hello there
normally, when I compile and link an executable with the cgt6, I would expect to see holes in the produced map that are in the range of a couple of bytes, like
87ba7444 00000145 c64pprocess.cpp.obj (.const)
87ba7589 00000003 --HOLE-- [fill = 0]
87ba758c 0000013e rts64plus.lib : xlocale.obj (.const)
87ba76ca 00000002 --HOLE-- [fill = 0]
87ba76cc 00000001 bios_NONINST.a64P : mbx_crea.o64P (.const)
87ba76cd 00000003 --HOLE-- [fill = 0]
87ba76d0 0000010c libtait-framework-main.r64P (.const)
87ba77dc 00000001 bios_NONINST.a64P : sem_crea.o64P (.const)
87ba77dd 00000003 --HOLE-- [fill = 0]
to align sections and symbols. when I do this for a huge project (i.e. the final executable would be in the range of 5MB) the linker starts to introduce holes of random sizes that can go up to a couple of kB (!). when I remove the largest library, it would behave normal again (besides the complaints about the missing symbols, of course). it seems to me like this erroneous behaviour is somehow coupled to the size of the total executable. is there a limit on the size or number of sections/objects the linker can cope with?
unfortunately, i can't boil it down to a limited set of files, nor am i allowed to supply the full set of input files.
but here's the linker command line:
cl6x --run_linker --absolute_exe --map_file=tait-c64pdsp.map --verbose_diagnostics --trampolines=on --disable_auto_rts --warn_sections --issue_remarks --reread_libs --rom_model --search_path=/home/nobss/Work/DBS/build/tmp/cross/c64p/lib --localize=*TID_i* --localize=*TID_v* --localize=*TID_Q2_3* --localize=*TID_Q3_3* --localize=*TID_Q3_5* --localize=*TID_Q4_4* --localize=*TID_Q5_4*
--output_file=tait-c64pdsp.x64P <object-files> <libraries> linker.cmd
and that's the linker file:
/* Do *not* directly modify this file. It was */
/* generated by the Configuration Tool; any */
/* changes risk being overwritten. */
/* INPUT bios_.cdb */
/* MODULE PARAMETERS */
-u _FXN_F_nop
GBL_USERINITFXN = _FXN_F_nop;
-u HEAP
MEM_SEGZERO = HEAP;
-u HEAP
MEM_MALLOCSEG = HEAP;
-u FXN_F_zero
CLK_TIMEFXN = FXN_F_zero;
-u FXN_F_nop
CLK_HOOKFXN = FXN_F_nop;
-u _KNL_tick
PRD_THOOKFXN = _KNL_tick;
-u DDR2
RTDX_DATAMEMSEG = DDR2;
-u DDR2
HST_DSMBUFSEG = DDR2;
-u GBL_NULL
SWI_EHOOKFXN = GBL_NULL;
-u GBL_NULL
SWI_IHOOKFXN = GBL_NULL;
-u SWI_F_exec
SWI_EXECFXN = SWI_F_exec;
-u SWI_F_run
SWI_RUNFXN = SWI_F_run;
-u HEAP
