I have a situation where CCS fails after hitting a breakpoint when remotely debugging a threaded application using gdbserver over tcp. When it happens, it fails to display the current thread function and current line in code. GDB output shows error ("Thread ID 2 has terminated.", see attached gdb trace log).
When paused, CCS has that weird behavior : It scans threads ID starting from 1 to infinite! The error seems to be related to this behavior... Is it normal ?
See the trace log:
789,332 1-environment-cd /home/user/VBoxShared/ThreadTest
789,335 1^done
789,340 (gdb)
789,345 2-gdb-set breakpoint pending on
789,346 2^done
789,346 (gdb)
789,352 3source /home/user/workspace_v5_1/.gdbinit
789,354 &"source /home/user/workspace_v5_1/.gdbinit\n"
789,356 3^done
789,356 (gdb)
789,361 4-gdb-set auto-solib-add on
789,362 4^done
789,362 (gdb)
789,387 5-file-exec-and-symbols /home/user/targetfs/home/root/main
789,399 5^done
789,399 (gdb)
789,408 6-target-select remote 192.168.0.102:4444
789,454 =thread-created,id="1"
789,514 =library-loaded,id="/lib/ld-linux.so.3",target-name="/lib/ld-linux.so.3",host-name="/home/us\
er/targetfs/lib/ld-linux.so.3",low-address="0x4003c7b0",high-address="0x40054460",symbols-loaded="0"\
789,555 *stopped,frame={addr="0x4003c7b0",func="??",args=[],from="/home/user/targetfs/lib/ld-linux.s\
o.3"},thread-id="1",stopped-threads="all"
789,564 6^connected
789,564 (gdb)
789,593 7-break-insert -f /home/user/VBoxShared/ThreadTest/main.c:7
789,622 7^done,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x00008488",func="ma\
in",file="main.c",fullname="/home/user/VBoxShared/ThreadTest/main.c",line="7",times="0",original-loc\
ation="/home/user/VBoxShared/ThreadTest/main.c:7"}
789,622 (gdb)
789,811 8-break-insert -t -f main
789,818 8^done,bkpt={number="2",type="breakpoint",disp="del",enabled="y",addr="0x0000847c",func="mai\
n",file="main.c",fullname="/home/user/VBoxShared/ThreadTest/main.c",line="5",times="0",original-loca\
tion="main"}
789,818 (gdb)
789,848 9-exec-continue
789,864 9^running
789,864 *running,thread-id="all"
789,864 (gdb)
790,013 =library-loaded,id="/lib/libgcc_s.so.1",target-name="/lib/libgcc_s.so.1",host-name="/home/us\
er/targetfs/lib/libgcc_s.so.1",low-address="0x400b0778",high-address="0x400b9190",symbols-loaded="0"\
790,016 =library-loaded,id="/lib/libpthread.so.0",target-name="/lib/libpthread.so.0",host-name="/hom\
e/user/targetfs/lib/libpthread.so.0",low-address="0x400c5ca0",high-address="0x400d4438",symbols-load\
ed="0"
790,022 =library-loaded,id="/lib/libc.so.6",target-name="/lib/libc.so.6",host-name="/home/user/targe\
tfs/lib/libc.so.6",low-address="0x400f6d60",high-address="0x401de100",symbols-loaded="0"
790,254 ~"[Switching to Thread 979]\n"
790,275 *stopped,reason="breakpoint-hit",disp="del",bkptno="2",frame={addr="0x0000847c",func="main",\
args=[{name="argc",value="1"},{name="argv",value="0xbeab7e24"}],file="main.c",fullname="/home/user/V\
BoxShared/ThreadTest/main.c",line="5"},thread-id="1",stopped-threads="all"
790,275 (gdb)
791,693 10-thread-list-ids
791,696 =thread-exited,id="1"
791,698 =thread-created,id="2"
791,698 ~"[New Thread 979]\n"
791,701 10^done,thread-ids={thread-id="2"},current-thread-id="2",number-of-threads="1"
791,701 (gdb)
791,711 11-thread-select 2
791,711 12-stack-info-depth 11
791,713 &"Thread ID 2 has terminated.\n"
791,714 11^error,msg="Thread ID 2 has terminated."
