Can the differential inputs on the TPA2016D2 be driven single ended.
I would presume to tie the negative input to ground through a 1uf capacitor as if it were driven from the negative output from a coded.
I am using a Realtek ALC268 codec, which only has single ended outputs, and I don't want an extra amplifier to convert the single ended output to differential.
