Part Number: TDA4VM
I'm trying to boot using SBL from OSPI on TDA4 device but I see the below error. What could be the issue?
Part Number: TDA4VM
Most likely the PHY tuning pattern is not flashed at the last sector of the OSPI flash. PHY tuning is required to set the optimal Tx and Rx delay in the OSPI controller for best performance.
Application note on OSPI PHY tuning: https://www.ti.com/lit/an/spract2/spract2.pdf
Where to find the PHY tuning binary in the SDK: ti-processor-sdk-rtos-j721e-evm-xx_yy_zz_ww/pdk_jacinto_xx_yy_zz_ww/packages/ti/board/src/flash/nor/ospi/nor_spi_patterns.bin
What offset to flash the binary to: nor_spi_patterns.bin needs to be flashed at the last sector of the OSPI flash.
flashing_offset = size_of_flash - sector_size
Example
Karan
