opt6x experienced a segmentation fault while processing function _AO_findMinMax
Compiling the following simple function causes a segmentation fault in the c6000 optimizer:
void AO_findMinMax(Int16 *restrict piImage, Int16 *piMin, Int16 *piMax)
    /* Find min/max of search area in image */
    Int16 min = 32767;
    Int16 max = -32767;
    Int16 x, y;
    Int16 temp;
    for(y = (10); y < (470-((30)+(30)+(30))) + ((30)+(30)+(30)); y++)
        for(x = (100); x < (600-((30)+(50)+(30))) + ((30)+(50)+(30)); x++)
            temp = piImage[x];
            if(temp < min)
                min = temp;
    *piMin = min;
    *piMax = max;
If I change "min = temp;" to "max = temp;" it compiles cleanly.
The preprocessed file is attached
 *  Copyright (c) 2008 Texas Instruments. All rights reserved.
 *  This program and the accompanying materials are made available under the
 *  terms of the Eclipse Public License v1.0 and Eclipse Distribution License
 *  v. 1.0 which accompanies this distribution. The Eclipse Public License is
 *  available at http://www.eclipse.org/legal/epl-v10.html and the Eclipse
 *  Distribution License is available at
 *  http://www.eclipse.org/org/documents/edl-v10.php.
 *  Contributors:
 *      Texas Instruments - initial implementation
/* stdarg.h   v7.3.2                                                         */
/* Copyright (c) 1993-2011 Texas Instruments Incorporated                    */
/* http://www.ti.com/                                                        */
/*  Redistribution and  use in source  and binary forms, with  or without    */
/*  modification,  are permitted provided  that the  following conditions    */
/*  are met:        */
/*     Redistributions  of source  code must  retain the  above copyright    */
/*     notice, this list of conditions and the following disclaimer.         */
/*     Redistributions in binary form  must reproduce the above copyright    */
/*     notice, this  list of conditions  and the following  disclaimer in    */
/*     the  documentation  and/or   other  materials  provided  with  the    */
/*     distribution.                                                         */
/*     Neither the  name of Texas Instruments Incorporated  nor the names    */
/*     of its  contributors may  be used to  endorse or  promote products    */
/*     derived  from   this  software  without   specific  prior  written    */
/*     permission.                                                           */
/*  THIS SOFTWARE  IS PROVIDED BY THE COPYRIGHT  HOLDERS AND CONTRIBUTORS    */
/*  "AS IS"  AND ANY  EXPRESS OR IMPLIED  WARRANTIES, INCLUDING,  BUT NOT    */
/*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR    */
/*  A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT    */
/*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,    */
/*  SPECIAL,  EXEMPLARY,  OR CONSEQUENTIAL  DAMAGES  (INCLUDING, BUT  NOT    */
/*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,    */
/*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY    */
/*  THEORY OF  LIABILITY, WHETHER IN CONTRACT, STRICT  LIABILITY, OR TORT    */
/*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE    */
/*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.     */
   typedef char *va_list;
/* VA_END - Reclaim resources used by varargs handling.                      */
/* No action needed                                                          */
/* VA_START - Set up the va_list pointer.				     */
/* COFF ABI convention:                                                      */
/* - va_list is kept aligned to 4 bytes.				     */
/* - va_list pointer points one word beyond the start of the last argument.  */
/* VA_ARG - Return the next argument, adjust va_list pointer		     */
/* Some arguments passed by value are turned into pass-by-reference by	     */
/* making a temporary object and passing a pointer to this temporary.  For   */
/* such an argument (indicated by __va_argref(_type)) the actual argument    */
/* passed is a pointer, so it must be dealt with specially.		     */
/* When an argument is larger than the maximum alignment (8 bytes for double */
/* or long long), we only align to 8 bytes.				     */
/* What happens on every va_arg(_ap, _type) call is:			     */
/* 1) Align the value of _ap (the va_list pointer) appropriately for _type   */
/*    (the requested type).						     */
/* 2) Increment _ap appropriately for _type.				     */
/* 3) Return the value desired by dereferencing _ap.			     */
