• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » CCS4 gmake error: missing separator
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • CCS4 gmake error: missing separator
    This question is answered
    Brighton Feng
    Posted by Brighton Feng
    on May 09 2011 22:23 PM
    Prodigy690 points
    In one of my CCS4 projects, I always encounter following error when I “Build Active Project” (I think this is incremental build); but this issue does not happen if I “Rebuild Active Project” (I think this is rebuild all).
    My CCS version is 4.2.2.00033. Do you know this issue? Or do you have any suggestion?
    Thank you very much!
    C:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake -k all
    src/KeyStone_Multicore_Navigator_drv.pp:61: *** missing separator.  Stop.
    Build complete for project Multicore_Navigator
    Best Regards, Brighton Feng ( 冯华亮 ) Communication Infrastructure Field Application Engineer Texas Instruments Shenzhen Branch Tel: 86-755-2600 7838 Fax: 86-755-2693 5678
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • desouza
      Posted by desouza
      on May 09 2011 23:11 PM
      Guru55990 points
      Brighton,
      This issue is reported in some references in the Eclipse website (here and here). Check line 61 of the file <src/Keystone_Multicore_Navigator_drv.pp>. Usually .pp files are autogenerated, but in this case it seems it may be a leftover from a previous build or compiler version (.pp files can also be output files generated by the compiler's preprocessor). Try to remove it from the project directories or rename it to a different extension and do a clean rebuild.
      You can also try to delete the directory Debug (or Release, depending on the Active Build Configuration you are using) and do a build to see if it works. Although the Rebuild Active Project erases several output files, some of them still remain in the output directory and may be causing such strange behaviour.
      Hope this helps,
      Rafael
      If my reply answers your question please click on the green button "Verify Answer".
      Search the wiki or go to useful pages for SDOWP, CGT, BIOS, CCSv3, CCSv4, CCSv5
      Report Abuse
      • Reply
    • Brighton Feng
      on May 10 2011 00:07 AM
      Prodigy690 points
      KeyStone_Multicore_Navigator_drv.zip
      Hi, Rafael,
      I tried to delete the file or directory, but the error still happened.
      Attached please find the <src/Keystone_Multicore_Navigator_drv.pp> file, could you help analyze it?
      Brighton
      Report Abuse
      • Reply
    • Brighton Feng
      on May 13 2011 22:59 PM
      Verified Answer
      Verified by Brighton Feng
      Prodigy690 points
      I found it is caused by following code, please note the space in <   >
      #include <cslr_cppidma_rx_flow_config.h    >
      After I remove the space as below, the problem does not happen again.
      #include <cslr_cppidma_rx_flow_config.h>
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
