I've flashed ZNP to my cc2531 usb dongle, and plug it onto a linux host, it is recognized as ttyACM0 by Linux.
I’ve followed the ways described in the documents “Z-Stack Monitor and Test API.pdf” to send commands wrapped in serial packet through the serial interface ttyACM0 to the dongle, and successfully got the feedback. That’s OK.
Now, I have a new requirement, that is to send ZCL(Zigbee Cluster Library) frame, which is a standard made by Zigbee Alliance and whose format is described in the document “Zigbee Cluster Library Specification” and is different from the frame format of Z-Stack Monitor and Test API.
What should I do?
Anyone has got an idea? Please help me! Thank you!
This requirement comes from the idea that we want to build our zigbee based solution on various kinds of hardware not limited to TI. I think those interfaces described in “Z-Stack Monitor and Test API” can only be appled to TI Zigbee module. However ZCL is part of Zigbee standard supported by all Zigbee devices. We want our software to be device independent.