TSK_STACKSEG = HEAP;
-u _dalinkTaskCreate
TSK_VCREATEFXN = _dalinkTaskCreate;
-u _dalinkTaskDelete
TSK_VDELETEFXN = _dalinkTaskDelete;
-u _FXN_F_nop
TSK_VEXITFXN = _FXN_F_nop;
-u _dalinkTaskSwitch
TSK_SWITCHFXN = _dalinkTaskSwitch;
-u GBL_NULL
IDL_CALIBRFXN = GBL_NULL;
-u _dalinkAbortInt
SYS_ABORTFXN = _dalinkAbortInt;
-u _dalinkError
SYS_ERRORFXN = _dalinkError;
-u _UTL_halt
SYS_EXITFXN = _UTL_halt;
-u _UTL_doPutc
SYS_PUTCFXN = _UTL_doPutc;
-u _FXN_F_nop
GIO_CREATEFXN = _FXN_F_nop;
-u _FXN_F_nop
GIO_DELETEFXN = _FXN_F_nop;
-u _FXN_F_nop
GIO_PENDFXN = _FXN_F_nop;
-u _FXN_F_nop
GIO_POSTFXN = _FXN_F_nop;
/* OBJECT ALIASES */
_CACHE_L2 = CACHE_L2;
_CACHE_L1P = CACHE_L1P;
_CACHE_L1D = CACHE_L1D;
_DDR2 = DDR2;
_L1DSRAM = L1DSRAM;
_ARM_RAM = ARM_RAM;
_BOOT = BOOT;
_BOOTTAB = BOOTTAB;
_DDR2_ROM = DDR2_ROM;
_HEAP = HEAP;
_prdStatFunc = prdStatFunc;
_prdSyncFunc = prdSyncFunc;
_HWI_RESET = HWI_RESET;
_HWI_NMI = HWI_NMI;
_HWI_RESERVED0 = HWI_RESERVED0;
_HWI_RESERVED1 = HWI_RESERVED1;
_HWI_INT4 = HWI_INT4;
_HWI_INT5 = HWI_INT5;
_HWI_INT6 = HWI_INT6;
_HWI_INT7 = HWI_INT7;
_HWI_INT8 = HWI_INT8;
_HWI_INT9 = HWI_INT9;
_HWI_INT10 = HWI_INT10;
_HWI_INT11 = HWI_INT11;
_HWI_INT12 = HWI_INT12;
_HWI_INT13 = HWI_INT13;
_HWI_INT14 = HWI_INT14;
_HWI_INT15 = HWI_INT15;
_EVENT4 = EVENT4;
_EVENT5 = EVENT5;
_EVENT6 = EVENT6;
_EVENT7 = EVENT7;
_EVENT8 = EVENT8;
_EVENT9 = EVENT9;
_EVENT10 = EVENT10;
_EVENT11 = EVENT11;
_EVENT12 = EVENT12;
_EVENT13 = EVENT13;
_EVENT14 = EVENT14;
_EVENT15 = EVENT15;
_EVENT16 = EVENT16;
_EVENT17 = EVENT17;
_EVENT18 = EVENT18;
_EVENT19 = EVENT19;
_EVENT20 = EVENT20;
_EVENT21 = EVENT21;
_EVENT22 = EVENT22;
_EVENT23 = EVENT23;
_EVENT24 = EVENT24;
_EVENT25 = EVENT25;
_EVENT26 = EVENT26;
_EVENT27 = EVENT27;
_EVENT28 = EVENT28;
_EVENT29 = EVENT29;
_EVENT30 = EVENT30;
_EVENT31 = EVENT31;
_EVENT32 = EVENT32;
_EVENT33 = EVENT33;
_EVENT34 = EVENT34;
_EVENT35 = EVENT35;
_EVENT36 = EVENT36;
_EVENT37 = EVENT37;
_EVENT38 = EVENT38;
_EVENT39 = EVENT39;
_EVENT40 = EVENT40;
_EVENT41 = EVENT41;
_EVENT42 = EVENT42;
_EVENT43 = EVENT43;
_EVENT44 = EVENT44;
_EVENT45 = EVENT45;
_EVENT46 = EVENT46;
_EVENT47 = EVENT47;
_EVENT48 = EVENT48;
_EVENT49 = EVENT49;
_EVENT50 = EVENT50;
_EVENT51 = EVENT51;
_EVENT52 = EVENT52;
_EVENT53 = EVENT53;
_EVENT54 = EVENT54;
_EVENT55 = EVENT55;
_EVENT56 = EVENT56;
_EVENT57 = EVENT57;
_EVENT58 = EVENT58;
_EVENT59 = EVENT59;
_EVENT60 = EVENT60;
