What exactly is the procedure to use MAP file for RAM and Flash usage calculation?
Map files are discussed a bit in section 7.4.15 of the assembly language user's guide:
http://www.ti.com/lit/ug/spru186w/spru186w.pdf (this is the one for C6000 but the content in that section is universal)
Note that there is also a utility call cg_xml where you can generate reports like size by section type and so forth:
http://processors.wiki.ti.com/index.php/Code_Generation_Tools_XML_Processing_Scripts
If you are using an MSP430, you will also be notified of the size of both code and data in CCS after download
ki
