• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Bluetooth® Low Energy & ANT Forum » New Sample Project - "KeyFobDemo" - Accelerometer, Battery, Proximity, KeyPress profiles
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
  • GregS
    Posted by GregS
    on Nov 16 2010 13:16 PM
    Expert4165 points
    We have a new sample project called KeyFobDemo which can be found on the following Texas Instruments Wiki
    http://processors.wiki.ti.com/index.php/Category:KeyFobDemo
    The example comes with source and binaries and will demonstrate the following functionality.
    • Report battery level
    • Report 3 axis accelerometer readings
    • Report proximity changes
    • Report key press changes
    • Buzzer/ LED
    These are implemented using GATT server profiles and the top level application.  Note, these profiles are not yet aligned with Bluetooth SIG profile specifications and are provided only as an example.  This demo uses the same libraries which were provided in the version 1.0 installation.
    LPRF Wiki: http://processors.wiki.ti.com/index.php/Category:LPRF
    LPRF Team
    Accelerometer Battery Buzzer CC2540DK KeyPress LED Proximity
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Christian Joly
    Posted by Christian Joly
    on Dec 01 2010 20:24 PM
    Intellectual330 points
    Thank you for this new code.
    I have a few question for the accelerometer part:
    - Is the sample code enabling the 2g or 8g range ?
    - Is there an example code to calculate the roll and tilt based on the CMA3000 accelerometer readings ?
    The datasheet of CMA3000 provide very little info.
    It states that the range is between -2g and +2g (or -8/+8g) and the sensitivity is 56 count per g for 2 g. Am I correct to assume that the -2g reading would be 0 and the +2g reading would be(4*56) -> 224 ? If that the case, why do I get reading up to 255 ?
    - How to you get the 0g offset value ? (I could not find it in the datasheet)
    Christian
    Report Abuse
    • Reply
  • Willis1
    Posted by Willis1
    on Dec 06 2010 18:20 PM
    Expert8195 points
    The KeyFobDemo project enables the 2g range of the accelerometer.
    More information on the accelerometer can be found on VTI's web site: http://www.vti.fi/en/products/accelerometers/consumer_electronics/cma3000_series/
    Report Abuse
    • Reply
  • Christian Joly
    on Dec 09 2010 15:27 PM
    Any inputs on my other questions ?
    Report Abuse
    • Reply
  • Muthu Kumar
    Posted by Muthu Kumar
    on Dec 29 2010 16:41 PM
    Intellectual350 points
    Hi,  I compiled this demo project and the hex file was ~284KB. The included hex file
    with this demo project is ~721KB.  What's the difference? Should I able to flash the
    hex file I produced? thanks
    Report Abuse
    • Reply
  • Willis1
    Posted by Willis1
    on Dec 29 2010 16:43 PM
    Expert8195 points
    The reason that the hex files included with the installer differ in size from that generated using IAR is because the file with the installer was generated by using the “Read flash into hex file” option in SmartRF Flash Programmer on a device that was programmed using the “Debug” command in IAR. If you look at the hex file included with the installer you will notice a large section of it contains all “FFFFFFF…”. This is because the read-back function with save blank sections of flash in the hex file.
    Report Abuse
    • Reply
  • Muthu Kumar
    on Dec 30 2010 23:41 PM
    Thanks for the clarification. I was able to flash the modified version.
    @ Christian
    were you able to use the accelerometer readings? my understanding after reading the data sheet
    is that the reported values are in 2's complement and requires further processing to get usable readings.
    Report Abuse
    • Reply
  • Michael Devine
    Posted by Michael Devine
    on Jan 01 2011 11:32 AM
    Prodigy160 points
    @Muthu - Did you have any luck running your build? While I can flash, I am finding varying degrees of instability in my own build that I do not find with the installer-provided hex file.
    One guess as to why I'm having trouble - I have applied all the available IAR patches to 7.51A (through to 7.51M) to my workbench installaiton. From the descirptions of the patches, it seems all are essential, so this is just a guess.
    What is the specific tool-set version and patch set applied in the released build of the demo?
    Michael Devine
    IAR Patch
    Report Abuse
    • Reply
  • Muthu Kumar
    on Jan 01 2011 12:45 PM
    Yes, it has been working fine. I have modified the demo project, bulit and flashed several times so far. No issues.
