Other Parts Discussed in Thread: LM5141-Q1, LP87523-Q1, , DRA722, TIDEP-01002
The SoC is DRA718BJGCBDQ1.
DDR3L is 1GB.
2 PCS of DDR3L/MT41K256M16TW-107 are used as x32 DRAM.
SDK is ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03
PMIC is LM5141-Q1 & LP87523-Q1
linux kernel boot fail with kernel panic.
Could you help me to debug?
the log is
Hit any key to stop autoboot: 2
U-Boot SPL 2019.01-00007-ga0ff74425a-dirty (Sep 23 2022 - 10:13:06 +0800)
omap_si_rev:0x 7220210
DRA722-GP ES2.1
Trying to boot from MMC1
no pinctrl state for default mode
DLP HCM has no palmas/tps65903x LDO1 for SD Card.
Loading Environment from MMC... OK
U-Boot 2019.01-00007-ga0ff74425a-dirty (Sep 23 2022 - 10:13:06 +0800)
CPU : DRA722-GP ES2.1
Model: TI DRA718 EVM
Board: DRA72x EVM REV
DRAM: 1 GiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Warning: fastboot.board_rev: unknown board revision
Net: Could not get PHY for ethernet@48484000: addr 2
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
282 bytes read in 0 ms
Loaded env from uEnv.txt
Importing environment from mmc0 ...
4407808 bytes read in 194 ms (21.7 MiB/s)
88107 bytes read in 5 ms (16.8 MiB/s)
Loading Device Tree to 8ffe7000, end 8ffff82a ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.73-00004-g31275c05a198-dirty (tjt@lotus) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Tue Sep 27 18:08:17 CST 2022
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: XY DRA718 HCM DLP-DLPC230-DLP553X
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 128 MiB at 0x00000000b0000000
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to (ptrval) for dram barrier
[ 0.000000] DRA722 ES2.1
[ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
[ 0.000000] percpu: Embedded 16 pages/cpu s36492 r8192 d20852 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 259648
[ 0.000000] Kernel command line: console=ttyO0,115200n8 elevator=noop root=PARTUUID=9444dd39-02 rw rootwait earlyprintk fixrtc omapdrm.num_crtc=2 consoleblank=0 cma=128M@0xB0000000 rootfstype=ext4 snd.slots_reserved=1,1
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 731024K/1045504K available (10240K kernel code, 341K rwdata, 2800K rodata, 2048K init, 269K bss, 27760K reserved, 286720K cma-reserved, 128000K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 342 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 270 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.008226] Switching to timer-based delay loop, resolution 162ns
[ 0.014747] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.024925] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.030543] Console: colour dummy device 80x30
[ 0.035113] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.041821] This ensures that you still see kernel messages. Please
[ 0.048253] update your kernel commandline.
[ 0.052578] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.063135] pid_max: default: 32768 minimum: 301
[ 0.067988] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.074785] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.082568] CPU: Testing write buffer coherency: ok
[ 0.087621] CPU0: Spectre v2: using ICIALLU workaround
[ 0.093098] /cpus/cpu@0 missing clock-frequency property
[ 0.098568] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.158695] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.165507] rcu: Hierarchical SRCU implementation.
[ 0.190640] EFI services will not be available.
[ 0.210511] smp: Bringing up secondary CPUs ...
[ 0.215158] smp: Brought up 1 node, 1 CPU
[ 0.219271] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[ 0.225631] CPU: All CPU(s) started in HYP mode.
[ 0.230366] CPU: Virtualization extensions available.
[ 0.236004] devtmpfs: initialized
[ 0.265896] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.274028] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.284153] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.295253] pinctrl core: initialized pinctrl subsystem
[ 0.301158] DMI not present or invalid.
[ 0.305388] NET: Registered protocol family 16
[ 0.316027] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.323950] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.514369] cpuidle: using governor ladder
[ 0.518596] cpuidle: using governor menu
[ 0.533228] OMAP GPIO hardware version 0.1
[ 0.561743] No ATAGs?
[ 0.561790] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.572355] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.578902] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.586492] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.594757] OMAP DMA hardware revision 0.0
[ 0.636365] edma 43300000.edma: memcpy is disabled
[ 0.644691] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.657345] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.667819] evm_5v0: supplied by evm_12v0
[ 0.672181] evm_3v6: supplied by evm_5v0
[ 0.676458] vsys_3v3: supplied by evm_12v0
[ 0.680947] evm_3v3: supplied by vsys_3v3
[ 0.685326] aic_dvdd: supplied by evm_3v3
[ 0.692669] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.698645] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.704710] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.710746] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.716915] iommu: Adding device 58820000.ipu to group 1
[ 0.722434] iommu: Adding device 55020000.ipu to group 2
[ 0.728017] iommu: Adding device 40800000.dsp to group 0
[ 0.734317] OF: graph: no port node found in /ocp/dss@58000000/ports
[ 0.741336] SCSI subsystem initialized
[ 0.770983] pcf857x: probe of 0-0020 failed with error -121
[ 0.776949] pcf857x: probe of 0-0021 failed with error -121
[ 0.782835] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.803360] omap_i2c 4807c000.i2c: timeout waiting for bus ready
[ 1.809537] pcf857x: probe of 4-0026 failed with error -16
[ 1.815473] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
[ 1.822952] pca953x 4-0020: Linked as a consumer to regulator.0
[ 2.849702] omap_i2c 4807c000.i2c: timeout waiting for bus ready
[ 2.855875] pca953x 4-0020: failed reading register
[ 2.860949] pca953x 4-0020: Dropping the link to regulator.0
[ 2.866779] pca953x: probe of 4-0020 failed with error -16
[ 2.872611] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[ 2.878528] media: Linux media interface: v0.10
[ 2.883272] videodev: Linux video capture interface: v2.00
[ 2.888964] pps_core: LinuxPPS API ver. 1 registered
[ 2.894099] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.903486] PTP clock support registered
[ 2.907566] EDAC MC: Ver: 3.0.0
[ 2.918168] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 2.924611] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 2.941067] Advanced Linux Sound Architecture Driver Initialized.
