CCS/EK-TM4C123GXL: Gmake error after making new project in CCS.
Part Number: EK-TM4C123GXL
Other Parts Discussed in Thread: TM4C123GH6PM
I am getting 3 errors immediately after making a new project in CCS. Snapshot of CCS is as shown.Please help to remove the errors.
  • From the screenshot it appears that the compiler is attempting to read the context of the driverlib.lib library file as an (include?) file during the compilation of the tm4c123gh6pm_startup_ccs.c source file.
    Can you paste the complete text from the CCS Console, as suspect a problem with how the project has been setup.
  • **** Build of configuration Debug for project led_button ****
    "C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
    'Building file: ../main.c'
    'Invoking: ARM Compiler'
    "C:/ti/ccsv6/tools/compiler/arm_15.12.3.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --preinclude="C:/ti/TivaWare_C_Series-2.1.4.178/driverlib/ccs/Debug/driverlib.lib" --include_path="C:/ti/TivaWare_C_Series-2.1.4.178" -g --gcc --define=ccs="ccs" --define=PART_TM4C123GH6PM --diag_wrap=off --diag_warning=225 --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="main.d" "../main.c"
    >> Compilation failure
    subdir_rules.mk:7: recipe for target 'main.obj' failed
    "C:/ti/TivaWare_C_Series-2.1.4.178/driverlib/ccs/Debug/driverlib.lib", line 1: error #171: expected a declaration
    "C:/ti/TivaWare_C_Series-2.1.4.178/driverlib/ccs/Debug/driverlib.lib", line 2: error #7: unrecognized token
    "C:/ti/TivaWare_C_Series-2.1.4.178/driverlib/ccs/Debug/driverlib.lib", line 3: warning #1268-D: null (zero) character in input line ignored
    "C:/ti/TivaWare_C_Series-2.1.4.178/driverlib/ccs/Debug/driverlib.lib", line 3: error #7: unrecognized token
    Error limit reached.
    100 errors detected in the compilation of "../main.c".
    Compilation terminated.
    gmake: *** [main.obj] Error 1
    'Building file: ../tm4c123gh6pm_startup_ccs.c'
    "C:/ti/ccsv6/tools/compiler/arm_15.12.3.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --preinclude="C:/ti/TivaWare_C_Series-2.1.4.178/driverlib/ccs/Debug/driverlib.lib" --include_path="C:/ti/TivaWare_C_Series-2.1.4.178" -g --gcc --define=ccs="ccs" --define=PART_TM4C123GH6PM --diag_wrap=off --diag_warning=225 --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="tm4c123gh6pm_startup_ccs.d" "../tm4c123gh6pm_startup_ccs.c"
    >> Compilation failure
    subdir_rules.mk:14: recipe for target 'tm4c123gh6pm_startup_ccs.obj' failed
    100 errors detected in the compilation of "../tm4c123gh6pm_startup_ccs.c".
    gmake: *** [tm4c123gh6pm_startup_ccs.obj] Error 1
    gmake: Target 'all' not remade because of errors.
    **** Build Finished ****
  • The error is coming from this option:
    Go into Project Properties->Build->Compiler->Include Options and delete that path from the --preinclude option box. That should fix that compile error.
    To add driverlib.lib to your project, add that path under Properties->Build->Linker->File Search Path (under --library option) instead.
  • I am still getting errors even after following steps told to follow earlier.Here is snapshot of console:
    **** Build of configuration Debug for project Pushbutton1 ****
    "C:/ti/ccsv6/tools/compiler/arm_15.12.3.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/ti/ccsv6/tools/compiler/arm_15.12.3.LTS/include" -g --gcc --define=ccs="ccs" --define=PART_TM4C123GH6PM --diag_wrap=off --diag_warning=225 --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="main.d" "../main.c"
    >> Compilation failure
    "../main.c", line 27: fatal error #1965: cannot open source file "inc/hw_memmap.h"
    1 catastrophic error detected in the compilation of "../main.c".
    "C:/ti/ccsv6/tools/compiler/arm_15.12.3.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/ti/ccsv6/tools/compiler/arm_15.12.3.LTS/include" -g --gcc --define=ccs="ccs" --define=PART_TM4C123GH6PM --diag_wrap=off --diag_warning=225 --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="tm4c123gh6pm_startup_ccs.d" "../tm4c123gh6pm_startup_ccs.c"
    'Finished building: ../tm4c123gh6pm_startup_ccs.c'
    Please see http://processors.wiki.ti.com/index.php/Compiler/diagnostic_messages/5
    To fix the error, you need to add an include path to the TivaWare root directory C:/ti/TivaWare_C_Series-2.1.4.178/
  • Avinash,
    Since I haven’t heard back from you, I’m assuming you were able to resolve your issue. If not, just post a reply below (or create a new thread if this thread has locked due to time-out). Thanks!
  • Can you please specify the steps to add an include path to the TivaWare root directory C:/ti/TivaWare_C_Series-2.1.4.178/
  • Go into Project Properties->Build->Compiler->Include Options, click on + sign in the --include_path option area (shown in screenshot below) , then add the path C:/ti/TivaWare_C_Series-2.1.4.178/
