QEM-CCR-2306-00760_TRS3221EIPWR
Hi This is Lily who is FQE.
As below information, this unit has passed on ATE, Bench test and I released TNI report.
I think it seems to be an implementation issue not a failed device issue.
So, We need to discuss with Eric who is application Engr and customer.
Please refer below information. Thanks.
1. Customer affected: Arrow / EMOTION 2. Failed at: Production 3. Fail temp: Room 4. Affected model name & application: Industrial 5. Failure rate & sample qty: 198 / 800 6. Failure symptom: This issue was occurred on in-line process of the customer. The quantity of same LOT is 12,000pcs(6 reels). On board level, there was RS-232 communication error. On IC level, the failed unit's waveform(Pin8/9/11/13) was different from the good unit's waveform. 7. ATE retest : Pass 8. Bench test : No abnormality observed |
