Part Number: TIDEP0032
Hi everyone,
I am considering to use TIDEP0032 for one of my projects, however, I wanted to know if the board has libraries for Profinet already installed and if it is plug and play. If not then what would be the steps required to use it as a PLC controller for profinet protocol. I referred a pdf (www.ti.com/.../tidua28a.pdf)and found this :
"Due to hardware constraints (ASIC/FPGA), most of the products for industrial automation solutions do not support multi-protocol industrial Ethernet and cannot load the industrial Ethernet protocol on-the-fly. PRU-ICSS-based products allow the support of multi-protocol industrial Ethernet applications, such as the industrial Ethernet firmware, which is loaded during device startup."
Just wanted to confirm if it comes pre-installed with the setup required for profinet.
Thank you.