/* The big- and little-endian variants are different only because we are     */
/* trying to support the case of the user asking for "char" or "short",	     */
/* which is actually undefined behavior (See ISO/IEC 9899:1999 7.15.1.1),    */
/* but we are trying to be friendly.					     */
/* stddef.h   v7.3.2                                                         */
/*  are met:        */
/*     distribution.                                                         */
/*     permission.                                                           */
typedef int ptrdiff_t;
typedef unsigned size_t;
typedef unsigned short wchar_t;
/* Define _win_t, for compiling GCC libraries with the TI compiler.      */
/* GCC's library (newlib) expects wint_t to be defined here, in stddef.h,*/
/* which is arguably incorrect, but we go along for compatibility.       */
/* This is outside the _STDDEF guard in case this file has already       */
/* been included without __need_wint_t.                                  */
/* macros to simplify "stringification" and computed includes */
/* TitleCase standard types */
typedef char            xdc_Char;
typedef unsigned char   xdc_UChar;
typedef short           xdc_Short;
typedef unsigned short  xdc_UShort;
typedef int             xdc_Int;
typedef unsigned int    xdc_UInt;
typedef long            xdc_Long;
typedef unsigned long   xdc_ULong;
typedef float           xdc_Float;
typedef double          xdc_Double;
typedef long double     xdc_LDouble;
typedef size_t          xdc_SizeT;
typedef va_list         xdc_VaList;
/* Generic Extended Types */
typedef unsigned short  xdc_Bool;       /* boolean flag */
typedef void            *xdc_Ptr;       /* data pointer */
typedef char            *xdc_String;    /* null terminated string */
/* we intentionally omit arguments from Fxn to indicate that it can have
 * any (or none).  Unfortunately this causes gcc to emit warnings when
 * -Wstrict-prototypes is used.  Newer gcc's support a pragma that
 * may work around this:
 *    #pragma GCC diagnostic ignored "-Wstrict-prototype"
typedef int             (*xdc_Fxn)();   /* function pointer */
 * Import the target-specific std.h
 *  Copyright (c) 2008 Texas Instruments and others.
 *  All rights reserved. This program and the accompanying materials
 *  are made available under the terms of the Eclipse Public License v1.0
 *  which accompanies this distribution, and is available at
 *  http://www.eclipse.org/legal/epl-v10.html
 *  Contributors:
 *  ======== ti/targets/std.h ========
 *  Standard types for supported TI compilers
/* include target-specific "portable" macros */
 *  Copyright 2011 by Texas Instruments Incorporated.
 *  ======== C674.h ========
 *  DO NOT MODIFY: This header is generated from stddef.xdt
 *  This header contains target-specific definitions of target-independent
 *  macros required by the ITarget interface.  These definitions allow C/C++
 *  sources to portably compile for multiple targets (using #ifdef ...).
 *  ======== ti_targets_C674 ========
 *  This macro identifies the specific target being used.  This macro should
 *  probably be avoided in portable sources.
 *  ======== xdc_target__isaCompatible_* macros ========
 *  The following definitions enable clients to conditionally compile for any
 *  compatible subset of the actual target ISA.
 *  ======== xdc_target__isa_674 ========
 *  This macro identifies the specific target ISA for which we are being
 *  compiled.
 *  ======== xdc_target__{big|little}Endian ========
 *  The following macro enables clients to portably compile for big or little
 *  endian targets.
 *  ======== xdc_target__os_undefined ========
 *  The following macro enables clients to portably compile for target specific
 *  OS; e.g., Linux, Solaris, Windows, undefined.
 *  ======== xdc_target__sizeof_ ========
 *  The following macros enable clients to portably determine type sizes
 *  within #ifdef blocks; sizeof() can't be used and the definitions in
 *  stdint.h are not available to C++ clients (unless the special macro
 *  __STDC_LIMIT_MACROS is defined).
 *  ======== xdc_target__alignof_ ========
 *  The following macros enable clients to portably determine type alignment
 *  within #ifdef blocks; even if provided by the compiler, alignof() can't
 *  be used in pre-processor statements.
 *  ======== xdc_target__bitsPerChar ========
 *  The number of bits in a char.  This macro allow one to determine the
 *  precise number of bits in any of the standard types (whose sizes are
 *  expressed as a number of chars).
