Compiling the following code
volatile unsigned lim;
void for_loop_u(void) {
unsigned i;
for (i=0; i<lim; i++);
void for_loop_i(void) {
int i;
with essentially the following options -k -q -pdr -pdv -pden -pds880 -pds238 -o2 ... -d"LARGE_MODEL" -d"__TMS320F28XX__" ... -mi -ml -v28 --float_support=fpu32 --gen_func_subsections -@"../Debug.lkf"
I get assembly output:
;* FNAME: _for_loop_u FR SIZE: 0 *
;* FUNCTION ENVIRONMENT *
;* FUNCTION PROPERTIES *
;* 0 Parameter, 0 Auto, 0 SOE *
_for_loop_u:
.dwcfi cfa_offset, -2
.dwcfi save_reg_to_mem, 26, 0
.dwcfi save_reg_to_reg, 78, 26
MOVW DP,#_lim ; [CPU_U]
.dwpsn file "for_loop.c",line 5,column 13,is_stmt
MOV AL,@_lim ; [CPU_] |5|
BF $C$L1,EQ ; [CPU_] |5|
; branchcc occurs ; [] |5|
$C$L1:
$C$DW$3 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$3, DW_AT_low_pc(0x00)
.dwattr $C$DW$3, DW_AT_TI_return
LRETR ; [CPU_]
; return occurs ; []
.dwattr $C$DW$2, DW_AT_TI_end_file("for_loop.c")
.dwattr $C$DW$2, DW_AT_TI_end_line(0x06)
.dwattr $C$DW$2, DW_AT_TI_end_column(0x01)
.dwendentry
.dwendtag $C$DW$2
.sect ".text:_for_loop_i"
.clink
.global _for_loop_i
$C$DW$4 .dwtag DW_TAG_subprogram, DW_AT_name("for_loop_i")
.dwattr $C$DW$4, DW_AT_low_pc(_for_loop_i)
.dwattr $C$DW$4, DW_AT_high_pc(0x00)
.dwattr $C$DW$4, DW_AT_TI_symbol_name("_for_loop_i")
.dwattr $C$DW$4, DW_AT_external
.dwattr $C$DW$4, DW_AT_TI_begin_file("for_loop.c")
.dwattr $C$DW$4, DW_AT_TI_begin_line(0x08)
.dwattr $C$DW$4, DW_AT_TI_begin_column(0x06)
.dwattr $C$DW$4, DW_AT_TI_max_frame_size(-2)
.dwpsn file "for_loop.c",line 8,column 23,is_stmt,address _for_loop_i
.dwfde $C$DW$CIE, _for_loop_i
;* FNAME: _for_loop_i FR SIZE: 0 *
_for_loop_i:
;* AL assigned to _i
$C$DW$5 .dwtag DW_TAG_variable, DW_AT_name("i")
.dwattr $C$DW$5, DW_AT_TI_symbol_name("_i")
.dwattr $C$DW$5, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$5, DW_AT_location[DW_OP_reg0]
.dwpsn file "for_loop.c",line 10,column 13,is_stmt
MOV AL,@_lim ; [CPU_] |10|
BF $C$L3,EQ ; [CPU_] |10|
; branchcc occurs ; [] |10|
.dwpsn file "for_loop.c",line 10,column 8,is_stmt
MOVB AL,#0 ; [CPU_] |10|
$C$L2:
ADDB AL,#1 ; [CPU_] |10|
CMP AL,@_lim ; [CPU_] |10|
B $C$L2,LO ; [CPU_] |10|
$C$L3:
$C$DW$6 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$6, DW_AT_low_pc(0x00)
.dwattr $C$DW$6, DW_AT_TI_return
LRETR ; [CPU_]
.dwattr $C$DW$4, DW_AT_TI_end_file("for_loop.c")
.dwattr $C$DW$4, DW_AT_TI_end_line(0x0b)
.dwattr $C$DW$4, DW_AT_TI_end_column(0x01)
.dwendentry
.dwendtag $C$DW$4
This looks as if the for loop in for_loop_u() has been optimized away despite lim being declared volatile.
Can someone please comment on this?
Thanks and regards
Johannes