[ 2.948233] clocksource: Switched to clocksource arch_sys_counter
[ 2.962608] NET: Registered protocol family 2
[ 2.967656] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 2.975592] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 2.982920] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 2.989687] TCP: Hash tables configured (established 8192 bind 8192)
[ 2.996269] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.002388] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.009050] NET: Registered protocol family 1
[ 3.044007] RPC: Registered named UNIX socket transport module.
[ 3.050137] RPC: Registered udp transport module.
[ 3.054964] RPC: Registered tcp transport module.
[ 3.059802] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.077976] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 3.087349] Initialise system trusted keyrings
[ 3.092104] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 3.103705] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.120261] NFS: Registering the id_resolver key type
[ 3.125457] Key type id_resolver registered
[ 3.129807] Key type id_legacy registered
[ 3.133950] ntfs: driver 2.1.32 [Flags: R/O].
[ 3.140405] Key type asymmetric registered
[ 3.144609] Asymmetric key parser 'x509' registered
[ 3.149727] bounce: pool size: 64 pages
[ 3.153685] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 3.161316] io scheduler noop registered (default)
[ 3.166232] io scheduler deadline registered
[ 3.170845] io scheduler cfq registered
[ 3.174779] io scheduler mq-deadline registered
[ 3.179474] io scheduler kyber registered
[ 3.188850] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[ 3.195079] pinctrl-single 4a002e8c.pinmux: please update dts to use #pinctrl-cells = <1>
[ 3.203531] pinctrl-single 4a002e8c.pinmux: initialized with no interrupts
[ 3.210628] pinctrl-single 4a002e8c.pinmux: 1 pins, size 4
[ 3.240211] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.0
[ 3.248383] dra7-pcie 51000000.pcie: WA for Errata i870 not applied
[ 3.254897] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 3.262627] dra7-pcie 51000000.pcie: IO 0x20003000..0x20012fff -> 0x00000000
[ 3.270161] dra7-pcie 51000000.pcie: MEM 0x20013000..0x2fffffff -> 0x20013000
[ 4.277935] dra7-pcie 51000000.pcie: Phy link never came up
[ 4.283802] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 4.290257] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.295889] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 4.302250] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 4.314976] PCI: bus0: Fast back to back transfers disabled
[ 4.325922] PCI: bus1: Fast back to back transfers enabled
[ 4.331600] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[ 4.339131] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 4.344809] pcieport 0000:00:00.0: Signaling PME with IRQ 169
[ 4.350851] pcieport 0000:00:00.0: AER enabled with IRQ 169
[ 5.644600] clock: dpll_abe_ck failed transition to 'locked'
[ 6.934727] clock: dpll_abe_ck failed transition to 'locked'
[ 6.940590] ------------[ cut here ]------------
[ 6.945339] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
[ 6.954717] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
[ 6.967119] Modules linked in:
[ 6.970259] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.73-00004-g31275c05a198-dirty #1
[ 6.978743] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 6.984996] Backtrace:
[ 6.987511] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
[ 6.995280] r7:c0dff4e8 r6:60000193 r5:00000000 r4:c1251ff0
[ 7.001093] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
[ 7.008505] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
[ 7.015563] r7:c0dff4e8 r6:00000009 r5:00000000 r4:ef0939c4
[ 7.021370] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
[ 7.029049] r9:ef1ba740 r8:f0882564 r7:c0dff414 r6:c0dff354 r5:c0dff4b8 r4:c1204c48
[ 7.037000] [<c022ddb0>] (warn_slowpath_fmt) from [<c0553cdc>] (l3_interrupt_handler+0x330/0x380)
[ 7.046102] r3:ef1bdac0 r2:c0dff4b8
[ 7.049768] r5:00000000 r4:80080003
[ 7.053437] [<c05539ac>] (l3_interrupt_handler) from [<c0288b70>] (__handle_irq_event_percpu+0x68/0x140)
[ 7.063168] r10:c1253c38 r9:ef1bbc00 r8:00000017 r7:ef093af0 r6:00000000 r5:ef1bbc68
[ 7.071202] r4:ef1bdf80
[ 7.073799] [<c0288b08>] (__handle_irq_event_percpu) from [<c0288c7c>] (handle_irq_event_percpu+0x34/0x88)