 *  @(#) ti.targets; 1, 0, 3,460; 7-12-2011 21:04:02; /db/ztree/library/trees/xdctargets/xdctargets-e06x/src/ xlibrary
/* STDINT.H v7.3.2                                                           */
/* Copyright (c) 2002-2011 Texas Instruments Incorporated                    */
/*  are met:        */
/*     distribution.                                                         */
/*     permission.                                                           */
/* 7.18.1.1 Exact-width integer types */
    typedef   signed char   int8_t;
    typedef unsigned char  uint8_t;
    typedef          short  int16_t;
    typedef unsigned short uint16_t;
    typedef          int    int32_t;
    typedef unsigned int   uint32_t;
    typedef          __int40_t  int40_t;
    typedef unsigned __int40_t uint40_t;
    typedef          long long  int64_t;
    typedef unsigned long long uint64_t;
/* 7.18.1.2 Minimum-width integer types */
    typedef  int8_t   int_least8_t;
    typedef uint8_t  uint_least8_t;
    typedef  int16_t  int_least16_t;
    typedef uint16_t uint_least16_t;
    typedef  int32_t  int_least32_t;
    typedef uint32_t uint_least32_t;
    typedef  int40_t  int_least40_t;
    typedef uint40_t uint_least40_t;
    typedef  int64_t  int_least64_t;
    typedef uint64_t uint_least64_t;
/* 7.18.1.3 Fastest minimum-width integer types */
    typedef  int32_t  int_fast8_t;
    typedef uint32_t uint_fast8_t;
    typedef  int32_t  int_fast16_t;
    typedef uint32_t uint_fast16_t;
    typedef  int32_t  int_fast32_t;
    typedef uint32_t uint_fast32_t;
    typedef  int40_t  int_fast40_t;
    typedef uint40_t uint_fast40_t;
    typedef  int64_t  int_fast64_t;
    typedef uint64_t uint_fast64_t;
/* 7.18.1.4 Integer types capable of holding object pointers */
    typedef          int intptr_t;
    typedef unsigned int uintptr_t;
/* 7.18.1.5 Greatest-width integer types */
    typedef          long long intmax_t;
    typedef unsigned long long uintmax_t;
   According to footnotes in the 1999 C standard, "C++ implementations
   should define these macros only when __STDC_LIMIT_MACROS is defined
   before <stdint.h> is included."
/* 7.18.2 Limits of specified width integer types */
/* 7.18.3 Limits of other integer types */
/* 7.18.4.1 Macros for minimum-width integer constants */
   There is a defect report filed against the C99 standard concerning how
   the (U)INTN_C macros should be implemented.  Please refer to --
   http://wwwold.dkuug.dk/JTC1/SC22/WG14/www/docs/dr_209.htm
   for more information.  These macros are implemented according to the
   suggestion given at this web site.
/* 7.18.4.2 Macros for greatest-width integer constants */
        typedef int xdc_Arg;    /* deprecated, but compatible with BIOS 5.x */
 * xdc__LONGLONG__ indicates if compiler supports 'long long' type
 * xdc__BITS<n> __ indicates if compiler supports 'uint<n>_t' type
     *  int40_t types are supported for ELF in 7.2.0A10197 and later.
     *  This ifdef should be removed when the cut over to 7.2 is complete.
 *  ======== [U]Int<n> ========
typedef int_least8_t    xdc_Int8;
typedef uint_least8_t   xdc_UInt8;
typedef int_least16_t   xdc_Int16;
typedef uint_least16_t  xdc_UInt16;
typedef int_least32_t   xdc_Int32;
typedef uint_least32_t  xdc_UInt32;
    typedef int_least64_t   xdc_Int64;
    typedef int_least64_t   xdc_UInt64;
    typedef int_least40_t   xdc_Int40;
    typedef uint_least40_t  xdc_UInt40;
  /*  the following unqualified names are here because 40-bit types are not
   *  supported by xdc/std.h
    typedef xdc_Int40       Int40;
    typedef xdc_UInt40      UInt40;
 *  ======== Bits<n> ========
    typedef uint8_t     xdc_Bits8;
    typedef uint16_t    xdc_Bits16;
    typedef uint32_t    xdc_Bits32;
    typedef uint64_t    xdc_Bits64;
 *  ======== [UI]Arg ========
typedef intptr_t        xdc_IArg;
typedef uintptr_t       xdc_UArg;
 *  ======== restrict ========
 *  ======== ti_targets_mkPragma ========
 *  ======== xdc__META ========
 *  ======== __ti__ ========
 *  These symbols are used by RTSC tools to indicate presence/absence of
 *  assorted #pragma options in TI compiler.
 *  @(#) ti.targets; 1, 0, 3,460; 7-12-2011 21:04:03; /db/ztree/library/trees/xdctargets/xdctargets-e06x/src/ xlibrary
/* Each modules' internal header file defines 'module' as
 * xdc__MODOBJADDR__(Module__state__V), where Module__state__V is the actual
 * object where the module state is kept. For most targets, the default macro
 * given here results in the construct '(&Module__state__V)->field', when the
 * expression 'module->field' is used. Compilers then generate the code that
 * doesn't dereference a pointer, but puts the address of the field in the
 * code.
