I am using a batch file to execute a CCS v4 build. The batch file is show below:
:: (U) Set environment variables for the build
set CCS4_DIR=C:\Program Files\Texas Instruments\ccsv4\eclipse
set WORKSPACE_DIR=U:\My Program\My Workspace\
set PROJECT_NAME=MyProject
:: (U) Execute the Java build command for the RPI project the CCS workspace
"%CCS4_DIR%\jre\bin\java" -jar "%CCS4_DIR%\startup.jar" -data "%WORKSPACE_DIR%" -application com.ti.ccstudio.apps.projectBuild -ccs.projects %PROJECT_NAME% -ccs.configuration %1
The batch file renders the following output, and ultimately Java exception when executed with the command "MyBat Debug":
C:\>"C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\java" -jar "C:\Program Files\Texas Instruments\ccsv4\ecli
pse\startup.jar" -data "U:\My Program\My Workspace\" -application com.ti.ccstudio.apps.projectBuild -ccs.projects MyProject -ccs.configuration Debug
CCS headless build starting... [Wed Aug 04 08:26:10 CDT 2010]
Pre processing...
Building...
org.eclipse.core.internal.resources.ResourceException: Errors during build.
at org.eclipse.core.internal.resources.Project.build(Project.java:91)
at com.ti.ccstudio.apps.project.Build.buildProjects(Build.java:246)
at com.ti.ccstudio.apps.project.Build.doRun(Build.java:104)
at com.ti.ccstudio.apps.project.BaseHeadlessApp$1.run(BaseHeadlessApp.java:168)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1737)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1719)
at com.ti.ccstudio.apps.project.BaseHeadlessApp.internalRun(BaseHeadlessApp.java:166)
at com.ti.ccstudio.apps.project.BaseHeadlessApp.run(BaseHeadlessApp.java:136)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:996)
at org.eclipse.core.launcher.Main.main(Main.java:971)
Unfortunately, I tried recreating this exception from a fairly empty, default project, and it did not occur. This means it must be something relating to the specifications of my project, but I am not able to share that project or any portions of its code here. If you have any ideas what may cause an error such as this, it would be much appreciated so I could try it on my project. I will continue to try to recreate this problem on a default project that I am able to share here.