[ 7.083710] r10:ef093d0c r9:ef092000 r8:ef008000 r7:00000001 r6:ef1bbc00 r5:ef1bbc68
[ 7.091743] r4:c1204c48
[ 7.094344] [<c0288c48>] (handle_irq_event_percpu) from [<c0288d10>] (handle_irq_event+0x40/0x64)
[ 7.103450] r6:c120a374 r5:ef1bbc68 r4:ef1bbc00
[ 7.108186] [<c0288cd0>] (handle_irq_event) from [<c028ca58>] (handle_fasteoi_irq+0xc0/0x168)
[ 7.116930] r7:00000001 r6:c120a374 r5:ef1bbc68 r4:ef1bbc00
[ 7.122743] [<c028c998>] (handle_fasteoi_irq) from [<c0287d6c>] (generic_handle_irq+0x2c/0x3c)
[ 7.131579] r7:00000001 r6:00000000 r5:00000000 r4:c1069cfc
[ 7.137386] [<c0287d40>] (generic_handle_irq) from [<c02883d0>] (__handle_domain_irq+0x64/0xbc)
[ 7.146318] [<c028836c>] (__handle_domain_irq) from [<c0552018>] (gic_handle_irq+0x44/0x80)
[ 7.154892] r9:ef092000 r8:fa213000 r7:ef093bb8 r6:fa212000 r5:fa21200c r4:c1205100
[ 7.162846] [<c0551fd4>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
[ 7.170525] Exception stack(0xef093bb8 to 0xef093c00)
[ 7.175704] 3ba0: c129155c 40000013
[ 7.184094] 3bc0: 00000000 00000442 c129155c ef69b784 40000013 c0e0d798 ef093c40 ef69b68c
[ 7.192485] 3be0: ef093d0c ef093c14 ef093c18 ef093c08 c084028c c0a12ecc a0000013 ffffffff
[ 7.200878] r9:ef092000 r8:ef093c40 r7:ef093bec r6:ffffffff r5:a0000013 r4:c0a12ecc
[ 7.208833] [<c0a12ea4>] (_raw_spin_unlock_irqrestore) from [<c084028c>] (of_find_property+0x48/0x54)
[ 7.218300] [<c0840244>] (of_find_property) from [<c08406e0>] (of_phandle_iterator_init+0x4c/0xac)
[ 7.227500] r9:ef69b68c r8:00000000 r7:c0e0d798 r6:ef69b68c r5:c1204c48 r4:ef093c78
[ 7.235451] [<c0840694>] (of_phandle_iterator_init) from [<c0841c00>] (__of_parse_phandle_with_args+0x40/0xf8)
[ 7.245716] r8:ef093d0c r7:c1204c48 r6:00000000 r5:00000000 r4:ef235e10
[ 7.252600] [<c0841bc0>] (__of_parse_phandle_with_args) from [<c0841d54>] (of_parse_phandle_with_args+0x2c/0x3c)
[ 7.263049] r8:00000000 r7:00000000 r6:ee85c7c0 r5:00000000 r4:ef235e10
[ 7.269934] [<c0841d28>] (of_parse_phandle_with_args) from [<c05c6b64>] (of_dra7_atl_clk_probe+0xe4/0x274)
[ 7.279851] [<c05c6a80>] (of_dra7_atl_clk_probe) from [<c06b3468>] (platform_drv_probe+0x50/0xa0)
[ 7.288956] r10:00000000 r9:c1228888 r8:00000000 r7:00000000 r6:c1228888 r5:00000000
[ 7.296996] r4:ef235e10
[ 7.299599] [<c06b3418>] (platform_drv_probe) from [<c06b14b8>] (really_probe+0x204/0x2c0)
[ 7.308079] r7:00000000 r6:c128f0b8 r5:ef235e10 r4:c128f0b4
[ 7.313889] [<c06b12b4>] (really_probe) from [<c06b1718>] (driver_probe_device+0x68/0x180)
[ 7.322374] r10:c1060bd8 r9:c104b834 r8:00000000 r7:c06b1830 r6:ef235e44 r5:c1228888
[ 7.330409] r4:ef235e10 r3:00000000
[ 7.334078] [<c06b16b0>] (driver_probe_device) from [<c06b1924>] (__driver_attach+0xf4/0xf8)
[ 7.342740] r9:c104b834 r8:00000000 r7:c06b1830 r6:ef235e44 r5:c1228888 r4:ef235e10
[ 7.350692] [<c06b1830>] (__driver_attach) from [<c06af588>] (bus_for_each_dev+0x7c/0xbc)
[ 7.359086] r7:c06b1830 r6:c1228888 r5:c1204c48 r4:ef22cfb4
[ 7.364897] [<c06af50c>] (bus_for_each_dev) from [<c06b0df0>] (driver_attach+0x24/0x28)
[ 7.373121] r7:00000000 r6:ee85c700 r5:c1236c90 r4:c1228888
[ 7.378927] [<c06b0dcc>] (driver_attach) from [<c06b086c>] (bus_add_driver+0x1c4/0x208)
[ 7.387142] [<c06b06a8>] (bus_add_driver) from [<c06b22f4>] (driver_register+0x7c/0x110)
[ 7.395447] r7:c10272fc r6:ffffe000 r5:c1204c48 r4:c1228888
[ 7.401256] [<c06b2278>] (driver_register) from [<c06b33cc>] (__platform_driver_register+0x48/0x50)
[ 7.410543] r5:c1204c48 r4:c1255740
[ 7.414214] [<c06b3384>] (__platform_driver_register) from [<c1027318>] (dra7_atl_clk_driver_init+0x1c/0x20)
[ 7.424303] [<c10272fc>] (dra7_atl_clk_driver_init) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
[ 7.433504] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
[ 7.442425] r8:c104b854 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000007
[ 7.449307] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
[ 7.457792] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
[ 7.465827] r4:00000000
[ 7.468427] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 7.476192] Exception stack(0xef093fb0 to 0xef093ff8)
[ 7.481376] 3fa0: 00000000 00000000 00000000 00000000
[ 7.489768] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 7.498154] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 7.504940] r5:c0a0ccd8 r4:00000000