 * The targets that need to do something different can define
 * xdc__MODOBJADDR__ in std.h for their target package.
/* Long Long Types */
typedef long long               xdc_LLong;
typedef unsigned long long      xdc_ULLong;
/* Arg to Ptr and Fxn conversion operators
 * Individual targets may override these definitions in the event
 * that compilers issue warnings about shortening of an Arg to a pointer,
 * for example.
static inline xdc_Ptr xdc_iargToPtr(xdc_IArg a) { return ((xdc_Ptr)a); }
static inline xdc_Ptr xdc_uargToPtr(xdc_UArg a) { return ((xdc_Ptr)a); }
static inline xdc_Fxn xdc_iargToFxn(xdc_IArg a) { return ((xdc_Fxn)a); }
static inline xdc_Fxn xdc_uargToFxn(xdc_UArg a) { return ((xdc_Fxn)a); }
 * functions to convert a single precision float to an arg
 * Here assumption is that sizeof(Float) <= sizeof(IArg);
typedef union xdc_FloatData {
    xdc_Float f;
    xdc_IArg  a;
} xdc_FloatData;
static inline xdc_IArg xdc_floatToArg(xdc_Float f)
     xdc_FloatData u;
     u.f = f;
     return (u.a);
static inline xdc_Float xdc_argToFloat(xdc_IArg a)
     xdc_FloatData u;
     u.a = a;
     return (u.f);
/* restrict keyword */
/* Unprefixed Aliases */
typedef xdc_Char        Char;
typedef xdc_UChar       UChar;
typedef xdc_Short       Short;
typedef xdc_UShort      UShort;
typedef xdc_Int         Int;
typedef xdc_UInt        UInt;
typedef xdc_Long        Long;
typedef xdc_ULong       ULong;
typedef xdc_LLong       LLong;
typedef xdc_ULLong      ULLong;
typedef xdc_Float       Float;
typedef xdc_Double      Double;
typedef xdc_LDouble     LDouble;
typedef xdc_SizeT       SizeT;
typedef xdc_VaList      VaList;
typedef xdc_IArg        IArg;
typedef xdc_UArg        UArg;
typedef xdc_Bool        Bool;
typedef xdc_Int8        Int8;
typedef xdc_Int16       Int16;
typedef xdc_Int32       Int32;
typedef xdc_Fxn         Fxn;
typedef xdc_Ptr         Ptr;
typedef xdc_String      String;
typedef xdc_UInt8       UInt8;
typedef xdc_UInt16      UInt16;
typedef xdc_UInt32      UInt32;
/* DEPRECATED Aliases */
/* xdc_Arg is defined only in ti/targets/std.h; use IArg and UArg instead */
typedef xdc_Arg         Arg;
typedef xdc_UInt8       Uint8;
typedef xdc_UInt16      Uint16;
typedef xdc_UInt32      Uint32;
typedef xdc_UInt        Uns;
 *  ======== optional types ========
 *  The following types are not always defined for all targets
typedef xdc_Int64       Int64;
typedef xdc_UInt64      UInt64;
/* The following exact size types are not required by C99 and may not be
 * supported by some compiler/processor environments.  For greater
 * portability, use the IntN or UIntN types above.
typedef xdc_Bits8       Bits8;
typedef xdc_Bits16      Bits16;
typedef xdc_Bits32      Bits32;
typedef xdc_Bits64      Bits64;
/* Standard Constants */
/* Declaration Qualifiers */
 *  ======== xdc__CODESECT ========
 *  Code-Section Directive
 *  Targets can optionally #define xdc__CODESECT in their specific
 *  std.h files.  This directive is placed in front of all
 *  "extern" function declarations, and specifies a section-name in
 *  which to place this function.  This approach
 *  provides more control on combining/organizing groups of
 *  related functions into a single named sub-section (e.g.,
 *  "init-code")  If this macro is not defined by the target, an
 *  empty definition is used instead.
 *  Embed unreferenced string in the current file
 *  Strings emebdded via xdc__META can be placed in a section that is
 *  _not_ loaded on the target but are, nevertheless, part of the
 *  executable and available to loaders.
 *  Different targets may define this macro in a way that places these
 *  strings in an output section that is not loaded (and therefore does
 *  not takeup space on the target).  Unless the target provides a
 *  definition of xdc__META, the definition below simply defines
 *  as string constant in the current file.
