-44100",
    			      "audio-refclk2",
    			      "audio-refclk2-48000", "audio-refclk2-44100";
    	vdd_mmc1: fixedregulator-sd {
    		regulator-name = "vdd_mmc1";
    		regulator-boot-on;
    		enable-active-high;
    		vin-supply = <&vsys_3v3>;
    		gpio = <&exp2 2 GPIO_ACTIVE_HIGH>;
    	vdd_sd_dv_alt: gpio-regulator-TLV71033 {
    		compatible = "regulator-gpio";
    		pinctrl-0 = <&vdd_sd_dv_alt_pins_default>;
    		regulator-name = "tlv71033";
    		regulator-min-microvolt = <1800000>;
    		regulator-boot-on;
    		vin-supply = <&vsys_5v0>;
    		gpios = <&main_gpio0 117 GPIO_ACTIVE_HIGH>;
    		states = <1800000 0x0
    			  3300000 0x1>;
    	cpsw9g_virt_mac: main_r5fss_cpsw9g_virt_mac0 {
    		compatible = "ti,j721e-cpsw-virt-mac";
    		dma-coherent;
    		ti,psil-base = <0x4a00>;
    		ti,remote-name = "mpu_1_0_ethswitch-device-0";
    		dmas = <&main_udmap 0xca00>,
    		       <&main_udmap 0xca01>,
    		       <&main_udmap 0xca02>,
    		       <&main_udmap 0xca03>,
    		       <&main_udmap 0xca04>,
    		       <&main_udmap 0xca05>,
    		       <&main_udmap 0xca06>,
    		       <&main_udmap 0xca07>,
    		       <&main_udmap 0x4a00>;
    		dma-names = "tx0", "tx1", "tx2", "tx3",
    			    "tx4", "tx5", "tx6", "tx7",
    			    "rx";
    		virt_emac_port {
    			ti,label = "virt-port";
    			/* local-mac-address = [0 0 0 0 0 0]; */
    	dp0: connector {
    		compatible = "dp-connector";
    		label = "DP0";
    		port {
    			dp_connector_in: endpoint {
    				remote-endpoint = <&dp_bridge_output>;
    	clk_ov5640_fixed: ov5640-xclk {
    		#clock-cells = <0>;
    		clock-frequency = <25000000>;
    &main_pmx0 {
    	sw10_button_pins_default: sw10_button_pins_default {
    		pinctrl-single,pins = <
    			J721E_IOPAD(0x0, PIN_INPUT, 7) /* (AC18) EXTINTn.GPIO0_0 */
    	dp0_pins_default: dp0_pins_default {
    			J721E_IOPAD(0x1c4, PIN_INPUT, 5) /* SPI0_CS1.DP0_HPD */
    	main_i2c1_exp4_pins_default: main-i2c1-exp4-pins-default {
    			J721E_IOPAD(0x230, PIN_INPUT, 7) /* (U2) ECAP0_IN_APWM_OUT.GPIO1_11 */
    	main_i2c0_pins_default: main-i2c0-pins-default {
    			J721E_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (AC5) I2C0_SCL */
    			J721E_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (AA5) I2C0_SDA */
    	main_i2c1_pins_default: main-i2c1-pins-default {
    			J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */
    			J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */
    	main_i2c2_pins_default: main-i2c2-pins-default {
    			J721E_IOPAD(0x1c8, PIN_INPUT_PULLUP, 2) /* (AB5) SPI0_CLK.I2C2_SCL */
    			J721E_IOPAD(0x1cc, PIN_INPUT_PULLUP, 2) /* (AA1) SPI0_D0.I2C2_SDA */
    	main_i2c3_pins_default: main-i2c3-pins-default {
    			J721E_IOPAD(0x270, PIN_INPUT_PULLUP, 4) /* (T26) MMC2_CLK.I2C3_SCL */
    			J721E_IOPAD(0x274, PIN_INPUT_PULLUP, 4) /* (T25) MMC2_CMD.I2C3_SDA */
    	main_i2c6_pins_default: main-i2c6-pins-default {
    			J721E_IOPAD(0x1d0, PIN_INPUT_PULLUP, 2) /* (AA3) SPI0_D1.I2C6_SCL */
    			J721E_IOPAD(0x1e4, PIN_INPUT_PULLUP, 2) /* (Y2) SPI1_D1.I2C6_SDA */
    	mcasp10_pins_default: mcasp10_pins_default {
    			J721E_IOPAD(0x158, PIN_OUTPUT_PULLDOWN, 12) /* (U23) RGMII5_TX_CTL.MCASP10_ACLKX */
