I am finding that calculation done in debug and release configuration results in two different answers. Specifically the between optimization levels 1 and 2. I get the correct result is 0x111111 with -O1 and the incorrect result of 0xAEC3 with -O2. Attached are source code, output and list for each level. Any ideas?
Version: C6747, CCv5.2, C6000 CGT 7.3.4
TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 1 1 ;****************************************************************************** 2 ;* TMS320C6x C/C++ Codegen PC v7.3.4 * 3 ;* Date/Time created: Wed Oct 10 12:34:46 2012 * 4 ;****************************************************************************** 5 .compiler_opts --abi=coffabi --c64p_l1d_workaround=off --endian=little --hll_source=on --long_ 6 7 ;****************************************************************************** 8 ;* GLOBAL FILE PARAMETERS * 9 ;* * 10 ;* Architecture : TMS320C674x * 11 ;* Optimization : Enabled at level 1 * 12 ;* Optimizing for : Compile time 1st, speed 2nd * 13 ;* Based on options: -o1, no -ms * 14 ;* Endian : Little * 15 ;* Interrupt Thrshld : Disabled * 16 ;* Data Access Model : Far Aggregate Data * 17 ;* Pipelining : Disabled * 18 ;* Memory Aliases : Presume are aliases (pessimistic) * 19 ;* Debug Info : DWARF Debug for Program Analysis w/Optimization * 20 ;* * 21 ;****************************************************************************** 22 23 .asg A15, FP 24 .asg B14, DP 25 .asg B15, SP 26 .global $bss 27 28 29 $C$DW$CU .dwtag DW_TAG_compile_unit 30 .dwattr $C$DW$CU, DW_AT_name("../crap.c") 31 .dwattr $C$DW$CU, DW_AT_producer("TMS320C6x C/C++ Codegen PC v7.3.4 Copyright (c) 1996-2012 Te 32 .dwattr $C$DW$CU, DW_AT_TI_version(0x01) 33 .dwattr $C$DW$CU, DW_AT_comp_dir("C:\Projects\XSENSOR\PSMNG\SCT\WIP\Software\dsp_only_hid_ccsv 34 35 $C$DW$1 .dwtag DW_TAG_subprogram, DW_AT_name("printf") 36 .dwattr $C$DW$1, DW_AT_TI_symbol_name("_printf") 37 .dwattr $C$DW$1, DW_AT_type(*$C$DW$T$10) 38 .dwattr $C$DW$1, DW_AT_declaration 39 .dwattr $C$DW$1, DW_AT_external 40 $C$DW$2 .dwtag DW_TAG_formal_parameter 41 .dwattr $C$DW$2, DW_AT_type(*$C$DW$T$27) 42 $C$DW$3 .dwtag DW_TAG_unspecified_parameters 43 .dwendtag $C$DW$1 44 45 ; C:\ti\ccsv5\tools\compiler\c6000_7.3.4\bin\opt6x.exe C:\\DOCUME~1\\nwong.SCT\\LOCALS~1\\Temp\\ 46 00000000 .sect ".text" 47 .clink 48 .global _crap 49 50 $C$DW$4 .dwtag DW_TAG_subprogram, DW_AT_name("crap") 51 .dwattr $C$DW$4, DW_AT_low_pc(_crap) 52 .dwattr $C$DW$4, DW_AT_high_pc(0x00) 53 .dwattr $C$DW$4, DW_AT_TI_symbol_name("_crap") 54 .dwattr $C$DW$4, DW_AT_external 55 .dwattr $C$DW$4, DW_AT_TI_begin_file("../crap.c") TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 2 56 .dwattr $C$DW$4, DW_AT_TI_begin_line(0x07) 57 .dwattr $C$DW$4, DW_AT_TI_begin_column(0x06) 58 .dwattr $C$DW$4, DW_AT_TI_max_frame_size(0x18) 59 .dwattr $C$DW$4, DW_AT_frame_base[DW_OP_breg31 24] 60 .dwattr $C$DW$4, DW_AT_TI_skeletal 61 .dwpsn file "../crap.c",line 8,column 1,is_stmt,address _crap 62 $C$DW$5 .dwtag DW_TAG_formal_parameter, DW_AT_name("ulFreqKHz_") 63 .dwattr $C$DW$5, DW_AT_TI_symbol_name("_ulFreqKHz_") 64 .dwattr $C$DW$5, DW_AT_type(*$C$DW$T$19) 65 .dwattr $C$DW$5, DW_AT_location[DW_OP_reg4] 66 ;---------------------------------------------------------------------- 67 ; 7 | void crap(uint32_t ulFreqKHz_) 68 ;---------------------------------------------------------------------- 69 70 ;****************************************************************************** 71 ;* FUNCTION NAME: crap * 72 ;* * 73 ;* Regs Modified : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,A11,B0,B1,B2,B3,B4,* 74 ;* B5,B6,B7,B8,B9,SP,A16,A17,A18,A19,A20,A21,A22, * 75 ;* A23,A24,A25,A26,A27,A28,A29,A30,A31,B16,B17,B18, * 76 ;* B19,B20,B21,B22,B23,B24,B25,B26,B27,B28,B29,B30, * 77 ;* B31 * 78 ;* Regs Used : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,A11,B0,B1,B2,B3,B4,* 79 ;* B5,B6,B7,B8,B9,DP,SP,A16,A17,A18,A19,A20,A21,A22,* 80 ;* A23,A24,A25,A26,A27,A28,A29,A30,A31,B16,B17,B18, * 81 ;* B19,B20,B21,B22,B23,B24,B25,B26,B27,B28,B29,B30, * 82 ;* B31 * 83 ;* Local Frame Size : 16 Args + 0 Auto + 8 Save = 24 byte * 84 ;****************************************************************************** 85 00000000 _crap: 86 ;** --------------------------------------------------------------------------* 87 ;---------------------------------------------------------------------- 88 ; 9 | uint64_t ullFreqReg; 89 ; 10 | uint32_t ulFreqReg; 90 ; 11 | ullFreqReg = FREQ_BIT_RESOLUTION; 91 ; 12 | ullFreqReg *= ulFreqKHz_; 92 ; 13 | ullFreqReg /= DSP_CLKIN_KHZ; 93 ; 14 | ulFreqReg = (uint32_t)ullFreqReg; 94 ;---------------------------------------------------------------------- 95 00000000 05bcd4f4 STW .D2T1 A11,*SP--(24) ; |8| 96 97 00000004 053ca2f5 STW .D2T1 A10,*+SP(20) ; |8| 98 00000008 4646 || MV .L1 A4,A10 ; |8| 99 100 0000000a 75c6 MV .L1X B3,A11 ; |8| 101 .dwpsn file "../crap.c",line 15,column 3,is_stmt 102 ;---------------------------------------------------------------------- 103 ; 15 | printf("%d %x\n", ulFreqKHz_, ulFreqReg); 104 ;---------------------------------------------------------------------- 105 0000000c 032b9ca2 SHL .S2X A10,28,B6 ; |15| 106 00000010 022ee02a MVK .S2 0x5dc0,B4 ; |15| 107 $C$DW$6 .dwtag DW_TAG_TI_branch 108 .dwattr $C$DW$6, DW_AT_low_pc(0x00) 109 .dwattr $C$DW$6, DW_AT_name("__divull") 110 .dwattr $C$DW$6, DW_AT_TI_call TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 3 111 112 00000014 10000013! CALLP .S2 __divull,B3 113 00000018 029089a1 || SHRU .S1 A4,4,A5 ; |15| 114 00000020 9346 || MV .L1X B6,A4 ; |15| 115 00000022 06a7 || ZERO .L2 B5 ; |15| 116 117 00000024 $C$RL2: ; CALL OCCURS {__divull} {0} ; |15| 118 ;** --------------------------------------------------------------------------* 119 120 00000024 0200002b% MVKL .S2 $C$SL1+0,B4 121 00000028 023c62f4 || STW .D2T1 A4,*+SP(12) ; |15| 122 123 0000002c 0200006b% MVKH .S2 $C$SL1+0,B4 124 00000030 053c42f4 || STW .D2T1 A10,*+SP(8) ; |15| 125 126 $C$DW$7 .dwtag DW_TAG_TI_branch 127 .dwattr $C$DW$7, DW_AT_low_pc(0x00) 128 .dwattr $C$DW$7, DW_AT_name("_printf") 129 .dwattr $C$DW$7, DW_AT_TI_call 130 131 00000034 1ffffc13! CALLP .S2 _printf,B3 132 00000038 bc45 || STW .D2T2 B4,*+SP(4) ; |15| 133 134 0000003a $C$RL3: ; CALL OCCURS {_printf} {0} ; |15| 135 ;** --------------------------------------------------------------------------* 136 .dwpsn file "../crap.c",line 16,column 1,is_stmt 137 0000003a 7587 MV .L2X A11,B3 ; |16| 138 $C$DW$8 .dwtag DW_TAG_TI_branch 139 .dwattr $C$DW$8, DW_AT_low_pc(0x00) 140 .dwattr $C$DW$8, DW_AT_TI_return 141 142 00000040 000c0363 RET .S2 B3 ; |16| 143 00000044 053ca2e4 || LDW .D2T1 *+SP(20),A10 ; |16| 144 145 00000048 05bcd2e4 LDW .D2T1 *++SP(24),A11 ; |16| 146 0000004c 00006000 NOP 4 147 ; BRANCH OCCURS {B3} ; |16| 148 .dwattr $C$DW$4, DW_AT_TI_end_file("../crap.c") 149 .dwattr $C$DW$4, DW_AT_TI_end_line(0x10) 150 .dwattr $C$DW$4, DW_AT_TI_end_column(0x01) 151 .dwendtag $C$DW$4 152 153 ;****************************************************************************** 154 ;* STRINGS * 155 ;****************************************************************************** 156 