CCSv5.2.0 Install Error in action ExecuteAction - error "not well-formed (invalid token)"
Hey there,
I tried to install CCS v5.2.0 today, and always got the error listed here. Do you have any idea, why this happens? I would be glad about any helpful comments.. :)
Thanks in advance!
Jördis
Error in action ExecuteScript
error "not well-formed (invalid token)" at line 4 character 99
    while executing
"::InstallJammer::actions::$component $this"
    while executing
"$obj execute"
    (procedure "::InstallJammer::ExecuteActions" line 69)
    invoked from within
"::InstallJammer::ExecuteActions $action -parent $id -conditions $eval"
    (procedure "::InstallJammer::actions::ExecuteAction" line 35)
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
"::InstallJammer::ExecuteActions $id -when $when"
    (procedure "::InstallJammer::RaiseEventHandler" line 93)
    invoked from within
"::InstallJammer::RaiseEventHandler  .wizard"
    (command bound to event)
  • Hi
    could you please send us the contents of your installjammer registry directory?  (found under program files or program files (x86))
    Could you please check
    - redownload in case of corruption
    - use the full installer
    - unzip before installing
    - do not use the program files directory or any directory with any accented or special characters
    - you have microsoft redistributable c 2005 installed.  I should have come with the installer, search vcredis*.exe
    Please keep us informed.
    Lisa
  • Hi Lisa,
    thanks for your answer!
    I think the directory should be ok, and i unziped before installing.. I just tried the microsoft redistributable as well, which had no effect.
    The contents of my installjammer registry directory should be attached !
    I'm downloading the full installer now, which will take some time. I'll continue tomorrow and keep you informed, thanks so far!
    Jordis
    0576.ccsv5.zip
  • Hi Joerdis,
    you seem to be using directories with accented characters .... this is probably the issue.  Your name has an o-umlaut ... please try a directory with no accented or special character for the zip file and the installation (both).
    Eg unzip and install to c:\myccs or c:\ti
    Lisa
  • Hi Lisa!
    You are so right, that was exactly the problem! How stupid, I should have known..
    Thank you so much, looking foreward to starting programming my msp430 tomorrow :) THANKS!
    Joerdis with the o-umlaut..
  • Hi Joerdis,
    my pleasure ... all the best with CCS and the MSP.
    Lisa
  • Now I got the same problem with web installer (CCSv6 beta 2). I have noted that the temp folder must not contain the problem symbols too. I mean the path c:/Users/<UserName>/AppData/Local/Temp. In ohter words UserName must contain the latin  symbols only.
    tnx for your advice.
    Slava V.