791,715 (gdb)
791,724 12^done,depth="1"
791,724 (gdb)
791,726 13-stack-list-frames
791,733 13^done,stack=[frame={level="0",addr="0x0000847c",func="main",file="main.c",fullname="/home/\
user/VBoxShared/ThreadTest/main.c",line="5"}]
791,733 (gdb)
792,178 14info threads
792,180 &"info threads\n"
792,182 =thread-exited,id="2"
792,186 =thread-created,id="3"
792,186 ~"[New Thread 979]\n"
792,201 ~"* 3 Thread 979 main (argc=1, argv=0xbeab7e24) at main.c:5\n"
792,202 14^done
792,202 (gdb)
792,657 15-thread-list-ids
792,660 =thread-exited,id="3"
792,662 =thread-created,id="4"
792,662 ~"[New Thread 979]\n"
792,665 15^done,thread-ids={thread-id="4"},current-thread-id="4",number-of-threads="1"
792,665 (gdb)
792,784 16info threads
792,786 &"info threads\n"
792,788 =thread-exited,id="4"
792,790 =thread-created,id="5"
792,792 ~"[New Thread 979]\n"
792,809 ~"* 5 Thread 979 main (argc=1, argv=0xbeab7e24) at main.c:5\n"
792,810 16^done
792,810 (gdb)
792,915 17-thread-select 4
792,916 18-stack-list-frames 0 0
792,917 &"Thread ID 4 not known.\n"
792,918 17^error,msg="Thread ID 4 not known."
792,918 (gdb)
792,921 18^done,stack=[frame={level="0",addr="0x0000847c",func="main",file="main.c",fullname="/home/\
792,921 (gdb)
792,929 19-stack-list-frames
792,934 19^done,stack=[frame={level="0",addr="0x0000847c",func="main",file="main.c",fullname="/home/\
792,934 (gdb)
792,944 20-stack-info-depth 11
792,945 20^done,depth="1"
792,945 (gdb)
793,446 21-thread-list-ids
793,451 =thread-exited,id="5"
793,455 =thread-created,id="6"
793,456 ~"[New Thread 979]\n"
793,459 21^done,thread-ids={thread-id="6"},current-thread-id="6",number-of-threads="1"
793,459 (gdb)
793,463 22-thread-list-ids
793,466 =thread-exited,id="6"
793,469 =thread-created,id="7"
793,470 ~"[New Thread 979]\n"
793,471 22^done,thread-ids={thread-id="7"},current-thread-id="7",number-of-threads="1"
793,471 (gdb)
793,504 23-thread-select 7
793,504 24-stack-info-depth 11
793,508 &"Thread ID 7 has terminated.\n"
793,508 23^error,msg="Thread ID 7 has terminated."
