AVSS, AGND and DGND pins are connected to 0V, and AVDD, DVDD pins are connected to 3V. Would you have any problems obtaining ECG signals?
Hi John,
You can use the ADS1298 with a 0-3V analog supply, but you would need to be sure to bring the ECG inputs up to the common mode point of the ADC to have good results. Please take a look at this application note:
http://focus.ti.com/lit/an/sbaa160a/sbaa160a.pdf
That document describes the basics of the analog front end for ECG applications and goes over both a bipolar supply implementation as well as a single ended supply.
Hi John,
Please take a look at mentioned app.note and also to my topic http://e2e.ti.com/support/data_converters/precision_data_converters/f/73/p/61014/218756.aspx
As you see, due to bipolar natue of ECG signal, if you want to power your ADS1298 from single-polar supply (as AVSS is connected to AGND), you need to apply level shifting, otherwise your signal will be cutted-off (it's negative part).
Ilia
