Error when not building from clean
We are currently using  Code Composer Version: 5.2.1.00018 to build a StarterWare project that uses a lot of file that are 'linked' into the project. When the project is build cleanly, it will build fully without errors. If I then modify one file and try to rebuild I get the following error:
Errors occurred during the build.
Errors running builder 'CDT Builder' on project 'concrete1'.
Generated resource conflict:
two resources of the same name: /concrete1/Debug/uartStdio.obj
generated by different tools
tool1: ARM Compiler
tool2: ARM Compiler
tool1: ARM Compiler
tool2: ARM Compiler
tool1: ARM Compiler
tool2: ARM Compiler
tool1: ARM Compiler
tool2: ARM Compiler
I can't see anything wrong with the uartStdio.c file. Where could we look to figure out what Code Composer is having issues with?
     John Conover
  • When looking at the error log we still can't see what to try.
    Thanks...
    !STACK 0 java.lang.IllegalArgumentException: Generated resource conflict: two resources of the same name: /concrete1/Debug/uartStdio.obj generated by different tools tool1: ARM Compiler tool2: ARM Compiler at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildResource.addToArg(BuildResource.java:154) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildIOType.addResource(BuildIOType.java:64) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.addOutputs(BuildDescription.java:1031) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.calculateOutputs(BuildDescription.java:1347) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.composeOutputs(BuildDescription.java:644) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.access$1(BuildDescription.java:537) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription$RcVisitor.doVisitFile(BuildDescription.java:252) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription$RcVisitor.visit(BuildDescription.java:173) at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:65) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:75) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.initDescription(BuildDescription.java:741) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.init(BuildDescription.java:810) at org.eclipse.cdt.managedbuilder.internal.buildmodel.DefaultBuildDescriptionFactory.createBuildDescription(DefaultBuildDescriptionFactory.java:44) at org.eclipse.cdt.managedbuilder.internal.buildmodel.DefaultBuildDescriptionFactory.createBuildDescription(DefaultBuildDescriptionFactory.java:36) at com.ti.ccstudio.project.core.internal.build.temp.BuildDescriptionManager.createBuildDescription(BuildDescriptionManager.java:87) at com.ti.ccstudio.project.core.internal.build.CCSMakefileGenerator.generateMakefiles(CCSMakefileGenerator.java:317) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performMakefileGeneration(CommonBuilder.java:999) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performPrebuildGeneration(CommonBuilder.java:864) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:739) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:501) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:450) at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239) at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295) at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351) at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374) at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:513) at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:432) at org.eclipse.ui.actions.BuildAction$1.runInWorkspace(BuildAction.java:305) at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !SUBENTRY 1 org.eclipse.cdt.managedbuilder.core 4 0 2012-09-25 11:35:07.144 !MESSAGE Generated resource conflict: two resources of the same name: /concrete1/Debug/uartStdio.obj generated by different tools tool1: ARM Compiler tool2: ARM Compiler !STACK 0 java.lang.IllegalArgumentException: Generated resource conflict: two resources of the same name: /concrete1/Debug/uartStdio.obj generated by different tools tool1: ARM Compiler tool2: ARM Compiler at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildResource.addToArg(BuildResource.java:154) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildIOType.addResource(BuildIOType.java:64) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.addOutputs(BuildDescription.java:1031) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.calculateOutputs(BuildDescription.java:1347) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.composeOutputs(BuildDescription.java:644) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.access$1(BuildDescription.java:537) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription$RcVisitor.doVisitFile(BuildDescription.java:252) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription$RcVisitor.visit(BuildDescription.java:173) at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:65) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:75) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.initDescription(BuildDescription.java:741) at org.eclipse.cdt.managedbuilder.internal.buildmodel.BuildDescription.init(BuildDescription.java:810) at org.eclipse.cdt.managedbuilder.internal.buildmodel.DefaultBuildDescriptionFactory.createBuildDescription(DefaultBuildDescriptionFactory.java:44) at org.eclipse.cdt.managedbuilder.internal.buildmodel.DefaultBuildDescriptionFactory.createBuildDescription(DefaultBuildDescriptionFactory.java:36) at com.ti.ccstudio.project.core.internal.build.temp.BuildDescriptionManager.createBuildDescription(BuildDescriptionManager.java:87) at com.ti.ccstudio.project.core.internal.build.CCSMakefileGenerator.generateMakefiles(CCSMakefileGenerator.java:317) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performMakefileGeneration(CommonBuilder.java:999) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performPrebuildGeneration(CommonBuilder.java:864) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:739) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:501) at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:450) at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239) at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295) at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351) at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374) at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:513) at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:432) at org.eclipse.ui.actions.BuildAction$1.runInWorkspace(BuildAction.java:305) at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
  • John,
    Your issue sounds similar to the one discussed in this thread: http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/211003/747052.aspx#747052
    Could you please take a look and see if the patch posted there helps address your issue?
  • Yes,
            The patch from that thread has resolved the issue.
    Thanks...