    			J721E_IOPAD(0x15c, PIN_OUTPUT_PULLDOWN, 12) /* (U26) RGMII5_RX_CTL.MCASP10_AFSX */
    			J721E_IOPAD(0x160, PIN_OUTPUT_PULLDOWN, 12) /* (V28) RGMII5_TD3.MCASP10_AXR0 */
    			J721E_IOPAD(0x164, PIN_OUTPUT_PULLDOWN, 12) /* (V29) RGMII5_TD2.MCASP10_AXR1 */
    			J721E_IOPAD(0x170, PIN_OUTPUT_PULLDOWN, 12) /* (U29) RGMII5_TXC.MCASP10_AXR2 */
    			J721E_IOPAD(0x174, PIN_OUTPUT_PULLDOWN, 12) /* (U25) RGMII5_RXC.MCASP10_AXR3 */
    			J721E_IOPAD(0x198, PIN_INPUT_PULLDOWN, 12) /* (V25) RGMII6_TD1.MCASP10_AXR4 */
    			J721E_IOPAD(0x19c, PIN_INPUT_PULLDOWN, 12) /* (W27) RGMII6_TD0.MCASP10_AXR5 */
    			J721E_IOPAD(0x1a0, PIN_INPUT_PULLDOWN, 12) /* (W29) RGMII6_TXC.MCASP10_AXR6 */
    	audi_ext_refclk2_pins_default: audi_ext_refclk2_pins_default {
    			J721E_IOPAD(0x1a4, PIN_OUTPUT, 3) /* (W26) RGMII6_RXC.AUDIO_EXT_REFCLK2 */
    	main_mmc1_pins_default: main_mmc1_pins_default {
    			J721E_IOPAD(0x254, PIN_INPUT, 0) /* (R29) MMC1_CMD */
    			J721E_IOPAD(0x250, PIN_INPUT, 0) /* (P25) MMC1_CLK */
    			J721E_IOPAD(0x2ac, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */
    			J721E_IOPAD(0x24c, PIN_INPUT, 0) /* (R24) MMC1_DAT0 */
    			J721E_IOPAD(0x248, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */
    			J721E_IOPAD(0x244, PIN_INPUT, 0) /* (R25) MMC1_DAT2 */
    			J721E_IOPAD(0x240, PIN_INPUT, 0) /* (R26) MMC1_DAT3 */
    			J721E_IOPAD(0x258, PIN_INPUT, 0) /* (P23) MMC1_SDCD */
    			J721E_IOPAD(0x25c, PIN_INPUT, 0) /* (R28) MMC1_SDWP */
    	vdd_sd_dv_alt_pins_default: vdd_sd_dv_alt_pins_default {
    			J721E_IOPAD(0x1d8, PIN_INPUT, 7) /* (W4) SPI1_CS1.GPIO0_117 */
    	main_usbss0_pins_default: main_usbss0_pins_default {
    			J721E_IOPAD(0x290, PIN_OUTPUT, 0) /* (U6) USB0_DRVVBUS */
    			J721E_IOPAD(0x210, PIN_INPUT, 7) /* (W3) MCAN1_RX.GPIO1_3 */
    	main_usbss1_pins_default: main_usbss1_pins_default {
    			J721E_IOPAD(0x214, PIN_OUTPUT, 4) /* (V4) MCAN1_TX.USB1_DRVVBUS */
    &wkup_pmx0 {
    	sw11_button_pins_default: sw11_button_pins_default {
    			J721E_WKUP_IOPAD(0xcc, PIN_INPUT, 7) /* (G28) WKUP_GPIO0_7 */
    	mcu_fss0_ospi1_pins_default: mcu-fss0-ospi1-pins-default {
    			J721E_WKUP_IOPAD(0x34, PIN_OUTPUT, 0) /* (F22) MCU_OSPI1_CLK */
    			J721E_WKUP_IOPAD(0x50, PIN_OUTPUT, 0) /* (C22) MCU_OSPI1_CSn0 */
    			J721E_WKUP_IOPAD(0x40, PIN_INPUT, 0) /* (D22) MCU_OSPI1_D0 */
    			J721E_WKUP_IOPAD(0x44, PIN_INPUT, 0) /* (G22) MCU_OSPI1_D1 */
    			J721E_WKUP_IOPAD(0x48, PIN_INPUT, 0) /* (D23) MCU_OSPI1_D2 */
    			J721E_WKUP_IOPAD(0x4c, PIN_INPUT, 0) /* (C23) MCU_OSPI1_D3 */
    			J721E_WKUP_IOPAD(0x3c, PIN_INPUT, 0) /* (B23) MCU_OSPI1_DQS */
    			J721E_WKUP_IOPAD(0x38, PIN_INPUT, 0) /* (A23) MCU_OSPI1_LBCLKO */
    &wkup_pmx0 {
    	mcu_cpsw_pins_default: mcu_cpsw_pins_default {
    			J721E_WKUP_IOPAD(0x0058, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */
    			J721E_WKUP_IOPAD(0x005c, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */
    			J721E_WKUP_IOPAD(0x0060, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */
    			J721E_WKUP_IOPAD(0x0064, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */
    			J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */
    			J721E_WKUP_IOPAD(0x006c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */
    			J721E_WKUP_IOPAD(0x0078, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */
    			J721E_WKUP_IOPAD(0x007c, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */
    			J721E_WKUP_IOPAD(0x0080, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */
    			J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */
    			J721E_WKUP_IOPAD(0x0070, PIN_INPUT, 0) /* MCU_RGMII1_TXC */
    			J721E_WKUP_IOPAD(0x0074, PIN_INPUT, 0) /* MCU_RGMII1_RXC */
    	mcu_mdio_pins_default: mcu_mdio1_pins_default {
    			J721E_WKUP_IOPAD(0x008c, PIN_OUTPUT, 0) /* MCU_MDIO0_MDC */
    			J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* MCU_MDIO0_MDIO */
    	mcu_mcan0_pins_default: mcu-mcan0-pins-default {
    			J721E_WKUP_IOPAD(0xac, PIN_INPUT, 0) /* (C29) MCU_MCAN0_RX */
    			J721E_WKUP_IOPAD(0xa8, PIN_OUTPUT, 0) /* (D29) MCU_MCAN0_TX */
    	mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-pins-default {
    			J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 7) /* (F26) WKUP_GPIO0_0 */
    			J721E_WKUP_IOPAD(0x98, PIN_INPUT, 7) /* (E28) MCU_SPI0_D1.WKUP_GPIO0_54 */
    	mcu_mcan1_pins_default: mcu-mcan1-pins-default {
    			J721E_WKUP_IOPAD(0xc4, PIN_INPUT, 0) /* (G24) WKUP_GPIO0_5.MCU_MCAN1_RX */
    			J721E_WKUP_IOPAD(0xc0, PIN_OUTPUT, 0) /* (G25) WKUP_GPIO0_4.MCU_MCAN1_TX */
    	mcu_mcan1_gpio_pins_default: mcu-mcan1-gpio-pins-default {
    			J721E_WKUP_IOPAD(0xb8, PIN_INPUT, 7) /* (F28) WKUP_GPIO0_2 */
    &wkup_uart0 {
    	/* Wakeup UART is used by System firmware */
    	status = "disabled";
    &mcu_uart0 {
    	/* UART not brought out */
    &main_uart0 {
    	power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
    &main_uart3 {
    &main_uart5 {
    &main_uart6 {
    &main_uart7 {
    &main_uart8 {
    &main_uart9 {
    &main_gpio2 {
    &main_gpio3 {
    &main_gpio4 {
    &main_gpio5 {
    &main_gpio6 {
    &main_gpio7 {
    &wkup_gpio1 {
    &mailbox0_cluster0 {
    	interrupts = <436>;
    	mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 {
    		ti,mbox-rx = <0 0 0>;
    		ti,mbox-tx = <1 0 0>;
    	mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 {
    		ti,mbox-rx = <2 0 0>;
    		ti,mbox-tx = <3 0 0>;
    &mailbox0_cluster1 {
    	interrupts = <432>;
    	mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 {
    	mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 {
    &mailbox0_cluster2 {
    	interrupts = <428>;
    	mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 {
    	mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 {
    &mailbox0_cluster3 {
    	interrupts = <424>;
    	mbox_c66_0: mbox-c66-0 {
    	mbox_c66_1: mbox-c66-1 {
    &mailbox0_cluster4 {
    	interrupts = <420>;
    	mbox_c71_0: mbox-c71-0 {
    &mailbox0_cluster5 {
    &mailbox0_cluster6 {
    &mailbox0_cluster7 {
    &mailbox0_cluster8 {
    &mailbox0_cluster9 {
    &mailbox0_cluster10 {
    &mailbox0_cluster11 {
    &mcu_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>;
    &mcu_r5fss0_core1 {
    	mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>;
    &main_r5fss0_core0 {
    	mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>;
    &main_r5fss0_core1 {
    	mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>;
    &main_r5fss1_core0 {
