recvfrom 'known limitation' for UDP packets
Hi TI,
As per release notes, CC3000 will not provide UDP packets one-by-one to the Host.
We believe that this is a sever limitation in regards to using this device for any generic/standardized protocols which depends on UDP (such as: MDNS, CoAP, mesh networking, multicasting etc) or anywhere else where you would want to make your device compatible with somebody else's implementation of the same protocol.
Can TI provide some kind of workaround such as putting Sender IP/Port and Data length in front of the packet?
CC3000 is a great solution in many other areas for IOT field and do not let this issue become a blocker :(.
Please re-consider providing a resolution for this issue.
Sachin
