Hex6x .c6xabi.exidx extraction from library with linker command file specification
I'm attempting to split out a library into a separate b0* file with other sections (.text, etc).  I'm doing this by creating separate sections to keep common code together, while separating non-common code for two libraries.
Problem:
.c6xabi.exidx will not split out.  Whilst,  .c6xabi.extab, does split properly.   Why does the exidx (exception table indices) not split, but the table (un-wind code entries) itself will?
Linker error:
"../finallnk.cmd", line 72: warning #10068-D: no matching section
relevant portion of my Linker Command File
.c6xabi.exidx
.split_me_exidx { -l=myLibrary.lib(.c6xabi.exidx) }
.c6xabi.extab
.split_me_extab { -l=myLibrary.lib(.c6xabi.extab) }
Generated map file
.c6xabi.exidx   (this demonstrates it didn't work )
* 0       e00625b0 00000930
            e00625b0 00000008         (.c6xabi.exidx.vecs:app_pe64Pe.oe64Pe)
            e00625b8 00000050        myLibrary.lib : Module.obj (.c6xabi.exidx:.text)
            e0062608 00000110                         : Executive.obj (.c6xabi.exidx:.text)
.split_me_extab         (this worked!)
* 0 e0063034 000003b4
e0063034 00000054                 myLibrary.lib : Executive.obj (.c6xabi.extab:_ZN7myLibrary9ExecutiveC1ER10CEventFlagiPNS0_13ExtensibilityE)
Any ideas?