 *  @(#) xdc; 1, 1, 1,343; 7-14-2011 17:21:47; /db/ztree/library/trees/xdc/xdc-x16x/src/packages/
//#include <smart/ipj/image/ImageTypes.h>
//#define PIXEL(image, x, y) (image[x + y*ImageTypes_FRAME_WIDTH_MAX])
void AO_findMinMax(Int16 *restrict piImage, Int16 *piMin, Int16 *piMax);
Int32 AO_calcInitialSSD(Int16 *restrict piImage, Int16 black, Int16 white);
    Int16 min = 32767;
    Int16 max = -32767;
    Int16 x, y;
    Int16 temp;
            temp = piImage[x];
            if(temp < min)
                min = temp;
    *piMin = min;
    *piMax = max;
the compile command is:
cl6x -c -qq -pdsw225 -mv6740 -eo.o674 -ea.s674  -mi100 -mo --gcc -O2 -fc autoorient_help1.pp
"Autoorient_help1.pp", line 537: warning: function "xdc_iargToPtr" was declared but never referenced
"Autoorient_help1.pp", line 538: warning: function "xdc_uargToPtr" was declared but never referenced
"Autoorient_help1.pp", line 540: warning: function "xdc_iargToFxn" was declared but never referenced
"Autoorient_help1.pp", line 541: warning: function "xdc_uargToFxn" was declared but never referenced
"Autoorient_help1.pp", line 552: warning: function "xdc_floatToArg" was declared but never referenced
"Autoorient_help1.pp", line 560: warning: function "xdc_argToFloat" was declared but never referenced
INTERNAL ERROR: opt6x.exe experienced a segmentation fault while processing function _AO_findMinMax file C:\\DOCUME~1\\xxx\\LOCALS~1\\Temp\\044043
This is a serious problem.  Please contact Customer
Support with this message and a copy of the input file
and help us to continue to make the tools more robust.
>> Compilation failure
Using version 7.3.2 of the tools; compiling for the c6748.
  • I've submitted SDSCM00044012 to track this issue.
  • Note: exactly the same result with version 7.3.5
  • As a workaround, try adding "#pragma UNROLL(1)" just ahead of the innermost for-loop.  (Unfortunately I can't test that at the moment, due to system issues here.  If it doesn't help, try adding it on the outer loop, or both loops.)
  • The compiler does not crash once #pragma UNROLL(1) is added before each for loop (one or the other is not enough), but it still takes several seconds to compile the file - many times longer than any other source file. The same structure (the two for loops) appears elsewhere in the code with different content and the two pragmas are required there too.
  • In the small test case, it was sufficient to place the pragma on the outer loop only.  With either one or two pragmas, I can't see any significant variation in compilation time, using a patched 7.5.0alpha on Linux.  Are you using Windows?  Is the file substantially larger than the small test case?
  • The real file has 261 lines, including six nested loops of the form in the example. If I only have the one nested loop (as in the example), a single pragma on the outer loop is sufficient. With two or more functions with nested loops, it segfaults without pragmas on both loops in both functions.
    I am using windoze and version 7.3.2 of the compiler. The compile time is 8 seconds for this file and less than 1 second for other files of similar size.
    The .o file is 13KB - normal for this size of file.
  • I'm a little curious about the crash behavior;  the bug lies in code specific to unrolling outer loops in loop nests, and I'm surprised that it takes more than just inhibiting that unrolling to avoid the crash.  Maybe there's an additional problem, or maybe my expectations are wrong.
    As for compilation time, it's a bit apples-and-oranges to compare two different files:  it's hard to know just what difference is causing it to take longer or not.  I was comparing pragma vs non-pragma, suggesting that the workaround is not itself affecting compilation time.  But if you really want to know, you could let us see two of the files with time differences and we could poke around with a profiler.
  • I removed the pragmas from all the inner loops. It took 4 minutes to compile that file with cg6x.exe at 100% CPU and up to 500MB of memory usage; but it did finish and the output .o file is still 18KB.
  • Thanks.  As well as reassuring me about a second crash problem, it tells me that your inner loops have small-enough known constant trip counts that the optimiser chooses to unroll (some of) them completely, giving it a lot of work to do, especially if the loops contain recurrences.  Probably best you use the pragmas on both loops.
    Once the original bug is patched, the outer loops will unroll instead and that'll be more efficient, but probably still not as fast as not unrolling at all.  The eight-second file will probably still take longer than the one-second file.