[ 7.508605] ---[ end trace 6ab99f172329d35f ]---
[ 7.513392] ------------[ cut here ]------------
[ 7.518134] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
[ 7.527507] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
[ 7.539912] Modules linked in:
[ 7.543053] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.73-00004-g31275c05a198-dirty #1
[ 7.552961] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 7.559209] Backtrace:
[ 7.561723] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
[ 7.569490] r7:c0dff4e8 r6:60000193 r5:00000000 r4:c1251ff0
[ 7.575303] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
[ 7.582719] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
[ 7.589771] r7:c0dff4e8 r6:00000009 r5:00000000 r4:ef0939c4
[ 7.595577] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
[ 7.603253] r9:ef1ba740 r8:f0882564 r7:c0dff414 r6:c0dff354 r5:c0dff4b8 r4:c1204c48
[ 7.611199] [<c022ddb0>] (warn_slowpath_fmt) from [<c0553cdc>] (l3_interrupt_handler+0x330/0x380)
[ 7.620302] r3:ef1bdac0 r2:c0dff4b8
[ 7.623965] r5:00000000 r4:80080003
[ 7.627634] [<c05539ac>] (l3_interrupt_handler) from [<c0288b70>] (__handle_irq_event_percpu+0x68/0x140)
[ 7.637365] r10:c1253c38 r9:ef1bbc00 r8:00000017 r7:ef093af0 r6:00000000 r5:ef1bbc68
[ 7.645400] r4:ef1bdf80
[ 7.648003] [<c0288b08>] (__handle_irq_event_percpu) from [<c0288c7c>] (handle_irq_event_percpu+0x34/0x88)
[ 7.657912] r10:ef093d0c r9:ef092000 r8:ef008000 r7:00000001 r6:ef1bbc00 r5:ef1bbc68
[ 7.665946] r4:c1204c48
[ 7.668548] [<c0288c48>] (handle_irq_event_percpu) from [<c0288d10>] (handle_irq_event+0x40/0x64)
[ 7.677650] r6:c120a374 r5:ef1bbc68 r4:ef1bbc00
[ 7.682390] [<c0288cd0>] (handle_irq_event) from [<c028ca58>] (handle_fasteoi_irq+0xc0/0x168)
[ 7.691141] r7:00000001 r6:c120a374 r5:ef1bbc68 r4:ef1bbc00
[ 7.696957] [<c028c998>] (handle_fasteoi_irq) from [<c0287d6c>] (generic_handle_irq+0x2c/0x3c)
[ 7.705794] r7:00000001 r6:00000000 r5:00000000 r4:c1069cfc
[ 7.711601] [<c0287d40>] (generic_handle_irq) from [<c02883d0>] (__handle_domain_irq+0x64/0xbc)
[ 7.720529] [<c028836c>] (__handle_domain_irq) from [<c0552018>] (gic_handle_irq+0x44/0x80)
[ 7.729106] r9:ef092000 r8:fa213000 r7:ef093bb8 r6:fa212000 r5:fa21200c r4:c1205100
[ 7.737059] [<c0551fd4>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
[ 7.744739] Exception stack(0xef093bb8 to 0xef093c00)
[ 7.749925] 3ba0: c129155c 40000013
[ 7.758318] 3bc0: 00000000 00000452 c129155c ef69b784 40000013 c0e0d798 ef093c40 ef69b68c
[ 7.766712] 3be0: ef093d0c ef093c14 ef093c18 ef093c08 c084028c c0a12ecc a0000013 ffffffff
[ 7.775106] r9:ef092000 r8:ef093c40 r7:ef093bec r6:ffffffff r5:a0000013 r4:c0a12ecc
[ 7.783057] [<c0a12ea4>] (_raw_spin_unlock_irqrestore) from [<c084028c>] (of_find_property+0x48/0x54)
[ 7.792525] [<c0840244>] (of_find_property) from [<c08406e0>] (of_phandle_iterator_init+0x4c/0xac)
[ 7.801723] r9:ef69b68c r8:00000000 r7:c0e0d798 r6:ef69b68c r5:c1204c48 r4:ef093c78
[ 7.809677] [<c0840694>] (of_phandle_iterator_init) from [<c0841c00>] (__of_parse_phandle_with_args+0x40/0xf8)
[ 7.819945] r8:ef093d0c r7:c1204c48 r6:00000003 r5:00000003 r4:ef03f6c4
[ 7.826828] [<c0841bc0>] (__of_parse_phandle_with_args) from [<c0841d54>] (of_parse_phandle_with_args+0x2c/0x3c)
[ 7.837275] r8:ee85f280 r7:00000000 r6:00000000 r5:00000003 r4:ef03f6c4
[ 7.844155] [<c0841d28>] (of_parse_phandle_with_args) from [<c05c6b64>] (of_dra7_atl_clk_probe+0xe4/0x274)
[ 7.854062] [<c05c6a80>] (of_dra7_atl_clk_probe) from [<c06b3468>] (platform_drv_probe+0x50/0xa0)
[ 7.863167] r10:00000000 r9:c1228888 r8:00000000 r7:00000000 r6:c1228888 r5:00000000
[ 7.871201] r4:ef235e10
[ 7.873802] [<c06b3418>] (platform_drv_probe) from [<c06b14b8>] (really_probe+0x204/0x2c0)
[ 7.882281] r7:00000000 r6:c128f0b8 r5:ef235e10 r4:c128f0b4
[ 7.888091] [<c06b12b4>] (really_probe) from [<c06b1718>] (driver_probe_device+0x68/0x180)
[ 7.896577] r10:c1060bd8 r9:c104b834 r8:00000000 r7:c06b1830 r6:ef235e44 r5:c1228888
[ 7.904611] r4:ef235e10 r3:00000000
[ 7.908283] [<c06b16b0>] (driver_probe_device) from [<c06b1924>] (__driver_attach+0xf4/0xf8)
[ 7.916947] r9:c104b834 r8:00000000 r7:c06b1830 r6:ef235e44 r5:c1228888 r4:ef235e10
[ 7.924896] [<c06b1830>] (__driver_attach) from [<c06af588>] (bus_for_each_dev+0x7c/0xbc)
[ 7.933289] r7:c06b1830 r6:c1228888 r5:c1204c48 r4:ef22cfb4
[ 7.939095] [<c06af50c>] (bus_for_each_dev) from [<c06b0df0>] (driver_attach+0x24/0x28)
