Other Parts Discussed in Thread: TCA9511A
Please fined the attached figure.
I want to place TCA9802 on Sub Board with a slave IC mounted on B side.
In debug phase of the slave IC... Debug board will be connected on A side with jumpers.
This should be fine as the topology is similar to an example on the datasheet except EN is left floating (I expect EN is still pulled-up to VCCA in TCA9802)
In normal use of the slave IC... Main board will be connected on B side whereas the debug board is disconnected.
My question is, does this concept work? Are there any negative impact when VCCA/SDAA/SCLA/EN pins are ally left floating?
