Hello TI support:
I am currently trying to pack data into 1 bit position of the data structure for serial communiction. In many compile using #pragma pack(1) to pack tight 1-byte positions. Why the TI compile doesn't support this.
What is the syntax for TI compile to support 1-byte packing (similar to #pragma pack(1) )?
------------- For example; Byte packing in Microsoft Visual Studio: ------------------
// pack data into 1 bit position
#pragma pack(push, 1)
// pack is into byte position NORMAL
//#pragma pack(pop)
----------- For example; RealView Compile --------------
#pragma push
#pragma pack(1)
#pragma pop
We support the GCC extension for packed structures instead. See this Wiki article for details on which targets are supported, and all the caveats.
Thanks and regards,
-George
Hi George,
I am using Code Composer Studio Version 4.2.1.00004 for the Stellaris DK-LM3S9B96 software development board.
How can I enable the Code Composer Studio to accept GCC extension?
Mike
If you are using the TI ARM compiler version 4.6.1 (do not confuse that version number with the CCS version number) or later, the GCC packed attribute is available when you use the --gcc option.
Hi Paul,
Yes, I have the --gcc option select. So, the default of the CCS 4.0 support it.
How to determine the TI ARM compiler version 4.6.1 from CCS 4.0?
Thank you
Mike
----------- Build CCS 4.0 configuration settings ----------------
-mv7M3 -g -O2 --gcc --define=ccs --define=PART_LM3S9B96 --define=TARGET_IS_TEMPEST_RB1 --define=UART_BUFFERED --define=SIMPLICITI_CONFIG_HEADER --include_path="C:/Program Files/Texas Instruments/ccsv4/tools/compiler/tms470/include" .........blah blah.......... --diag_warning=225 -me --gen_func_subsections --abi=eabi --code_state=16 --ual
------------------------- CCS 4.0 Platform Details ---------------------
*** Date: Wed Jan 19 09:24:04 CST 2011
*** Platform Details:
*** System properties:
DEFAULT_CCS_TARGET_CONFIGURATION=......................
XPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
awt.toolkit=sun.awt.windows.WToolkit
deployment.browser.args=-raise -remote openURL(%u,new-window)
deployment.browser.path=C:\Program Files\Mozilla Firefox\firefox.exe
deployment.cache.jarcompression=0
deployment.cache.max.size=-1
deployment.capture.mime.types=false
deployment.console.startup.mode=HIDE
deployment.control.panel.log=false
deployment.home.j2se.url=http://java.sun.com/j2se/
deployment.javapi.cache.enabled=true
deployment.javapi.lifecycle.exception=false
deployment.javapi.log.filename=
deployment.javapi.runtime.type=0
deployment.javapi.trace.filename=
deployment.javaws.associations=ASK_USER
deployment.javaws.autodownload=ALWAYS
deployment.javaws.home.jnlp.url=http://java.sun.com/products/javawebstart
deployment.javaws.installURL=http://java.sun.com/products/autodl/j2se
deployment.javaws.logFileName=
deployment.javaws.muffin.max=256
deployment.javaws.shortcut=ASK_IF_HINTED
deployment.javaws.ssv.enabled=true
deployment.javaws.traceFileName=
deployment.javaws.uninstall.shortcut=false
deployment.javaws.update.timeout=1500
deployment.log=false
deployment.mime.types.use.default=true
deployment.proxy.bypass.local=false
deployment.proxy.override.hosts=
deployment.proxy.same=false
deployment.proxy.type=3
deployment.repository.askdownloaddialog.show=true
deployment.repository.enabled=true
deployment.security.SSLv2Hello=true
deployment.security.SSLv3=true
deployment.security.TLSv1=false
deployment.security.askgrantdialog.notinca=true
deployment.security.askgrantdialog.show=true
deployment.security.authenticator=true
deployment.security.browser.keystore.use=true
deployment.security.clientauth.keystore.auto=true
deployment.security.jsse.hostmismatch.warning=true
deployment.security.sandbox.awtwarningwindow=true
deployment.security.sandbox.jnlp.enhanced=true
deployment.security.trusted.policy=
deployment.trace=false
deployment.update.mime.types=true
deployment.version=6.0
eclipse.buildId=4.2.1.00004
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Program Files\Texas Instruments\ccsv4\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
9b8_8c
-vm
C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=com.ti.ccstudio.branding.product
eclipse.startTime=1295449940546
eclipse.vm=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-XX:MaxPermSize=96m
-DXPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dxpcom.bridge.executeOnDedicatedThread=no
-Dorg.eclipse.swt.browser.XULRunnerPath=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dosgi.instance.area.default=....................
