• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » System Analyzer seems unreliable
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • System Analyzer seems unreliable
    This question is answered
    David Aldrich
    Posted by David Aldrich
    on Feb 22 2012 05:53 AM
    Expert1320 points
    Hi
    I am running CCS 5.1.0.0900 and MCSDK 1.0.0.15 on a TMDXEVM6618LXE board.  I am trying to get System Analyzer to work reliably.  I have successfully run the CCS System Analyzer tutorials 1 and 3A. I have also succeeded in displaying CPU Load graphically for two cores with my application.  However, sometimes it works and sometimes it doesn't (i.e. no events are logged and no load graphs appear), for both the tutorials and my app.
    I have read mention on these forums that there can be a problem if MCSDK is installed after CCS 5.1.  Is this true?
    Would there be any merit in me reinstalling CCS 5.1?
    If yes, what should I do precisiely (e.g. do I have to uninstall) ?
    Best regards
    David
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Ki-Soo Lee
      Posted by Ki-Soo Lee
      on Feb 22 2012 09:33 AM
      Verified Answer
      Verified by David Aldrich
      Guru119215 points
      Hi David,
      What OS are you running? I have heard of some cases where people with Windows 7 ran into similar issues. But it was never confirmed if Windows 7 was the culprit.
      Personally, I've found that every so often I have to restart CCS to get data displayed.
      ki
      Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
      Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
      Having CCSv5 problems? Check out the CCSv5 Troubleshooting Guide
      Click here to track an issue. Enter your bug id in the "Find Record ID" box
      Report Abuse
      • Reply
    • David Aldrich
      on Feb 22 2012 09:36 AM
      Expert1320 points
      Hi Ki
      I am running Windows 7.
      I will try restarting CCS as you suggest.
      David
      Report Abuse
      • Reply
    • Imtaz Ali
      Posted by Imtaz Ali
      on Feb 23 2012 16:11 PM
      Expert3525 points
      David,
      This should not be related to the MCSDK installation. As Ki mentioned, there is a know issue with System Analyzer initialization which can result in no data showing up. When this problem occurs the only way to recover is to restart CCS.
      Let me know if you're ok installing a patch and I'll look at posting one up.
      Imtaz.
      Report Abuse
      • Reply
    • David Aldrich
      on Feb 24 2012 05:50 AM
      Expert1320 points
      Ali
      Thanks, I am ok with installing a patch. Please make it available.
      Is this the same as bug SDSCM00042361, mentioned in the CCS 5.1.1 release notes?
      David
      Report Abuse
      • Reply
    • Imtaz Ali
      Posted by Imtaz Ali
      on Feb 24 2012 09:44 AM
      Expert3525 points
      David,
      This issue is tracked as SDSCM00043256 ... the fix will be in CCS5.2 (not 5.1.1). We're in the process of creating the patch. Hopefully we can release later today (ET) if not then Monday.
      Imtaz.
      Report Abuse
      • Reply
    • Imtaz Ali
      Posted by Imtaz Ali
      on Feb 28 2012 08:17 AM
      Expert3525 points
      David,
      I posted the DVT (Data Analysis and Visualization Technology) patch up which contain a fix for the intermittent problem in System Analyzer. See instruction below to install. Please let us know if this resolves your problem.
      Steps to install DVT patch in CCS5.1.x (This is not compatible with CCS 5.0.x):
      • From CCS main menu: select Help->Install New Software
      • In Install dialog: select “Add…” to add the DVT (Data Analysis and Visualization Technology) update site
      • In the Add Repositorydialog:
        • Specify a Name: e.g DVT_for_CCS5.1
        • Specify the DVT update site: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/DVT_for_CCS5.1
        • Select OK
        • In Install dialog select DVT. Then select Next to install
      Imtaz.
      Report Abuse
      • Reply
    • David Aldrich92784
      Posted by David Aldrich92784
      on Mar 01 2012 03:38 AM
      Expert1345 points
      Hi Ali
      Thanks for the patch. I have installed it and it seems to be working well..
      Best regards
      David
      Report Abuse
      • Reply
    • Lucifar He
      Posted by Lucifar He
      on Mar 15 2012 22:00 PM
      Expert1345 points
      Thanks ali,
      I will try.
      Lucifar
      Report Abuse
      • Reply
    • Patrick Klok
      Posted by Patrick Klok
      on Aug 03 2012 02:09 AM
      Prodigy50 points
      Does this patch also apply for CCS5.2
      Report Abuse
      • Reply
    • Imtaz Ali
      Posted by Imtaz Ali
      on Aug 03 2012 09:44 AM
      Expert3525 points
      Patrick,
      This patch should not be required for CCS5.2. Are you running into issues on 5.2?
      Imtaz.
      Report Abuse
      • Reply
    • Patrick Klok
      on Aug 06 2012 07:59 AM
      Prodigy50 points
      Yes I do,
      For some reason there was nothing collected inside the system analyzer's live view, I have done several attempts and scenario's (simulated, jtag and a lot of the given examples) with no success, not even with the System Analyzer provided examples and tutorials.
      Therfore I have upgraded to CCS Version: 5.2.1.00018 and the latest DVT and system analyzer, and it works :-), most likely something.
      I am able to collect and see the data in combination with the examples.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