[ 7.947307] r7:00000000 r6:ee85c700 r5:c1236c90 r4:c1228888
[ 7.953117] [<c06b0dcc>] (driver_attach) from [<c06b086c>] (bus_add_driver+0x1c4/0x208)
[ 7.961332] [<c06b06a8>] (bus_add_driver) from [<c06b22f4>] (driver_register+0x7c/0x110)
[ 7.969635] r7:c10272fc r6:ffffe000 r5:c1204c48 r4:c1228888
[ 7.975445] [<c06b2278>] (driver_register) from [<c06b33cc>] (__platform_driver_register+0x48/0x50)
[ 7.984727] r5:c1204c48 r4:c1255740
[ 7.988398] [<c06b3384>] (__platform_driver_register) from [<c1027318>] (dra7_atl_clk_driver_init+0x1c/0x20)
[ 7.998491] [<c10272fc>] (dra7_atl_clk_driver_init) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
[ 8.007696] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
[ 8.016627] r8:c104b854 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000007
[ 8.023511] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
[ 8.031997] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
[ 8.040031] r4:00000000
[ 8.042628] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 8.050390] Exception stack(0xef093fb0 to 0xef093ff8)
[ 8.055573] 3fa0: 00000000 00000000 00000000 00000000
[ 8.063964] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.072356] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 8.079142] r5:c0a0ccd8 r4:00000000
[ 8.082810] ---[ end trace 6ab99f172329d360 ]---
[ 8.087580] ------------[ cut here ]------------
[ 8.092327] WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:828 clk_core_disable+0xa4/0xa8
[ 8.100448] atl_cm:clk:0000:0 already disabled
[ 8.105005] Modules linked in:
[ 8.108144] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.73-00004-g31275c05a198-dirty #1
[ 8.118050] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 8.124300] Backtrace:
[ 8.126817] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
[ 8.134587] r7:c0e0b28c r6:60000093 r5:00000000 r4:c1251ff0
[ 8.140394] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
[ 8.147805] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
[ 8.154861] r7:c0e0b28c r6:00000009 r5:00000000 r4:ef093ad4
[ 8.160668] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
[ 8.168351] r9:c1204c48 r8:c0220b58 r7:c1203d00 r6:c1212e74 r5:c0e0b33c r4:c1204c48
[ 8.176301] [<c022ddb0>] (warn_slowpath_fmt) from [<c05bcf04>] (clk_core_disable+0xa4/0xa8)
[ 8.184865] r3:ef01c640 r2:c0e0b33c
[ 8.188528] r5:ef01b600 r4:ef01b600
[ 8.192198] [<c05bce60>] (clk_core_disable) from [<c05bcf28>] (clk_core_disable_lock+0x20/0x2c)
[ 8.201128] r5:ef01b600 r4:80000093
[ 8.204801] [<c05bcf08>] (clk_core_disable_lock) from [<c05bcf58>] (clk_disable+0x24/0x28)
[ 8.213285] r5:c1255dbc r4:c1212e74
[ 8.216958] [<c05bcf34>] (clk_disable) from [<c021d74c>] (_disable_clocks+0x20/0x98)
[ 8.224909] [<c021d72c>] (_disable_clocks) from [<c021e334>] (_idle+0x188/0x248)
[ 8.232496] r7:c1203d00 r6:c1204c48 r5:c1255dbc r4:c1212e74
[ 8.238307] [<c021e1ac>] (_idle) from [<c021ffcc>] (omap_hwmod_idle+0x2c/0x4c)
[ 8.245723] r9:c1204c48 r8:c0220b58 r7:c1203d00 r6:a0000093 r5:c1212ec0 r4:c1212e74
[ 8.253671] [<c021ffa0>] (omap_hwmod_idle) from [<c0220b04>] (omap_device_idle+0x48/0x9c)
[ 8.262071] r7:c1203d00 r6:00000001 r5:ef238840 r4:00000000
[ 8.267877] [<c0220abc>] (omap_device_idle) from [<c0220b7c>] (_od_runtime_suspend+0x24/0x28)
[ 8.276627] r7:c1203d00 r6:ef235e88 r5:00000000 r4:ef235e10
[ 8.282442] [<c0220b58>] (_od_runtime_suspend) from [<c06bce1c>] (__rpm_callback+0x3c/0x1e0)
[ 8.291102] r5:00000000 r4:ef235e10
[ 8.294776] [<c06bcde0>] (__rpm_callback) from [<c06bcfe8>] (rpm_callback+0x28/0x88)
[ 8.302724] r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220b58 r5:00000000
[ 8.310760] r4:ef235e10
[ 8.313362] [<c06bcfc0>] (rpm_callback) from [<c06bc040>] (rpm_suspend+0x148/0x518)
[ 8.321221] r7:c1203d00 r6:c0220b58 r5:00000000 r4:ef235e10
[ 8.327032] [<c06bbef8>] (rpm_suspend) from [<c06bc59c>] (rpm_idle+0xc8/0x148)
[ 8.334447] r10:ef093d0c r9:ef69b68c r8:ef235ed4 r7:00000000 r6:00000004 r5:00000000
[ 8.342479] r4:ef235e10
[ 8.345081] [<c06bc4d4>] (rpm_idle) from [<c06bc680>] (__pm_runtime_idle+0x64/0x88)
[ 8.352940] r9:ef69b68c r8:ee85f2c0 r7:60000013 r6:ef235e88 r5:00000004 r4:ef235e10
[ 8.360895] [<c06bc61c>] (__pm_runtime_idle) from [<c05c6c74>] (of_dra7_atl_clk_probe+0x1f4/0x274)
[ 8.370089] r7:00000000 r6:ee85c7c0 r5:00000004 r4:ef03f8c4