-jar
C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\endorsed
java.ext.dirs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\ext
java.home=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre
java.io.tmpdir=C:\DOCUME~1\WINCE_~1\LOCALS~1\Temp\
java.library.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin;.;C:\WINDOWS\system32;C:\WINDOWS;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:/Program Files/Texas Instruments/xdctools_3_20_03_63;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Intel\DMIX;C:\Program Files\doxygen\bin;"C:\Program Files\Notepad++";c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\TortoiseSVN\bin;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files\GnuWin32\bin;C:/Program Files/Texas Instruments/xdctools_3_20_03_63;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\emulation\analysis\bin\
java.net.useSystemProxies=true
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_14-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_14
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_14-b03
javaplugin.proxy.config.type=direct
line.separator=
org.eclipse.swt.browser.XULRunnerInitialized=true
org.eclipse.ui.workbench.activePerspective=org.eclipse.cdt.ui.CPerspective
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax.activity,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=com.ti.ccstudio.osgi,org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles
osgi.configuration.area=file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/configuration/
osgi.framework=file:/c:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-201010201600.jar
osgi.framework.beginningstartlevel=1
osgi.framework.extensions=com.ti.ccstudio.osgi
osgi.framework.shape=jar
osgi.framework.version=3.2.0.vTI-201010201600
osgi.frameworkClassPath=., file:c:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.201010201600.jar
osgi.install.area=file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/
osgi.instance.area=file:/C:/Documents and Settings/wince_dev/My Documents/workspace2/
osgi.instance.area.default=file:/C:/Documents and Settings/wince_dev/My Documents/workspace/
osgi.logfile=C:\Documents and Settings\wince_dev\My Documents\workspace2\.metadata\.log
osgi.manifest.cache=C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\Program Files\Texas Instruments\ccsv4\eclipse\plugins\com.ti.ccstudio.branding_4.1.0.201010201600\splash.bmp
osgi.splashPath=platform:/base/plugins/com.ti.ccstudio.branding
osgi.syspath=c:\Program Files\Texas Instruments\ccsv4\eclipse\plugins
osgi.user.area=file:/C:/Documents and Settings/wince_dev/user/
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\rt.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\i18n.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\sunrsasign.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\jsse.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\jce.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\charsets.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\classes
sun.boot.library.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 3
user.country=US
user.dir=C:\Program Files\Texas Instruments
user.home=C:\Documents and Settings\wince_dev
user.language=en
user.name=wince_dev
user.timezone=America/Chicago
user.variant=
*** Features:
com.ti.ccstudio (4.0.0.201010201600) "CCE Product Branding"
com.ti.dvt.graph.visualization (2.0.0.201008091238) "Visualization Plug-in"
com.ti.dvt.profileanalysismanager (2.0.0.201008091238) "Profiler Analysis Manager"
com.ti.dvt.rta (2.0.0.201008091238) "DSP/BIOS RTA"
com.ti.dvt.scripting.ui (2.0.0.201008091238) "DVT Scripting Plugin"
com.xdais_7_10_00_06 (7.10.00.06) "XDAIS 7.10.00.06 Help"
org.eclipse.cdt (3.1.0.vTI-201010201600) "Eclipse C/C++ Development Tools"
org.eclipse.platform (3.2.0.vTI-201010201600) "Eclipse Platform"
org.eclipse.rcp (3.2.0.vTI-201010201600) "Eclipse RCP"
org.eclipse.rtsc.xdctools_3.20 (3.20.3.63) "XDCtools UI Plugin"
org.eclipse.tm.terminal (1.0.0.vTI-201010201600) "Target Management Terminal Widget"
*** Plug-in Registry:
com.ibm.icu (3.4.4.1) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
com.ti.bios.rta (5.41.7.24) "BIOS 5 RTA Plug-in" [Resolved]
com.ti.ccstudio.apps (4.2.0.201010201600) "CCS Headless Applications" [Resolved]
com.ti.ccstudio.binaryparser (4.0.0.201010201600) "CCE Binary Parser" [Active]
com.ti.ccstudio.branding (4.1.0.201010201600) "CCE Product Branding" [Active]
com.ti.ccstudio.breakpoint (4.0.0.201010201600) "Property Breakpoint Interfaces" [Resolved]
com.ti.ccstudio.breakpoint.core (4.0.0.201010201600) "Property Breakpoint Core" [Active]
com.ti.ccstudio.breakpoint.ui (4.0.0.201010201600) "Property Breakpoint User Interface" [Active]
com.ti.ccstudio.buildDefinitions.C2000 (4.2.0.201010201600) "CCS C2000 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.C2000_4.1 (4.2.0.201010201600) "CCE C2000 v4.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_5.0 (4.2.0.201010201600) "CCE C2000 v5.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_5.1 (4.2.0.201010201600) "CCE C2000 v5.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_5.2 (4.2.0.201010201600) "CCE C2000 v5.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_6.0 (4.2.0.201010201600) "CCS C2000 v6.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_legacy (4.1.0.201010201600) "CCS C2000 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5400 (4.2.0.201010201600) "CCS C5400 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.C5400_4.1 (4.2.0.201010201600) "CCE C5400 v4.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5400_4.2 (4.2.0.201010201600) "CCE C5400 v4.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5400_legacy (4.1.0.201010201600) "CCS C5400 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500 (4.2.0.201010201600) "CCS C5500 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.C5500_4.0 (4.2.0.201010201600) "CCE C5500 v4.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500_4.1 (4.2.0.201010201600) "CCE C5500 v4.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500_4.2 (4.2.0.201010201600) "CCE C5500 v4.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500_4.3 (4.2.0.201010201600) "CCE C5500 v4.3 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500_legacy (4.1.0.201010201600) "CCE C5500 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000 (4.2.0.201010201600) "CCS C6000 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.C6000_5.3 (4.2.0.201010201600) "C6000 v5.3 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_6.0 (4.2.0.201010201600) "C6000 v6.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_6.1 (4.2.0.201010201600) "C6000 v6.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_7.0 (4.2.0.201010201600) "C6000 v7.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_7.2 (4.1.3.201010201600) "C6000 v7.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_legacy (4.1.0.201010201600) "C6000 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.core (4.2.0.201010201600) "Managed Build Definitions Core" [Active]
