Part Number: BQ28Z610EVM-532
Other Parts Discussed in Thread: GPCRB, BQSTUDIO
Last week, I performed the GPCRB procedure to optimize gauging at cold temperature. However, the gauge had done some learning with the learning cycle previously. I did the GPCRB procedure now knowing this was a problem, and got the error after I sent in the zip file:
The following errors were reported by the calculation engine:
Error: Ra table could not be extracted from GG file. Make sure that chem ID was freshly programmed and no learning took place. Flags ff55 or ffff should be present 0
So this week I programmed the chem ID fresh, and I confirmed that the Ra table showed the flags = FF55 and FFFF before I began the procedure again. Then I sent in the data, but I'm getting the same error:
Why is this? The chem ID was already freshly programmed and the flags were FF55 FFFF before I started.
Kelvin
