• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » C28xx: Trouble Setting Breakpoint with the Action "Finish Auto Run"
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • C28xx: Trouble Setting Breakpoint with the Action "Finish Auto Run"
    • Adjeiinfo
      Posted by Adjeiinfo
      on Mar 27 2012 00:20 AM
      Prodigy200 points
      I migrated my project from ccs3.3 to ccs5.1. After building I tried to load into the ram of my dsp but got the following arror:
      C28xx: Trouble Setting Breakpoint with the Action "Finish Auto Run" at 0x20c223: Error 0x00000008/-1066 Error during: Break Point, Cannot set/verify breakpoint at 0x0020C223
      In our project we use a customized command file. Please if you have some hints to solve this issue, you are welcome.
      My DSP is F28335 and I use the disgital spectrum xds510 usb emulator
      Keli
      ccsv5.1 code composer
      Report Abuse
      • Reply
      You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    • Ki-Soo Lee
      Posted by Ki-Soo Lee
      on Mar 27 2012 09:42 AM
      Guru116865 points
      Hello Keli,
      CCSv5 will try to auto-run to main on program load. It will try to set a breakpoint at main and then run to it. The error above looks like it failed to set this breakpoint. Do you have a 'main' in your application? If you do, can you manually set a breakpoint there?
      ki
      Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
      Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
      Having CCSv5 problems? Check out the CCSv5 Troubleshooting Guide
      Click here to track an issue. Enter your bug id in the "Find Record ID" box
      Report Abuse
      • Reply
    • Adjeiinfo
      Posted by Adjeiinfo
      on Mar 28 2012 03:36 AM
      Prodigy200 points
      Thank you for your answer. Yes there is a main and the address given is the entry point of the program.
      The  break point set manually does not work.
      Today when I tried to load I got the following error
      "C28xx: Trouble Setting Breakpoint with the Action "Finish Auto Run" at 0x20e2c5: Error 0x00000008/-1066 Error during: Break Point,
      Cannot set/verify breakpoint at 0x0020E2C5 "
      The desassembly code gives something as following
              main:
      20e2c5: 0000 ITRAP0
      20e2c6: 0000 ITRAP0
      20e2c7: 0000 ITRAP0
      41 asm(" ESTOP1");
      20e2c8: 0000 ITRAP0
      44 InitSysCtrl(); //c.f. DSP2833x_SysCtrl.c
      20e2c9: 0000 ITRAP0
      20e2ca: 0000 ITRAP0
      20e2cb: 0000 ITRAP0
      47 InitXintf();
      20e2cc: 0000 ITRAP0
      20e2cd: 0000 ITRAP0
      51 EALLOW;
      20e2ce: 0000 ITRAP0
      I dont know if there is something wrong.
      I will really appreciate your help.
      Keli
      ccsv5.1
      Report Abuse
      • Reply
    • N Luna
      Posted by N Luna
      on Aug 03 2012 10:30 AM
      Intellectual575 points
      Hello Keli,
      Did you solve your problem ?
      I got the same problem and I would like to know if you have any solution for this issue.
      Nicolas
      Report Abuse
      • Reply
    • Adjeiinfo
      Posted by Adjeiinfo
      on Aug 05 2012 19:22 PM
      Prodigy200 points
      Luna,
      Finally I could sove my problem.
      The gel file coming with the CCS5 for my DSP generation (F28335) disables by default the XINTF. Mine is locate in
      ccs5_2\ccsv5\ccs_base\emulation\gel
      You can edit and uncomment the following line
      OnReset(int nErrorCode)
      XINTF_Enable(); /* Uncomment to enable XINTF on Reset */
      Hope it will work with you too
      CCS5
      Report Abuse
      • Reply
    • N Luna
      Posted by N Luna
      on Aug 06 2012 08:02 AM
      Thanks Adjeiinfo !
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