com.ti.ccstudio.buildDefinitions.GNU (4.1.0.201010201600) "CCE GNU Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.MSP430 (4.2.0.201010201600) "CCS MSP430 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.MSP430_2.0 (4.2.0.201010201600) "MSP430 v2.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.0 (4.2.0.201010201600) "MSP430 v3.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.1 (4.2.0.201010201600) "MSP430 v3.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.2 (4.2.0.201010201600) "MSP430 v3.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.3 (4.1.3.201010201600) "MSP430 v3.3 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.4 (4.2.0.201010201600) "MSP430 v3.4 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_legacy (4.2.0.201010201600) "CCS MSP430 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470 (4.2.0.201010201600) "CCS TMS470 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.TMS470_2.54 (4.2.0.201010201600) "CCE TMS470 v2.54 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_2.71 (4.2.0.201010201600) "CCS TMS470 v2.71 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.1 (4.2.0.201010201600) "CCS TMS470 v4.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.4 (4.2.0.201010201600) "CCE TMS470 v4.4 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.5 (4.2.0.201010201600) "CCS TMS470 v4.5 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.6 (4.2.0.201010201600) "CCS TMS470 v4.6 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.7 (4.2.0.201010201600) "CCS TMS470 v4.7 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.8 (4.2.0.201010201600) "CCS TMS470 v4.8 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_legacy (4.1.0.201010201600) "CCE TMS470 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.c2000help.doc (4.0.0) "com.ti.ccstudio.c2000help.doc" [Resolved]
com.ti.ccstudio.c5000help.doc (4.0.0) "com.ti.ccstudio.c5000help.doc" [Resolved]
com.ti.ccstudio.c6000help.doc (4.0.0) "com.ti.ccstudio.c6000help.doc" [Resolved]
com.ti.ccstudio.debug.breakpoint.ui (4.0.0.201010201600) "TI Debugger Breakpoint User Interface" [Active]
com.ti.ccstudio.debug.cacheview (1.0.0) "Cache View Plug-in" [Resolved]
com.ti.ccstudio.debug.core (4.0.0.201010201600) "CCE Debug Core" [Active]
com.ti.ccstudio.debug.memoryserver (4.0.0.201010201600) "Memory Server Plugin" [Resolved]
com.ti.ccstudio.debug.mptv (4.0.0.201010201600) "MptvName" [Resolved]
com.ti.ccstudio.debug.registers.ui (4.1.0.201010201600) "Registers UI Plug-in" [Resolved]
com.ti.ccstudio.debug.server.extensions (4.0.0.201010201600) "CCE Debug Server Extensions" [Active]
com.ti.ccstudio.debug.server.factory (4.0.0.201010201600) "CCE Debug Server Factory" [Active]
com.ti.ccstudio.debug.trace.core (4.0.0.201010201600) "Trace Core" [Resolved]
com.ti.ccstudio.debug.trace.msp430 (4.0.0.201010201600) "MSP430 State Storage" [Resolved]
com.ti.ccstudio.debug.trace.ui (4.0.0.201010201600) "Trace UI" [Resolved]
com.ti.ccstudio.debug.ui (4.2.0.201010201600) "CCE Debug User Interface" [Active]
com.ti.ccstudio.debug.ui.msp430 (4.0.0.201010201600) "CCE Debug User Interface for MSP430" [Active]
com.ti.ccstudio.device.setup (4.2.0.201010201600) "CCS Device Setup" [Active]
com.ti.ccstudio.disassembly.core (4.1.0.201010201600) "CCS Disassembly Core Plug-in" [Active]
com.ti.ccstudio.disassembly.ui (4.1.0.201010201600) "CCS Disassembly UI Plug-in" [Active]
com.ti.ccstudio.errorparser (4.0.0.201010201600) "CCE Error Parser" [Resolved]
com.ti.ccstudio.gelhelp.doc (4.0.0.201010201600) "GEL Help Document Plug-in" [Resolved]
com.ti.ccstudio.jline (4.0.0.201010201600) "Jline" [Resolved]
com.ti.ccstudio.mainhelp.doc (4.0.0) "CCS Help 4.0 Plugin" [Resolved]
com.ti.ccstudio.managedbuild.core (4.2.0.201010201600) "CCS Managed Build Core" [Active]
com.ti.ccstudio.managedbuild.ui (4.2.0.201010201600) "CCE Managed Build User Interface" [Active]
com.ti.ccstudio.marker (4.0.0.201010201600) "Marker Plug-in" [Active]
com.ti.ccstudio.memory.ui (4.0.0.201010201600) "CCS Memory UI Plug-in" [Active]
com.ti.ccstudio.multi.purpose.view (4.2.0.201010201600) "CCS Control Panel View" [Active]
com.ti.ccstudio.multi.purpose.view.contributors (4.1.0.201010201600) "Control Panel View Contributors" [Active]
com.ti.ccstudio.osgi (4.0.0.201010201600) "CCE OSGi Hooks" [Resolved]
com.ti.ccstudio.pinconnect (4.0.0.201010201600) "PinConnect Tool Plug-in" [Resolved]
com.ti.ccstudio.pinport.common (4.0.0.201010201600) "Common Plug-in For Pin and Port Connect Tools" [Resolved]
com.ti.ccstudio.portconnect (4.0.0.201010201600) "PortConnect Tool Plug-in" [Resolved]
com.ti.ccstudio.product.paths (4.1.0.201010201600) "CCS Product Paths" [Active]
com.ti.ccstudio.profile.setup (4.0.0.201010201600) "Profile Setup Plug-in" [Resolved]
com.ti.ccstudio.profile.setup.ui (4.0.0.201010201600) "Profile SetupUI Plug-in" [Active]
com.ti.ccstudio.project.core (4.2.0.201010201600) "CCS Project Core" [Resolved]
com.ti.ccstudio.project.templates (4.2.0.201010201600) "CCS Built-in Project Templates" [Resolved]
com.ti.ccstudio.project.ui (4.2.0.201010201600) "CCE Project User Interface" [Active]
com.ti.ccstudio.rhino (4.0.0.201010201600) "CCE Rhino JavaScript Engine" [Resolved]
com.ti.ccstudio.scripting.console (4.0.0.201010201600) "Scripting Console" [Active]
com.ti.ccstudio.scripting.dss (4.0.0.201010201600) "Debug Server Scripting" [Resolved]
com.ti.ccstudio.scripting.environment (4.0.0.201010201600) "CCE Scripting Environment" [Resolved]
com.ti.ccstudio.scripting.gss (4.2.0.201010201600) "CodeComposer Studio Scripting" [Resolved]
com.ti.ccstudio.scripting.ui (4.0.0.201010201600) "User Interface Scripting" [Resolved]
com.ti.ccstudio.system.hotmenu (4.0.0.201010201600) "CCS System Hotmenu Plug-in" [Active]
com.ti.ccstudio.system.setup (4.2.0.201010201600) "CCE System Setup" [Active]
com.ti.ccstudio.system.setup.ui (4.0.0.201010201600) "CCS System Setup Editor Plug-in" [Active]
com.ti.ccstudio.tms470help.doc (4.0.0) "com.ti.ccstudio.tms470help.doc" [Resolved]
com.ti.ccstudio.trace.control (4.1.0.201010201600) "Trace Control Plug-in" [Active]
com.ti.ccstudio.ui (4.1.0.201010201600) "CCS Platform User Interface" [Active]
com.ti.ccstudio.ui.cheatsheets (4.0.0.201010201600) "Cheatsheets Plug-in" [Resolved]
com.ti.ccstudio.ui.forms (4.0.0.201010201600) "Forms Plug-in" [Resolved]
com.ti.ccstudio.update (4.0.0.201010201600) "CCS Update Plug-in" [Active]
com.ti.ccstudio.useaccess (4.0.0.201010201600) "Use Access Plug-in" [Resolved]
com.ti.common.core (4.2.0.201010201600) "Common TI Platform Core" [Active]
com.ti.common.managedbuild.core (4.2.0.201010201600) "TI Common Managed-Build Core" [Active]
com.ti.common.managedbuild.ui (4.2.0.201010201600) "TI Common Managed-Build UI" [Active]
com.ti.common.project.core (4.2.0.201010201600) "TI Common Project Core" [Resolved]
com.ti.common.project.ui (4.2.0.201010201600) "TI Common Project UI" [Resolved]
com.ti.common.ui (4.1.0.201010201600) "Common TI User Interface" [Active]
com.ti.common.update.discovery (4.1.1.201010201600) "Extension Site Discovery" [Active]
com.ti.dvt.analysis.framework (2.0.0.201008091238) "DVT Analysis Framework" [Resolved]
com.ti.dvt.cceideadapter (2.0.0.201008091238) "CCStudio v4 IDE Adapter" [Resolved]
com.ti.dvt.ccesymbolmanager (2.0.0.201008091238) "CCStudio 4.0 Symbol Manager" [Resolved]
com.ti.dvt.codegenCoverage (2.0.0.201008091238) "Codegen_Code_Coverage Plug-in" [Active]
com.ti.dvt.control.engine (2.0.0.201008091238) "DVT Control Engine" [Resolved]
com.ti.dvt.control.gui (2.0.0.201008091238) "DVT Control GUI" [Resolved]
com.ti.dvt.coverageplugin (2.0.0.201008091238) "Coverageplugin Plug-in" [Active]
com.ti.dvt.datamodel (2.0.0.201008091238) "DVT Model" [Active]
com.ti.dvt.graph.visualization (2.0.0.201008091238) "Visualization Plug-in" [Active]
com.ti.dvt.graph.visualization.doc (2.0.0.201008091238) "Graph Visualization Help Plug-in" [Resolved]
com.ti.dvt.gridview (2.0.0.201008091238) "Gridview Plug-in" [Resolved]
com.ti.dvt.ideadapter (2.0.0.201008091238) "IDEAdapter" [Active]
com.ti.dvt.ideadapterplugin (2.0.0.201008091238) "IDEAdapter Plug-in" [Active]
com.ti.dvt.ofssymbolmanager (2.0.0.201008091238) "OFSSymbolManager Plug-in" [Resolved]
com.ti.dvt.profileanalysis (2.0.0.201008091238) "DVT Profile Analysis Providers" [Resolved]
com.ti.dvt.profileanalysis.doc (2.0.0.201008091238) "DVT Profile Analysis Providers Help" [Resolved]
