I have to read a analog sensor's value and transmit the same value to an android phone via bluetooth.
Please suggest how i shall start.
Although we don't have an exact ADC > BLE example, the SimpleLink Audio Plugin may be of help, as it shows the interaction between a peripheral, the Stack and opening a data streaming way.
https://dev.ti.com/tirex/explore/node?node=AFFVIsO6lK9zZEzi2G-Sig__RW99gST__LATEST
Another project that interfaces the peripheral APIs (in this case it is the GPIO) and the Stack is the project zero:
https://dev.ti.com/tirex/explore/node?node=AD5s-AKnP1FeVvpY4QPIbw__G3CJGEK__LATEST
I would start by studying these two projects and the TI Drivers API guide and the initialization of a typical ADC from the adcbufcontinuous project:
https://dev.ti.com/tirex/explore/node?node=AOPWOAGldx2kPSsfJeOo0Q__G3CJGEK__LATEST
Hopefully the examples will help you accomplish this task.
Rafael
Okay thanks for your response.
Please tell how to use a plugin in the CCS IDE and how can i store the same incoming data into an SD CARD?
shivam
Shivam,
The "plugin" is, in fact, an example code and not something that is installed into CCS.
Unfortunately I do not have an example that redirects information to the SD card, but you can try to leverage an SPI example project such as spimaster or spiffsexternal to your SD card in SPI mode.
Hope this helps,
Rafael
I am getting following message below when i am trying to access the links mentioned above.
This resource does not exist. Check your URL or select another resource to view.
regards,
shivam
Shivam,
Please apologize for the links. I fixed them but, if they don't work, go to https://dev.ti.com/tirex/explore and browse to the following tree:
Rafael