00000000 .sect ".const:.string" 157 00000000 00000025 $C$SL1: .string "%d %x",10,0 00000001 00000064 00000002 00000020 00000003 00000025 00000004 00000078 00000005 0000000A 00000006 00000000 158 ;***************************************************************************** 159 ;* UNDEFINED EXTERNAL REFERENCES * TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 4 160 ;***************************************************************************** 161 .global _printf 162 .global __divull 163 164 ;****************************************************************************** 165 ;* BUILD ATTRIBUTES * 166 ;****************************************************************************** 167 .battr "TI", Tag_File, 1, Tag_ABI_stack_align_needed(0) 168 .battr "TI", Tag_File, 1, Tag_ABI_stack_align_preserved(0) 169 .battr "TI", Tag_File, 1, Tag_Tramps_Use_SOC(1) 170 171 ;****************************************************************************** 172 ;* TYPE INFORMATION * 173 ;****************************************************************************** 174 $C$DW$T$4 .dwtag DW_TAG_base_type 175 .dwattr $C$DW$T$4, DW_AT_encoding(DW_ATE_boolean) 176 .dwattr $C$DW$T$4, DW_AT_name("bool") 177 .dwattr $C$DW$T$4, DW_AT_byte_size(0x01) 178 $C$DW$T$5 .dwtag DW_TAG_base_type 179 .dwattr $C$DW$T$5, DW_AT_encoding(DW_ATE_signed_char) 180 .dwattr $C$DW$T$5, DW_AT_name("signed char") 181 .dwattr $C$DW$T$5, DW_AT_byte_size(0x01) 182 $C$DW$T$6 .dwtag DW_TAG_base_type 183 .dwattr $C$DW$T$6, DW_AT_encoding(DW_ATE_unsigned_char) 184 .dwattr $C$DW$T$6, DW_AT_name("unsigned char") 185 .dwattr $C$DW$T$6, DW_AT_byte_size(0x01) 186 $C$DW$T$7 .dwtag DW_TAG_base_type 187 .dwattr $C$DW$T$7, DW_AT_encoding(DW_ATE_signed_char) 188 .dwattr $C$DW$T$7, DW_AT_name("wchar_t") 189 .dwattr $C$DW$T$7, DW_AT_byte_size(0x02) 190 $C$DW$T$8 .dwtag DW_TAG_base_type 191 .dwattr $C$DW$T$8, DW_AT_encoding(DW_ATE_signed) 192 .dwattr $C$DW$T$8, DW_AT_name("short") 193 .dwattr $C$DW$T$8, DW_AT_byte_size(0x02) 194 $C$DW$T$9 .dwtag DW_TAG_base_type 195 .dwattr $C$DW$T$9, DW_AT_encoding(DW_ATE_unsigned) 196 .dwattr $C$DW$T$9, DW_AT_name("unsigned short") 197 .dwattr $C$DW$T$9, DW_AT_byte_size(0x02) 198 $C$DW$T$10 .dwtag DW_TAG_base_type 199 .dwattr $C$DW$T$10, DW_AT_encoding(DW_ATE_signed) 200 .dwattr $C$DW$T$10, DW_AT_name("int") 201 .dwattr $C$DW$T$10, DW_AT_byte_size(0x04) 202 $C$DW$T$11 .dwtag DW_TAG_base_type 203 .dwattr $C$DW$T$11, DW_AT_encoding(DW_ATE_unsigned) 204 .dwattr $C$DW$T$11, DW_AT_name("unsigned int") 205 .dwattr $C$DW$T$11, DW_AT_byte_size(0x04) 206 $C$DW$T$19 .dwtag DW_TAG_typedef, DW_AT_name("uint32_t") 207 .dwattr $C$DW$T$19, DW_AT_type(*$C$DW$T$11) 208 .dwattr $C$DW$T$19, DW_AT_language(DW_LANG_C) 209 $C$DW$T$12 .dwtag DW_TAG_base_type 210 .dwattr $C$DW$T$12, DW_AT_encoding(DW_ATE_signed) 211 .dwattr $C$DW$T$12, DW_AT_name("long") 212 .dwattr $C$DW$T$12, DW_AT_byte_size(0x08) 213 .dwattr $C$DW$T$12, DW_AT_bit_size(0x28) 214 .dwattr $C$DW$T$12, DW_AT_bit_offset(0x18) TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 5 215 $C$DW$T$13 .dwtag DW_TAG_base_type 216 .dwattr $C$DW$T$13, DW_AT_encoding(DW_ATE_unsigned) 217 .dwattr $C$DW$T$13, DW_AT_name("unsigned long") 218 .dwattr $C$DW$T$13, DW_AT_byte_size(0x08) 219 .dwattr $C$DW$T$13, DW_AT_bit_size(0x28) 220 .dwattr $C$DW$T$13, DW_AT_bit_offset(0x18) 221 $C$DW$T$14 .dwtag DW_TAG_base_type 222 .dwattr $C$DW$T$14, DW_AT_encoding(DW_ATE_signed) 223 .dwattr $C$DW$T$14, DW_AT_name("long long") 224 .dwattr $C$DW$T$14, DW_AT_byte_size(0x08) 225 $C$DW$T$15 .dwtag DW_TAG_base_type 226 .dwattr $C$DW$T$15, DW_AT_encoding(DW_ATE_unsigned) 227 .dwattr $C$DW$T$15, DW_AT_name("unsigned long long") 228 .dwattr $C$DW$T$15, DW_AT_byte_size(0x08) 229 $C$DW$T$32 .dwtag DW_TAG_typedef, DW_AT_name("uint64_t") 230 .dwattr $C$DW$T$32, DW_AT_type(*$C$DW$T$15) 231 .dwattr $C$DW$T$32, DW_AT_language(DW_LANG_C) 232 $C$DW$T$16 .dwtag DW_TAG_base_type 233 .dwattr $C$DW$T$16, DW_AT_encoding(DW_ATE_float) 234 .dwattr $C$DW$T$16, DW_AT_name("float") 235 .dwattr $C$DW$T$16, DW_AT_byte_size(0x04) 236 $C$DW$T$17 .dwtag DW_TAG_base_type 237 .dwattr $C$DW$T$17, DW_AT_encoding(DW_ATE_float) 238 .dwattr $C$DW$T$17, DW_AT_name("double") 239 .dwattr $C$DW$T$17, DW_AT_byte_size(0x08) 240 $C$DW$T$18 .dwtag DW_TAG_base_type 241 .dwattr $C$DW$T$18, DW_AT_encoding(DW_ATE_float) 242 .dwattr $C$DW$T$18, DW_AT_name("long double") 243 .dwattr $C$DW$T$18, DW_AT_byte_size(0x08) 244 $C$DW$T$25 .dwtag DW_TAG_base_type 245 .dwattr $C$DW$T$25, DW_AT_encoding(DW_ATE_signed_char) 246 .dwattr $C$DW$T$25, DW_AT_name("signed char") 247 .dwattr $C$DW$T$25, DW_AT_byte_size(0x01) 248 $C$DW$T$26 .dwtag DW_TAG_const_type 249 .dwattr $C$DW$T$26, DW_AT_type(*$C$DW$T$25) 250 $C$DW$T$27 .dwtag DW_TAG_pointer_type 251 .dwattr $C$DW$T$27, DW_AT_type(*$C$DW$T$26) 252 .dwattr $C$DW$T$27, DW_AT_address_class(0x20) 253 .dwattr $C$DW$CU, DW_AT_language(DW_LANG_C) 254 255 ;*************************************************************** 256 ;* DWARF REGISTER MAP * 257 ;*************************************************************** 258 259 $C$DW$9 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A0") 260 .dwattr $C$DW$9, DW_AT_location[DW_OP_reg0] 261 $C$DW$10 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A1") 262 .dwattr $C$DW$10, DW_AT_location[DW_OP_reg1] 263 $C$DW$11 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A2") 264 .dwattr $C$DW$11, DW_AT_location[DW_OP_reg2] 265 $C$DW$12 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A3") 266 .dwattr $C$DW$12, DW_AT_location[DW_OP_reg3] 267 $C$DW$13 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A4") 268 .dwattr $C$DW$13, DW_AT_location[DW_OP_reg4] 269 $C$DW$14 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A5") TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 6 270 .dwattr $C$DW$14, DW_AT_location[DW_OP_reg5] 271 $C$DW$15 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A6") 272 .dwattr $C$DW$15, DW_AT_location[DW_OP_reg6] 273 $C$DW$16 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A7") 274 .dwattr $C$DW$16, DW_AT_location[DW_OP_reg7] 275 $C$DW$17 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A8") 276 .dwattr $C$DW$17, DW_AT_location[DW_OP_reg8] 277 $C$DW$18 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A9") 278 .dwattr $C$DW$18, DW_AT_location[DW_OP_reg9] 279 $C$DW$19 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A10") 280 .dwattr $C$DW$19, DW_AT_location[DW_OP_reg10] 281 $C$DW$20 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A11") 282 .dwattr $C$DW$20, DW_AT_location[DW_OP_reg11] 283 $C$DW$21 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A12") 284 .dwattr $C$DW$21, DW_AT_location[DW_OP_reg12] 285 $C$DW$22 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A13") 286 .dwattr $C$DW$22, DW_AT_location[DW_OP_reg13] 287 $C$DW$23 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A14") 288 .dwattr $C$DW$23, DW_AT_location[DW_OP_reg14] 289 $C$DW$24 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A15") 290 .dwattr $C$DW$24, DW_AT_location[DW_OP_reg15] 291 $C$DW$25 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B0") 292 .dwattr $C$DW$25, DW_AT_location[DW_OP_reg16] 293 $C$DW$26 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B1") 294 .dwattr $C$DW$26, DW_AT_location[DW_OP_reg17] 295 $C$DW$27 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B2") 296 .dwattr $C$DW$27, DW_AT_location[DW_OP_reg18] 297 $C$DW$28 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B3") 298 .dwattr $C$DW$28, DW_AT_location[DW_OP_reg19] 299 $C$DW$29 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B4") 300 .dwattr $C$DW$29, DW_AT_location[DW_OP_reg20] 301 $C$DW$30 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B5") 302 .dwattr $C$DW$30, DW_AT_location[DW_OP_reg21] 303 $C$DW$31 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B6") 304 .dwattr $C$DW$31, DW_AT_location[DW_OP_reg22] 305 $C$DW$32 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B7") 306 .dwattr $C$DW$32, DW_AT_location[DW_OP_reg23] 307 $C$DW$33 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B8") 308 .dwattr $C$DW$33, DW_AT_location[DW_OP_reg24] 309 $C$DW$34 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B9") 310 .dwattr $C$DW$34, DW_AT_location[DW_OP_reg25] 311 $C$DW$35 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B10") 312 .dwattr $C$DW$35, DW_AT_location[DW_OP_reg26] 313 $C$DW$36 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B11") 314 .dwattr $C$DW$36, DW_AT_location[DW_OP_reg27] 315 $C$DW$37 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B12") 316 .dwattr $C$DW$37, DW_AT_location[DW_OP_reg28] 317 $C$DW$38 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B13") 318 .dwattr $C$DW$38, DW_AT_location[DW_OP_reg29] 319 $C$DW$39 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DP") 320 .dwattr $C$DW$39, DW_AT_location[DW_OP_reg30] 321 $C$DW$40 .dwtag DW_TAG_TI_assign_register, DW_AT_name("SP") 322 .dwattr $C$DW$40, DW_AT_location[DW_OP_reg31] 323 $C$DW$41 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FP") 324 .dwattr $C$DW$41, DW_AT_location[DW_OP_regx 0x20] TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 7 325 $C$DW$42 .dwtag DW_TAG_TI_assign_register, DW_AT_name("PC") 326 .dwattr $C$DW$42, DW_AT_location[DW_OP_regx 0x21] 327 $C$DW$43 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IRP") 328 .dwattr $C$DW$43, DW_AT_location[DW_OP_regx 0x22] 329 $C$DW$44 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IFR") 330 .dwattr $C$DW$44, DW_AT_location[DW_OP_regx 0x23] 331 $C$DW$45 .dwtag DW_TAG_TI_assign_register, DW_AT_name("NRP") 332 .dwattr $C$DW$45, DW_AT_location[DW_OP_regx 0x24] 333 $C$DW$46 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A16") 334 .dwattr $C$DW$46, DW_AT_location[DW_OP_regx 0x25] 335 $C$DW$47 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A17") 336 .dwattr $C$DW$47, DW_AT_location[DW_OP_regx 0x26] 337 $C$DW$48 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A18") 338 .dwattr $C$DW$48, DW_AT_location[DW_OP_regx 0x27] 339 $C$DW$49 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A19") 340 .dwattr $C$DW$49, DW_AT_location[DW_OP_regx 0x28] 341 $C$DW$50 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A20") 342 .dwattr $C$DW$50, DW_AT_location[DW_OP_regx 0x29] 343 $C$DW$51 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A21") 344 .dwattr $C$DW$51, DW_AT_location[DW_OP_regx 0x2a] 345 $C$DW$52 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A22") 346 .dwattr $C$DW$52, DW_AT_location[DW_OP_regx 0x2b] 347 $C$DW$53 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A23") 348 .dwattr $C$DW$53, DW_AT_location[DW_OP_regx 0x2c] 349 $C$DW$54 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A24") 350 .dwattr $C$DW$54, DW_AT_location[DW_OP_regx 0x2d] 351 $C$DW$55 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A25") 352 .dwattr $C$DW$55, DW_AT_location[DW_OP_regx 0x2e] 353 $C$DW$56 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A26") 354 .dwattr $C$DW$56, DW_AT_location[DW_OP_regx 0x2f] 355 $C$DW$57 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A27") 356 .dwattr $C$DW$57, DW_AT_location[DW_OP_regx 0x30] 357 $C$DW$58 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A28") 358 .dwattr $C$DW$58, DW_AT_location[DW_OP_regx 0x31] 359 $C$DW$59 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A29") 360 .dwattr $C$DW$59, DW_AT_location[DW_OP_regx 0x32] 361 $C$DW$60 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A30") 362 .dwattr $C$DW$60, DW_AT_location[DW_OP_regx 0x33] 363 $C$DW$61 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A31") 364 .dwattr $C$DW$61, DW_AT_location[DW_OP_regx 0x34] 365 $C$DW$62 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B16") 366 .dwattr $C$DW$62, DW_AT_location[DW_OP_regx 0x35] 367 $C$DW$63 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B17") 368 .dwattr $C$DW$63, DW_AT_location[DW_OP_regx 0x36] 369 $C$DW$64 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B18") 370 .dwattr $C$DW$64, DW_AT_location[DW_OP_regx 0x37] 371 $C$DW$65 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B19") 372 .dwattr $C$DW$65, DW_AT_location[DW_OP_regx 0x38] 373 $C$DW$66 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B20") 374 .dwattr $C$DW$66, DW_AT_location[DW_OP_regx 0x39] 375 $C$DW$67 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B21") 376 .dwattr $C$DW$67, DW_AT_location[DW_OP_regx 0x3a] 377 $C$DW$68 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B22") 378 .dwattr $C$DW$68, DW_AT_location[DW_OP_regx 0x3b] 379 $C$DW$69 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B23") TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 8 380 .dwattr $C$DW$69, DW_AT_location[DW_OP_regx 0x3c] 381 $C$DW$70 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B24") 382 .dwattr $C$DW$70, DW_AT_location[DW_OP_regx 0x3d] 383 $C$DW$71 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B25") 384 .dwattr $C$DW$71, DW_AT_location[DW_OP_regx 0x3e] 385 $C$DW$72 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B26") 386 .dwattr $C$DW$72, DW_AT_location[DW_OP_regx 0x3f] 387 $C$DW$73 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B27") 388 .dwattr $C$DW$73, DW_AT_location[DW_OP_regx 0x40] 389 $C$DW$74 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B28") 390 .dwattr $C$DW$74, DW_AT_location[DW_OP_regx 0x41] 391 $C$DW$75 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B29") 392 .dwattr $C$DW$75, DW_AT_location[DW_OP_regx 0x42] 393 $C$DW$76 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B30") 394 .dwattr $C$DW$76, DW_AT_location[DW_OP_regx 0x43] 395 $C$DW$77 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B31") 396 .dwattr $C$DW$77, DW_AT_location[DW_OP_regx 0x44] 397 $C$DW$78 .dwtag DW_TAG_TI_assign_register, DW_AT_name("AMR") 398 .dwattr $C$DW$78, DW_AT_location[DW_OP_regx 0x45] 399 $C$DW$79 .dwtag DW_TAG_TI_assign_register, DW_AT_name("CSR") 400 .dwattr $C$DW$79, DW_AT_location[DW_OP_regx 0x46] 401 $C$DW$80 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ISR") 402 .dwattr $C$DW$80, DW_AT_location[DW_OP_regx 0x47] 403 $C$DW$81 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ICR") 404 .dwattr $C$DW$81, DW_AT_location[DW_OP_regx 0x48] 405 $C$DW$82 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IER") 