    	mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core0>;
    &main_r5fss1_core1 {
    	mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core1>;
    &c66_0 {
    	mboxes = <&mailbox0_cluster3 &mbox_c66_0>;
    &c66_1 {
    	mboxes = <&mailbox0_cluster3 &mbox_c66_1>;
    &c71_0 {
    	mboxes = <&mailbox0_cluster4 &mbox_c71_0>;
    &ospi1 {
    	pinctrl-0 = <&mcu_fss0_ospi1_pins_default>;
    	flash@0{
    		compatible = "jedec,spi-nor";
    		reg = <0x0>;
    		spi-tx-bus-width = <1>;
    		spi-rx-bus-width = <4>;
    		spi-max-frequency = <40000000>;
    		cdns,tshsl-ns = <60>;
    		cdns,tsd2d-ns = <60>;
    		cdns,tchsh-ns = <60>;
    		cdns,tslch-ns = <60>;
    		cdns,read-delay = <2>;
    		#address-cells = <1>;
    		#size-cells = <1>;
    &tscadc0 {
    	adc {
    		ti,adc-channels = <0 1 2 3 4 5 6 7>;
    &tscadc1 {
    	adc {
    &dss {
    	status = "ok";
    &dss_ports {
    	#size-cells = <0>;
    	port@0 {
    		reg = <0>;
    		dpi_out_real0: endpoint {
    			remote-endpoint = <&dp_bridge_input>;
    &mhdp {
    	status = "ok";
    	pinctrl-0 = <&dp0_pins_default>;
    &dp0_ports {
    	#size-cells = <0>;
    	port@0 {
    		reg = <0>;
    		dp_bridge_input: endpoint {
    			remote-endpoint = <&dpi_out_real0>;
    	port@1 {
    		reg = <1>;
    		dp_bridge_output: endpoint {
    			remote-endpoint = <&dp_connector_in>;
    &main_i2c0 {
    	pinctrl-0 = <&main_i2c0_pins_default>;
    	clock-frequency = <400000>;
    	exp1: gpio@20 {
    		compatible = "ti,tca6416";
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	exp2: gpio@22 {
    		compatible = "ti,tca6424";
    		reg = <0x22>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		p08 {
    			/* P10 - PM_I2C_CTRL_OE */
    			gpio-hog;
    			gpios = <8 GPIO_ACTIVE_HIGH>;
    			output-high;
    			line-name = "CTRL_PM_I2C_OE";
    		p09 {
    			/* P11 - MCASP/TRACE_MUX_S0 */
    			gpio-hog;
    			gpios = <9 GPIO_ACTIVE_HIGH>;
    			output-low;
    			line-name = "MCASP/TRACE_MUX_S0";
    		p10 {
    			/* P12 - MCASP/TRACE_MUX_S1 */
    			gpio-hog;
    			gpios = <10 GPIO_ACTIVE_HIGH>;
    			output-high;
    			line-name = "MCASP/TRACE_MUX_S1";
    &main_i2c2 {
    	pinctrl-0 = <&main_i2c2_pins_default>;
    	ina226@40 {
    		compatible = "ti,ina226";
    		reg = <0x40>;
    		shunt-resistor = <10000>;
    	ina226@41 {
    		reg = <0x41>;
    	ina226@42 {
    		reg = <0x42>;
    	ina226@43 {
    		reg = <0x43>;
    	ina226@44 {
    		reg = <0x44>;
    	ina226@45 {
    		reg = <0x45>;
    		shunt-resistor = <5000>;
    	ina226@46 {
    		reg = <0x46>;
    	ina226@47 {
    		reg = <0x47>;
    	ina226@48 {
    		reg = <0x48>;
    	ina226@49 {
    		reg = <0x49>;
    	ina226@4a {
    		reg = <0x4a>;
    	ina226@4b {
    		reg = <0x4b>;
    	ina226@4c {
    		reg = <0x4c>;
    	ina226@4d {
    		reg = <0x4d>;
    	ina226@4e {
    		reg = <0x4e>;
    	ina226@4f {
    		reg = <0x4f>;
    &main_i2c1 {
    	pinctrl-0 = <&main_i2c1_pins_default>;
    	exp4: gpio@20 {
    		compatible = "ti,tca6408";
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		pinctrl-0 = <&main_i2c1_exp4_pins_default>;
    		interrupt-parent = <&main_gpio1>;
    		interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
