[FAQ] TDA4VM: How to print the ALE table for CPSW in TDA4/DRA8 devices
Part Number: TDA4VM
Other Parts Discussed in Thread: DRA821, , TDA4VH, DRA829
Are there any tools available for printing ALE for the different ethernet applications with enet LLD, ethfw and Native Linux Driver?
    From CCS (Enet LLD applications and Ethfw)
    • Launch the correct target configuration and connect to the core running the application. It will be mcu2_0(MAIN_Cortex_R5_0_0 in CCS Debug window) in case of Ethfw server.
    • Select the Tools → GEL Files option. It should open a window titled GEL Files
    • Right Click on the empty area on the right side of the GEL Files window and select "Load GEL..."
    • Navigate to "[PSDK-RTOS-INSTALL-DIR]/pdk-[version]/packages/ti/drv/enet/tool/debug_gels/" folder and select the cpsw_ale_print_table.gel
    • You should see "cpsw_ale_print_table.gel" in the GEL Files window. Pause/Suspend the core which you have connected to.
    • Go to Scripts → CPSW ALE Print Table and select the IP for which you would like to print the ALE Table for
      • cpsw_ale_print_table_2g for MCU CPSW 2G
      • cpsw_ale_print_table_5g for MAIN CPSW 5G (DRA821)
      • cpsw_ale_print_table_9g for MAIN CPSW 9G (DRA829/TDA4VM/TDA4VH)
    • You should see the ALE Table printed in Console. The output will be like the following :
      • MAIN_Cortex_R5_0_1: GEL Output: ---------------------------------------------
        MAIN_Cortex_R5_0_1: GEL Output: -------CPSW2G ALE TABLE----------------------
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 0 - VLAN
        MAIN_Cortex_R5_0_1: GEL Output: ENTRY_TYPE        = 2
        MAIN_Cortex_R5_0_1: GEL Output: VLAN_ID           = 0
        MAIN_Cortex_R5_0_1: GEL Output: FORCE_UNTAG_EG    = 3
        MAIN_Cortex_R5_0_1: GEL Output: REG_MCAST_FLOOD   = 272
        MAIN_Cortex_R5_0_1: GEL Output: UNREG_MCAST_FLOOD = 0
        MAIN_Cortex_R5_0_1: GEL Output: VLAN_MEMBER_LIST  = 3
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 1 - Unicast
        MAIN_Cortex_R5_0_1: GEL Output: PORT_NUMBER      = 0
        MAIN_Cortex_R5_0_1: GEL Output: BLOCK            = 0
        MAIN_Cortex_R5_0_1: GEL Output: SECURE           = 1
        MAIN_Cortex_R5_0_1: GEL Output: UNICAST_TYPE     = 0
        MAIN_Cortex_R5_0_1: GEL Output: ENTRY_TYPE       = 1
        MAIN_Cortex_R5_0_1: GEL Output: UNICAST_ADDR     = 0x00002476 0x25934C39
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 2 - VLAN/Multicast
        MAIN_Cortex_R5_0_1: GEL Output: PORT_MASK        = 0x00000003
        MAIN_Cortex_R5_0_1: GEL Output: SUPER            = 0
        MAIN_Cortex_R5_0_1: GEL Output: MCAST_FWD_STATE  = 3
        MAIN_Cortex_R5_0_1: GEL Output: ENTRY_TYPE       = 3
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x0000FFFF 0xFFFFFFFF
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 3 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: PORT_MASK        = 0x00000001
        MAIN_Cortex_R5_0_1: GEL Output: MCAST_FWD_STATE  = 0
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00003333 0x00000001
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 4 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00000100 0x5E000001
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 5 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00000180 0xC2000000
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 6 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00000180 0xC2000003
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 7 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00000180 0xC200000E
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 8 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00003333 0xFF934C39
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 9 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00003333 0x000000FB
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 10 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00003333 0x00010003
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 11 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00000100 0x5E0000FC
        MAIN_Cortex_R5_0_1: GEL Output:  Entry 12 - Multicast
        MAIN_Cortex_R5_0_1: GEL Output: MULTICAST_ADDR   = 0x00000100 0x5E0000FB
        MAIN_Cortex_R5_0_1: GEL Output: Completed analysis of 64 ALE entries
    From Ethfw with Linux (Output on Ethfw UART)
    • From Linux Command Prompt, run the following command :
      • ethtool -t $IF_NAME
        • $IF_NAME=eth1 for switch port (Default)
        • $IF_NAME=eth2 for MAC-only port (Default)
    • You should be able to see the ALE Table printed on Ethfw UART (MAIN UART 2 on EVM).