406 .dwattr $C$DW$82, DW_AT_location[DW_OP_regx 0x49] 407 $C$DW$83 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ISTP") 408 .dwattr $C$DW$83, DW_AT_location[DW_OP_regx 0x4a] 409 $C$DW$84 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IN") 410 .dwattr $C$DW$84, DW_AT_location[DW_OP_regx 0x4b] 411 $C$DW$85 .dwtag DW_TAG_TI_assign_register, DW_AT_name("OUT") 412 .dwattr $C$DW$85, DW_AT_location[DW_OP_regx 0x4c] 413 $C$DW$86 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ACR") 414 .dwattr $C$DW$86, DW_AT_location[DW_OP_regx 0x4d] 415 $C$DW$87 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ADR") 416 .dwattr $C$DW$87, DW_AT_location[DW_OP_regx 0x4e] 417 $C$DW$88 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FADCR") 418 .dwattr $C$DW$88, DW_AT_location[DW_OP_regx 0x4f] 419 $C$DW$89 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FAUCR") 420 .dwattr $C$DW$89, DW_AT_location[DW_OP_regx 0x50] 421 $C$DW$90 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FMCR") 422 .dwattr $C$DW$90, DW_AT_location[DW_OP_regx 0x51] 423 $C$DW$91 .dwtag DW_TAG_TI_assign_register, DW_AT_name("GFPGFR") 424 .dwattr $C$DW$91, DW_AT_location[DW_OP_regx 0x52] 425 $C$DW$92 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DIER") 426 .dwattr $C$DW$92, DW_AT_location[DW_OP_regx 0x53] 427 $C$DW$93 .dwtag DW_TAG_TI_assign_register, DW_AT_name("REP") 428 .dwattr $C$DW$93, DW_AT_location[DW_OP_regx 0x54] 429 $C$DW$94 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TSCL") 430 .dwattr $C$DW$94, DW_AT_location[DW_OP_regx 0x55] 431 $C$DW$95 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TSCH") 432 .dwattr $C$DW$95, DW_AT_location[DW_OP_regx 0x56] 433 $C$DW$96 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ARP") 434 .dwattr $C$DW$96, DW_AT_location[DW_OP_regx 0x57] TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 9 435 $C$DW$97 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ILC") 436 .dwattr $C$DW$97, DW_AT_location[DW_OP_regx 0x58] 437 $C$DW$98 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RILC") 438 .dwattr $C$DW$98, DW_AT_location[DW_OP_regx 0x59] 439 $C$DW$99 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DNUM") 440 .dwattr $C$DW$99, DW_AT_location[DW_OP_regx 0x5a] 441 $C$DW$100 .dwtag DW_TAG_TI_assign_register, DW_AT_name("SSR") 442 .dwattr $C$DW$100, DW_AT_location[DW_OP_regx 0x5b] 443 $C$DW$101 .dwtag DW_TAG_TI_assign_register, DW_AT_name("GPLYA") 444 .dwattr $C$DW$101, DW_AT_location[DW_OP_regx 0x5c] 445 $C$DW$102 .dwtag DW_TAG_TI_assign_register, DW_AT_name("GPLYB") 446 .dwattr $C$DW$102, DW_AT_location[DW_OP_regx 0x5d] 447 $C$DW$103 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TSR") 448 .dwattr $C$DW$103, DW_AT_location[DW_OP_regx 0x5e] 449 $C$DW$104 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ITSR") 450 .dwattr $C$DW$104, DW_AT_location[DW_OP_regx 0x5f] 451 $C$DW$105 .dwtag DW_TAG_TI_assign_register, DW_AT_name("NTSR") 452 .dwattr $C$DW$105, DW_AT_location[DW_OP_regx 0x60] 453 $C$DW$106 .dwtag DW_TAG_TI_assign_register, DW_AT_name("EFR") 454 .dwattr $C$DW$106, DW_AT_location[DW_OP_regx 0x61] 455 $C$DW$107 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ECR") 456 .dwattr $C$DW$107, DW_AT_location[DW_OP_regx 0x62] 457 $C$DW$108 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IERR") 458 .dwattr $C$DW$108, DW_AT_location[DW_OP_regx 0x63] 459 $C$DW$109 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DMSG") 460 .dwattr $C$DW$109, DW_AT_location[DW_OP_regx 0x64] 461 $C$DW$110 .dwtag DW_TAG_TI_assign_register, DW_AT_name("CMSG") 462 .dwattr $C$DW$110, DW_AT_location[DW_OP_regx 0x65] 463 $C$DW$111 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DT_DMA_ADDR") 464 .dwattr $C$DW$111, DW_AT_location[DW_OP_regx 0x66] 465 $C$DW$112 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DT_DMA_DATA") 466 .dwattr $C$DW$112, DW_AT_location[DW_OP_regx 0x67] 467 $C$DW$113 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DT_DMA_CNTL") 468 .dwattr $C$DW$113, DW_AT_location[DW_OP_regx 0x68] 469 $C$DW$114 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TCU_CNTL") 470 .dwattr $C$DW$114, DW_AT_location[DW_OP_regx 0x69] 471 $C$DW$115 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_REC_CNTL") 472 .dwattr $C$DW$115, DW_AT_location[DW_OP_regx 0x6a] 473 $C$DW$116 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_XMT_CNTL") 474 .dwattr $C$DW$116, DW_AT_location[DW_OP_regx 0x6b] 475 $C$DW$117 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_CFG") 476 .dwattr $C$DW$117, DW_AT_location[DW_OP_regx 0x6c] 477 $C$DW$118 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_RDATA") 478 .dwattr $C$DW$118, DW_AT_location[DW_OP_regx 0x6d] 479 $C$DW$119 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_WDATA") 480 .dwattr $C$DW$119, DW_AT_location[DW_OP_regx 0x6e] 481 $C$DW$120 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_RADDR") 482 .dwattr $C$DW$120, DW_AT_location[DW_OP_regx 0x6f] 483 $C$DW$121 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_WADDR") 484 .dwattr $C$DW$121, DW_AT_location[DW_OP_regx 0x70] 485 $C$DW$122 .dwtag DW_TAG_TI_assign_register, DW_AT_name("MFREG0") 486 .dwattr $C$DW$122, DW_AT_location[DW_OP_regx 0x71] 487 $C$DW$123 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DBG_STAT") 488 .dwattr $C$DW$123, DW_AT_location[DW_OP_regx 0x72] 489 $C$DW$124 .dwtag DW_TAG_TI_assign_register, DW_AT_name("BRK_EN") TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:34:46 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 10 490 .dwattr $C$DW$124, DW_AT_location[DW_OP_regx 0x73] 491 $C$DW$125 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP0_CNT") 492 .dwattr $C$DW$125, DW_AT_location[DW_OP_regx 0x74] 493 $C$DW$126 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP0") 494 .dwattr $C$DW$126, DW_AT_location[DW_OP_regx 0x75] 495 $C$DW$127 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP1") 496 .dwattr $C$DW$127, DW_AT_location[DW_OP_regx 0x76] 497 $C$DW$128 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP2") 498 .dwattr $C$DW$128, DW_AT_location[DW_OP_regx 0x77] 499 $C$DW$129 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP3") 500 .dwattr $C$DW$129, DW_AT_location[DW_OP_regx 0x78] 501 $C$DW$130 .dwtag DW_TAG_TI_assign_register, DW_AT_name("OVERLAY") 502 .dwattr $C$DW$130, DW_AT_location[DW_OP_regx 0x79] 503 $C$DW$131 .dwtag DW_TAG_TI_assign_register, DW_AT_name("PC_PROF") 504 .dwattr $C$DW$131, DW_AT_location[DW_OP_regx 0x7a] 505 $C$DW$132 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ATSR") 506 .dwattr $C$DW$132, DW_AT_location[DW_OP_regx 0x7b] 507 $C$DW$133 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TRR") 508 .dwattr $C$DW$133, DW_AT_location[DW_OP_regx 0x7c] 509 $C$DW$134 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TCRR") 510 .dwattr $C$DW$134, DW_AT_location[DW_OP_regx 0x7d] 511 $C$DW$135 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DESR") 512 .dwattr $C$DW$135, DW_AT_location[DW_OP_regx 0x7e] 513 $C$DW$136 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DETR") 514 .dwattr $C$DW$136, DW_AT_location[DW_OP_regx 0x7f] 515 $C$DW$137 .dwtag DW_TAG_TI_assign_register, DW_AT_name("CIE_RETA") 516 .dwattr $C$DW$137, DW_AT_location[DW_OP_regx 0xe4] 517 .dwendtag $C$DW$CU 518 No Assembly Errors, No Assembly Warnings
