Hello CCS Champs,
I have a CCS4.2.x and have an XDS100V2 which I am trying to connect to EVM365.
On connecting I get below error due to trouble reading some registers with gel file/function OnTargetConnect (std gel coming with CCS)
It seems to be looking for ICE crush Jtag! Please see dump below. Kindly help!
Feroz
Console Dump
ARM9: GEL Output:
DM365EVM ARM Startup Sequence
ARM9: GEL Output: Disable IRQ/FIQ
ARM9: GEL Output: Flush Cache
ARM9: GEL Output: Disable MMU
ARM9: GEL Output: Setup Power Modules (All on)...ARM9: GEL Output: [Done]
ARM9: GEL Output: Setup PinMux...ARM9: GEL Output: [Done]
ARM9: GEL Output: Setup PLL0...ARM9: GEL: Error while executing OnTargetConnect(): Target failed to write memory at 0x01C40900.
ARM9: Trouble Reading Register REG_END: (Error -1060 @ 0x2E18) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
ARM9: Trouble getting target property: (Error -1060 @ 0x2E18) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
ARM9: Warning: (Error -1060 @ 0x2E18) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
ARM9: Trouble Reading Memory Block at 0x81098d34 on Page 0 of Length 0x21: (Error -1060 @ 0x2E18) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
ARM9: Error: (Error -1029 @ 0x2B5F) Invalid data read from ICECrusher register. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