      • For Devices like DRA821 which do not print ethfw logs on any UART and custom boards which do not have an Ethfw UART brought out, you will be able to see them from remoteproc trace buffers using command :
      • cat /sys/kernel/debug/remoteproc/remoteproc*/trace0
    • Sample Log
      •  0: Vlanid: 012c, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff RAW:[0 212c1ff1 ff0001ff]
             1: Vlanid: 0000, UTagged: 13, Mult: 13, UMult: 13, Member: 13 RAW:[0 20000130 13013013]
             2: Vlanid: 0001, UTagged: 1ed, Mult: 1ed, UMult: 0, Member: 1ed RAW:[0 20011ed1 ed0001ed]
             3: Address: ffffffffffff, Member:1ff Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[7fc 1000ffff ffffffff]
             4: Address: 70ff761d92c3, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[1 100070ff 761d92c3]
             5: EtherType: 0806 RAW:[1 20000000 00000806]
             6: Address: 70ff761d92c2, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[0 100070ff 761d92c2]
             7: Address: 333300000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10003333 00000001]
             8: Address: 70ff761d92c1, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[1 100070ff 761d92c1]
             9: Address: 01005e000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000100 5e000001]
            10: Address: 3333ff1d92c2, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10003333 ff1d92c2]
            11: Address: 3333000000fb, Member:1ed Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[7b4 10003333 000000fb]
            12: Address: 0180c2000000, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000180 c2000000]
            13: Address: 0180c2000003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000180 c2000003]
            14: Address: 333300010003, Member:1ed Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[7b4 10003333 00010003]
        1009 Free Entries
            0: POLICER_DST_MAC,ALE Index: 3
            0: POLICER_ETHERTYPE,ALE Index: 5
            0: POLICER_THREAD,THREAD ID:4
            0: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
            1: POLICER_DST_MAC,ALE Index: 6
            1: POLICER_THREAD,THREAD ID:1
            1: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
            2: POLICER_PORT, PORT_NUM: 1 ISTRUNK:0
            2: POLICER_THREAD,THREAD ID:0
            2: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
            3: POLICER_DST_MAC,ALE Index: 11
            3: POLICER_THREAD,THREAD ID:1
            3: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
            4: POLICER_DST_MAC,ALE Index: 14
            4: POLICER_THREAD,THREAD ID:1
            4: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
        91 Free Entries
    From Linux (for Native Linux Driver)
    • From the linux command prompt, run the following command
      • switch-config --ndev $IF_NAME -d
        • Where $IF_NAME is the interface name like eth0, eth1.....
        • The interfaces from the same CPSW IP will print the same ALE Table
    • Sample Log :
      • root@j7200-evm:~# switch-config --ndev eth1 -d
        K3 cpsw dump version (1) len(11704)
        ALE table dump ents(512):
        0   : type: vlan , vid = 0, untag_force = 0x7, reg_mcast = 0x1, unreg_mcast = 0x0, member_list = 0x7
        1   : type: mcast, addr = 01:00:5e:00:00:01, mcast_state = f, no super, port_mask = 0x1
        2   : type: ucast, vid = 1, addr = 70:ff:76:1d:a0:7b, ucast_type = persistant, port_num = 0x0, Secure, Blocked
        3   : type: mcast, vid = 1, addr = ff:ff:ff:ff:ff:ff, mcast_state = f, no super, port_mask = 0x7
        4   : type: mcast, addr = 01:80:c2:00:00:00, mcast_state = f, no super, port_mask = 0x1
        5   : type: mcast, addr = 01:80:c2:00:00:03, mcast_state = f, no super, port_mask = 0x1
        6   : type: mcast, addr = 01:80:c2:00:00:0e, mcast_state = f, no super, port_mask = 0x1
        7   : type: ucast, vid = 1, addr = 70:ff:76:1d:a0:7c, ucast_type = persistant, port_num = 0x0, Secure, Blocked
        8   : type: mcast, addr = 33:33:00:00:00:01, mcast_state = f, no super, port_mask = 0x1
        9   : type: mcast, addr = 33:33:ff:1d:a0:7c, mcast_state = f, no super, port_mask = 0x1
        12  : type: vlan , vid = 1, untag_force = 0x6, reg_mcast = 0x0, unreg_mcast = 0x0, member_list = 0x6
        33  : type: ucast, vid = 1, addr = 24:76:25:93:4c:39, ucast_type = touched   , port_num = 0x1
        50  : type: ucast, vid = 1, addr = 00:68:eb:b6:6e:6e, ucast_type = untouched , port_num = 0x2
    • The source code for the switch-config can be found here.
    Tanmay
