• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCrafter and LightCrafter 4500 Development Platform Forum » How many patterns can be loaded in DLPC300's memory (mDDR) in the LightCrafter?
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
This question is not answered
Divya
Posted by Divya
on Oct 18 2012 15:33 PM
Expert3855 points
It is possible to store 96 bit planes (608*684) for fast pattern mode, which translates to a little over 5MB.  The mDDR memory also stores information for the DMD system like splash screens, sequences, color tables, etc. So not all the 32MB of memory is available for pattern storage.
However, additional 24-bit RGB patterns can be input through the parallel interface at 60Hz rate. These patterns can be stored in SD card or NAND flash with much more storage capacity in the "External Pattern" mode. The DM365 can read the patterns from SD card or NAND flash and input into the DLPC300. This mode is currently not supported in the software and will be offered in a future software revision.
www.ti.com/mems
DLPC300 FPGA
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Jordanka Tasseva
    Posted by Jordanka Tasseva
    on Oct 15 2012 05:34 AM
    Intellectual355 points
    Dear Divya,
    We are considering to purchase one of the DMD based projector systems available. We need to be able to project binary frames at 4-5 kHz rate (coming from the PC preferably without additional harware). I understand from some of your replies that an upgrade was expected to the Light Crafter allowing for loading of more than 96 frames (with res. 608/684) on the memory of the device and then projecting them at 4kHz. Has that upgrade already been released? What is the advantage of a CEL5500 system in respect to the Light Crafter. Another possibility of high-speed projection would be to stream 24 binary frames preliminarily encoded in single 24 bit color frame. Is any of these two systems able to decode and then - project these as binary frames at the required speed? Another question is the brightness of the projected images - projecting at maximum rate would it be sufficient to see the image at normal light or just in dark room?
    Thank you for your time,
    Jordanka
    Report Abuse
    • Reply
  • Justin Lemon
    Posted by Justin Lemon
    on Oct 17 2012 10:20 AM
    Intellectual285 points
    Hi Jordanka,
    Thanks for your participation on the E2E Community.  I want to follow up in regards to your above questions about the LightCrafter vs CEL5500 Light Engines.  I have a few specification tables I want to reference in order to easily outline the differences between the two light Engines.
    Report Abuse
    • Reply
  • Jordanka Tasseva
    on Oct 17 2012 10:34 AM
    Hi Justin,
    Thank you for your reply. Looking forward to your considerations.
    Kind regards,
    Jordanka
    Report Abuse
    • Reply
  • Justin Lemon
    on Oct 17 2012 10:39 AM
    Hi Jordanka,
    Thanks for the quick reply.  For some reason, it did not post my full reply.  I have some specifications charts for both the CEL5500 & LightCrafter as well as their respective Chipset and a straight-forward Product Comparison Outline.  I'm working with the E2E Team now to see if I can retrieve it somehow.  I will keep you updated.
    Justin
    Report Abuse
    • Reply
  • Jordanka Tasseva
    Hi Justin,
    Thank you. I am mainly interested in where stays the limitation to the speed. Both systems support frame rates that are ok for us - LCrafter - 4 kHz and the CEL - 5 kHz binary. As far as I understood in real time transfer from the PC, however, due to limitations of the HDMI's maximum transfer rate, the speed is limited to 1440 Hz binary (speaking for the Light Crafter). From the specifications I understood that on the mDDR can be uploaded and subsequently projected (at 4 kHz) (24x 4) 96 binary frames. Then we can send the next "package of 4 24bit frames" and subsequently project them. However, if I understood correctly there is 1/60 s lag for the buffer to be filled, that practically means that the rate of 4 kHz can not be achieved (since between each 96 binary images, projected at 4k). I don't know if I put it clear. But what I understood is the following: If we want to consecutively upload to the maximum capacity of the buffer 3 sets of (24x4)binary frames and then display them, we wouldn't be able to do this in (3x96/4000) 72 ms but will need (72 ms + 50 ms) for these three sets that is 2360 Hz. If that is correct, my question is: how could that be resolved in order to reach the maximum rate of 4 kHz. And are these 4 kHz limited only by the response time of the DMD chip or also by the process of decoding from 24 bit to binary. In other words, if we don't have a limitation from the graphics card of the PC and can work at for example 200 Hz, does the electronics of the Light Crafter allow for projection of 200x24 binary frames. If not, is that possible with the CEL.
    Many thanks! Have a nice day,
    Jordanka
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
