Hello, i didn't see a controlSUITE Forum so thought i'd post in the CCS Forum as they are closely related (i already downloaded and installed the Free CCS 4.2.4 tools and they seem OK).
I just downloaded the Free controlSUITE utility. It installed without any hitches -but- when i go to launch the application, i get the following message:
"A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be available in order to run Eclipse. No Java Virtual Machine was found after searching the following locations: c:\ti\controlSUITE\eclipse\jre\bin\javaw.exe or javaw.exe in your current PATH."
There IS an <eclipse> directory under controlSUITE -but- there is no <jre> subdirectory there and no javaw.exe file. So why supply the eclipse directory if is incomplete and MISSING files needed to make the GUI work??? What is the easiest way to fix this issue? I'm surprised there isn't already a thread for this.
Thanks! J