[ 8.375897] [<c05c6a80>] (of_dra7_atl_clk_probe) from [<c06b3468>] (platform_drv_probe+0x50/0xa0)
[ 8.385005] r10:00000000 r9:c1228888 r8:00000000 r7:00000000 r6:c1228888 r5:00000000
[ 8.393037] r4:ef235e10
[ 8.395638] [<c06b3418>] (platform_drv_probe) from [<c06b14b8>] (really_probe+0x204/0x2c0)
[ 8.404121] r7:00000000 r6:c128f0b8 r5:ef235e10 r4:c128f0b4
[ 8.409931] [<c06b12b4>] (really_probe) from [<c06b1718>] (driver_probe_device+0x68/0x180)
[ 8.418411] r10:c1060bd8 r9:c104b834 r8:00000000 r7:c06b1830 r6:ef235e44 r5:c1228888
[ 8.426445] r4:ef235e10 r3:00000000
[ 8.430114] [<c06b16b0>] (driver_probe_device) from [<c06b1924>] (__driver_attach+0xf4/0xf8)
[ 8.438772] r9:c104b834 r8:00000000 r7:c06b1830 r6:ef235e44 r5:c1228888 r4:ef235e10
[ 8.446722] [<c06b1830>] (__driver_attach) from [<c06af588>] (bus_for_each_dev+0x7c/0xbc)
[ 8.455112] r7:c06b1830 r6:c1228888 r5:c1204c48 r4:ef22cfb4
[ 8.460919] [<c06af50c>] (bus_for_each_dev) from [<c06b0df0>] (driver_attach+0x24/0x28)
[ 8.469131] r7:00000000 r6:ee85c700 r5:c1236c90 r4:c1228888
[ 8.474939] [<c06b0dcc>] (driver_attach) from [<c06b086c>] (bus_add_driver+0x1c4/0x208)
[ 8.483155] [<c06b06a8>] (bus_add_driver) from [<c06b22f4>] (driver_register+0x7c/0x110)
[ 8.491458] r7:c10272fc r6:ffffe000 r5:c1204c48 r4:c1228888
[ 8.497269] [<c06b2278>] (driver_register) from [<c06b33cc>] (__platform_driver_register+0x48/0x50)
[ 8.506553] r5:c1204c48 r4:c1255740
[ 8.510224] [<c06b3384>] (__platform_driver_register) from [<c1027318>] (dra7_atl_clk_driver_init+0x1c/0x20)
[ 8.520313] [<c10272fc>] (dra7_atl_clk_driver_init) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
[ 8.529508] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
[ 8.538437] r8:c104b854 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000007
[ 8.545324] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
[ 8.553804] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
[ 8.561835] r4:00000000
[ 8.564435] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 8.572203] Exception stack(0xef093fb0 to 0xef093ff8)
[ 8.577390] 3fa0: 00000000 00000000 00000000 00000000
[ 8.585781] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8.594175] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 8.600961] r5:c0a0ccd8 r4:00000000
[ 8.604630] ---[ end trace 6ab99f172329d361 ]---
[ 8.654730] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 8.664889] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 45, base_baud = 3000000) is a 8250
[ 8.673958] console [ttyS0] enabled
[ 8.681080] bootconsole [earlycon0] disabled
[ 8.692141] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 8.698497] random: fast init done
[ 8.702033] random: crng init done
[ 8.706478] omapdss_dss 58000000.dss: 58000000.dss supply vdda_video not found, using dummy regulator
[ 8.715848] omapdss_dss 58000000.dss: Linked as a consumer to regulator.0
[ 8.722780] DSS: OMAP DSS rev 6.1
[ 8.727359] OF: graph: no port node found in /ocp/dss@58000000/ports
[ 8.735306] omapdss_hdmi5 58040000.encoder: 58040000.encoder supply vdda not found, using dummy regulator
[ 8.744998] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.0
[ 8.752437] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.0
[ 8.771978] brd: module loaded
[ 8.781378] loop: module loaded
[ 8.789529] m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
[ 8.794610] 10 fixed-partitions partitions found on MTD device spi0.0
[ 8.801169] Creating 10 MTD partitions on "spi0.0":
[ 8.806073] 0x000000000000-0x000000010000 : "QSPI.SPL"
[ 8.811961] 0x000000010000-0x000000020000 : "QSPI.SPL.backup1"
[ 8.818470] 0x000000020000-0x000000030000 : "QSPI.SPL.backup2"
[ 8.824936] 0x000000030000-0x000000040000 : "QSPI.SPL.backup3"
[ 8.831434] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[ 8.837475] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[ 8.844169] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[ 8.850575] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[ 8.857641] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[ 8.863711] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[ 8.870773] libphy: Fixed MDIO Bus: probed
[ 8.938266] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 8.945964] libphy: 48485000.mdio: probed
[ 8.950893] mdio_bus 48485000.mdio: MDIO device at address 2 is missing.
[ 8.958721] mdio_bus 48485000.mdio: MDIO device at address 3 is missing.