_EVENT61 = EVENT61;
_EVENT62 = EVENT62;
_EVENT63 = EVENT63;
_EVENT64 = EVENT64;
_EVENT65 = EVENT65;
_EVENT66 = EVENT66;
_EVENT67 = EVENT67;
_EVENT68 = EVENT68;
_EVENT69 = EVENT69;
_EVENT70 = EVENT70;
_EVENT71 = EVENT71;
_EVENT72 = EVENT72;
_EVENT73 = EVENT73;
_EVENT74 = EVENT74;
_EVENT75 = EVENT75;
_EVENT76 = EVENT76;
_EVENT77 = EVENT77;
_EVENT78 = EVENT78;
_EVENT79 = EVENT79;
_EVENT80 = EVENT80;
_EVENT81 = EVENT81;
_EVENT82 = EVENT82;
_EVENT83 = EVENT83;
_EVENT84 = EVENT84;
_EVENT85 = EVENT85;
_EVENT86 = EVENT86;
_EVENT87 = EVENT87;
_EVENT88 = EVENT88;
_EVENT89 = EVENT89;
_EVENT90 = EVENT90;
_EVENT91 = EVENT91;
_EVENT92 = EVENT92;
_EVENT93 = EVENT93;
_EVENT94 = EVENT94;
_EVENT95 = EVENT95;
_EVENT96 = EVENT96;
_EVENT97 = EVENT97;
_EVENT98 = EVENT98;
_EVENT99 = EVENT99;
_EVENT100 = EVENT100;
_EVENT101 = EVENT101;
_EVENT102 = EVENT102;
_EVENT103 = EVENT103;
_EVENT104 = EVENT104;
_EVENT105 = EVENT105;
_EVENT106 = EVENT106;
_EVENT107 = EVENT107;
_EVENT108 = EVENT108;
_EVENT109 = EVENT109;
_EVENT110 = EVENT110;
_EVENT111 = EVENT111;
_EVENT112 = EVENT112;
_EVENT113 = EVENT113;
_EVENT114 = EVENT114;
_EVENT115 = EVENT115;
_EVENT116 = EVENT116;
_EVENT117 = EVENT117;
_EVENT118 = EVENT118;
_EVENT119 = EVENT119;
_EVENT120 = EVENT120;
_EVENT121 = EVENT121;
_EVENT122 = EVENT122;
_EVENT123 = EVENT123;
_EVENT124 = EVENT124;
_EVENT125 = EVENT125;
_EVENT126 = EVENT126;
_EVENT127 = EVENT127;
_KNL_swi = KNL_swi;
_PRD_swi = PRD_swi;
_TSK_idle = TSK_idle;
_statIdl = statIdl;
_LOG_system = LOG_system;
/* MODULE GBL */
SECTIONS {
.vers (COPY): {} /* version information */
-priority
--trampolines
-llnknone.a64P
-ldrivers.a64P /* device drivers support */
-lsioboth.a64P /* supports both SIO models */
-lbiosDM420IDMA0.a64P /* BIOS clock specific library */
-lbios_NONINST.a64P /* DSP/BIOS support */
-lrts64plus.lib /* C and C++ run-time library support */
_GBL_CACHE = GBL_CACHE;
_BCACHE_bootInit=_BCACHE_setCacheToSram;
/* MODULE MEM */
-stack 0x4000
MEMORY {
CACHE_L2 : origin = 0x11800000, len = 0x10000
CACHE_L1P : origin = 0x11e08000, len = 0x8000
CACHE_L1D : origin = 0x11f10000, len = 0x8000
DDR2 : origin = 0x87e00000, len = 0x100000
L1DSRAM : origin = 0x11f04000, len = 0xc000
ARM_RAM : origin = 0x10008000, len = 0x4000
BOOT : origin = 0x87800000, len = 0x20
BOOTTAB : origin = 0x87800020, len = 0xa0
DDR2_ROM : origin = 0x87800100, len = 0x5fff00
HEAP : origin = 0x87f00000, len = 0x100000