    I've been using the keyfob to develop a demo (on windows) as well. No problems so far.
    I'm using 7.60 (EW8051-EV-web-7601.exe) and installed only one patch (EW8051-7.60-4-EV.zip) that was specific to CC2540.
    What were the instability issues you ran into?
    Report Abuse
    • Reply
  • Michael Devine
    on Jan 03 2011 12:19 PM
    Prodigy160 points
    Is support for IAR 7.60 official? The docs I have explicitly state otherwise, indicating support for 7.51A. Perhaps I need to pull forward to 7.60? Is there an official statement of support yet? If so, then do I also need to acquire fresh BLE stack libraries?
    Report Abuse
    • Reply
  • Muthu Kumar
    on Jan 03 2011 12:25 PM
    I'm not sure. I downloaded that version first and it worked. So, sticking to it.
    Just install the 7.61 and overwrite the files with the content from the patch. Thats it...
    Report Abuse
    • Reply
  • El dorado
    Posted by El dorado
    on Jan 05 2011 08:59 AM
    Prodigy240 points
    quoting http://processors.wiki.ti.com/index.php/Category:KeyFobDemo#Proximity_Callback :
    The functionality of the proximity profile is based on the Bluetooth SIG draft document Proximity Use Case, Requirements, and Design Document D05r06. Note that even though the profile functionality is based on a Bluetooth SIG document, the UUID values that are used by the profile are custom, and do not conform to any values defined by the Bluetooth SIG. This is because the SIG has not yet assigned any UUID values for the proximity profile. The functionality implemented on the keyfob is the role of the “Proximity Reporter” as defined by the document. A mobile phone or PC would typically implement the role of “Proximity Monitor”; however this full functionality has not yet been implemented in the USB Dongle software or BTool.
    Is there an official data when this functionalities will be implemented?
    Kind regards
    Report Abuse
    • Reply
  • Willis1
    Posted by Willis1
    on Jan 10 2011 13:31 PM
    Expert8195 points
    There is official date as of yet; however a reasonable guess would be in the next few months.
    Report Abuse
    • Reply
  • Angela
    Posted by Angela
    on Feb 21 2011 21:24 PM
    Intellectual605 points
    In the CC2540 Keyfob reference design, can we use CR1220 coin cell battery with 220uF cap instead of CR2032 with 47uF cap?
    Model IEC
    (JIS)
    Electrical Characteristics Operating
    Temperature
    Range
    Dimensions PDF
    Nominal
    Voltage
    (V)
    Nominal
    Capacity
    (mAh)
    Standard
    Discharge
    Current
    (mA)
    Diameter
    (mm)
    Height
    (mm)
    Weight
    (g)
    CR1216 CR1216 3 30 0.1 -30°C to 70°C 12.5 1.6 0.7
    CR1220 CR1220 3 40 0.1 -30°C to 70°C 12.5 2.0 0.8
    CR1616 CR1616 3 60 0.1 -30°C to 70°C 16.0 1.6 1.1
    CR1620 CR1620 3 78 0.1 -30°C to 70°C 16.0 2.0 1.2
    CR2016 CR2016 3 90 0.1 -30°C to 70°C 20.0 1.6 1.7
    CR2025 CR2025 3 160 0.2 -30°C to 70°C 20.0 2.5 2.4
    CR2032 CR2032 3 220 0.2 -30°C to 70°C 20.0 3.2 3.2
    Here is the website I found regarding coin cell spec http://www.sony.net/Products/MicroBattery/cr/spec.html
    CC2540 & SPP
    Report Abuse
    • Reply
  • Angela
    Posted by Angela
    on Feb 21 2011 21:26 PM
    Another question on keyfob reference design,
    The CC2540 datasheet and BLE specification allows me to calculate the battery droop due to an RF interaction as 0.33 V maximum (use 24 mA for 3 mA and calculate maximum droop as I = C * dV / dt ignoring the battery’s contribution to the pulse load), but I cannot tell what will happen if I try to erase a Flash memory block to write new data (I do not know the current or time to erase a Flash block per the original question below).  Ironically, I cannot even verify the Keyfob reference design through specifications because this data is lacking and does not allow me to verify the CR2032 battery is adequate
    CC2540 & SPP
    Report Abuse
    • Reply
1234
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