793,508 (gdb)
793,521 24^done,depth="1"
793,521 (gdb)
793,542 25-stack-list-frames
793,546 25^done,stack=[frame={level="0",addr="0x0000847c",func="main",file="main.c",fullname="/home/\
793,547 (gdb)
793,570 26info threads
793,573 &"info threads\n"
793,574 =thread-exited,id="7"
793,577 =thread-created,id="8"
793,584 ~"[New Thread 979]\n"
793,593 ~"* 8 Thread 979 main (argc=1, argv=0xbeab7e24) at main.c:5\n"
793,594 26^done
793,594 (gdb)
794,030 27-thread-list-ids
794,033 =thread-exited,id="8"
794,036 =thread-created,id="9"
794,037 ~"[New Thread 979]\n"
794,040 27^done,thread-ids={thread-id="9"},current-thread-id="9",number-of-threads="1"
794,040 (gdb)
794,075 28-thread-list-ids
794,078 =thread-exited,id="9"
794,084 =thread-created,id="10"
794,084 ~"[New Thread 979]\n"
794,087 28^done,thread-ids={thread-id="10"},current-thread-id="10",number-of-threads="1"
794,087 (gdb)
794,326 29-thread-list-ids
794,329 =thread-exited,id="10"
794,332 =thread-created,id="11"
794,332 ~"[New Thread 979]\n"
794,334 29^done,thread-ids={thread-id="11"},current-thread-id="11",number-of-threads="1"
794,334 (gdb)
794,743 30-thread-list-ids
794,746 =thread-exited,id="11"
794,749 =thread-created,id="12"
794,749 ~"[New Thread 979]\n"
794,751 30^done,thread-ids={thread-id="12"},current-thread-id="12",number-of-threads="1"
794,758 (gdb)
794,863 31-thread-list-ids
794,865 =thread-exited,id="12"
794,868 =thread-created,id="13"
794,869 ~"[New Thread 979]\n"
794,872 31^done,thread-ids={thread-id="13"},current-thread-id="13",number-of-threads="1"
794,872 (gdb)
795,036 32-thread-list-ids
795,038 =thread-exited,id="13"
795,042 =thread-created,id="14"
795,042 ~"[New Thread 979]\n"
795,044 32^done,thread-ids={thread-id="14"},current-thread-id="14",number-of-threads="1"
795,046 (gdb)
795,164 33-thread-list-ids
795,166 =thread-exited,id="14"
795,168 =thread-created,id="15"
795,171 ~"[New Thread 979]\n"
795,176 33^done,thread-ids={thread-id="15"},current-thread-id="15",number-of-threads="1"
795,176 (gdb)
795,297 34-thread-list-ids
795,299 =thread-exited,id="15"
795,303 =thread-created,id="16"
795,304 ~"[New Thread 979]\n"
795,309 34^done,thread-ids={thread-id="16"},current-thread-id="16",number-of-threads="1"
795,309 (gdb)
795,432 35-thread-list-ids
795,435 =thread-exited,id="16"
795,437 =thread-created,id="17"
795,438 ~"[New Thread 979]\n"
795,442 35^done,thread-ids={thread-id="17"},current-thread-id="17",number-of-threads="1"
795,442 (gdb)
795,567 36-thread-list-ids
795,569 =thread-exited,id="17"
795,572 =thread-created,id="18"
795,572 ~"[New Thread 979]\n"
795,574 36^done,thread-ids={thread-id="18"},current-thread-id="18",number-of-threads="1"
795,575 (gdb)
795,828 37-thread-list-ids
795,831 =thread-exited,id="18"
795,833 =thread-created,id="19"
795,836 ~"[New Thread 979]\n"
795,838 37^done,thread-ids={thread-id="19"},current-thread-id="19",number-of-threads="1"
795,838 (gdb)
795,984 38-exec-continue
795,991 38^running
795,991 *running,thread-id="all"
795,991 (gdb)
800,764 *stopped,reason="breakpoint-hit",disp="keep",bkptno="1",frame={addr="0x00008488",func="main"\
,args=[{name="argc",value="1"},{name="argv",value="0xbeab7e24"}],file="main.c",fullname="/home/user/\
VBoxShared/ThreadTest/main.c",line="7"},thread-id="19",stopped-threads="all"
