Other Parts Discussed in Thread: AWR1642BOOST, AWR1642
I'm using DCA1000EVM with Ti-ARW1642BOOST on mmWaveStudio. I followed the instructions in the different user guides (mmwave studio, arw1642 and DCA1000EVM) when it came to install the right drivers for the different com ports (XDS110 and FTDI) and configure the ethernet connection (change the static IP adress). I tried to run an acquisition following the instructions in the mmwave studio user guide but when I tried to "SetUp DCA1000", I received this error message:
[11:39:54] [RadarAPI]: Sending fpga command to DCA1000
[11:40:04] [RadarAPI]:
[11:40:04] FPGA Configuration :
[11:40:04] Timeout Error! System disconnected
[11:40:04] [RadarAPI]: Sending fpga_version command to DCA1000
[11:40:14] [RadarAPI]:
[11:40:14]
[11:40:14] Unable to read FPGA Version. [error -5]
And it did the same using the LUA script "DataCaptureDemo_xWR.lua".
Do you have any solution? Thank you in advance.