[C674X_0] 100 111111
TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 1 1 ;****************************************************************************** 2 ;* TMS320C6x C/C++ Codegen PC v7.3.4 * 3 ;* Date/Time created: Wed Oct 10 12:35:52 2012 * 4 ;****************************************************************************** 5 .compiler_opts --abi=coffabi --c64p_l1d_workaround=off --endian=little --hll_source=on --long_ 6 7 ;****************************************************************************** 8 ;* GLOBAL FILE PARAMETERS * 9 ;* * 10 ;* Architecture : TMS320C674x * 11 ;* Optimization : Enabled at level 2 * 12 ;* Optimizing for : Speed * 13 ;* Based on options: -o2, no -ms * 14 ;* Endian : Little * 15 ;* Interrupt Thrshld : Disabled * 16 ;* Data Access Model : Far Aggregate Data * 17 ;* Pipelining : Enabled * 18 ;* Speculate Loads : Enabled with threshold = 0 * 19 ;* Memory Aliases : Presume are aliases (pessimistic) * 20 ;* Debug Info : DWARF Debug for Program Analysis w/Optimization * 21 ;* * 22 ;****************************************************************************** 23 24 .asg A15, FP 25 .asg B14, DP 26 .asg B15, SP 27 .global $bss 28 29 30 $C$DW$CU .dwtag DW_TAG_compile_unit 31 .dwattr $C$DW$CU, DW_AT_name("../crap.c") 32 .dwattr $C$DW$CU, DW_AT_producer("TMS320C6x C/C++ Codegen PC v7.3.4 Copyright (c) 1996-2012 Te 33 .dwattr $C$DW$CU, DW_AT_TI_version(0x01) 34 .dwattr $C$DW$CU, DW_AT_comp_dir("C:\Projects\XSENSOR\PSMNG\SCT\WIP\Software\dsp_only_hid_ccsv 35 36 $C$DW$1 .dwtag DW_TAG_subprogram, DW_AT_name("printf") 37 .dwattr $C$DW$1, DW_AT_TI_symbol_name("_printf") 38 .dwattr $C$DW$1, DW_AT_type(*$C$DW$T$10) 39 .dwattr $C$DW$1, DW_AT_declaration 40 .dwattr $C$DW$1, DW_AT_external 41 $C$DW$2 .dwtag DW_TAG_formal_parameter 42 .dwattr $C$DW$2, DW_AT_type(*$C$DW$T$27) 43 $C$DW$3 .dwtag DW_TAG_unspecified_parameters 44 .dwendtag $C$DW$1 45 46 ; C:\ti\ccsv5\tools\compiler\c6000_7.3.4\bin\opt6x.exe C:\\DOCUME~1\\nwong.SCT\\LOCALS~1\\Temp\\ 47 00000000 .sect ".text" 48 .clink 49 .global _crap 50 51 $C$DW$4 .dwtag DW_TAG_subprogram, DW_AT_name("crap") 52 .dwattr $C$DW$4, DW_AT_low_pc(_crap) 53 .dwattr $C$DW$4, DW_AT_high_pc(0x00) 54 .dwattr $C$DW$4, DW_AT_TI_symbol_name("_crap") 55 .dwattr $C$DW$4, DW_AT_external TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 2 56 .dwattr $C$DW$4, DW_AT_TI_begin_file("../crap.c") 57 .dwattr $C$DW$4, DW_AT_TI_begin_line(0x07) 58 .dwattr $C$DW$4, DW_AT_TI_begin_column(0x06) 59 .dwattr $C$DW$4, DW_AT_TI_max_frame_size(0x18) 60 .dwattr $C$DW$4, DW_AT_frame_base[DW_OP_breg31 24] 61 .dwattr $C$DW$4, DW_AT_TI_skeletal 62 .dwpsn file "../crap.c",line 8,column 1,is_stmt,address _crap 63 $C$DW$5 .dwtag DW_TAG_formal_parameter, DW_AT_name("ulFreqKHz_") 64 .dwattr $C$DW$5, DW_AT_TI_symbol_name("_ulFreqKHz_") 65 .dwattr $C$DW$5, DW_AT_type(*$C$DW$T$19) 66 .dwattr $C$DW$5, DW_AT_location[DW_OP_reg4] 67 ;---------------------------------------------------------------------- 68 ; 7 | void crap(uint32_t ulFreqKHz_) 69 ;---------------------------------------------------------------------- 70 71 ;****************************************************************************** 72 ;* FUNCTION NAME: crap * 73 ;* * 74 ;* Regs Modified : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,A11,B0,B1,B2,B3,B4,* 75 ;* B5,B6,B7,B8,B9,SP,A16,A17,A18,A19,A20,A21,A22, * 76 ;* A23,A24,A25,A26,A27,A28,A29,A30,A31,B16,B17,B18, * 77 ;* B19,B20,B21,B22,B23,B24,B25,B26,B27,B28,B29,B30, * 78 ;* B31 * 79 ;* Regs Used : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,A11,B0,B1,B2,B3,B4,* 80 ;* B5,B6,B7,B8,B9,DP,SP,A16,A17,A18,A19,A20,A21,A22,* 81 ;* A23,A24,A25,A26,A27,A28,A29,A30,A31,B16,B17,B18, * 82 ;* B19,B20,B21,B22,B23,B24,B25,B26,B27,B28,B29,B30, * 83 ;* B31 * 84 ;* Local Frame Size : 16 Args + 0 Auto + 8 Save = 24 byte * 85 ;****************************************************************************** 86 00000000 _crap: 87 ;** --------------------------------------------------------------------------* 88 ;---------------------------------------------------------------------- 89 ; 9 | uint64_t ullFreqReg; 90 ; 10 | uint32_t ulFreqReg; 91 ; 11 | ullFreqReg = FREQ_BIT_RESOLUTION; 92 ; 12 | ullFreqReg *= ulFreqKHz_; 93 ; 13 | ullFreqReg /= DSP_CLKIN_KHZ; 94 ; 14 | ulFreqReg = (uint32_t)ullFreqReg; 95 ;---------------------------------------------------------------------- 96 00000000 05bcd4f4 STW .D2T1 A11,*SP--(24) ; |8| 97 98 00000004 053ca2f5 STW .D2T1 A10,*+SP(20) ; |8| 99 0000000c 4646 || MV .L1 A4,A10 ; |8| 100 00000008 022ee02b || MVK .S2 0x5dc0,B4 ; |15| 101 102 $C$DW$6 .dwtag DW_TAG_TI_branch 103 .dwattr $C$DW$6, DW_AT_low_pc(0x04) 104 .dwattr $C$DW$6, DW_AT_name("__divull") 105 .dwattr $C$DW$6, DW_AT_TI_call 106 107 0000000e 75c6 MV .L1X B3,A11 ; |8| 108 00000010 10000013! || CALLP .S2 __divull,B3 109 00000014 022b8ca1 || SHL .S1 A10,28,A4 ; |15| 110 00000018 1af6 || ZERO .D1 A5 ; |15| TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 3 111 0000001a 06a7 || ZERO .L2 B5 ; |15| 112 113 .dwpsn file "../crap.c",line 15,column 3,is_stmt 114 ;---------------------------------------------------------------------- 115 ; 15 | printf("%d %x\n", ulFreqKHz_, ulFreqReg); 116 ;---------------------------------------------------------------------- 117 00000020 $C$RL2: ; CALL OCCURS {__divull} {0} ; |15| 118 ;** --------------------------------------------------------------------------* 119 120 00000020 0200002b% MVKL .S2 $C$SL1+0,B4 121 00000024 023c62f4 || STW .D2T1 A4,*+SP(12) ; |15| 122 123 00000028 0200006b% MVKH .S2 $C$SL1+0,B4 124 0000002c 053c42f4 || STW .D2T1 A10,*+SP(8) ; |15| 125 126 $C$DW$7 .dwtag DW_TAG_TI_branch 127 .dwattr $C$DW$7, DW_AT_low_pc(0x00) 128 .dwattr $C$DW$7, DW_AT_name("_printf") 129 .dwattr $C$DW$7, DW_AT_TI_call 130 131 00000030 1ffffc13! CALLP .S2 _printf,B3 132 00000034 bc45 || STW .D2T2 B4,*+SP(4) ; |15| 133 134 00000036 $C$RL3: ; CALL OCCURS {_printf} {0} ; |15| 135 ;** --------------------------------------------------------------------------* 136 .dwpsn file "../crap.c",line 16,column 1,is_stmt 137 00000036 7587 MV .L2X A11,B3 ; |16| 138 $C$DW$8 .dwtag DW_TAG_TI_branch 139 .dwattr $C$DW$8, DW_AT_low_pc(0x00) 140 .dwattr $C$DW$8, DW_AT_TI_return 141 142 00000040 000c0362 RET .S2 B3 ; |16| 143 00000038 053ca2e5 || LDW .D2T1 *+SP(20),A10 ; |16| 144 145 00000044 05bcd2e4 LDW .D2T1 *++SP(24),A11 ; |16| 146 00000048 00006000 NOP 4 147 ; BRANCH OCCURS {B3} ; |16| 148 .dwattr $C$DW$4, DW_AT_TI_end_file("../crap.c") 149 .dwattr $C$DW$4, DW_AT_TI_end_line(0x10) 150 .dwattr $C$DW$4, DW_AT_TI_end_column(0x01) 151 .dwendtag $C$DW$4 152 153 ;****************************************************************************** 154 ;* STRINGS * 155 ;****************************************************************************** 156 00000000 .sect ".const:.string" 157 00000000 00000025 $C$SL1: .string "%d %x",10,0 00000001 00000064 00000002 00000020 00000003 00000025 00000004 00000078 00000005 