com.ti.dvt.profileanalysismanager (2.0.0.201008091238) "Profiler Analysis Manager" [Resolved]
com.ti.dvt.profileanalysismanagerplugin (2.0.0.201008091238) "Profile Server Plug-in" [Active]
com.ti.dvt.profiledata (2.0.0.201008091238) "Profile Data Source" [Resolved]
com.ti.dvt.rovsupport (2.0.0.201008091238) "Rovsupport Plug-in" [Active]
com.ti.dvt.rovsupport.doc (2.0.0.201008091238) "ROV Support Doc Plug-in" [Resolved]
com.ti.dvt.rta (2.0.0.201008091238) "DSP/BIOS RTA" [Active]
com.ti.dvt.rta.doc (2.0.0.201008091238) "RTA Help" [Resolved]
com.ti.dvt.rta.interfaces (2.0.0.201008091238) "RTA interfaces" [Resolved]
com.ti.dvt.scripting.ui (2.0.0.201008091238) "DVT Scripting Plugin" [Resolved]
com.ti.dvt.server (3.20.3.63) "ROV Controller" [Resolved]
com.ti.dvt.sourceref (2.0.0.201008091238) "Source Reference Plug-in" [Resolved]
com.ti.dvt.sourcerefplugin (2.0.0.201008091238) "Source Reference Preference Plug-in" [Resolved]
com.ti.dvt.symbolmanager (2.0.0.201008091238) "SymbolManager" [Resolved]
com.ti.dvt.symbolmanagerplugin (2.0.0.201008091238) "SymbolManager Plug-in" [Active]
com.ti.dvt.tidisassembly (2.0.0.201008091238) "TIDisassembly Plug-in" [Resolved]
com.ti.dvt.trace (2.0.0.201008091238) "DVT Trace Analyzer" [Active]
com.ti.dvt.trace.doc (2.0.0.201008091238) "Trace_Analyzer_User_Guide" [Resolved]
com.ti.dvt.ui (2.0.0.201008091238) "DvtUI Plug-in" [Active]
com.ti.dvt.ui.doc (2.0.0.201008091238) "com.ti.dvt.ui.doc" [Resolved]
com.ti.dvt.via.doc (2.0.0.201008091238) "Image Analyzer" [Resolved]
com.ti.dvt.via.imvr (2.0.0.201008091238) "Image Viewer Plug-in" [Resolved]
com.ti.dvt.via.plugin (2.0.0.201008091238) "Image Analyzer" [Active]
com.ti.dvt.via.plugin.ccs (2.0.0.201008091238) "Image Analyzer (CCS)" [Active]
com.ti.fnc (4.0.0.201010201600) "FlexNet Connect Plug-in" [Active]
com.ti.rta (3.20.3.63) "XDC RTA Plug-in" [Resolved]
com.ti.rta.support (3.20.3.63) "Shared ROV interface implementations" [Resolved]
com.ti.rtsc.DSPBIOS.product_5.41.7.24 (5.41.7.24) "DSP/BIOS Tool Plugin" [Resolved]
com.ti.rtsc.DSPBIOS.product.ui (5.41.7.24) "DSP/BIOS UI Plugin" [Resolved]
com.ti.rtsc.IPC.product_1.21.2.23 (1.21.2.23) "IPC (Multicore and I/O) Tool Plugin" [Resolved]
com.ti.rtsc.IPC.product.ui (1.21.2.23) "IPC (Multicore and I/O) UI Plugin" [Resolved]
com.ti.rtsc.SYSBIOS.product_6.30.2.42 (6.30.2.42) "SYS/BIOS Tool Plugin" [Resolved]
com.ti.rtsc.SYSBIOS.product.ui (6.30.2.42) "SYS/BIOS UI Plugin" [Resolved]
com.ti.targets.omf (3.20.3.63) "Object file readers" [Resolved]
com.ti.util (2.0.0.201008091238) "Util Plug-in" [Resolved]
com.ti.util.ui (2.0.0.201008091238) "Util Plug-in" [Active]
com.xdais_7_10_00_06 (7.10.00.06) "XDAIS 7.10.00.06 Help" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.cdt (3.1.0.200606261600) "Eclipse C/C++ Development Tools" [Resolved]
org.eclipse.cdt.core (3.1.0.vTI-201010201600) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.win32 (3.1.0.200606261600) "C/C++ Development Tools Core for Windows" [Resolved]
org.eclipse.cdt.debug.core (3.1.0.vTI-201010201600) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.mi.core (3.1.0.200606261600) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (3.1.0.200606261600) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (3.1.0.vTI-201010201600) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.launch (3.1.0.vTI-201010201600) "C/C++ Development Tools Launching Support" [Resolved]
org.eclipse.cdt.make.core (3.1.0.vTI-201010201600) "C/C++ Standard make Build Core" [Resolved]
org.eclipse.cdt.make.ui (3.1.0.vTI-201010201600) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (3.1.0.vTI-201010201600) "C/C++ Managed Builder Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.0.vTI-201010201600) "GNU Managed Build Definitions" [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.1.0.vTI-201010201600) "C/C++ Managed Builder UI" [Active]
org.eclipse.cdt.refactoring (3.1.0.vTI-201010201600) "C/C++ Refactoring" [Resolved]
org.eclipse.cdt.ui (3.1.0.vTI-201010201600) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.2.0.vTI-201010201600) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism" [Active]
org.eclipse.core.expressions (3.2.0.v20060605-1400) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.2.0.v20060605-1400) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.vTI-201010201600) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.vTI-201010201600) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.vTI-201010201600) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060603) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.dd.debug.memory.renderings.traditional (1.0.0.vTI-201010201600) "Traditional Memory Rendering" [Resolved]
org.eclipse.debug.core (3.2.0.vTI-201010201600) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.vTI-201010201600) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0.v20060626) "Draw2d" [Resolved]
org.eclipse.equinox.common (3.2.0.vTI-201010201600) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.common (3.2.0.vTI-201008051800) "Common Eclipse Runtime" [Installed]
org.eclipse.equinox.preferences (3.2.0.v20060601) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.0.v20060601) "Extension Registry Support" [Active]
org.eclipse.gef (3.2.0.v20060626) "Graphical Editing Framework" [Resolved]
org.eclipse.help (3.2.0.v20060602) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server" [Resolved]
org.eclipse.help.base (3.2.0.v20060601) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.0.v20060602) "Help System Webapp" [Resolved]
org.eclipse.jface (3.2.0.vTI-201010201600) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding" [Resolved]
org.eclipse.jface.text (3.2.0.vTI-201010201600) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.0.v20060605-1400) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.2.0.v20060605-1400) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environment Runtime" [Resolved]
org.eclipse.platform (3.2.0.vTI-201010201600) "Eclipse Platform" [Resolved]
org.eclipse.rcp (3.2.0.vTI-201010201600) "Eclipse RCP" [Resolved]
org.eclipse.rtsc.project.templates (3.20.3.63) "RTSC Built-in Project Templates" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS (1.2.0.201010201600) "DSP/BIOS Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31 (1.2.0.201010201600) "DSP/BIOS v5.31 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40 (1.2.0.201010201600) "DSP/BIOS v5.40 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC (1.2.0.201010201600) "XDC Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00 (1.2.0.201010201600) "XDC v3.00 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10 (1.2.0.201010201600) "XDC v3.10 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15 (1.2.0.201010201600) "XDC v3.15 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16 (1.2.0.201010201600) "XDC v3.16 Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.contenttype (3.20.3.63) "RTSC file content describers" [Resolved]
org.eclipse.rtsc.xdctools.core (3.20.3.63) "XDCtools core" [Resolved]
org.eclipse.rtsc.xdctools.managedbuild.core (1.2.0.201010201600) "RTSC Managed Build Core" [Active]
org.eclipse.rtsc.xdctools.managedbuild.ui (1.2.0.201010201600) "RTSC Managed Build UI" [Active]
org.eclipse.rtsc.xdctools.model (3.20.3.63) "Model Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.model.lang (3.20.3.63) "Lang Fragment" [Resolved]
org.eclipse.rtsc.xdctools.product_3.20.3.63 (3.20.3.63) "XDCtools Tool Plugin" [Resolved]
org.eclipse.rtsc.xdctools.product.ui (3.20.3.63) "XDCtools UI Plugin" [Resolved]
org.eclipse.rtsc.xdctools.rta (3.20.3.63) "XDCtools RTA" [Resolved]
org.eclipse.rtsc.xdctools.server (3.20.3.63) "XDCscript command server" [Resolved]