    		interrupt-controller;
    		#interrupt-cells = <2>;
    		p0 {
    			/* P0 - DP0_PWR_SW_EN */
    			gpio-hog;
    			gpios = <0 GPIO_ACTIVE_HIGH>;
    			output-high;
    			line-name = "DP0_PWR_SW_EN";
    &k3_clks {
    	/* Confiure AUDIO_EXT_REFCLK2 pin as output */
    	pinctrl-0 = <&audi_ext_refclk2_pins_default>;
    &main_i2c3 {
    	pinctrl-0 = <&main_i2c3_pins_default>;
    	exp3: gpio@20 {
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	pcm3168a_1: audio-codec@44 {
    		compatible = "ti,pcm3168a";
    		reg = <0x44>;
    		#sound-dai-cells = <1>;
    		reset-gpios = <&exp3 0 GPIO_ACTIVE_LOW>;
    		/* C_AUDIO_REFCLK2 -> RGMII6_RXC (W26) */
    		clocks = <&k3_clks 157 371>;
    		clock-names = "scki";
    		/* HSDIV3_16FFT_MAIN_4_HSDIVOUT2_CLK -> REFCLK2 */
    		assigned-clocks = <&k3_clks 157 371>;
    		assigned-clock-parents = <&k3_clks 157 400>;
    		assigned-clock-rates = <24576000>; /* for 48KHz */
    		VDD1-supply = <&vsys_3v3>;
    		VDD2-supply = <&vsys_3v3>;
    		VCCAD1-supply = <&vsys_5v0>;
    		VCCAD2-supply = <&vsys_5v0>;
    		VCCDA1-supply = <&vsys_5v0>;
    		VCCDA2-supply = <&vsys_5v0>;
    &main_i2c6 {
    	pinctrl-0 = <&main_i2c6_pins_default>;
    	exp5: gpio@20 {
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	ov5640: camera@3c {
    		compatible = "ovti,ov5640";
    		reg = <0x3c>;
    		clocks = <&clk_ov5640_fixed>;
    		clock-names = "xclk";
    		reset-gpios = <&exp5 0 GPIO_ACTIVE_LOW>;
    		port {
    			csi2_cam0: endpoint {
    				remote-endpoint = <&csi2rx0_in_sensor>;
    				clock-lanes = <0>;
    				data-lanes = <1 2>;
    &mcasp10 {
    	#sound-dai-cells = <0>;
    	pinctrl-0 = <&mcasp10_pins_default>;
    	op-mode = <0>;          /* MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	auxclk-fs-ratio = <256>;
    	serial-dir = <	/* 0: INACTIVE, 1: TX, 2: RX */
    		1 1 1 1
    		2 2 2 0
    	tx-num-evt = <0>;
    	rx-num-evt = <0>;
    	status = "okay";
    &mcu_cpsw {
    	pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>;
    &davinci_mdio {
    	phy0: ethernet-phy@0 {
    		reg = <0>;
    		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
    		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
    &cpsw_port1 {
    	phy-mode = "rgmii-rxid";
    	phy-handle = <&phy0>;
    &main_sdhci0 {
    	/* eMMC */
    	non-removable;
    	ti,driver-strength-ohm = <50>;
    	disable-wp;
    &main_sdhci1 {
    	/* SD/MMC */
    	vmmc-supply = <&vdd_mmc1>;
    	vqmmc-supply = <&vdd_sd_dv_alt>;
    	pinctrl-0 = <&main_mmc1_pins_default>;
    	disable-wp;
    &main_sdhci2 {
    	/* Unused */
    &serdes0 {
    	serdes0_pcie_link: link@0 {
    		reg = <0>;
    		cdns,num-lanes = <1>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_PCIE>;
    		resets = <&serdes_wiz0 1>;
    &serdes1 {
    	serdes1_pcie_link: link@0 {
    		reg = <0>;
    		cdns,num-lanes = <2>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>;
    &serdes2 {
    	serdes2_pcie_link: link@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>;
    &pcie0_rc {
    	reset-gpios = <&exp1 6 GPIO_ACTIVE_HIGH>;
    	phys = <&serdes0_pcie_link>;
    	phy-names = "pcie_phy";
    	num-lanes = <1>;
    &pcie1_rc {
    	reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>;
