• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCrafter Development Platform » Is there a USB driver available to talk to DLP LightCrafter board?
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
  • ELD
    Posted by ELD
    on Apr 12 2012 17:47 PM
    Intellectual910 points
    No, the DLP LightCrafter DM365 software is using USB in USB gadget mode a.k.a Ethernet over USB mode. When connected to PC it is recognized as Ethernet device and uses RNDIS – Remote Driver Interface Specification driver to communicate with the DLP LightCrafter.
    USB
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Daniel Hochbaum
    Posted by Daniel Hochbaum
    on Jan 30 2012 20:09 PM
    Prodigy120 points
    I've tried connecting the lightcrafter through usb to two windows 7 professional 64bit computers. I've followed the directions in the user manual but when trying to install the remote NDIS compatible device driver I consistently get a code 10 error: "This device cannot start. (Code 10)". Any advise?
    Report Abuse
    • Reply
  • PedroGelabert
    Posted by PedroGelabert
    on Jan 31 2012 09:56 AM
    Intellectual1980 points
    Daniel,
    We have been using LightCrafter on a couple of 64-bit Windows 7 computers here without issue. Seems Windows 7 installs the incorrect driver and you need to remove it before installing the new one. Windows 7 includes two drivers, one under Microsoft and another under Microsoft Corporation. Use the "Microsoft Corporation" one.
    The code 10 errors are due to corrupt drivers, so you will need to uninstall it and re-install it. To uninstall, go to the device manager (Control Panel -> System and Security -> System -> Device Manager) and remove the networking entries for RNDIS. Look under Network adapters, select RNDIS/Ethernet Gadget and right-click uninstall. Then install following the steps in the LightCrafter User's Guide.
    Report Abuse
    • Reply
  • Daniel Hochbaum
    on Jan 31 2012 14:26 PM
    Prodigy120 points
    Hi Pedro,
    I have repeated the above protocol several times yesterday and today without luck. I was careful to pick microsoft corporation. I have a laptop which is 64bit windows 7 (home, not professional), which had no problem connecting to the device, but these windows 7 professional desktops continually give me the code 10 error. Would it be possible to get a link to download these drivers explicitly? Maybe that would help...
    Daniel
    Report Abuse
    • Reply
  • Håkan Wedelsbäck
    Posted by Håkan Wedelsbäck
    on Feb 01 2012 04:07 AM
    Prodigy30 points
    I have the same problem on 32-bit Windows 7 Enterprise edition. Even if I reinstall the correct driver I get the code 10 error.
    /Håkan
    Report Abuse
    • Reply
  • Daniel Hochbaum
    on Feb 01 2012 22:46 PM
    Prodigy120 points
    Have you tested the USB connection with windows 7 professional? I have successfully installed the driver after connecting the device with computers running Windows 7 Home Premium and Windows 7 Ultimate editions, but no luck with my computer running windows 7 professional (all 64 bit), even after I did a clean re-install of the OS. Those other 2 versions of windows superficially seem to have media abilities not built into professional, could that be a problem? Again, could a driver be made available for download?
    Daniel
    Report Abuse
    • Reply
  • Peter Ferland
    Posted by Peter Ferland
    on Feb 02 2012 09:31 AM
    Prodigy110 points
    I have it working under Windows 7 Profession x64 so I imagine that isn't the issue.  If it helps anyone the driver used on my computer was found at C:\Windows\system32\DRIVERS\usb8023.sys
    Provider: Microsoft Corporation
    File Version 6.1.7600.16385 (win7_rtm.090713-1255)
    In USB Ethernet/RNDIS Gadget properties under the driver tab the driver provider appears to be "Acer Incorporated", Driver Date 1/13/2010 and driver version 1.0.0.0.
    Report Abuse
    • Reply
  • PedroGelabert
    on Feb 02 2012 18:29 PM
    Peter,
    Thanks for your help!! Greatly appreciate the screen shots with driver info.
    Daniel and Håkan,
    Microsoft has a page giving some information on Code 10 errors here. There might be some useful debug information there.
    Report Abuse
    • Reply
  • Marc Mignard
    Posted by Marc Mignard
    on Feb 07 2012 16:53 PM
    Prodigy40 points
    On my Win 7 computer, only some of the USB ports work. On the ports that did not work, however, the LightCrafter device showed up as "unknown" under USB controllers, rather than as "RNDIS" device.
    Report Abuse
    • Reply
  • Divya
    Posted by Divya
    on Feb 07 2012 17:33 PM
    Expert3680 points
    Hi Marc,
    Welcome to TI DLP E2E Forum.
    I have seen the same behavior on my computer running on Windows XP.  We have acknowledged the issue and still exploring on it.
    From your post, I understand the you are able to connect LightCrafter to the computer through USB. Please let us know if you need any help.
    Divya
    www.ti.com/mems
    Report Abuse
    • Reply
  • PedroGelabert
    on Feb 09 2012 19:46 PM
    Marc, Some USB ports on a PC have an internal USB hub. It will help us debug this issue if you can indicate if the port that did not work had a hub or not. I have also seen that Windows assigns a driver to each port. Sometimes, there is some issue and I needed to uninstall the driver on the problematic port and reinstall it.
    Report Abuse
    • Reply
  • Peter Ferland
    on Feb 14 2012 23:04 PM
    Prodigy110 points
    So this worked with two computers I tried it on - a HP z200 SFF workstation (Win7 x64) and an early 2011 Apple MBP (boot camp, Win 7 x64).  I now am trying to get this driver working on a Dell Precision T5500 (Win7 32bit) and its doing the code 10 thing.  On the T5500 the RNDIS device appearws on Port_#0001.Hub_#0004 and only "USB Root Hub" devices appear in device manager (no "Generic" hubs).  On my MBP it appears as Port_#0003.Hub_#0006, which is not one of the hubs in "Generic USB Hubs".  The MBP and z200 only contain EHCI controllers where as the Dell has 2 EHCI and 6 UHCI.
    I think this is the same problem with this post on Microsoft's forums here which unfortunately went unresolved.
    Report Abuse
    • Reply
  • Peter Ferland
    on Feb 15 2012 03:16 AM
    Prodigy110 points
    As an update to my previous post, I installed a EHCI PCI USB card and the device is recognized on that.  Looks like thats your only chance if you're on a Dell workstation...
    Report Abuse
    • Reply
  • Adam Cohen91406
    Posted by Adam Cohen91406
    on Mar 02 2012 18:31 PM
    Prodigy30 points
    Peter,
    Can you please recommend the brand and model number of EHCI PCI USB card that you used?  We are facing the same problem trying to get the lightcrafter to work on a Dell T5500.  Also, I am curious whether you tried any of the internal USB ports.  The T5500 spec sheet lists 11 USB ports: 2 front panel, 6 back panel, and three internal ones on the motherboard.  Thanks!
    Adam
    Report Abuse
    • Reply
  • Peter Ferland
    on Mar 05 2012 13:31 PM
    Prodigy110 points
    I didn't try any of the internal ports.  The card we used is this one: http://www.amazon.co.jp/%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%AD%E3%83%BC-BUFFALO-IFC-PCI5U2V/dp/B0000DJLOC
    This exact card is apparently only available in Japan, but it is based on a VIA VT6212, something like this one should be equivalent: http://www.newegg.com/Product/Product.aspx?Item=N82E16815158220
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
