Part Number: TM4C1237H6PGE
I am revisiting a project that is several years old and I recently upgraded the compiler to gain access to time64_t. After recompiling, I received several warnings from the compiler as follows. I will say this project is currently using stellarisware (To show how old it is). I will eventually be migrating to Tivaware, but one problem at a time. Could someone please point me in the right direction?
"C:\Stellarisware\driverlib\pin_map.h", line 59069: warning #48-D: incompatible redefinition of macro "GPIO_PA2_SSI0CLK" (declared at line 42782) "C:\Stellarisware\driverlib\pin_map.h", line 59071: warning #48-D: incompatible redefinition of macro "GPIO_PA3_SSI0FSS" (declared at line 42786) "C:\Stellarisware\driverlib\pin_map.h", line 59073: warning #48-D: incompatible redefinition of macro "GPIO_PA4_SSI0RX" (declared at line 42790) "C:\Stellarisware\driverlib\pin_map.h", line 59075: warning #48-D: incompatible redefinition of macro "GPIO_PA5_SSI0TX" (declared at line 42795) "C:\Stellarisware\driverlib\pin_map.h", line 59077: warning #48-D: incompatible redefinition of macro "GPIO_PA6_I2C1SCL" (declared at line 42800) "C:\Stellarisware\driverlib\pin_map.h", line 59080: warning #48-D: incompatible redefinition of macro "GPIO_PA7_I2C1SDA" (declared at line 42808) "C:\Stellarisware\driverlib\pin_map.h", line 59083: warning #48-D: incompatible redefinition of macro "GPIO_PB0_U1RX" (declared at line 42819) "C:\Stellarisware\driverlib\pin_map.h", line 59086: warning #48-D: incompatible redefinition of macro "GPIO_PB1_U1TX" (declared at line 42824) "C:\Stellarisware\driverlib\pin_map.h", line 59089: warning #48-D: incompatible redefinition of macro "GPIO_PB2_I2C0SCL" (declared at line 42826) "C:\Stellarisware\driverlib\pin_map.h", line 59092: warning #48-D: incompatible redefinition of macro "GPIO_PB3_I2C0SDA" (declared at line 42832) "C:\Stellarisware\driverlib\pin_map.h", line 59097: warning #48-D: incompatible redefinition of macro "GPIO_PB4_CAN0RX" (declared at line 42838) "C:\Stellarisware\driverlib\pin_map.h", line 59102: warning #48-D: incompatible redefinition of macro "GPIO_PB5_CAN0TX" (declared at line 42847) "C:\Stellarisware\driverlib\pin_map.h", line 59105: warning #48-D: incompatible redefinition of macro "GPIO_PC0_TCK" (declared at line 42862) "C:\Stellarisware\driverlib\pin_map.h", line 59106: warning #48-D: incompatible redefinition of macro "GPIO_PC0_SWCLK" (declared at line 42863) "C:\Stellarisware\driverlib\pin_map.h", line 59109: warning #48-D: incompatible redefinition of macro "GPIO_PC1_TMS" (declared at line 42865) "C:\Stellarisware\driverlib\pin_map.h", line 59110: warning #48-D: incompatible redefinition of macro "GPIO_PC1_SWDIO" (declared at line 42866) "C:\Stellarisware\driverlib\pin_map.h", line 59113: warning #48-D: incompatible redefinition of macro "GPIO_PC2_TDI" (declared at line 42868) "C:\Stellarisware\driverlib\pin_map.h", line 59116: warning #48-D: incompatible redefinition of macro "GPIO_PC3_SWO" (declared at line 42870) "C:\Stellarisware\driverlib\pin_map.h", line 59117: warning #48-D: incompatible redefinition of macro "GPIO_PC3_TDO" (declared at line 42871) "C:\Stellarisware\driverlib\pin_map.h", line 59140: warning #48-D: incompatible redefinition of macro "GPIO_PC7_USB0PFLT" (declared at line 42902) "C:\Stellarisware\driverlib\pin_map.h", line 59229: warning #48-D: incompatible redefinition of macro "GPIO_PF2_SSI1CLK" (declared at line 43022) "C:\Stellarisware\driverlib\pin_map.h", line 59238: warning #48-D: incompatible redefinition of macro "GPIO_PF3_SSI1FSS" (declared at line 43027)
