• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Temperature Sensors » Temperature Sensors Forum » Temperature sensor for measuring human body temperature
Share
Temperature Sensors
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
satish goplala
Posted by satish goplala
on Jun 23 2011 10:20 AM
Prodigy10 points
Hi. I'm doing a project in body sensor networks. In this i'm measuring the body temperature. In previous forums you have suggested to use SA1-RTD from OMEGA company for measuring the temperature. Will this give the exact temperature of the body? Can you suggest me an alternative way to measure the temperature of a human body? Waiting for your reply.
Thank you,
Satish
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Neil Albaugh
    Posted by Neil Albaugh
    on Jun 23 2011 19:20 PM
    Genius4945 points
    Satish;
    A properly-selected thermistor can give you good accuracy in the temperature range that you need and they have a far greater output than an RTD.
    Regards, Neil P. Albaugh   ex-Burr-Brown
    RTD thermistor temperature
    Report Abuse
    • Reply
  • Ian Williams
    Posted by Ian Williams
    on Jun 24 2011 15:22 PM
    Verified Answer
    Verified by Ian Williams
    Genius14235 points
    Satish,
    An RTD or thermistor will do a good job of measuring the temperature of whichever surface it is in contact with. If that surface is the skin on a human's body, then that temperature will be accurately reported (within the accuracy and linearity limitations of the sensor, of course). If skin temperature is what you want to measure in your body sensor network, then your solution is very simple. However, if you're attempting to measure the internal/core temperature of the human body, then that becomes more complex.
    I recommend you read through this article: Body Temperature Variability (Part 1): A Review of the History of Body Temperature and its Variability Due to Site Selection, Biological Rhythms, Fitness, and Aging. Of most interest to your application will be the section covering temperature variability due to site selection. This section discusses the range of temperature values one should expect when measuring internally and externally, and since the human body uses the skin as a cooling mechanism the temperatures measured on the skin will generally be lower than the core body temperature. Axillary (under the arm) measurements are a good option for a convenient external site, but some sort of correction would be required in order to approximate the internal temperature.
    Ian Williams
    Linear Applications Engineer
    High Performance Linear
    RTD thermistor human body temperature measurement
    Report Abuse
    • Reply
  • Neil Albaugh
    on Jun 24 2011 17:13 PM
    Genius4945 points
    Satish;
    There are tiny thermistors mounted in the point of a hypodermic needle that will measure the temperature of a body wherever you like-- this is an invasive method, of course.
    A non-invasive (and non-trivial) method of measuring internal body temperatures is to use a microwave radiometer. In the low GHz range, the body has sufficient microwave attenuation to be a decent blackbody radiator. In this area of the spectrum, the Rayleigh-Jeans Approximation holds true and the RF power emission is proportional to absolute temperature. This method is complex and expensive, but-- depending on the frequency choice-- temperature measurement from virtually any tissue depth is possible.
    thermistor radiometer
    Report Abuse
    • Reply
  • Son Hoang
    Posted by Son Hoang
    on Jul 15 2011 10:06 AM
    Prodigy10 points
    Hi Niel,
    Can you elaborate on the use of microwave radiometer in core body temperature? I'm interested in learning more about this technique. Is there any papers that you know of that you could direct me to ? I would love to talk more about this with you if you sometime.
    Report Abuse
    • Reply
  • Neil Albaugh
    on Jul 15 2011 11:12 AM
    Genius4945 points
    Son;
    Any object above 0 degrees Kelven radiates energy; very hot objects, such as the sun, radiate at mainly the visible and infrared wavelengths but cooler objects have their peak energy radiated at longer wavelengths. Look up the "Wein Displacement Law".
    A microwave radiometer measures energy in the short radio wavelengths that are radiated by an object. In the case of a human body, the choice of wavelength determines how far into the body the energy is measured. By chosing a wavelength that has sufficient attenuation in the depth that the measurement is desired, the internal temperature can be determined. Very high attenuation prevents looking deep into the body-- think of the IR sensors, the IR attenuation is so high that it only barely penetrates the skin. This is why IR thermometers measure skin temperatures. At too long a wavelength, the body tissues become rather transparent to RF and a measurement cannot be made. I'm sure a bit of research can uncover some wavelength vs attenuation in human tissue data. Tissue is a high percentage of water so it may be around 2.4GHz.
    Microwave radiometers are not simple or cheap, but they are far more feasible these days with low noise solid-state amplifiers. Another factor is the antenna used to focus on the area to be measured.  At millimeter wavelengths, pyramidal horns become small enough to be practical and generate a reasonably small beamwidth. These wavelengths raise the radiometer complexity and cost, however.
    Read about radio astromony-- measuring temperature with a radiometer is the fundamental principle.
    radiometers
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
