The attached word document explains the procedure for using the JTAG on TPS65950.
I was just trying to dig this information out of TPS65920 TRM and it wasn't that clear. I'm under the assumptation that JTAG setup for the TPS65950 will be the same as that for the TPS65920. Unfortunately I do not see an attached document as stated in your posting. Can you repost or point to the right location. Thanks.
I have attached the document. You are correct, the JTAG setup is same for TPS65950/30/20 devices.
Let me know if you have any questions.
