The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
AWR2243: SOP PIN setup and SPI connection
Part Number: AWR2243
Hi TI support team,
We have a custom board of single AWR2243p chip and try to control it via SPI.
1) We happened to connect the SOP pins, [SOP2 SOP1 SOP0] = [0 0 0].
    Is it impossible to make a SPI connection in this case?
2)  Do we need to set the SOP strictly to one of 3 SOP modes; [0 0 1], [1 0 1], [0 1 1] for starting SPI communication?
3) Is the bootup flow diagram shown in Figure 3.2 of the document, "mmwave radar Interface Control Document Rev.2.13" available commonly for the above 3 modes?
4) Could you recommend some documents to understand the difference of the above 3 bootup modes?
     I would like to know what SOP setup we should select.
5) Do we need to connect the sync_out pin to sync_in pin in the single chip operation?
Your kind advice is greatly appreciated.