    	phys = <&serdes1_pcie_link>;
    	num-lanes = <2>;
    &pcie2_rc {
    	reset-gpios = <&exp2 20 GPIO_ACTIVE_HIGH>;
    	phys = <&serdes2_pcie_link>;
    	num-lanes = <2>;
    &pcie0_ep {
    	num-lanes = <1>;
    &pcie1_ep {
    	num-lanes = <2>;
    &pcie2_ep {
    	num-lanes = <2>;
    &pcie3_rc {
    &pcie3_ep {
    &usb_serdes_mux {
    	idle-states = <1>, <0>; /* USB0 to SERDES3, USB1 to SERDES1 */
    &serdes_ln_ctrl {
    	idle-states = <SERDES0_LANE0_PCIE0_LANE0>, <SERDES0_LANE1_PCIE0_LANE1>,
    		      <SERDES1_LANE0_PCIE1_LANE0>, <SERDES1_LANE1_PCIE1_LANE1>,
    		      <SERDES2_LANE0_PCIE2_LANE0>, <SERDES2_LANE1_PCIE2_LANE1>,
    		      <SERDES3_LANE0_USB3_0_SWAP>, <SERDES3_LANE1_USB3_0>,
    		      <SERDES4_LANE0_EDP_LANE0>, <SERDES4_LANE1_EDP_LANE1>, <SERDES4_LANE2_EDP_LANE2>, <SERDES4_LANE3_EDP_LANE3>;
    &serdes_wiz3 {
    	typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_HIGH>;
    	typec-dir-debounce-ms = <700>;	/* TUSB321, tCCB_DEFAULT 133 ms */
    &serdes3 {
    	serdes3_usb_link: link@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_USB3>;
    		resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>;
    &usbss0 {
    	pinctrl-0 = <&main_usbss0_pins_default>;
    	ti,vbus-divider;
    &usb0 {
    	dr_mode = "otg";
    	maximum-speed = "super-speed";
    	phys = <&serdes3_usb_link>;
    	phy-names = "cdns3,usb3-phy";
    &usbss1 {
    	pinctrl-0 = <&main_usbss1_pins_default>;
    	ti,usb2-only;
    &usb1 {
    	dr_mode = "host";
    	maximum-speed = "high-speed";
    /* uart2 assigned to cpsw9g eth-switch fw running on remote CPU core */
    &main_uart2 {
    &mcu_mcan0 {
    	status = "okay";
    	pinctrl-0 = <&mcu_mcan0_pins_default &mcu_mcan0_gpio_pins_default>;
    	stb-gpios = <&wkup_gpio0 54 GPIO_ACTIVE_HIGH>;
    	en-gpios = <&wkup_gpio0 0 GPIO_ACTIVE_HIGH>;
    	can-transceiver {
    		max-bitrate = <5000000>;
    &mcu_mcan1 {
    	status = "okay";
    	pinctrl-0 = <&mcu_mcan1_pins_default &mcu_mcan1_gpio_pins_default>;
    	stb-gpios = <&wkup_gpio0 2 GPIO_ACTIVE_LOW>;
    	can-transceiver {
    &main_mcan0 {
    &main_mcan1 {
    &main_mcan2 {
    &main_mcan3 {
    &main_mcan4 {
    &main_mcan5 {
    &main_mcan6 {
    &main_mcan7 {
    &main_mcan8 {
    &main_mcan9 {
    &main_mcan10 {
    &main_mcan11 {
    &main_mcan12 {
    &main_mcan13 {
    &csi2_0 {
    	csi2rx0_in_sensor: endpoint {
    		remote-endpoint = <&csi2_cam0>;
    		bus-type = <4>; /* CSI2 DPHY. */
    		clock-lanes = <0>;
    		data-lanes = <1 2>;
    Makefile:
    5775.makefile.txt
    -include Rules.make
    MAKE_JOBS ?= 1
    linux: linux-dtbs
    		exit 1; \
    	fi
    linux_clean:
    arm-benchmarks:
    am-sysinfo:
    am-sysinfo_clean:
    am-sysinfo_install:
    oprofile-example:
    linux-dtbs:
    	done
    linux-dtbs_install:
    		exit 1; \
    	fi
    	done
    linux-dtbs_clean:
    cryptodev: linux
    cryptodev_clean:
    cryptodev_install:
    		exit 1; \
    	fi
    SYSFW_CONFIG = evm
    else
    endif
    SYSFW_MAKEARGS_gp =
    sysfw-image_clean:
    # jailhouse module
    JH_ARCH = "arm64"
    JH_PLATFORM = "k3"
    jailhouse_config:
    jailhouse_clean:
    jailhouse_install:
    oob-demo:
    oob-demo_clean:
    oob-demo_install:
    else
