Our customer found that there is some residue voltage on Oring controller TPS2412 pin A. VDD is powered from 12V bus.
The test condition is two PSUs in parallel and only peer PSU has 12V on the bus, the local PSU is shutdown but it has about 2.5V on 12V_pre_oring. With remove this IC, no such residue voltage on 12V_pre_oring.
Could you help to comment the reason of this symptom? Any method to fix it?