org.eclipse.rtsc.xdctools.sg (3.20.3.63) "XDCtools SG Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.sg.def (3.20.3.63) "XDCtools SG Def Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.ui (3.20.3.63) "Eclipse Plug-in" [Active]
org.eclipse.rtsc.xdctools.ui.contentassist (3.20.3.63) "RTSC C/C++ Content Assist" [Resolved]
org.eclipse.rtsc.xdctools.ui.editors (3.20.3.63) "Editors Plug-in" [Resolved]
org.eclipse.search (3.2.0.vTI-201010201600) "Search Support" [Active]
org.eclipse.swt (3.2.0.vTI-201010201600) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.0.vTI-201010201600) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.2.0.I200606051140) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.0.M20060628) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.0.I200606051140) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.0.I200606051140) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tm.terminal (1.0.0.vTI-201010201600) "Target Management Terminal Widget" [Resolved]
org.eclipse.tm.terminal.serial (1.0.0.v20070605) "Target Management Terminal Serial Connector" [Resolved]
org.eclipse.tm.terminal.view (1.0.0.v20070620) "Target Management Terminal View" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.0.vTI-201010201600) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.0.vTI-201010201600) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.vTI-201010201600) "Console" [Active]
org.eclipse.ui.editors (3.2.0.vTI-201010201600) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.100.vTI-201010201600) "External Tools" [Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.0.vTI-201010201600) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.0.v20060601) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.0.v20060602) "Universal Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.0.I20060605-1400) "Common Navigator View" [Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20060605-1400) "Navigator Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.2.0.vTI-201010201600) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.0.I20060605-1400) "Tabbed Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.0.vTI-201010201600) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.vTI-201010201600) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.2.0.vTI-201010201600) "Install/Update Configurator" [Active]
org.eclipse.update.core (3.2.0.vTI-201010201600) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.0.vTI-201010201600) "Install/Update Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.0.v20060605) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.2.0.vTI-201010201600) "Install/Update UI" [Active]
system.bundle (3.2.0.vTI-201010201600) "OSGi System Bundle" [Active]
xdc.tools.xgconf.modeldata (3.20.3.63) "Modeldata Plug-in" [Resolved]
*** User Preferences:
#Wed Jan 19 09:24:04 CST 2011
/instance/org.eclipse.cdt.managedbuilder.core/properties/grlib.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.1330941337/com.ti.ccstudio.buildDefinitions.TMS470.Debug.254580361=\#\r\n\#Tue Jan 18 16\:21\:19 CST 2011\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.library.compilerDebug.100231076\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.library.librarianDebug.1802144948\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470.Debug.254580361\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.libraryDebugToolchain.1499848055\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\n
@org.eclipse.cdt.debug.core=3.1.0.vTI-201010201600
/instance/org.eclipse.ui.ide/platformState=1294180125855
/instance/org.eclipse.cdt.managedbuilder.core/properties/usblib.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.1744356621/com.ti.ccstudio.buildDefinitions.TMS470.Release.1444619537=\#\r\n\#Tue Jan 18 16\:21\:19 CST 2011\r\ncom.ti.ccstudio.buildDefinitions.TMS470.Release.1444619537\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrcState\\\=-1\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/Controller.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.2143718189/com.ti.ccstudio.buildDefinitions.TMS470.Release.1840911366=\#\r\n\#Tue Jan 18 16\:21\:19 CST 2011\r\ncom.ti.ccstudio.buildDefinitions.TMS470.Release.1840911366\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrcState\\\=-1\\r\\n\r\n
/instance/com.ti.ccstudio.debug.core/CCEDebugOptions.TARGET_CONFIGURATION_FILE=C\:/A_projects/Soul/trunk/SourceCode/Controller/target_LM3S9B96_config.ccxml
@com.ti.ccstudio.debug.ui=4.2.0.201010201600
file_export_version=3.0
/project/Controller/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Debug.1957668251/internalBuilder/enabled=false
/instance/org.eclipse.cdt.managedbuilder.core/macros/workspace=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<macros>\r\n<stringMacro name\="SW_ROOT" type\="VALUE_PATH_DIR" value\="C\:/StellarisWare"/>\r\n<stringMacro name\="SRC_ROOT" type\="VALUE_PATH_DIR" value\="C\:/A_projects/Soul/trunk/SourceCode"/>\r\n</macros>\r\n
/project/i2s_demo/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Release.791301200/internalBuilder/ignoreErr=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/driverlib.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.513319276/com.ti.ccstudio.buildDefinitions.TMS470.Debug.1457915166=\#\r\n\#Tue Jan 18 16\:21\:19 CST 2011\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.libraryDebugToolchain.2043645373\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470.Debug.1457915166\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.library.compilerDebug.880633025\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.library.librarianDebug.2095443568\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/grlib.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.1330941337/com.ti.ccstudio.buildDefinitions.TMS470.Release.218777868=\#\r\n\#Tue Jan 18 16\:21\:19 CST 2011\r\ncom.ti.ccstudio.buildDefinitions.TMS470.Release.218777868\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrcState\\\=-1\\r\\n\r\n
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.core.resources/pathvariable.CCS_TMS470_4_6_3_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/tms470
/instance/org.eclipse.core.resources/version=1
@org.eclipse.cdt.managedbuilder.core=3.1.0.vTI-201010201600
/project/i2s_filter/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Release.293933529/internalBuilder/ignoreErr=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
/instance/org.eclipse.core.resources/pathvariable.CCS_MSP430_3_3_1_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/msp430
/project/Controller/org.eclipse.cdt.managedbuilder.core/environment/project/com.ti.ccstudio.buildDefinitions.TMS470.Debug.1957668251=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<environment/>\r\n
/project/i2s_demo/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Debug.1503645863/internalBuilder/enabled=false
/instance/org.eclipse.ui/showIntro=false
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Documents and Settings\\wince_dev\\My Documents\\workspace2,C\:\\Documents and Settings\\wince_dev\\My Documents\\workspace
/instance/org.eclipse.core.resources/pathvariable.CCS_C5500_4_3_6_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/c5500
/instance/org.eclipse.core.resources/pathvariable.CCS_C6000_7_0_3_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/c6000
/instance/org.eclipse.core.resources/pathvariable.CCS_C2000_5_2_6_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/c2000
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/project/i2s_filter/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Debug.542690987/internalBuilder/ignoreErr=true
