Part Number: ADS8353
We are trying to use ADS8353 IC in 32-CLK, Single-SDO Mode (CFR.B11 = 0, CFR.B10 = 1) with bit banging in software. We are using STM32 chip.
But the results from the IC is inconsistent. Raw ADC values changes every sample. Is this normal?
AINM pin is connected to ground. AINP pin is connected to our voltage supply(ADC V-C1 in the picture). VRef is 2.163 Volts. ADC V-C1(AINP) is 1.740 Volts when we measured it with multimeter. But ADS8353 output range looks between 1400-1900 after calculations. The supply voltage looks stable.
The result we get with Logic Analyzer and the schematic is in the pictures below.
Can you help us in this situtation, thank you.