800,771 (gdb)
800,794 39-thread-list-ids
800,796 =thread-exited,id="19"
800,800 =thread-created,id="20"
800,800 ~"[New Thread 979]\n"
800,806 39^done,thread-ids={thread-id="20"},current-thread-id="20",number-of-threads="1"
800,806 (gdb)
800,976 40-thread-list-ids
800,979 =thread-exited,id="20"
800,986 =thread-created,id="21"
800,986 ~"[New Thread 979]\n"
800,986 40^done,thread-ids={thread-id="21"},current-thread-id="21",number-of-threads="1"
800,986 (gdb)
801,280 41-thread-list-ids
801,283 =thread-exited,id="21"
801,286 =thread-created,id="22"
801,287 ~"[New Thread 979]\n"
801,290 41^done,thread-ids={thread-id="22"},current-thread-id="22",number-of-threads="1"
801,290 (gdb)
801,446 42-thread-list-ids
801,449 =thread-exited,id="22"
801,453 =thread-created,id="23"
801,453 ~"[New Thread 979]\n"
801,454 42^done,thread-ids={thread-id="23"},current-thread-id="23",number-of-threads="1"
801,455 (gdb)
801,557 43-thread-list-ids
801,560 =thread-exited,id="23"
801,562 =thread-created,id="24"
801,562 ~"[New Thread 979]\n"
801,564 43^done,thread-ids={thread-id="24"},current-thread-id="24",number-of-threads="1"
801,564 (gdb)
801,690 44-thread-list-ids
801,693 =thread-exited,id="24"
801,697 =thread-created,id="25"
801,701 ~"[New Thread 979]\n"
801,703 44^done,thread-ids={thread-id="25"},current-thread-id="25",number-of-threads="1"
801,707 (gdb)
801,895 45-thread-list-ids
801,899 =thread-exited,id="25"
801,904 =thread-created,id="26"
801,907 ~"[New Thread 979]\n"
801,911 45^done,thread-ids={thread-id="26"},current-thread-id="26",number-of-threads="1"
801,911 (gdb)
802,171 46-thread-list-ids
802,174 =thread-exited,id="26"
802,177 =thread-created,id="27"
802,178 ~"[New Thread 979]\n"
802,181 46^done,thread-ids={thread-id="27"},current-thread-id="27",number-of-threads="1"
802,181 (gdb)
802,358 47-thread-list-ids
802,361 =thread-exited,id="27"
802,363 =thread-created,id="28"
802,364 ~"[New Thread 979]\n"
802,366 47^done,thread-ids={thread-id="28"},current-thread-id="28",number-of-threads="1"
802,366 (gdb)
803,116 48-thread-list-ids
803,119 =thread-exited,id="28"
803,121 =thread-created,id="29"
803,121 ~"[New Thread 979]\n"
803,123 48^done,thread-ids={thread-id="29"},current-thread-id="29",number-of-threads="1"
803,123 (gdb)
803,490 49-thread-list-ids
803,492 =thread-exited,id="29"
803,496 =thread-created,id="30"
803,497 ~"[New Thread 979]\n"
803,500 49^done,thread-ids={thread-id="30"},current-thread-id="30",number-of-threads="1"
803,500 (gdb)
803,622 50-thread-list-ids
803,624 =thread-exited,id="30"
803,628 =thread-created,id="31"
803,628 ~"[New Thread 979]\n"
803,630 50^done,thread-ids={thread-id="31"},current-thread-id="31",number-of-threads="1"
803,630 (gdb)
803,777 51-thread-list-ids
803,780 =thread-exited,id="31"
803,782 =thread-created,id="32"
803,783 ~"[New Thread 979]\n"
803,786 51^done,thread-ids={thread-id="32"},current-thread-id="32",number-of-threads="1"
803,787 (gdb)
804,023 52-thread-list-ids
804,025 =thread-exited,id="32"
804,029 =thread-created,id="33"
804,030 ~"[New Thread 979]\n"
804,032 52^done,thread-ids={thread-id="33"},current-thread-id="33",number-of-threads="1"
804,032 (gdb)
804,233 53-thread-list-ids
804,236 =thread-exited,id="33"
804,239 =thread-created,id="34"
804,239 ~"[New Thread 979]\n"