    endif
    u-boot-a72:
    u-boot-a72_clean:
    u-boot-r5:
    u-boot-r5_clean:
    u-boot_install:
    	cd linux/decoder; \
    	cd ../encoder; \
    	cd linux/decoder; \
    	cd ../encoder; \
    	cd linux/decoder; \
    	cd ../encoder; \
    Also i had a doubt wrto the linker file,I have replaced the
    but in env.mk what should be the linker file used.
    Attaching env,mk used while building app:
    2818.env.txt
    # are met:
    # Module paths
      PATH_SEPARATOR = ;
    else
      PATH_SEPARATOR = :
      UTILSPATH = /bin/
    endif
      # BIOS
      export bios_INCLUDE
      # XDC
      export xdc_INCLUDE
      # EDMA
      export edma_INCLUDE
      # NDK
      export ndk_INCLUDE
      # NS
      export ns_INCLUDE
    endif
    # Radar mmwavelink
    # PDK
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    endif
    export pdk_INCLUDE
    export PACKAGE_ROOT
    # Tools paths
    # Cortex-A8
    CODEGEN_PATH_A8 =
    # DSP
    MV = $(UTILSPATH)mv
      else
        MAKE = gmake
      endif
    else
      MAKE = make
    endif
    CP = $(UTILSPATH)cp
    else
    endif
        endif
      endif
        endif
      endif
    endif
        endif
      endif
        endif
      endif
        endif
      endif
        endif
        endif
        endif
      endif
        endif
        endif
      endif
    endif
        endif
        endif
      endif
        endif
        endif
        endif
      endif
        endif
        endif
        endif
      endif
        endif
        endif
        endif
      endif
        endif
        endif
        endif
      endif
        endif
        endif
        endif
      endif
        endif
        endif
      endif
        endif
        endif
      endif
        endif
        endif
        endif
      endif
        endif
        endif
        endif
      endif
        endif
        endif
        endif
      endif
        endif
      endif
        endif
      endif
      ifeq ($(SOC),k2g)
        endif
        endif
      endif
    #Used linker file
       endif
       endif
       endif
       endif
      endif
        endif
      endif
        endif
        endif
        endif
      endif
      export XDCROOT
      export XDCTOOLS
      export BIOSROOT
    endif
    export CGTOOLS
    export CGTOOLS_DSP
    export CGTOOLS_A8
    export CGTOOLS_A9
    export CGTOOLS_ARM9
    export CGTOOLS_A15
    export CGTOOLS_EVE
    Here I tried testing the app first linking
    CONFIG_BLD_LNK_r5f = /home/($user)/Desktop/SBL_boot/linker_files/linker_r5f_mcu1_0_btcm_sysbios.lds
    and then with:
    commenting the above linker_r5f_mcu1_0_btcm_sysbios.lds.
    But both didint work. Getting same error as attached above.
    Ketaki
  • Hi Ketaki,
    You do not need to change anything in env.mk, by default it will pick up linker_r5_sysbios.lds from ti/build/j721e, so just replace this file with the one shared in the zip file. That linker file contains the required changes.
    Was your UART_TestApp build successful? If yes, can you please share the readelf -l output of your generated binary?
    Also, please connect to MCU UART console to check if your UART App is booted or not.
    Parth
  • Hello Parth,
    Using the linker_r5_sysbios.lds file as suggested.