/project/Controller/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Debug.1957668251/internalBuilder/ignoreErr=true
@org.eclipse.ui.ide=3.2.0.vTI-201010201600
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.core.cDebug.common_source_containers=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<sourceLookupDirector>\r\n<sourceContainers duplicates\="false"/>\r\n</sourceLookupDirector>\r\n
/project/i2s_filter/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Release.293933529/internalBuilder/enabled=false
@org.eclipse.cdt.ui=3.1.0.vTI-201010201600
@org.eclipse.core.resources=3.2.0.vTI-201010201600
@org.eclipse.ui=3.2.0.vTI-201010201600
/instance/org.eclipse.cdt.managedbuilder.core/properties/Controller.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.2143718189/com.ti.ccstudio.buildDefinitions.TMS470.Debug.1957668251=\#\r\n\#Tue Jan 18 16\:21\:19 CST 2011\r\ncom.ti.ccstudio.buildDefinitions.TMS470.Debug.1957668251\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.exe.DebugToolchain.813684686\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.exe.compilerDebug.1896725462\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.exe.linkerDebug.1828168653\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\n
@com.ti.ccstudio.ui=4.1.0.201010201600
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/com.ti.ccstudio.ui/CCStudioUIPreferences.IS_NOT_FIRST_CCE_LAUNCH=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/driverlib.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.513319276/com.ti.ccstudio.buildDefinitions.TMS470.Release.1592790743=\#\r\n\#Tue Jan 18 16\:21\:19 CST 2011\r\ncom.ti.ccstudio.buildDefinitions.TMS470.Release.1592790743\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrcState\\\=-1\\r\\n\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=2
/project/i2s_demo/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Release.791301200/internalBuilder/enabled=false
@com.ti.common.ui=4.1.0.201010201600
/project/Controller/org.eclipse.cdt.managedbuilder.core/environment/project=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<environment/>\r\n
/instance/org.eclipse.core.resources/pathvariable.CCS_C5400_4_2_0_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/c5400
@org.eclipse.ui.editors=3.2.0.vTI-201010201600
/instance/org.eclipse.cdt.managedbuilder.core/properties/usblib.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.1744356621/com.ti.ccstudio.buildDefinitions.TMS470.Debug.1863109604=\#\r\n\#Tue Jan 18 16\:21\:19 CST 2011\r\ncom.ti.ccstudio.buildDefinitions.TMS470.Debug.1863109604\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.libraryDebugToolchain.1104599836\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.library.librarianDebug.167899792\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.TMS470_4.6.library.compilerDebug.2133168260\=\\\#\\r\\n\\\#Tue Jan 18 16\\\:21\\\:19 CST 2011\\r\\nrebuildState\\\=false\\r\\n\r\n
/project/Controller/org.eclipse.ltk.core.refactoring/org.eclipse.ltk.core.refactoring.enable.project.refactoring.history=false
/instance/org.eclipse.core.resources/pathvariable.SW_ROOT=C\:/StellarisWare
/project/Controller/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Release.1840911366/internalBuilder/ignoreErr=true
/project/Controller/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Release.1840911366/internalBuilder/enabled=false
/project/i2s_filter/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Debug.542690987/internalBuilder/enabled=false
/instance/com.ti.ccstudio.debug.ui/com.ti.ccstudio.debug.ui.legacy.LaunchConfigurationMigrator.ran=true
/instance/com.ti.common.ui/activeProject=Controller
@com.ti.ccstudio.debug.core=4.0.0.201010201600
/project/i2s_demo/org.eclipse.cdt.managedbuilder.core/com.ti.ccstudio.buildDefinitions.TMS470.Debug.1503645863/internalBuilder/ignoreErr=true
/instance/org.eclipse.core.resources/pathvariable.SRC_ROOT=C\:/A_projects/Soul/trunk/SourceCode
*** Current Install Configuration:
Install configuration:
Last changed on Jan 4, 2011
Location: file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/configuration/org.eclipse.update/platform.xml
Configured sites:
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/
file:/C:/Program Files/Texas Instruments/bios_6_30_02_42/eclipse/
platform:/base/
file:/C:/Program Files/Texas Instruments/bios_5_41_07_24/eclipse/
file:/C:/Program Files/Texas Instruments/ipc_1_21_02_23/eclipse/
file:/C:/Program Files/Texas Instruments/xdais_7_10_00_06/eclipse/
Configured features:
ID: org.eclipse.rtsc.xdctools.product.ui, Version: 3.20.3.63
ID: com.ti.bios_6.30, Version: 6.30.2.42
ID: com.ti.ccstudio.msp430, Version: 4.0.0.201010201600
ID: com.ti.ccstudio.emu.5.0.158.1, Version: 5.0.158.1
ID: com.blackhawkdsp.ccstudio.emulation, Version: 4.2.0.6
ID: org.eclipse.cdt, Version: 3.1.0.vTI-201010201600
ID: com.ti.dvt.rov, Version: 2.0.0.201008091238
ID: com.ti.ccstudio.c5400, Version: 4.0.0.201010201600
ID: com.ti.ccstudio.product, Version: 4.2.1.00004
ID: com.ti.cgt.c6000.7.0, Version: 7.0.2
ID: com.ti.cgt.c5400.4.2, Version: 4.2.0
ID: com.ti.ccstudio.tms470, Version: 4.0.0.201010201600
ID: com.ti.ccstudio.c2000, Version: 4.0.0.201010201600
ID: com.ti.dvt.ccstudio, Version: 2.0.0.201008091238
ID: com.ti.ccstudio.c6000, Version: 4.0.0.201010201600
ID: org.eclipse.tm.terminal, Version: 1.0.0.vTI-201010201600
ID: org.eclipse.platform, Version: 3.2.0.vTI-201010201600
ID: com.ti.ccstudio.c5500, Version: 4.0.0.201010201600
ID: com.ti.dvt.profileanalysismanager, Version: 2.0.0.201008091238
ID: com.ti.dvt.via.ccs, Version: 2.0.0.201008091238
ID: com.ti.dvt.analysis, Version: 2.0.0.201008091238
ID: com.ti.dvt.trace.ccs, Version: 2.0.0.201008091238
ID: com.ti.ccstudio.branding, Version: 4.0.0.201010201600
ID: org.eclipse.rcp, Version: 3.2.0.vTI-201010201600
ID: com.sd.ccstudio.emulation, Version: 4.2.1.8
ID: com.ti.cgt.tms470.4.6, Version: 4.6.3
ID: com.ti.ccstudio.rtsc, Version: 4.0.0.201010201600
ID: com.ti.dvt.rta, Version: 2.0.0.201008091238
ID: com.ti.dvt.graph.visualization, Version: 2.0.0.201008091238
ID: com.ti.dvt.scripting.ui, Version: 2.0.0.201008091238
ID: com.ti.dvt.core.ccstudio, Version: 2.0.0.201008091238
ID: com.ti.cgt.c2000.5.2, Version: 5.2.6
ID: com.ti.dvt.control, Version: 2.0.0.201008091238
ID: com.ti.cgt.c5500.4.3, Version: 4.3.6
ID: com.ti.bios_5.41, Version: 5.41.7.24
ID: com.ti.ipc_1.21, Version: 1.21.2.23
ID: com.xdais_7_10_00_06, Version: 7.10.00.06
Configured plug-ins:
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/com.ti.dvt.server_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/com.ti.rta.support_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/com.ti.rta_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/com.ti.targets.omf_3.20.3.63/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.project.templates_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.contenttype_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.core_3.20.3.63/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.model.lang_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.model_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.product.ui_3.20.3.63/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.product_3.20.3.63/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.rta_3.20.3.63/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.server_3.20.3.63/
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.sg.def_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.sg_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.ui.contentassist_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.ui.editors_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/org.eclipse.rtsc.xdctools.ui_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/xdctools_3_20_03_63/eclipse/plugins/xdc.tools.xgconf.modeldata_3.20.3.63.jar