804,241 53^done,thread-ids={thread-id="34"},current-thread-id="34",number-of-threads="1"
804,241 (gdb)
804,392 54-thread-list-ids
804,394 =thread-exited,id="34"
804,397 =thread-created,id="35"
804,398 ~"[New Thread 979]\n"
804,403 54^done,thread-ids={thread-id="35"},current-thread-id="35",number-of-threads="1"
804,405 (gdb)
804,543 55-thread-list-ids
804,546 =thread-exited,id="35"
804,552 =thread-created,id="36"
804,553 ~"[New Thread 979]\n"
804,555 55^done,thread-ids={thread-id="36"},current-thread-id="36",number-of-threads="1"
804,556 (gdb)
804,698 =thread-exited,id="36"
804,698 =thread-created,id="37"
804,698 ~"[New Thread 979]\n"
804,698 56^done,thread-ids={thread-id="37"},current-thread-id="37",number-of-threads="1"
804,698 (gdb)
804,672 56-thread-list-ids
804,920 57-thread-list-ids
804,923 =thread-exited,id="37"
804,927 =thread-created,id="38"
804,928 ~"[New Thread 979]\n"
804,931 57^done,thread-ids={thread-id="38"},current-thread-id="38",number-of-threads="1"
804,932 (gdb)
805,136 58-thread-list-ids
805,140 =thread-exited,id="38"
805,144 =thread-created,id="39"
805,146 ~"[New Thread 979]\n"
805,150 58^done,thread-ids={thread-id="39"},current-thread-id="39",number-of-threads="1"
805,150 (gdb)
805,649 59-thread-list-ids
805,652 =thread-exited,id="39"
805,657 =thread-created,id="40"
805,658 ~"[New Thread 979]\n"
805,662 59^done,thread-ids={thread-id="40"},current-thread-id="40",number-of-threads="1"
805,662 (gdb)
805,775 60-thread-list-ids
805,777 =thread-exited,id="40"
805,782 =thread-created,id="41"
805,783 ~"[New Thread 979]\n"
805,785 60^done,thread-ids={thread-id="41"},current-thread-id="41",number-of-threads="1"
805,787 (gdb)
805,906 61-thread-list-ids
805,908 =thread-exited,id="41"
805,911 =thread-created,id="42"
805,911 ~"[New Thread 979]\n"
805,913 61^done,thread-ids={thread-id="42"},current-thread-id="42",number-of-threads="1"
805,913 (gdb)
806,044 62-thread-list-ids
806,046 =thread-exited,id="42"
806,048 =thread-created,id="43"
806,048 ~"[New Thread 979]\n"
806,050 62^done,thread-ids={thread-id="43"},current-thread-id="43",number-of-threads="1"
806,050 (gdb)
806,184 63-thread-list-ids
806,186 =thread-exited,id="43"
806,188 =thread-created,id="44"
806,190 ~"[New Thread 979]\n"
806,193 63^done,thread-ids={thread-id="44"},current-thread-id="44",number-of-threads="1"
806,198 (gdb)
806,324 64-thread-list-ids
806,326 =thread-exited,id="44"
806,330 =thread-created,id="45"
806,331 ~"[New Thread 979]\n"
806,334 64^done,thread-ids={thread-id="45"},current-thread-id="45",number-of-threads="1"
806,335 (gdb)
806,461 65-thread-list-ids
806,464 =thread-exited,id="45"
806,466 =thread-created,id="46"
806,466 ~"[New Thread 979]\n"
806,468 65^done,thread-ids={thread-id="46"},current-thread-id="46",number-of-threads="1"
806,468 (gdb)
806,546 66-exec-continue
806,551 66^running
806,551 *running,thread-id="46"
806,551 (gdb)
806,551 &"warning: Invalid remote reply: \n"
[...] 790,275 *stopped,reason="breakpoint-hit",disp="del",bkptno="2",frame={addr="0x0000847c",func="main",\ [...] |
Here is my main.c:
#include <stdio.h> |
and my makefile:
| export EZSDK=/home/user/ti-ezsdk_dm816x-evm_5_02_02_60/ include ${EZSDK}/Rules.make all: $(CSTOOL_PREFIX)gcc -pthread -g -o main main.c cp main /home/user/targetfs/home/root/ |
