PCM9211 usb eval board and Zeta SDR
Other Parts Discussed in Thread: PCM9211
There is a simple project, called ZETA SDR. Simple antenna input and RF output connected to
you mic. input on your pc. Depending on your sampling rate of your soundcard e.g 96khz.
Your bandwidth will be 96khz. Now I saw the PCM9211 USB eval board. It has a maximum
sample rate of 216khz. My question therefore is:
Can I use the PCM9211 USB eval board as a 'usb-audio-stick' and having a breader
bandwidth with 216khz (instead of the 96Khz I now have inside the pc)?