file:/C:/Program Files/Texas Instruments/bios_6_30_02_42/eclipse/plugins/com.ti.rtsc.SYSBIOS.product.ui_6.30.2.42/
file:/C:/Program Files/Texas Instruments/bios_6_30_02_42/eclipse/plugins/com.ti.rtsc.SYSBIOS.product_6.30.2.42/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ibm.icu_3.4.4.1.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.jcraft.jsch_0.1.28.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.apps_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.binaryparser_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.branding_4.1.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.core_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.1_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.0_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.1_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.2_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_6.0_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_legacy_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_4.1_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_4.2_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_legacy_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.0_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.1_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.2_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.3_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_legacy_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_5.3_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_6.0_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_6.1_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_7.0_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_7.2_4.1.3.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_legacy_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.GNU_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_2.0_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.0_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.1_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.2_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.3_4.1.3.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.4_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_legacy_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_2.54_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_2.71_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.1_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.4_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.5_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.6_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.7_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.8_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_legacy_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.c2000help.doc_4.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.c5000help.doc_4.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.c6000help.doc_4.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.breakpoint.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.cacheview_1.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.core_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.memoryserver_4.0.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.mptv_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.registers.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.extensions_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.factory_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.core_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.msp430_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui.msp430_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.device.setup_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.core_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.errorparser_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.gelhelp.doc_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.jline_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.mainhelp.doc_4.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.marker_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.memory.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view.contributors_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinconnect_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinport.common_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.portconnect_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.product.paths_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.templates_4.2.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.rhino_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.console_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.dss_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.environment_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.gss_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.hotmenu_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup.ui_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.tms470help.doc_4.0.0.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.trace.control_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.cheatsheets_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.forms_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.update_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.useaccess_4.0.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.project.core_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.project.ui_4.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.ui_4.1.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.update.discovery_4.1.1.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.analysis.framework_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.cceideadapter_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ccesymbolmanager_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.codegenCoverage_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.control.engine_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.control.gui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.coverageplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.datamodel_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization.doc_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.gridview_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapterplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapter_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ofssymbolmanager_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis.doc_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanagerplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanager_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profiledata_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport.doc_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.interfaces_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.scripting.ui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourcerefplugin_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourceref_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanagerplugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanager_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.tidisassembly_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.doc_2.0.0.201008091238/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.imvr_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin.ccs_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.fnc_4.0.0.201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util.ui_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util_2.0.0.201008091238.