    The readelf -l output
    ketaki@ketaki-VirtualBox:~/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/binary/UART_TestApp/bin/j721e_evm$ readelf -l UART_j721e_evm_mcu1_0TestApp_release_strip.xer5f
    Elf file type is EXEC (Executable file)
    Entry point 0x41010000
    There are 14 program headers, starting at offset 192024
    Program Headers:
      Type           Offset   VirtAddr   PhysAddr   FileSiz MemSiz  Flg Align
      LOAD           0x000038 0x41010000 0x41010000 0x00040 0x00040 R   0x8
      LOAD           0x000080 0x41010100 0x41010100 0x00580 0x00580 R E 0x10
      LOAD           0x000600 0xa0400000 0xa0400000 0x19020 0x19020 R E 0x10
      LOAD           0x019620 0xa0419020 0xa0419020 0x00000 0x18e57 RW  0x8
      LOAD           0x019620 0xa0431e78 0xa0431e78 0x0e3ca 0x0e3ca R   0x8
      LOAD           0x0279ec 0xa0440244 0xa0440244 0x00000 0x00004 RW  0x4
      LOAD           0x027a00 0xa0440280 0xa0440280 0x00000 0x05880 RW  0x80
      LOAD           0x027a00 0xa0445b00 0xa0445b00 0x03b1e 0x03b1e R   0x4
      LOAD           0x02b520 0xa0449620 0xa0449620 0x00000 0x02000 RW  0x8
      LOAD           0x02b580 0xa044b680 0xa044b680 0x01700 0x01700 R   0x80
      LOAD           0x02cc80 0xa044cd80 0xa044cd80 0x00000 0x00f14 RW  0x4
      LOAD           0x02cc80 0xa044dc94 0xa044dc94 0x00770 0x00770 R   0x4
      LOAD           0x02d3f0 0xa044e404 0xa044e404 0x00000 0x001e8 RW  0x4
      LOAD           0x02d3f0 0xa044e5f0 0xa044e5f0 0x01570 0x01570 R   0x8
     Section to Segment mapping:
      Segment Sections...
       00     .vecs .vecs
       01     .init_text .text:xdc_runtime_Startup_reset__I .ipcCopyVecsToExc
       02     .text __llvm_prf_cnts
       03     .bss
       04     .const .const.devgroup.DMSC_INTERNAL
       05     .bss.devgroup.DMSC_INTERNAL
       06     .data
       07     .const.devgroup.MAIN
       08     .stack
       09     .boardcfg_data
       10     .bss.devgroup.MAIN
       11     .const.devgroup.MCU_WAKEUP
       12     .bss.devgroup.MCU_WAKEUP
       13     .cinit
    The Mcu Uart console is connected but getting the log as:
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.4(release):07.03.00.005-dirty
    NOTICE:  BL31: Built : 00:15:40, Apr 10 2021
    Trying to boot from MMC2
    Ketaki
  • Hi Ketaki,
    These logs should be coming from Main UART. Can you please check if any logs are coming on MCU UART. Just want to check if UART_TestApp is booted or not. If you are using EVM you'll need to connect to J43 header.
    Parth
  • Hello Parth,
    J43 is the microUSB header right?
    I am connecting both J43 and J44 headers and opening all 6 USB ports to see the logs.But only in one window the output is coming as above .
    Nothing coming on other ports.
    Ketaki
  • Can you try UART_TestApp binary at your end? Just point UBOOT_DM to this binary and re-build the U-boot and then copy tispl.bin, u-boot.img and tiboot3.bin and explained in the previous post and see if you are getting anything on MCU_UART.
    Parth
  • Hello Parth,
    This app is running successfully at my side.
    Can u share a zip with all the required files used, I can compare where I am going wrong.
    With Regards,
    Ketaki
  • Kataki,
    Please find the zip attached: Uart_App
    Parth
  • Hello Parth,
    The App is running .
    The things that needed changes were:
    1]Earlier I had tried UART multicore so I had changed the BOARD_UART_INSTANCE to 2U for Mcu2_0 in UART_board.h
    2]The additions in main_uart_test.c were placed incorrectly.
    After correcting the above two files, the app ran successfully.
    Thanks for your consistent help throughout the thread .
    Looking forward to explore more on tda4vm.
    Ketaki
  • Hi Ketaki,
    Glad to know that you are able to run the app successfully. Closing this thread. Let us know if you have any further queries.
    Parth