[ 8.966178] cpsw 48484000.ethernet: Detected MACID = 3c:e4:b0:32:5f:6c
[ 8.972798] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 8.979198] cpsw 48484000.ethernet: ALE Table size 1024
[ 8.984486] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 8.993328] i2c /dev entries driver
[ 9.001738] cpu cpu0: dev_pm_opp_set_regulators: no regulator (vdd) found: -19
[ 9.009537] sdhci: Secure Digital Host Controller Interface driver
[ 9.015745] sdhci: Copyright(c) Pierre Ossman
[ 9.021060] sdhci-pltfm: SDHCI platform and OF driver helper
[ 9.027825] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 9.036703] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 9.041560] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.9
[ 9.048409] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.8
[ 9.055202] sdhci-omap 4809c000.mmc: Dropping the link to regulator.8
[ 9.061798] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.8
[ 9.068851] sdhci-omap 4809c000.mmc: Dropping the link to regulator.8
[ 9.075373] sdhci-omap 4809c000.mmc: Dropping the link to regulator.9
[ 9.082453] sdhci-omap 480b4000.mmc: 480b4000.mmc supply vqmmc not found, using dummy regulator
[ 9.091289] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.0
[ 9.098070] sdhci-omap 480b4000.mmc: Dropping the link to regulator.0
[ 9.105113] Unable to handle kernel NULL pointer dereference at virtual address 0000003d
[ 9.113294] pgd = c2f82e04
[ 9.116013] [0000003d] *pgd=80000080004003, *pmd=00000000
[ 9.121490] Internal error: Oops: 206 [#1] PREEMPT SMP ARM
[ 9.127000] Modules linked in:
[ 9.130076] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.73-00004-g31275c05a198-dirty #1
[ 9.139770] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 9.145898] PC is at regulator_set_voltage+0x18/0x48
[ 9.150888] LR is at mmc_regulator_set_ocr+0x4c/0xe8
[ 9.155873] pc : [<c05e0f78>] lr : [<c08045a4>] psr: 20000013
[ 9.162167] sp : ef093c30 ip : ef093c50 fp : ef093c4c
[ 9.167414] r10: ee463c40 r9 : ee47c1f0 r8 : ee47c3c8
[ 9.172662] r7 : 00100600 r6 : 0033e140 r5 : 00325aa0 r4 : ffffffed
[ 9.179216] r3 : 00155cc0 r2 : 0033e140 r1 : 00325aa0 r0 : ffffffed
[ 9.185772] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 9.192938] Control: 30c5387d Table: 80003000 DAC: fffffffd
[ 9.198708] Process swapper/0 (pid: 1, stack limit = 0x0c4cfad6)
[ 9.204741] Stack: (0xef093c30 to 0xef094000)
[ 9.209118] 3c20: ee47c000 ee47c000 ffffffed 00100600
[ 9.217333] 3c40: ef093c6c ef093c50 c08045a4 c05e0f6c ee47c000 ee47c21c ee47c340 00100600
[ 9.225547] 3c60: ef093c7c ef093c70 c08284c8 c0804564 ef093ca4 ef093c80 c081cbb0 c08284bc
[ 9.233762] 3c80: ee47c000 ee47c21c 00000000 00100600 ee47c3c8 ee47c1f0 ef093ccc ef093ca8
[ 9.241975] 3ca0: c082829c c081cac8 ee47c000 ee47c21c ee47c000 ee47c534 ee47c3c8 ee47c1f0
[ 9.250189] 3cc0: ef093ce4 ef093cd0 c0805c20 c08281d0 ee47c000 00000015 ef093cfc ef093ce8
[ 9.258402] 3ce0: c0805e50 c0805b94 ee47c000 00000000 ef093d14 ef093d00 c0806b5c c0805e18
[ 9.266616] 3d00: ee47c000 00000000 ef093d2c ef093d18 c0807f60 c0806ad4 ee47c340 00000000
[ 9.274830] 3d20: ef093d5c ef093d30 c081c4d4 c0807f0c ee466480 ee47c340 ef228a00 ee47c340
[ 9.283043] 3d40: ef228a00 ee47c000 ef228a10 ee47c640 ef093d8c ef093d60 c0828ac8 c081c3a0
[ 9.291257] 3d60: c08285ac ef228a10 00000000 c1245ab8 00000000 00000000 c1245ab8 00000000
[ 9.299470] 3d80: ef093dac ef093d90 c06b3468 c08285b8 c128f0b4 ef228a10 c128f0b8 00000000
[ 9.307684] 3da0: ef093ddc ef093db0 c06b14b8 c06b3424 00000000 ef228a10 c1245ab8 ef228a44
[ 9.315898] 3dc0: c06b1830 00000000 c104b834 c1060e04 ef093e14 ef093de0 c06b1718 c06b12c0
[ 9.324112] 3de0: c0842ae0 c0840900 ef093e14 ef093df8 ef228a10 c1245ab8 ef228a44 c06b1830
[ 9.332326] 3e00: 00000000 c104b834 ef093e34 ef093e18 c06b1924 c06b16bc ef22c234 c1204c48
[ 9.340540] 3e20: c1245ab8 c06b1830 ef093e64 ef093e38 c06af588 c06b183c ef093e70 ef007f58
[ 9.348755] 3e40: ef22c234 b12be995 c1245ab8 c1236c90 ee463780 00000000 ef093e74 ef093e68
[ 9.356968] 3e60: c06b0df0 c06af518 ef093e9c ef093e78 c06b086c c06b0dd8 c0e4f2b4 ef093e88
[ 9.365181] 3e80: c1245ab8 c1204c48 ffffe000 c102ec60 ef093eb4 ef093ea0 c06b22f4 c06b06b4
[ 9.373395] 3ea0: c1255740 c1204c48 ef093ec4 ef093eb8 c06b33cc c06b2284 ef093ed4 ef093ec8
[ 9.381608] 3ec0: c102ec7c c06b3390 ef093f4c ef093ed8 c020265c c102ec6c 00000000 c0dd4f58
[ 9.389823] 3ee0: c0dd4f38 c0dd4f00 c0de0e44 c1204c48 00000000 c0dd4f10 00000006 00000006
[ 9.398037] 3f00: 00000000 c0e39424 c10004f0 c0ebad30 ef093f34 ef669824 ef669837 b12be995
