• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Applications » Motor Drivers » Motor Drivers Forum » Using VPROPI on DRV8801
Share
Motor Drivers
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
  • Raphael Gordon
    Posted by Raphael Gordon
    on Aug 02 2012 13:15 PM
    Prodigy40 points
    I am interested in steady state idle current (or lack of current) measurement for fault detection.  Also, for active current measurement I need to know the offset that corresponds to idle (i.e. zero current).  VPROPI signal seems to drift up after power up for ~1hour while driver is idling; the drift before setting is ~170mV, which quite significant in terms of current measurement in our application.  The test environment is thermally  stable.
    Is the drift a normal behavior? Is it possible/meaningful to use VPOPI output of the driver to detect idle current, i.e.winding current when ENABLE pin is low?
    Thank you,
    Raphael
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Jose Quinones
    Posted by Jose Quinones
    on Aug 02 2012 13:30 PM
    Expert7390 points
    Hi Raphael,
    When the H bridge is disabled, there should not be any current. There might be some while the current decays, shortly after disablement. But once current reaches zero, the outputs are tri stated, so there will be no current flowing through the FETs afterwards.
    This also means there is no current flowing through the SENSE resistor, so the VPROPI output is to be completely ignored. VPROPI only makes sense when there is current through the SENSE resistor. Do note that during slow decay, there is no current flow through the SENSE resistor, so VPROPI cannot offer information either.
    Hope the info helps. Best regards,
    Jose Quinones
    Report Abuse
    • Reply
  • Raphael Gordon
    on Aug 02 2012 13:49 PM
    Prodigy40 points
    Hi Jose,
    Thanks for the promp reply.
    I understand all this from the datasheet and the app notes, but it doesn't quite answer my question which has to do with a fault detection. I need to detect a fault condition when the H-bridge fails such that the motor is energized even if the ENABLE pin is low.  Not knowing all the internals of the driver, I assume that in my fault scenario there will be current flow through the SENSE resistor. If VPROPI amplifier is independent of the H-Bridge operation and  ENABLE pin state, I would think there will be current indication on VPROPI pin.  Also, there is an offset voltage at VPROPI pin at zero current that needs to be included in the math when the driver is active.  With a signinficant idle drift of VPROPI signal the current measurement acuracy degrades.
    Raphael
    Report Abuse
    • Reply
  • Jose Quinones
    on Aug 02 2012 14:36 PM
    Expert7390 points
    Hi Raphael,
    I think I understand the problem, but what I am having a hard time is accepting the possibility of the motor being energized through the device's FETs when the H bridge is disabled. But let's assume it does happen. In this case you should see VPROPI output being 5X the winding current. As you stated, the VPROPI output is independent of the H bridge. What it is not independent of is the SENSE node. If there is a voltage here, you will get 5X at the VPROPI output.
    I am not aware of an offset on the output while there is a current present, but I will check with the design team. When there is no current (H Bridge is tri stated), I would imagine the VPROPI will drift as the amplifier's inputs are floating.
    Jose Quinones
    Report Abuse
    • Reply
  • Raphael Gordon
    on Aug 02 2012 15:24 PM
    Prodigy40 points
    Hi Jose,
    In our application unless I can quantify the likelyhood of the of a failure, I need to mitigate all single point failures. As unlikely as it may sound, the failure I need to mitigate here is the H-bridge control failure.  Whether it's caused by FETS, control logic, or something else is immaterial.  The bottom line is:  does the VPROPI output produce 5X Vsense regardless of the ENABLE pin state?  If so, is the drift an expected behavior, and what is the cause?  If the amplifier is independent of the ENABLE signal, then it's input is not really floating because Rsense provides pretty strong bias to GND.
    Raphael
    Report Abuse
    • Reply
  • Jose Quinones
    on Aug 02 2012 16:13 PM
    Expert7390 points
    Hi Rapahel,
    To answer your question, yes, the VPROPI output operates regardless of what the ENABLE input is doing or whether there is current or not on the H Bridge. It is a separate block and it works standalone.
    As you specified, the SENSE resistor is basically grounded when there is no current. In this case, the amplifier is an undefined state. Design tells me there is about +/- 10 mV of bias in the inputs, so you can see as much as 50 mV bias at the output.
    Hope this answers the question, but do let me know if there is anything else I can help you with. Best regards,
    Jose Quinones
    Report Abuse
    • Reply
  • Raphael Gordon
    on Aug 03 2012 12:05 PM
    Prodigy40 points
    Hi Jose,
    Thanks for the support.  Your last response regarding VPROPI operation answered my question.  As far as the drift, please disregard that. The drift I see is not related to the driver, and it has been fixed.
    Thanks again,
    Raphael
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
