Could anybody please supply me with the sugested foorprint and land pattern (with dimensions) for TPS84250 and TPS84259?
The datasheet curiously have nice drawings but no dimensions.
Many thanks in advance!
The TPS84250 datasheet appears to have fully dimensioned drawings for the package, footprint and stencil. They are missing for TPS84259, but I think the package is identical. the mechanical info is not technically part of the datasheet, but is appended to the datasheet proper when it is published to the web. Let me know if you do not see the mechanical data for TPS84250.
Thanks John, for whatever reason the datasheet I was referencing did not have the mechanical data that the document you referenced has.
Thanks again!
-Steve
It is appended data that is added to the PDF file. Sometimes it is missing form the uploaded files and subsequent refreshes restore it. Le me know if yo need further assistance.
The dimensions are the same for both devices. For some reason they are not appending on the end of the datasheet for the TPS84259. We should have this fixed shortly.
See the attached drawings.