[ 9.406251] 3f20: 00000000 b12be995 c1255740 00000007 c1255740 c1255740 c10004f0 c104b854
[ 9.414463] 3f40: ef093f94 ef093f50 c1000fe8 c02025e4 00000006 00000006 00000000 c10004f0
[ 9.422677] 3f60: c0ebad30 000000e5 ffffe000 00000000 c0a0ccd8 00000000 00000000 00000000
[ 9.430891] 3f80: 00000000 00000000 ef093fac ef093f98 c0a0cce8 c1000e30 00000000 c0a0ccd8
[ 9.439104] 3fa0: 00000000 ef093fb0 c02010d8 c0a0cce4 00000000 00000000 00000000 00000000
[ 9.447318] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 9.455531] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 9.463740] Backtrace:
[ 9.466206] [<c05e0f60>] (regulator_set_voltage) from [<c08045a4>] (mmc_regulator_set_ocr+0x4c/0xe8)
[ 9.475380] r7:00100600 r6:ffffffed r5:ee47c000 r4:ee47c000
[ 9.481071] [<c0804558>] (mmc_regulator_set_ocr) from [<c08284c8>] (sdhci_omap_set_power+0x18/0x1c)
[ 9.490158] r7:00100600 r6:ee47c340 r5:ee47c21c r4:ee47c000
[ 9.495847] [<c08284b0>] (sdhci_omap_set_power) from [<c081cbb0>] (sdhci_set_ios+0xf4/0x56c)
[ 9.504325] [<c081cabc>] (sdhci_set_ios) from [<c082829c>] (sdhci_omap_set_ios+0xd8/0x114)
[ 9.512627] r9:ee47c1f0 r8:ee47c3c8 r7:00100600 r6:00000000 r5:ee47c21c r4:ee47c000
[ 9.520410] [<c08281c4>] (sdhci_omap_set_ios) from [<c0805c20>] (mmc_set_initial_state+0x98/0x9c)
[ 9.529322] r9:ee47c1f0 r8:ee47c3c8 r7:ee47c534 r6:ee47c000 r5:ee47c21c r4:ee47c000
[ 9.537102] [<c0805b88>] (mmc_set_initial_state) from [<c0805e50>] (mmc_power_up.part.8+0x44/0xcc)
[ 9.546099] r5:00000015 r4:ee47c000
[ 9.549694] [<c0805e0c>] (mmc_power_up.part.8) from [<c0806b5c>] (mmc_start_host+0x94/0xa0)
[ 9.558079] r5:00000000 r4:ee47c000
[ 9.561674] [<c0806ac8>] (mmc_start_host) from [<c0807f60>] (mmc_add_host+0x60/0x84)
[ 9.569450] r5:00000000 r4:ee47c000
[ 9.573043] [<c0807f00>] (mmc_add_host) from [<c081c4d4>] (__sdhci_add_host+0x140/0x2ac)
[ 9.581168] r5:00000000 r4:ee47c340
[ 9.584763] [<c081c394>] (__sdhci_add_host) from [<c0828ac8>] (sdhci_omap_probe+0x51c/0x5bc)
[ 9.593238] r8:ee47c640 r7:ef228a10 r6:ee47c000 r5:ef228a00 r4:ee47c340
[ 9.599974] [<c08285ac>] (sdhci_omap_probe) from [<c06b3468>] (platform_drv_probe+0x50/0xa0)
[ 9.608450] r10:00000000 r9:c1245ab8 r8:00000000 r7:00000000 r6:c1245ab8 r5:00000000
[ 9.616313] r4:ef228a10 r3:c08285ac
[ 9.619907] [<c06b3418>] (platform_drv_probe) from [<c06b14b8>] (really_probe+0x204/0x2c0)
[ 9.628208] r7:00000000 r6:c128f0b8 r5:ef228a10 r4:c128f0b4
[ 9.633895] [<c06b12b4>] (really_probe) from [<c06b1718>] (driver_probe_device+0x68/0x180)
[ 9.642197] r10:c1060e04 r9:c104b834 r8:00000000 r7:c06b1830 r6:ef228a44 r5:c1245ab8
[ 9.650060] r4:ef228a10 r3:00000000
[ 9.653654] [<c06b16b0>] (driver_probe_device) from [<c06b1924>] (__driver_attach+0xf4/0xf8)
[ 9.662129] r9:c104b834 r8:00000000 r7:c06b1830 r6:ef228a44 r5:c1245ab8 r4:ef228a10
[ 9.669908] [<c06b1830>] (__driver_attach) from [<c06af588>] (bus_for_each_dev+0x7c/0xbc)
[ 9.678121] r7:c06b1830 r6:c1245ab8 r5:c1204c48 r4:ef22c234
[ 9.683808] [<c06af50c>] (bus_for_each_dev) from [<c06b0df0>] (driver_attach+0x24/0x28)
[ 9.691846] r7:00000000 r6:ee463780 r5:c1236c90 r4:c1245ab8
[ 9.697532] [<c06b0dcc>] (driver_attach) from [<c06b086c>] (bus_add_driver+0x1c4/0x208)
[ 9.705574] [<c06b06a8>] (bus_add_driver) from [<c06b22f4>] (driver_register+0x7c/0x110)
[ 9.713700] r7:c102ec60 r6:ffffe000 r5:c1204c48 r4:c1245ab8
[ 9.719388] [<c06b2278>] (driver_register) from [<c06b33cc>] (__platform_driver_register+0x48/0x50)
[ 9.728472] r5:c1204c48 r4:c1255740
[ 9.732068] [<c06b3384>] (__platform_driver_register) from [<c102ec7c>] (sdhci_omap_driver_init+0x1c/0x20)
[ 9.741769] [<c102ec60>] (sdhci_omap_driver_init) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
[ 9.750599] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
[ 9.759337] r8:c104b854 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000007
[ 9.766073] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
[ 9.774374] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
[ 9.782236] r4:00000000
[ 9.784783] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 9.792383] Exception stack(0xef093fb0 to 0xef093ff8)
[ 9.797456] 3fa0: 00000000 00000000 00000000 00000000
[ 9.805669] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 9.813882] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 9.820524] r5:c0a0ccd8 r4:00000000
[ 9.824116] Code: e24cb004 e1a04000 e1a05001 e1a06002 (e5900050)
[ 9.831404] ---[ end trace 6ab99f172329d362 ]---
[ 9.836060] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 9.836060]
[ 9.845243] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 9.845243] ]---