/* MODULE CLK */
SECTIONS {
.clk: {
/* no CLK objs */
} > DDR2, RUN_START(CLK_A_TABBEG)
_CLK_PRD = CLK_PRD;
_CLK_COUNTSPMS = CLK_COUNTSPMS;
_CLK_REGS = CLK_REGS;
_CLK_USETIMER = CLK_USETIMER;
_CLK_TIMERNUM = CLK_TIMERNUM;
_CLK_TDDR = CLK_TDDR;
/* MODULE PRD */
SECTIONS {
.prd: RUN_START(PRD_A_TABBEG), RUN_END(PRD_A_TABEND) {
} > DDR2
PRD_A_TABLEN = 2;
_HWI_CFGDISPATCHED = HWI_CFGDISPATCHED;
/* MODULE SWI */
SECTIONS {
.swi: RUN_START(SWI_A_TABBEG), RUN_END(SWI_A_TABEND) {
} > DDR2
SWI_A_TABLEN = 2;
/* MODULE TSK */
SECTIONS {
.tsk: {
*(.tsk)
} > DDR2
/* MODULE IDL */
SECTIONS {
.idl: {
*(.idl)
} > DDR2, RUN_START(IDL_A_TABBEG)
.idlcal: {
*(.idlcal)
} > DDR2, RUN_START(IDL_A_CALBEG)
LOG_A_TABLEN = 1; _LOG_A_TABLEN = 1;
PIP_A_TABLEN = 0;
SECTIONS {
.bss: {} > DDR2
.far: {} > DDR2
.sysdata: {} > DDR2
.dsm: {} > DDR2
.cio: {} > DDR2
.sysregs: {} > DDR2
.trcdata: {} > DDR2
.hwi: {} > DDR2
.TSK_idle$stk: {
*(.TSK_idle$stk)
} > DDR2
/* LOG_system buffer */
.LOG_system$buf: align = 0x100 {} > DDR2
.args: align=4 fill=0 {
*(.args)
. += 0x4;
} > DDR2
.trace: fill = 0x0 align = 0x4 {
_SYS_PUTCBEG = .;
. += 0x200;
_SYS_PUTCEND = . - 1;
} > DDR2
.hst: RUN_START(HST_A_TABBEG), RUN_START(_HST_A_TABBEG), RUN_END(HST_A_TABEND), RUN_END(_HST_A_TABEND) {
} > DDR2
.log: RUN_START(LOG_A_TABBEG), RUN_START(_LOG_A_TABBEG), RUN_END(LOG_A_TABEND), RUN_END(_LOG_A_TABEND) {
} > DDR2
.pip: RUN_START(PIP_A_TABBEG), RUN_START(_PIP_A_TABBEG), RUN_END(PIP_A_TABEND), RUN_END(_PIP_A_TABEND) {
} > DDR2
.sts: RUN_START(STS_A_TABBEG), RUN_START(_STS_A_TABBEG), RUN_END(STS_A_TABEND), RUN_END(_STS_A_TABEND) {
} > DDR2
.stack: align = 0x8 {
GBL_stackbeg = .;
*(.stack)
GBL_stackend = GBL_stackbeg + 0x4000 - 1;
_HWI_STKBOTTOM = GBL_stackbeg + 0x4000 - 8;
_HWI_STKTOP = GBL_stackbeg;
} > DDR2
.hwi_vec: {
*(.hwi_vec)
} align = 0x400, RUN_START(HWI_A_VECS) > DDR2_ROM
frt: {} > DDR2_ROM
.mem: {} > DDR2_ROM
.bios: {} > DDR2_ROM
.data: {} > DDR2_ROM
.gio: {} > DDR2_ROM
.pinit: {} > DDR2_ROM
.sys: {} > DDR2_ROM
.text: {} > DDR2_ROM
.cinit: {} > DDR2_ROM
.switch: {} > DDR2_ROM
.gblinit: {} > DDR2_ROM
.sysinit: {} > DDR2_ROM
GROUP {
.const: align = 0x8 {}
.printf (COPY): {}
} > DDR2_ROM
.HEAP$heap: {
. += 0x100000;
} RUN_START(HEAP$B), RUN_START(_HEAP_base), RUN_SIZE(HEAP$L), RUN_SIZE(_HEAP_length) > HEAP
i'm using the 6.1.13 version of the code generation tools.
any ideas?
cheers,
sam
