Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
changing BT address to something custom
Other Parts Discussed in Thread: AM3505, WL1271
I have a question about the Bluetooth portion of the 1271.  There is a vendor command to set the Bluetooth Address.  I need to know what needs to occur in order to use this to set the Bluetooth Address to something custom (ie:  is there a procedure that must be followed before the new address can be used or do you issue the command and and it takes effect instantly).  Also, how many times can this address be changed – (I assume there is a flash block that contains the address so I would like to know how many writes we can perform before we can reasonably expect a flash failure)?
--Gunter
