Hi, I am using a TLV320DAC32 with an external MCLK input and I want to continuously vary MCLK on the fly while it its playing audio over a wide range e.g. a 4:1 frequency range to achieve artificial Doppler Shift of the audio signal. The DAC is in I2S Master mode. I can vary MCLK over a narrow range, but not nearly up by 2 or down by half. I am using an external clock synthesizer chip to generate MCLK.
Does TI make any audio DACs that can do this?.
I just discovered your newer PCM5121/PCM5141 DACS. Could they do this? Thanks.
David Harrison
Model Sounds Inc.
www.modelsoundsinc.com