0000000A 00000006 00000000 158 ;***************************************************************************** 159 ;* UNDEFINED EXTERNAL REFERENCES * TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 4 160 ;***************************************************************************** 161 .global _printf 162 .global __divull 163 164 ;****************************************************************************** 165 ;* BUILD ATTRIBUTES * 166 ;****************************************************************************** 167 .battr "TI", Tag_File, 1, Tag_ABI_stack_align_needed(0) 168 .battr "TI", Tag_File, 1, Tag_ABI_stack_align_preserved(0) 169 .battr "TI", Tag_File, 1, Tag_Tramps_Use_SOC(1) 170 171 ;****************************************************************************** 172 ;* TYPE INFORMATION * 173 ;****************************************************************************** 174 $C$DW$T$4 .dwtag DW_TAG_base_type 175 .dwattr $C$DW$T$4, DW_AT_encoding(DW_ATE_boolean) 176 .dwattr $C$DW$T$4, DW_AT_name("bool") 177 .dwattr $C$DW$T$4, DW_AT_byte_size(0x01) 178 $C$DW$T$5 .dwtag DW_TAG_base_type 179 .dwattr $C$DW$T$5, DW_AT_encoding(DW_ATE_signed_char) 180 .dwattr $C$DW$T$5, DW_AT_name("signed char") 181 .dwattr $C$DW$T$5, DW_AT_byte_size(0x01) 182 $C$DW$T$6 .dwtag DW_TAG_base_type 183 .dwattr $C$DW$T$6, DW_AT_encoding(DW_ATE_unsigned_char) 184 .dwattr $C$DW$T$6, DW_AT_name("unsigned char") 185 .dwattr $C$DW$T$6, DW_AT_byte_size(0x01) 186 $C$DW$T$7 .dwtag DW_TAG_base_type 187 .dwattr $C$DW$T$7, DW_AT_encoding(DW_ATE_signed_char) 188 .dwattr $C$DW$T$7, DW_AT_name("wchar_t") 189 .dwattr $C$DW$T$7, DW_AT_byte_size(0x02) 190 $C$DW$T$8 .dwtag DW_TAG_base_type 191 .dwattr $C$DW$T$8, DW_AT_encoding(DW_ATE_signed) 192 .dwattr $C$DW$T$8, DW_AT_name("short") 193 .dwattr $C$DW$T$8, DW_AT_byte_size(0x02) 194 $C$DW$T$9 .dwtag DW_TAG_base_type 195 .dwattr $C$DW$T$9, DW_AT_encoding(DW_ATE_unsigned) 196 .dwattr $C$DW$T$9, DW_AT_name("unsigned short") 197 .dwattr $C$DW$T$9, DW_AT_byte_size(0x02) 198 $C$DW$T$10 .dwtag DW_TAG_base_type 199 .dwattr $C$DW$T$10, DW_AT_encoding(DW_ATE_signed) 200 .dwattr $C$DW$T$10, DW_AT_name("int") 201 .dwattr $C$DW$T$10, DW_AT_byte_size(0x04) 202 $C$DW$T$11 .dwtag DW_TAG_base_type 203 .dwattr $C$DW$T$11, DW_AT_encoding(DW_ATE_unsigned) 204 .dwattr $C$DW$T$11, DW_AT_name("unsigned int") 205 .dwattr $C$DW$T$11, DW_AT_byte_size(0x04) 206 $C$DW$T$19 .dwtag DW_TAG_typedef, DW_AT_name("uint32_t") 207 .dwattr $C$DW$T$19, DW_AT_type(*$C$DW$T$11) 208 .dwattr $C$DW$T$19, DW_AT_language(DW_LANG_C) 209 $C$DW$T$12 .dwtag DW_TAG_base_type 210 .dwattr $C$DW$T$12, DW_AT_encoding(DW_ATE_signed) 211 .dwattr $C$DW$T$12, DW_AT_name("long") 212 .dwattr $C$DW$T$12, DW_AT_byte_size(0x08) 213 .dwattr $C$DW$T$12, DW_AT_bit_size(0x28) 214 .dwattr $C$DW$T$12, DW_AT_bit_offset(0x18) TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 5 215 $C$DW$T$13 .dwtag DW_TAG_base_type 216 .dwattr $C$DW$T$13, DW_AT_encoding(DW_ATE_unsigned) 217 .dwattr $C$DW$T$13, DW_AT_name("unsigned long") 218 .dwattr $C$DW$T$13, DW_AT_byte_size(0x08) 219 .dwattr $C$DW$T$13, DW_AT_bit_size(0x28) 220 .dwattr $C$DW$T$13, DW_AT_bit_offset(0x18) 221 $C$DW$T$14 .dwtag DW_TAG_base_type 222 .dwattr $C$DW$T$14, DW_AT_encoding(DW_ATE_signed) 223 .dwattr $C$DW$T$14, DW_AT_name("long long") 224 .dwattr $C$DW$T$14, DW_AT_byte_size(0x08) 225 $C$DW$T$15 .dwtag DW_TAG_base_type 226 .dwattr $C$DW$T$15, DW_AT_encoding(DW_ATE_unsigned) 227 .dwattr $C$DW$T$15, DW_AT_name("unsigned long long") 228 .dwattr $C$DW$T$15, DW_AT_byte_size(0x08) 229 $C$DW$T$32 .dwtag DW_TAG_typedef, DW_AT_name("uint64_t") 230 .dwattr $C$DW$T$32, DW_AT_type(*$C$DW$T$15) 231 .dwattr $C$DW$T$32, DW_AT_language(DW_LANG_C) 232 $C$DW$T$16 .dwtag DW_TAG_base_type 233 .dwattr $C$DW$T$16, DW_AT_encoding(DW_ATE_float) 234 .dwattr $C$DW$T$16, DW_AT_name("float") 235 .dwattr $C$DW$T$16, DW_AT_byte_size(0x04) 236 $C$DW$T$17 .dwtag DW_TAG_base_type 237 .dwattr $C$DW$T$17, DW_AT_encoding(DW_ATE_float) 238 .dwattr $C$DW$T$17, DW_AT_name("double") 239 .dwattr $C$DW$T$17, DW_AT_byte_size(0x08) 240 $C$DW$T$18 .dwtag DW_TAG_base_type 241 .dwattr $C$DW$T$18, DW_AT_encoding(DW_ATE_float) 242 .dwattr $C$DW$T$18, DW_AT_name("long double") 243 .dwattr $C$DW$T$18, DW_AT_byte_size(0x08) 244 $C$DW$T$25 .dwtag DW_TAG_base_type 245 .dwattr $C$DW$T$25, DW_AT_encoding(DW_ATE_signed_char) 246 .dwattr $C$DW$T$25, DW_AT_name("signed char") 247 .dwattr $C$DW$T$25, DW_AT_byte_size(0x01) 248 $C$DW$T$26 .dwtag DW_TAG_const_type 249 .dwattr $C$DW$T$26, DW_AT_type(*$C$DW$T$25) 250 $C$DW$T$27 .dwtag DW_TAG_pointer_type 251 .dwattr $C$DW$T$27, DW_AT_type(*$C$DW$T$26) 252 .dwattr $C$DW$T$27, DW_AT_address_class(0x20) 253 .dwattr $C$DW$CU, DW_AT_language(DW_LANG_C) 254 255 ;*************************************************************** 256 ;* DWARF REGISTER MAP * 257 ;*************************************************************** 258 259 $C$DW$9 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A0") 260 .dwattr $C$DW$9, DW_AT_location[DW_OP_reg0] 261 $C$DW$10 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A1") 262 .dwattr $C$DW$10, DW_AT_location[DW_OP_reg1] 263 $C$DW$11 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A2") 264 .dwattr $C$DW$11, DW_AT_location[DW_OP_reg2] 265 $C$DW$12 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A3") 266 .dwattr $C$DW$12, DW_AT_location[DW_OP_reg3] 267 $C$DW$13 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A4") 268 .dwattr $C$DW$13, DW_AT_location[DW_OP_reg4] 269 $C$DW$14 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A5") TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 6 270 .dwattr $C$DW$14, DW_AT_location[DW_OP_reg5] 271 $C$DW$15 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A6") 272 .dwattr $C$DW$15, DW_AT_location[DW_OP_reg6] 273 $C$DW$16 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A7") 274 .dwattr $C$DW$16, DW_AT_location[DW_OP_reg7] 275 $C$DW$17 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A8") 276 .dwattr $C$DW$17, DW_AT_location[DW_OP_reg8] 277 $C$DW$18 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A9") 278 .dwattr $C$DW$18, DW_AT_location[DW_OP_reg9] 279 $C$DW$19 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A10") 280 .dwattr $C$DW$19, DW_AT_location[DW_OP_reg10] 281 $C$DW$20 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A11") 282 .dwattr $C$DW$20, DW_AT_location[DW_OP_reg11] 283 $C$DW$21 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A12") 284 .dwattr $C$DW$21, DW_AT_location[DW_OP_reg12] 285 $C$DW$22 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A13") 286 .dwattr $C$DW$22, DW_AT_location[DW_OP_reg13] 287 $C$DW$23 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A14") 288 .dwattr $C$DW$23, DW_AT_location[DW_OP_reg14] 289 $C$DW$24 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A15") 290 .dwattr $C$DW$24, DW_AT_location[DW_OP_reg15] 291 $C$DW$25 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B0") 292 .dwattr $C$DW$25, DW_AT_location[DW_OP_reg16] 293 $C$DW$26 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B1") 294 .dwattr $C$DW$26, DW_AT_location[DW_OP_reg17] 295 $C$DW$27 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B2") 296 .dwattr $C$DW$27, DW_AT_location[DW_OP_reg18] 297 $C$DW$28 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B3") 298 .dwattr $C$DW$28, DW_AT_location[DW_OP_reg19] 299 $C$DW$29 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B4") 300 .dwattr $C$DW$29, DW_AT_location[DW_OP_reg20] 301 $C$DW$30 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B5") 302 .dwattr $C$DW$30, DW_AT_location[DW_OP_reg21] 303 $C$DW$31 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B6") 304 .dwattr $C$DW$31, DW_AT_location[DW_OP_reg22] 305 $C$DW$32 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B7") 306 .dwattr $C$DW$32, DW_AT_location[DW_OP_reg23] 307 $C$DW$33 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B8") 308 .dwattr $C$DW$33, DW_AT_location[DW_OP_reg24] 309 $C$DW$34 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B9") 310 .dwattr $C$DW$34, DW_AT_location[DW_OP_reg25] 311 $C$DW$35 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B10") 312 .dwattr $C$DW$35, DW_AT_location[DW_OP_reg26] 313 $C$DW$36 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B11") 314 .dwattr $C$DW$36, DW_AT_location[DW_OP_reg27] 315 $C$DW$37 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B12") 316 .dwattr $C$DW$37, DW_AT_location[DW_OP_reg28] 317 $C$DW$38 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B13") 318 .dwattr $C$DW$38, DW_AT_location[DW_OP_reg29] 319 $C$DW$39 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DP") 320 .dwattr $C$DW$39, DW_AT_location[DW_OP_reg30] 321 $C$DW$40 .dwtag DW_TAG_TI_assign_register, DW_AT_name("SP") 322 .dwattr $C$DW$40, DW_AT_location[DW_OP_reg31] 323 $C$DW$41 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FP") 324 .dwattr $C$DW$41, DW_AT_location[DW_OP_regx 0x20] TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 7 325 $C$DW$42 .dwtag DW_TAG_TI_assign_register, DW_AT_name("PC") 326 .dwattr $C$DW$42, DW_AT_location[DW_OP_regx 0x21] 327 $C$DW$43 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IRP") 328 .dwattr $C$DW$43, DW_AT_location[DW_OP_regx 0x22] 329 $C$DW$44 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IFR") 330 .dwattr $C$DW$44, DW_AT_location[DW_OP_regx 0x23] 331 $C$DW$45 .dwtag DW_TAG_TI_assign_register, DW_AT_name("NRP") 332 .dwattr $C$DW$45, DW_AT_location[DW_OP_regx 0x24] 333 $C$DW$46 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A16") 334 .dwattr $C$DW$46, DW_AT_location[DW_OP_regx 0x25] 335 $C$DW$47 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A17") 336 .dwattr $C$DW$47, DW_AT_location[DW_OP_regx 0x26] 337 $C$DW$48 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A18") 338 .dwattr $C$DW$48, DW_AT_location[DW_OP_regx 0x27] 339 $C$DW$49 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A19") 340 .dwattr $C$DW$49, DW_AT_location[DW_OP_regx 0x28] 341 $C$DW$50 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A20") 342 .dwattr $C$DW$50, DW_AT_location[DW_OP_regx 0x29] 343 $C$DW$51 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A21") 344 .dwattr $C$DW$51, DW_AT_location[DW_OP_regx 0x2a] 345 $C$DW$52 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A22") 346 .dwattr $C$DW$52, DW_AT_location[DW_OP_regx 0x2b] 347 $C$DW$53 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A23") 348 .dwattr $C$DW$53, DW_AT_location[DW_OP_regx 0x2c] 349 $C$DW$54 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A24") 350 .dwattr $C$DW$54, DW_AT_location[DW_OP_regx 0x2d] 351 $C$DW$55 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A25") 352 .dwattr $C$DW$55, DW_AT_location[DW_OP_regx 0x2e] 353 $C$DW$56 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A26") 354 .dwattr $C$DW$56, DW_AT_location[DW_OP_regx 0x2f] 355 $C$DW$57 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A27") 356 .dwattr $C$DW$57, DW_AT_location[DW_OP_regx 0x30] 357 $C$DW$58 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A28") 358 .dwattr $C$DW$58, DW_AT_location[DW_OP_regx 0x31] 359 $C$DW$59 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A29") 360 .dwattr $C$DW$59, DW_AT_location[DW_OP_regx 0x32] 361 $C$DW$60 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A30") 362 .dwattr $C$DW$60, DW_AT_location[DW_OP_regx 0x33] 363 $C$DW$61 .dwtag DW_TAG_TI_assign_register, DW_AT_name("A31") 364 .dwattr $C$DW$61, DW_AT_location[DW_OP_regx 0x34] 365 $C$DW$62 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B16") 366 .dwattr $C$DW$62, DW_AT_location[DW_OP_regx 0x35] 367 $C$DW$63 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B17") 368 .dwattr $C$DW$63, DW_AT_location[DW_OP_regx 0x36] 369 $C$DW$64 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B18") 370 .dwattr $C$DW$64, DW_AT_location[DW_OP_regx 0x37] 371 $C$DW$65 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B19") 372 .dwattr $C$DW$65, DW_AT_location[DW_OP_regx 0x38] 373 $C$DW$66 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B20") 374 .dwattr $C$DW$66, DW_AT_location[DW_OP_regx 0x39] 375 $C$DW$67 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B21") 376 .dwattr $C$DW$67, DW_AT_location[DW_OP_regx 0x3a] 377 $C$DW$68 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B22") 378 .dwattr $C$DW$68, DW_AT_location[DW_OP_regx 0x3b] 379 $C$DW$69 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B23") TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 8 380 .dwattr $C$DW$69, DW_AT_location[DW_OP_regx 0x3c] 381 $C$DW$70 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B24") 382 .dwattr $C$DW$70, DW_AT_location[DW_OP_regx 0x3d] 383 $C$DW$71 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B25") 384 .dwattr $C$DW$71, DW_AT_location[DW_OP_regx 0x3e] 385 $C$DW$72 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B26") 386 .dwattr $C$DW$72, DW_AT_location[DW_OP_regx 0x3f] 387 $C$DW$73 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B27") 388 .dwattr $C$DW$73, DW_AT_location[DW_OP_regx 0x40] 389 $C$DW$74 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B28") 390 .dwattr $C$DW$74, DW_AT_location[DW_OP_regx 0x41] 391 $C$DW$75 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B29") 392 .dwattr $C$DW$75, DW_AT_location[DW_OP_regx 0x42] 393 $C$DW$76 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B30") 394 .dwattr $C$DW$76, DW_AT_location[DW_OP_regx 0x43] 395 $C$DW$77 .dwtag DW_TAG_TI_assign_register, DW_AT_name("B31") 396 .dwattr $C$DW$77, DW_AT_location[DW_OP_regx 0x44] 397 $C$DW$78 .dwtag DW_TAG_TI_assign_register, DW_AT_name("AMR") 398 .dwattr $C$DW$78, DW_AT_location[DW_OP_regx 0x45] 399 $C$DW$79 .dwtag DW_TAG_TI_assign_register, DW_AT_name("CSR") 400 .dwattr $C$DW$79, DW_AT_location[DW_OP_regx 0x46] 401 $C$DW$80 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ISR") 402 .dwattr $C$DW$80, DW_AT_location[DW_OP_regx 0x47] 403 $C$DW$81 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ICR") 404 .dwattr $C$DW$81, DW_AT_location[DW_OP_regx 0x48] 405 $C$DW$82 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IER") 406 .dwattr $C$DW$82, DW_AT_location[DW_OP_regx 0x49] 407 $C$DW$83 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ISTP") 408 .dwattr $C$DW$83, DW_AT_location[DW_OP_regx 0x4a] 409 $C$DW$84 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IN") 410 .dwattr $C$DW$84, DW_AT_location[DW_OP_regx 0x4b] 411 $C$DW$85 .dwtag DW_TAG_TI_assign_register, DW_AT_name("OUT") 412 .dwattr $C$DW$85, DW_AT_location[DW_OP_regx 0x4c] 413 $C$DW$86 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ACR") 414 .dwattr $C$DW$86, DW_AT_location[DW_OP_regx 0x4d] 415 $C$DW$87 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ADR") 416 .dwattr $C$DW$87, DW_AT_location[DW_OP_regx 0x4e] 417 $C$DW$88 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FADCR") 418 .dwattr $C$DW$88, DW_AT_location[DW_OP_regx 0x4f] 419 $C$DW$89 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FAUCR") 420 .dwattr $C$DW$89, DW_AT_location[DW_OP_regx 0x50] 421 $C$DW$90 .dwtag DW_TAG_TI_assign_register, DW_AT_name("FMCR") 422 .dwattr $C$DW$90, DW_AT_location[DW_OP_regx 0x51] 423 $C$DW$91 .dwtag DW_TAG_TI_assign_register, DW_AT_name("GFPGFR") 424 .dwattr $C$DW$91, DW_AT_location[DW_OP_regx 0x52] 425 $C$DW$92 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DIER") 426 .dwattr $C$DW$92, DW_AT_location[DW_OP_regx 0x53] 427 $C$DW$93 .dwtag DW_TAG_TI_assign_register, DW_AT_name("REP") 428 .dwattr $C$DW$93, DW_AT_location[DW_OP_regx 0x54] 429 $C$DW$94 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TSCL") 430 .dwattr $C$DW$94, DW_AT_location[DW_OP_regx 0x55] 431 $C$DW$95 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TSCH") 432 .dwattr $C$DW$95, DW_AT_location[DW_OP_regx 0x56] 433 $C$DW$96 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ARP") 434 .dwattr $C$DW$96, DW_AT_location[DW_OP_regx 0x57] TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 9 435 $C$DW$97 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ILC") 436 .dwattr $C$DW$97, DW_AT_location[DW_OP_regx 0x58] 437 $C$DW$98 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RILC") 438 .dwattr $C$DW$98, DW_AT_location[DW_OP_regx 0x59] 439 $C$DW$99 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DNUM") 440 .dwattr $C$DW$99, DW_AT_location[DW_OP_regx 0x5a] 441 $C$DW$100 .dwtag DW_TAG_TI_assign_register, DW_AT_name("SSR") 442 .dwattr $C$DW$100, DW_AT_location[DW_OP_regx 0x5b] 443 $C$DW$101 .dwtag DW_TAG_TI_assign_register, DW_AT_name("GPLYA") 444 .dwattr $C$DW$101, DW_AT_location[DW_OP_regx 0x5c] 445 $C$DW$102 .dwtag DW_TAG_TI_assign_register, DW_AT_name("GPLYB") 446 .dwattr $C$DW$102, DW_AT_location[DW_OP_regx 0x5d] 447 $C$DW$103 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TSR") 448 .dwattr $C$DW$103, DW_AT_location[DW_OP_regx 0x5e] 449 $C$DW$104 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ITSR") 450 .dwattr $C$DW$104, DW_AT_location[DW_OP_regx 0x5f] 451 $C$DW$105 .dwtag DW_TAG_TI_assign_register, DW_AT_name("NTSR") 452 .dwattr $C$DW$105, DW_AT_location[DW_OP_regx 0x60] 453 $C$DW$106 .dwtag DW_TAG_TI_assign_register, DW_AT_name("EFR") 454 .dwattr $C$DW$106, DW_AT_location[DW_OP_regx 0x61] 455 $C$DW$107 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ECR") 456 .dwattr $C$DW$107, DW_AT_location[DW_OP_regx 0x62] 457 $C$DW$108 .dwtag DW_TAG_TI_assign_register, DW_AT_name("IERR") 458 .dwattr $C$DW$108, DW_AT_location[DW_OP_regx 0x63] 459 $C$DW$109 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DMSG") 460 .dwattr $C$DW$109, DW_AT_location[DW_OP_regx 0x64] 461 $C$DW$110 .dwtag DW_TAG_TI_assign_register, DW_AT_name("CMSG") 462 .dwattr $C$DW$110, DW_AT_location[DW_OP_regx 0x65] 463 $C$DW$111 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DT_DMA_ADDR") 464 .dwattr $C$DW$111, DW_AT_location[DW_OP_regx 0x66] 465 $C$DW$112 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DT_DMA_DATA") 466 .dwattr $C$DW$112, DW_AT_location[DW_OP_regx 0x67] 467 $C$DW$113 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DT_DMA_CNTL") 468 .dwattr $C$DW$113, DW_AT_location[DW_OP_regx 0x68] 469 $C$DW$114 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TCU_CNTL") 470 .dwattr $C$DW$114, DW_AT_location[DW_OP_regx 0x69] 471 $C$DW$115 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_REC_CNTL") 472 .dwattr $C$DW$115, DW_AT_location[DW_OP_regx 0x6a] 473 $C$DW$116 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_XMT_CNTL") 474 .dwattr $C$DW$116, DW_AT_location[DW_OP_regx 0x6b] 475 $C$DW$117 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_CFG") 476 .dwattr $C$DW$117, DW_AT_location[DW_OP_regx 0x6c] 477 $C$DW$118 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_RDATA") 478 .dwattr $C$DW$118, DW_AT_location[DW_OP_regx 0x6d] 479 $C$DW$119 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_WDATA") 480 .dwattr $C$DW$119, DW_AT_location[DW_OP_regx 0x6e] 481 $C$DW$120 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_RADDR") 482 .dwattr $C$DW$120, DW_AT_location[DW_OP_regx 0x6f] 483 $C$DW$121 .dwtag DW_TAG_TI_assign_register, DW_AT_name("RTDX_WADDR") 484 .dwattr $C$DW$121, DW_AT_location[DW_OP_regx 0x70] 485 $C$DW$122 .dwtag DW_TAG_TI_assign_register, DW_AT_name("MFREG0") 486 .dwattr $C$DW$122, DW_AT_location[DW_OP_regx 0x71] 487 $C$DW$123 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DBG_STAT") 488 .dwattr $C$DW$123, DW_AT_location[DW_OP_regx 0x72] 489 $C$DW$124 .dwtag DW_TAG_TI_assign_register, DW_AT_name("BRK_EN") TMS320C6x Assembler PC v7.3.4 Wed Oct 10 12:35:52 2012 Tools Copyright (c) 1996-2012 Texas Instruments Incorporated crap.asm PAGE 10 490 .dwattr $C$DW$124, DW_AT_location[DW_OP_regx 0x73] 491 $C$DW$125 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP0_CNT") 492 .dwattr $C$DW$125, DW_AT_location[DW_OP_regx 0x74] 493 $C$DW$126 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP0") 494 .dwattr $C$DW$126, DW_AT_location[DW_OP_regx 0x75] 495 $C$DW$127 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP1") 496 .dwattr $C$DW$127, DW_AT_location[DW_OP_regx 0x76] 497 $C$DW$128 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP2") 498 .dwattr $C$DW$128, DW_AT_location[DW_OP_regx 0x77] 499 $C$DW$129 .dwtag DW_TAG_TI_assign_register, DW_AT_name("HWBP3") 500 .dwattr $C$DW$129, DW_AT_location[DW_OP_regx 0x78] 501 $C$DW$130 .dwtag DW_TAG_TI_assign_register, DW_AT_name("OVERLAY") 502 .dwattr $C$DW$130, DW_AT_location[DW_OP_regx 0x79] 503 $C$DW$131 .dwtag DW_TAG_TI_assign_register, DW_AT_name("PC_PROF") 504 .dwattr $C$DW$131, DW_AT_location[DW_OP_regx 0x7a] 505 $C$DW$132 .dwtag DW_TAG_TI_assign_register, DW_AT_name("ATSR") 506 .dwattr $C$DW$132, DW_AT_location[DW_OP_regx 0x7b] 507 $C$DW$133 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TRR") 508 .dwattr $C$DW$133, DW_AT_location[DW_OP_regx 0x7c] 509 $C$DW$134 .dwtag DW_TAG_TI_assign_register, DW_AT_name("TCRR") 510 .dwattr $C$DW$134, DW_AT_location[DW_OP_regx 0x7d] 511 $C$DW$135 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DESR") 512 .dwattr $C$DW$135, DW_AT_location[DW_OP_regx 0x7e] 513 $C$DW$136 .dwtag DW_TAG_TI_assign_register, DW_AT_name("DETR") 514 .dwattr $C$DW$136, DW_AT_location[DW_OP_regx 0x7f] 515 $C$DW$137 .dwtag DW_TAG_TI_assign_register, DW_AT_name("CIE_RETA") 516 .dwattr $C$DW$137, DW_AT_location[DW_OP_regx 0xe4] 517 .dwendtag $C$DW$CU 518 No Assembly Errors, No Assembly Warnings
[C674X_0] 100 aec3