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.apache.ant_1.6.5/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.apache.lucene_1.4.103.v20060601/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ant.core_3.1.100.v20060531.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core.win32_3.1.0.200606261600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.mi.core_3.1.0.200606261600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.mi.ui_3.1.0.200606261600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.launch_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.core_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.gnu.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.refactoring_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.ui_3.1.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt_3.1.0.200606261600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.compare_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.boot_3.1.100.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.commands_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.contenttype_3.2.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.expressions_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filebuffers_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filesystem.win32.x86_1.0.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filesystem_1.0.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.jobs_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources.compatibility_3.2.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources.win32_3.2.0.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry_3.2.0.v20060603/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility_3.1.100.v20060603.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.variables_3.1.100.v20060605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.dd.debug.memory.renderings.traditional_1.0.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.core_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.ui_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.draw2d_3.2.0.v20060626.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201008051800.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.preferences_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.registry_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.gef_3.2.0.v20060626.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.appserver_3.1.100.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.base_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.ui_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.webapp_3.2.0.v20060602/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.databinding_1.0.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.text_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi.services_3.1.100.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi.util_3.1.100.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.pde.runtime_3.2.0.v20060605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.platform_3.2.0.vTI-201010201600/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rcp_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.core_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.ui_1.2.0.201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.search_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.core_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.core_3.2.0.M20060628.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.0.I200606011710.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ui_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.ui_3.2.0.I200606051140.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.text_3.2.0.v20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal.serial_1.0.0.v20070605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal.view_1.0.0.v20070620.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal_1.0.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tomcat_4.1.130.v20060601/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.browser_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.console_3.1.100.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.editors_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.externaltools_3.1.100.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.forms_3.2.0.v20060602.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.ide_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.intro.universal_3.2.0.v20060602/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.intro_3.2.0.v20060601.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.navigator.resources_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.navigator_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.win32_3.2.0.I20060605-1400.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20060605-1400/
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.configurator_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core.win32_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.scheduler_3.2.0.v20060605.jar
file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.ui_3.2.0.vTI-201010201600.jar
file:/C:/Program Files/Texas Instruments/bios_5_41_07_24/eclipse/plugins/com.ti.bios.rta_5.41.7.24.jar
file:/C:/Program Files/Texas Instruments/bios_5_41_07_24/eclipse/plugins/com.ti.rtsc.DSPBIOS.product.ui_5.41.7.24/
file:/C:/Program Files/Texas Instruments/bios_5_41_07_24/eclipse/plugins/com.ti.rtsc.DSPBIOS.product_5.41.7.24/
file:/C:/Program Files/Texas Instruments/ipc_1_21_02_23/eclipse/plugins/com.ti.rtsc.IPC.product.ui_1.21.2.23/
file:/C:/Program Files/Texas Instruments/ipc_1_21_02_23/eclipse/plugins/com.ti.rtsc.IPC.product_1.21.2.23/
file:/C:/Program Files/Texas Instruments/xdais_7_10_00_06/eclipse/plugins/com.xdais_7_10_00_06/
I'm not a much of an expert on CCS, but last I knew selecting "About..." under the Help menu would include the version number for Code Generation Tools in its display. However, that will be the currently selected toolset. You may have more than one available. The Component Manager will show you what is available and what is selected. It used to be that you would get to the Component Manager via a buttom on that same "About..." display. If this is no longer the deal, my guess is somebody on this forum will let us know.
Also, you could try using the packed attribute and see if the compiler chokes on it. That would be pretty definitive.
To determine the version of compiler being used in your project build in CCS4, go to Project Properties->CCS Build. Note that you could have multiple versions of the codegen tools installed (by installing updates via Help->Software Updates->Find and Install), so the CCS Build interface can be used to select the version of codegen tools you want to use for the build.
The default version originally installed with CCS can be found in the \<install_dir>\ccsv4\tools\compiler\tms470 folder. If this is the only version you have, then it will be the only version displayed in the CCS Build window.
Hi:
My CCS4 Too-chain Settings to "Code Generation tools version: 4.6.3".
In the header file (protocol.h). I have #pragma pack(1), and #pragma pack(pop) at the bottom of the header file. The CCS4 compiler complaint that "unrecognized #pragma" warning.
Do you have CCS4 / TI compiler bug?
NOTE: Using Microsoft Visual Studio; I don't have problem #pragma and it work inside the header file.
Mike
The TI compilers do not currently support the #pragma pack construct. What Georgem was referring to was the GCC packed attribute. (See GCC Variable Attributes and GCC Type Attributes for more information.)
