Why not state hex6x -b option to generate binary in assembly tools user guide?
 Why not state hex6x.exe -b option in assembly tools user guide?
Customer often ask how to convert .out to .bin, and we always point them to google for hex2bin tools, in fact TI hex6x.exe has this feature.
  • The term "binary file" is not standardized.  While the general concept is fairly clear, the details are not.  And how the hex utility -b option handles some of those details does not work for all users.
     The cg_xml package includes a method for converting TI object files to what most users consider to be a flat binary.  These details are copied from the readme file.
    Convert TI Executable to .bin Format
    The Windows batch file tiobj2bin.bat converts a TI executable file, COFF
    or ELF, to a "binary" file.  This binary format is the one defined by the
    "objcopy" Unix command.  Here is a description of the format from the
    objcopy man page ...
           When objcopy generates a raw binary file, it will essentially produce
           a memory dump of the  contents of  the input object file.  All symbols
           and relocation information will be discarded.  The memory dump will
           start at the load address of the lowest section copied into the output
           file.
    This batch file makes use of a new script mkhex4bin.pl to create a hex
    utility command file.  The hex utility does the heavy lifting.  Documentation
    on how to use tiobj2bin.bat is contained in comments at the top of the
    file.  To see a command invocation summary, run tiobj2bin.bat with no
    parameters.
    Thanks and regards,
    -George
