Other Parts Discussed in Thread: BQ78350,
I know there is a bug that the IPScale-ing bits do not work and it does not scale the current related parameters but my main question is if it affects anything when I set the bit to scale 10x. I will scale manually at the calibraton stage my self. If the IPScale-ing does not affect any internals then that is good, so I can use it as a flag to indicate that the currents and other related parameters are scaled 10 times.
Also will there be an update for the firmware to correct this bug?
Janar
